Iptables für 7270v3 - Fehlendes Modul xt_time
JohnDoe42
Aktives Mitglied
17 Mrz 2009
meine Versuche, ein Image inklusive des Iptables-Moduls xt_time zu bauen, schlugen leider fehl.
Hier meine .config:
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3272 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_6842 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
FREETZ_TYPE_7270_V3=y
# FREETZ_TYPE_7272 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_XL is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
# FREETZ_TYPE_7390 is not set
# FREETZ_TYPE_7490 is not set
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_7270=y
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_FIRMWARE_05_2X=y
# FREETZ_TYPE_FIRMWARE_05_5X is not set
# FREETZ_TYPE_FIRMWARE_LABOR is not set
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="de"
# FREETZ_TYPE_ALIEN_HARDWARE is not set
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_REPLACE_KERNEL=y
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_262144 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_524288 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_1048576 is not set
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Removal patches
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
# Remove piglet
FREETZ_REMOVE_ASSISTANT=y
# FREETZ_REMOVE_ASSISTANT_SIP is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_NAS is not set
FREETZ_REMOVE_FHEM=y
FREETZ_REMOVE_AVM_VPN=y
# Remove brandings
FREETZ_REMOVE_BRANDING_1und1=y
# FREETZ_REMOVE_BRANDING_avm is not set
FREETZ_REMOVE_BRANDING_otwo=y
FREETZ_REMOVE_CAPIOVERTCP=y
FREETZ_REMOVE_CHRONYD=y
FREETZ_REMOVE_DECT=y
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
FREETZ_REMOVE_FTPD=y
FREETZ_REMOVE_HELP=y
# FREETZ_REMOVE_JFFS2 is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NTFS is not set
FREETZ_REMOVE_PRINTSERV=y
FREETZ_REMOVE_PRINTSERV_MODULE=y
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SUPPORT is not set
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_TR069_FWUPDATE=y
FREETZ_REMOVE_TR069_HTTPSDL=y
FREETZ_REMOVE_UMTSD=y
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
# FREETZ_REMOVE_AVM_E2FSPROGS is not set
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
FREETZ_REMOVE_WEBDAV=y
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_VCC is not set
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_DSL_EXPERT is not set
# FREETZ_ADD_REGEXT_GUI is not set
# FREETZ_PATCH_SIGNED is not set
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_EXT4 is not set
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# FREETZ_REPLACE_SSL_LIBS is not set
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
# FREETZ_AVMDAEMON_DISABLE_NTP is not set
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
FREETZ_AVMDAEMON_DISABLE_TR069=y
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Additional components ------------------
# Packages
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
FREETZ_PACKAGE_LDD=y
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
FREETZ_PACKAGE_STRACE=y
# FREETZ_PACKAGE_TARGET_TESTER is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
FREETZ_PACKAGE_BRIDGE_UTILS=y
FREETZ_PACKAGE_CALLMONITOR=y
FREETZ_PACKAGE_CALLMONITOR_webif=y
FREETZ_PACKAGE_CALLMONITOR_actions=y
FREETZ_PACKAGE_CALLMONITOR_monitor=y
FREETZ_PACKAGE_CALLMONITOR_phonebook=y
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
FREETZ_PACKAGE_CIFSMOUNT=y
# FREETZ_PACKAGE_CIFSMOUNT_REMOVE_WEBIF is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
FREETZ_PACKAGE_CURL=y
# FREETZ_PACKAGE_CURL_STATIC is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_DISABLE_HOST_LOOKUP=y
# FREETZ_PACKAGE_DROPBEAR_UTMP is not set
# FREETZ_PACKAGE_DROPBEAR_WTMP is not set
# FREETZ_PACKAGE_DROPBEAR_STATIC is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# E-MailRelay (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPSEC_TOOLS is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# OpenSSH
FREETZ_PACKAGE_OPENSSH=y
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# Build OpenSSH client (ssh) (not available, provided by dropbear)
# Build OpenSSH secure copy utility (scp) (not available, provided by dropbear)
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
FREETZ_PACKAGE_OPENSSH_sftp_server=y
# Build statically linked binaries ---
# FREETZ_PACKAGE_OPENSSH_STATIC is not set
# FREETZ_PACKAGE_OPENSSL is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_2 is not set
FREETZ_PACKAGE_OPENVPN_OPENSSL=y
# FREETZ_PACKAGE_OPENVPN_POLARSSL is not set
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
FREETZ_PACKAGE_OPENVPN_WITH_MGMNT=y
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
# FREETZ_PACKAGE_OPENVPN_USE_V2_CGI is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PPP is not set
FREETZ_PACKAGE_PRIVOXY=y
FREETZ_PACKAGE_PRIVOXY_WITH_ADBLOCK=y
FREETZ_PACKAGE_PRIVOXY_WITH_SHARED_PCRE=y
# FREETZ_PACKAGE_PRIVOXY_WITH_ZLIB is not set
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
FREETZ_PACKAGE_SAMBA=y
# FREETZ_SAMBA_VERSION_3_0 is not set
FREETZ_SAMBA_VERSION_3_6=y
FREETZ_PACKAGE_SAMBA_SMBD=y
FREETZ_PACKAGE_SAMBA_NMBD=y
# FREETZ_PACKAGE_SAMBA_SMBCLIENT is not set
# FREETZ_PACKAGE_SAMBA_NMBLOOKUP is not set
FREETZ_PACKAGE_SAMBA_MAX_DEBUG_LEVEL=-1
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_TIFF is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TMUX is not set
FREETZ_PACKAGE_TOR=y
FREETZ_PACKAGE_TOR_GEOIP=y
# FREETZ_PACKAGE_TOR_STATIC is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
FREETZ_PACKAGE_UNRAR=y
# FREETZ_PACKAGE_UNRAR_STATIC is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
FREETZ_PACKAGE_VSFTPD=y
FREETZ_PACKAGE_VSFTPD_WITH_SSL=y
# FREETZ_PACKAGE_VSFTPD_STATIC is not set
# FREETZ_PACKAGE_VTUN is not set
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WGET_WITH_SSL=y
# FREETZ_PACKAGE_WGET_USE_GNUTLS is not set
# FREETZ_PACKAGE_WGET_STATIC is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Unstable
# FREETZ_PACKAGE_ASTERISK is not set
# FREETZ_PACKAGE_AVM_FORWARDING is not set
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
FREETZ_PACKAGE_IPTABLES_XML=y
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
FREETZ_PACKAGE_IPTABLES_CGI=y
# FREETZ_PACKAGE_NHIPT is not set
FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES=y
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
# FREETZ_MODULE_ip_conntrack is not set
FREETZ_MODULE_nf_conntrack=y
FREETZ_MODULE_nf_conntrack_ftp=y
# FREETZ_MODULE_nf_conntrack_h323 is not set
# FREETZ_MODULE_nf_conntrack_irc is not set
FREETZ_MODULE_nf_conntrack_ipv4=y
# FREETZ_MODULE_nf_conntrack_pptp is not set
# FREETZ_MODULE_nf_conntrack_proto_gre is not set
# FREETZ_MODULE_nf_conntrack_tftp is not set
# FREETZ_MODULE_nf_defrag_ipv4 is not set
# FREETZ_MODULE_nf_nat is not set
# FREETZ_MODULE_nf_nat_ftp is not set
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
# FREETZ_MODULE_nf_nat_tftp is not set
FREETZ_MODULE_iptable_filter=y
FREETZ_MODULE_iptable_mangle=y
FREETZ_MODULE_iptable_nat=y
# FREETZ_MODULE_iptable_raw is not set
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
# FREETZ_MODULE_ipt_ttl is not set
# FREETZ_MODULE_ipt_TTL is not set
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
# FREETZ_MODULE_xt_CLASSIFY is not set
# FREETZ_MODULE_xt_comment is not set
# FREETZ_MODULE_xt_esp is not set
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
# FREETZ_MODULE_xt_NFQUEUE is not set
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
# FREETZ_MODULE_xt_quota is not set
# FREETZ_MODULE_xt_realm is not set
FREETZ_MODULE_xt_state=y
FREETZ_MODULE_xt_statistic=y
FREETZ_MODULE_xt_string=y
FREETZ_MODULE_xt_tcpudp=y
# FREETZ_MODULE_xt_tcpmss is not set
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
FREETZ_LIB_libipt_addrtype=y
# FREETZ_LIB_libipt_ah is not set
# FREETZ_LIB_libipt_CLUSTERIP is not set
FREETZ_LIB_libipt_DNAT=y
# FREETZ_LIB_libipt_ecn is not set
# FREETZ_LIB_libipt_ECN is not set
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
# FREETZ_LIB_libipt_MIRROR is not set
# FREETZ_LIB_libipt_NETMAP is not set
# FREETZ_LIB_libipt_realm is not set
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
# FREETZ_LIB_libipt_SAME is not set
FREETZ_LIB_libipt_SNAT=y
# FREETZ_LIB_libipt_ttl is not set
# FREETZ_LIB_libipt_TTL is not set
FREETZ_LIB_libipt_ULOG=y
# FREETZ_LIB_libipt_unclean is not set
# Select shared libraries (both IPv4 and IPv6)
FREETZ_LIB_libxt_CLASSIFY=y
# FREETZ_LIB_libxt_comment is not set
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
# FREETZ_LIB_libxt_CONNSECMARK is not set
# FREETZ_LIB_libxt_conntrack is not set
# FREETZ_LIB_libxt_dscp is not set
# FREETZ_LIB_libxt_DSCP is not set
# FREETZ_LIB_libxt_esp is not set
# FREETZ_LIB_libxt_hashlimit is not set
# FREETZ_LIB_libxt_helper is not set
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
# FREETZ_LIB_libxt_NFLOG is not set
# FREETZ_LIB_libxt_NFQUEUE is not set
# FREETZ_LIB_libxt_NOTRACK is not set
# FREETZ_LIB_libxt_owner is not set
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
# FREETZ_LIB_libxt_quota is not set
# FREETZ_LIB_libxt_rateest is not set
# FREETZ_LIB_libxt_RATEEST is not set
# FREETZ_LIB_libxt_sctp is not set
# FREETZ_LIB_libxt_SECMARK is not set
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
# FREETZ_LIB_libxt_statistic is not set
FREETZ_LIB_libxt_string=y
# FREETZ_LIB_libxt_tcpmss is not set
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
FREETZ_LIB_libxt_time=y
# FREETZ_LIB_libxt_tos is not set
# FREETZ_LIB_libxt_TOS is not set
# FREETZ_LIB_libxt_TRACE is not set
# FREETZ_LIB_libxt_u32 is not set
FREETZ_LIB_libxt_udp=y
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
FREETZ_LIB_libip6t_icmp6=y
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
# FREETZ_PACKAGE_SQUID is not set
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_ZABBIX is not set
# Web interfaces
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_CPMACCFG_CGI is not set
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
FREETZ_PACKAGE_OPENVPN_CGI=y
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
FREETZ_PACKAGE_RRDSTATS=y
# FREETZ_PACKAGE_RRDSTATS_CABLEMODEM is not set
# FREETZ_PACKAGE_RRDSTATS_SEGMENTLOAD is not set
FREETZ_PACKAGE_RRDSTATS_STORAGE=y
FREETZ_PACKAGE_RRDSTATS_NETWORK=y
FREETZ_PACKAGE_RRDSTATS_TEMPERATURE_SENSOR=y
# FREETZ_PACKAGE_RRDSTATS_DIGITEMP is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
FREETZ_LIB_STDCXXLIB=y
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
FREETZ_LIB_libuClibc__=y
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md5 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libpolarssl_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl_WITH_GENRSA is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
FREETZ_OPENSSL_VERSION_0=y
# FREETZ_OPENSSL_VERSION_1 is not set
FREETZ_OPENSSL_SHLIB_VERSION="0.9.8"
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
FREETZ_LIB_libsqlite3=y
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
FREETZ_LIB_libexif=y
FREETZ_LIB_libjpeg=y
# FREETZ_LIB_liblept is not set
FREETZ_LIB_libpng12=y
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
FREETZ_LIB_libFLAC=y
# FREETZ_LIB_libmad is not set
FREETZ_LIB_libogg=y
# FREETZ_LIB_libopus is not set
# FREETZ_LIB_libspeex is not set
# FREETZ_LIB_libspeexdsp is not set
# FFmpeg libraries
FREETZ_LIB_libavcodec=y
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
FREETZ_LIB_libavformat=y
FREETZ_LIB_libavutil=y
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
FREETZ_LIB_libvorbis=y
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
FREETZ_LIB_libid3tag=y
# FREETZ_LIB_libtag is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
FREETZ_LIB_libcapi20=y
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libgsm is not set
# FREETZ_LIB_libiksemel is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# FREETZ_LIB_libspandsp is not set
# FREETZ_LIB_libsrtp is not set
# PJ Project
# FREETZ_LIB_libpj is not set
# FREETZ_LIB_libpjlib_util is not set
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
# FREETZ_LIB_libpjnath is not set
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
FREETZ_LIB_libpcre=y
FREETZ_LIB_libpcreposix=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
FREETZ_LIB_libcurl=y
FREETZ_LIB_libcurl_WITH_SSL=y
# FREETZ_LIB_libcurl_WITH_CYASSL is not set
FREETZ_LIB_libcurl_WITH_OPENSSL=y
# FREETZ_LIB_libcurl_WITH_POLARSSL is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libev is not set
FREETZ_LIB_libevent=y
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpcsclite is not set
FREETZ_LIB_libpopt=y
# FREETZ_LIB_libprotobuf_c is not set
FREETZ_LIB_librrd=y
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
FREETZ_KERNEL_VERSION_2_6_32_41=y
# FREETZ_KERNEL_VERSION_2_6_32_60 is not set
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_UR8=y
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_MODULES_KVER="2.6.32.41"
FREETZ_KERNEL_PATCHES="${FREETZ_MODULES_KVER}"
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_block2mtd is not set
# FREETZ_MODULE_ramzswap is not set
# FREETZ_MODULE_xvmalloc is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_crypto_blkcipher is not set
# FREETZ_MODULE_crypto_hash is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_sha1_generic is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_btusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
FREETZ_MODULE_cifs=y
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_ext4 is not set
FREETZ_MODULE_fat=y
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
FREETZ_MODULE_fuse=y
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd2 is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
FREETZ_MODULE_vfat=y
FREETZ_MODULE_msdos=y
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc16 is not set
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
FREETZ_BUSYBOX_BUNZIP2=y
FREETZ_BUSYBOX_BZIP2=y
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
# FREETZ_BUSYBOX_UNLZMA is not set
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_UNZIP=y
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
FREETZ_BUSYBOX_BASE64=y
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
# FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SEQ=y
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
FREETZ_BUSYBOX_USLEEP=y
FREETZ_BUSYBOX_UUDECODE=y
FREETZ_BUSYBOX_UUENCODE=y
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
FREETZ_BUSYBOX_FGCONSOLE=y
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_FEATURE_START_STOP_DAEMON_FANCY=y
FREETZ_BUSYBOX_WHICH=y
# Editors
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
FREETZ_BUSYBOX_CMP=y
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
# FREETZ_BUSYBOX_BLKID is not set
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
FREETZ_BUSYBOX_FLOCK=y
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
FREETZ_BUSYBOX_HEXDUMP=y
# FREETZ_BUSYBOX_FEATURE_HEXDUMP_REVERSE is not set
# FREETZ_BUSYBOX_HD is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
FREETZ_BUSYBOX_SETSERIAL=y
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
FREETZ_BUSYBOX_UBIMKVOL=y
FREETZ_BUSYBOX_UBIRMVOL=y
FREETZ_BUSYBOX_UBIRSVOL=y
FREETZ_BUSYBOX_UBIUPDATEVOL=y
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RFKILL is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
# FREETZ_BUSYBOX_TASKSET is not set
FREETZ_BUSYBOX_TIME=y
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
# FREETZ_BUSYBOX_NC_SERVER is not set
FREETZ_BUSYBOX_NC_EXTRA=y
# FREETZ_BUSYBOX_NC_110_COMPAT is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY is not set
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
# FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS is not set
# FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
# FREETZ_BUSYBOX_TELNET is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
# FREETZ_BUSYBOX_FEATURE_TFTP_GET is not set
# FREETZ_BUSYBOX_FEATURE_TFTP_PUT is not set
# FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE is not set
# FREETZ_BUSYBOX_TFTP_DEBUG is not set
FREETZ_BUSYBOX_TRACEROUTE=y
# FREETZ_BUSYBOX_TRACEROUTE6 is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP is not set
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
FREETZ_BUSYBOX_WGET=y
FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR=y
FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION=y
FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
FREETZ_BUSYBOX_IOSTAT=y
# FREETZ_BUSYBOX_LSOF is not set
FREETZ_BUSYBOX_MPSTAT=y
# FREETZ_BUSYBOX_NMETER is not set
FREETZ_BUSYBOX_PMAP=y
# FREETZ_BUSYBOX_POWERTOP is not set
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
FREETZ_SKIN_phoenix=y
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_0_9_32=y
# FREETZ_TARGET_UCLIBC_0_9_33 is not set
# FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace is not set
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_VERSION="4.6.4"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
FREETZ_BACKUP_CONFIG_CACHE=y
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="bfb124a63693dc982aaa713325a9ebea"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r10381"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="5bf2f39f33f4e9d810f78ab0a5d48c26"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="e396bbfcbd88c09cfcc652f94b7f8a57"
FREETZ_DL_SITE="@AVM/Downgrade/FRITZ!Box Fon WLAN 7270 v3/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270_v3.74.05.22.image"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
FREETZ_DL_SOURCE_MD5="6ebca9c6011d54f678dac33b3d092346"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
FREETZ_AVM_HAS_LABOR=y
# FREETZ_AVM_HAS_FW6XX is not set
FREETZ_AVM_HAS_FW55X=y
FREETZ_AVM_HAS_FW52X=y
# FREETZ_AVM_HAS_FW4XX is not set
# FREETZ_AVM_HAS_FWEWE_05_2X is not set
# FREETZ_AVM_HAS_FWEWE_05_5X is not set
FREETZ_AVM_HAS_LANG_DE=y
# FREETZ_AVM_HAS_LANG_A_CH is not set
FREETZ_AVM_HAS_LANG_EN=y
# FREETZ_AVM_HAS_LANG_IT is not set
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
FREETZ_AVM_UCLIBC_0_9_32=y
# FREETZ_AVM_UCLIBC_0_9_33 is not set
# FREETZ_AVM_UCLIBC_NPTL_ENABLED is not set
# FREETZ_AVM_GCC_3_4 is not set
FREETZ_AVM_GCC_4_6=y
# FREETZ_AVM_GCC_4_7 is not set
FREETZ_AVM_HAS_PRINTK=y
# FREETZ_AVM_HAS_PIGLET is not set
FREETZ_AVM_HAS_PTY_SUPPORT=y
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_AURA_USB=y
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_EXT3=y
# FREETZ_AVM_HAS_ISOFS is not set
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_OPENSSL_LIBS=y
FREETZ_AVM_HAS_LSOF=y
# FREETZ_AVM_HAS_SOCAT is not set
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_TAM=y
FREETZ_AVM_HAS_UDEV=y
# FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
FREETZ_AVM_HAS_USB_HOST=y
# FREETZ_AVM_HAS_USB_HOST_AHCI is not set
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_UMTS=y
FREETZ_AVM_HAS_JFFS2=y
# FREETZ_AVM_HAS_JUNK_BYTES is not set
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
FREETZ_AVM_HAS_MULTI_ANNEX=y
FREETZ_AVM_HAS_RAMZSWAP=y
# FREETZ_AVM_HAS_AHA is not set
FREETZ_AVM_HAS_TEMPERATURE_SENSOR=y
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7270_05_21=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_2X=y
FREETZ_TYPE_7270_16=y
FREETZ_AVM_VERSION_STRING="7270_05.21"
FREETZ_TYPE_PREFIX="7270_v3"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_2X"
Kernel-Config:
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.32.41
# Sun Jun 10 15:06:04 2012
CONFIG_MIPS=y
# Machine selection
# CONFIG_MACH_ALCHEMY is not set
# CONFIG_AR7 is not set
CONFIG_MIPS_UR8=y
# CONFIG_BASLER_EXCITE is not set
# CONFIG_BCM47XX is not set
# CONFIG_BCM63XX is not set
# CONFIG_MIPS_COBALT is not set
# CONFIG_MACH_FUSIV is not set
# CONFIG_LANTIQ is not set
# CONFIG_MACH_DECSTATION is not set
# CONFIG_MACH_JAZZ is not set
# CONFIG_LASAT is not set
# CONFIG_MACH_LOONGSON is not set
# CONFIG_MIPS_MALTA is not set
# CONFIG_MIPS_SIM is not set
# CONFIG_NEC_MARKEINS is not set
# CONFIG_MACH_VR41XX is not set
# CONFIG_NXP_STB220 is not set
# CONFIG_NXP_STB225 is not set
# CONFIG_PNX8550_JBS is not set
# CONFIG_PNX8550_STB810 is not set
# CONFIG_PMC_MSP is not set
# CONFIG_PMC_YOSEMITE is not set
# CONFIG_SGI_IP22 is not set
# CONFIG_SGI_IP27 is not set
# CONFIG_SGI_IP28 is not set
# CONFIG_SGI_IP32 is not set
# CONFIG_SIBYTE_CRHINE is not set
# CONFIG_SIBYTE_CARMEL is not set
# CONFIG_SIBYTE_CRHONE is not set
# CONFIG_SIBYTE_RHONE is not set
# CONFIG_SIBYTE_SWARM is not set
# CONFIG_SIBYTE_LITTLESUR is not set
# CONFIG_SIBYTE_SENTOSA is not set
# CONFIG_SIBYTE_BIGSUR is not set
# CONFIG_SNI_RM is not set
# CONFIG_MACH_TX39XX is not set
# CONFIG_MACH_TX49XX is not set
# CONFIG_MIKROTIK_RB532 is not set
# CONFIG_WR_PPMC is not set
# CONFIG_CAVIUM_OCTEON_SIMULATOR is not set
# CONFIG_CAVIUM_OCTEON_REFERENCE_BOARD is not set
# CONFIG_MACH_AR7240 is not set
# CONFIG_MACH_AR724x is not set
# CONFIG_MACH_AR933x is not set
# CONFIG_MACH_AR934x is not set
# CONFIG_MACH_AR7100 is not set
# CONFIG_MACH_HORNET is not set
# CONFIG_ALCHEMY_GPIO_INDIRECT is not set
CONFIG_RWSEM_GENERIC_SPINLOCK=y
# CONFIG_ARCH_HAS_ILOG2_U32 is not set
# CONFIG_ARCH_HAS_ILOG2_U64 is not set
# CONFIG_MIPS_FUSIV is not set
# CONFIG_MACH_ATHEROS is not set
CONFIG_ARCH_SUPPORTS_OPROFILE=y
CONFIG_GENERIC_FIND_NEXT_BIT=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
# *** AVM Board PCI Configuration ***
CONFIG_AVM_PCI_DEVICE_COUNT=1
CONFIG_AVM_PCI_INT_A=y
# CONFIG_AVM_PCI_INT_B is not set
# CONFIG_AVM_PCI_INT_C is not set
CONFIG_AVM_PCI_REQ_AND_GNT_0=y
# CONFIG_AVM_PCI_REQ_AND_GNT_1 is not set
# CONFIG_AVM_PCI_REQ_AND_GNT_2 is not set
CONFIG_AVM_PCI_DEV1_SLOT=14
CONFIG_AVM_PCI_DEV1_INT=0
CONFIG_MIPS_UR8_C55_MEMORY=0x40
CONFIG_MIPS_UR8_WLAN_MEMORY=0x180
CONFIG_MIPS_UR8_PHY_MEMSTART=0x14000000
CONFIG_DISABLE_OOM_KILLER=y
# CONFIG_UR8_CLOCK_SWITCH is not set
# CONFIG_VLYNQ_SUPPORT is not set
# CONFIG_GPIO_SSI is not set
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_TIME=y
# CONFIG_GENERIC_CMOS_UPDATE is not set
CONFIG_SCHED_OMIT_FRAME_POINTER=y
CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
CONFIG_CEVT_R4K_LIB=y
CONFIG_CEVT_R4K=y
CONFIG_CSRC_R4K_LIB=y
CONFIG_CSRC_R4K=y
CONFIG_DMA_NONCOHERENT=y
CONFIG_DMA_NEED_PCI_MAP_STATE=y
CONFIG_EARLY_PRINTK=y
CONFIG_SYS_HAS_EARLY_PRINTK=y
CONFIG_MIPS_FPU_EMU=y
# CONFIG_MIPS_MACHINE is not set
# CONFIG_IMAGE_CMDLINE_HACK is not set
# CONFIG_NO_IOPORT is not set
CONFIG_GENERIC_GPIO=y
# CONFIG_CPU_HAS_DSP_ASE is not set
# CONFIG_CPU_BIG_ENDIAN is not set
CONFIG_CPU_LITTLE_ENDIAN=y
CONFIG_SYS_SUPPORTS_LITTLE_ENDIAN=y
CONFIG_IRQ_CPU=y
CONFIG_MIPS_BOARDS_GEN=y
CONFIG_NO_EXCEPT_FILL=y
CONFIG_SWAP_IO_SPACE=y
CONFIG_BOOT_ELF32=y
CONFIG_MIPS_L1_CACHE_SHIFT=5
# CPU selection
# CONFIG_CPU_LOONGSON2E is not set
# CONFIG_CPU_MIPS32_R1 is not set
CONFIG_CPU_MIPS32_R2=y
# CONFIG_CPU_MIPS_24K is not set
# CONFIG_CPU_MIPS_34K is not set
# CONFIG_CPU_MIPS_74K is not set
# CONFIG_CPU_MIPS64_R1 is not set
# CONFIG_CPU_MIPS64_R2 is not set
# CONFIG_CPU_R3000 is not set
# CONFIG_CPU_TX39XX is not set
# CONFIG_CPU_VR41XX is not set
# CONFIG_CPU_R4300 is not set
# CONFIG_CPU_R4X00 is not set
# CONFIG_CPU_TX49XX is not set
# CONFIG_CPU_R5000 is not set
# CONFIG_CPU_R5432 is not set
# CONFIG_CPU_R5500 is not set
# CONFIG_CPU_R6000 is not set
# CONFIG_CPU_NEVADA is not set
# CONFIG_CPU_R8000 is not set
# CONFIG_CPU_R10000 is not set
# CONFIG_CPU_RM7000 is not set
# CONFIG_CPU_RM9000 is not set
# CONFIG_CPU_SB1 is not set
# CONFIG_CPU_CAVIUM_OCTEON is not set
CONFIG_SYS_HAS_CPU_MIPS32_R1=y
CONFIG_SYS_HAS_CPU_MIPS32_R2=y
CONFIG_CPU_MIPS32=y
CONFIG_CPU_MIPSR2=y
CONFIG_SYS_SUPPORTS_32BIT_KERNEL=y
CONFIG_CPU_SUPPORTS_32BIT_KERNEL=y
CONFIG_HARDWARE_WATCHPOINTS=y
# Kernel type
# CONFIG_LTQ is not set
# CONFIG_LTQ_OPTIMIZATION is not set
CONFIG_32BIT=y
# CONFIG_64BIT is not set
CONFIG_PAGE_SIZE_4KB=y
# CONFIG_PAGE_SIZE_8KB is not set
# CONFIG_PAGE_SIZE_16KB is not set
# CONFIG_PAGE_SIZE_32KB is not set
# CONFIG_PAGE_SIZE_64KB is not set
CONFIG_THREAD_SIZE_ORDER=2
CONFIG_CPU_HAS_PREFETCH=y
CONFIG_MIPS_MT_DISABLED=y
# CONFIG_MIPS_MT_SMP is not set
# CONFIG_MIPS_MT_SMTC is not set
CONFIG_CPU_HAS_SYNC=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_POPULATES_NODE_MAP=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_VIRT_TO_BUS=y
CONFIG_HAVE_MLOCK=y
CONFIG_HAVE_MLOCKED_PAGE_BIT=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_AVM_LOW_MEMORY_STRATEGY=y
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
# CONFIG_HZ_48 is not set
CONFIG_HZ_100=y
# CONFIG_HZ_128 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_256 is not set
# CONFIG_HZ_1000 is not set
# CONFIG_HZ_1024 is not set
CONFIG_SYS_SUPPORTS_ARBIT_HZ=y
CONFIG_HZ=100
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CONFIG_KEXEC is not set
CONFIG_SECCOMP=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_CONSTRUCTORS=y
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_TREE_PREEMPT_RCU is not set
# CONFIG_RCU_TRACE is not set
CONFIG_RCU_FANOUT=32
# CONFIG_RCU_FANOUT_EXACT is not set
# CONFIG_TREE_RCU_TRACE is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=15
# CONFIG_CGROUPS is not set
# CONFIG_SYSFS_DEPRECATED_V2 is not set
# CONFIG_RELAY is not set
# CONFIG_NAMESPACES is not set
# CONFIG_BLK_DEV_INITRD is not set
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EMBEDDED=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
# CONFIG_PCSPKR_PLATFORM is not set
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
# Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
# CONFIG_PCI_QUIRKS is not set
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
CONFIG_PROFILING=y
CONFIG_AVM_SIMPLE_PROFILING=y
# CONFIG_OPROFILE is not set
CONFIG_HAVE_OPROFILE=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL_ENABLE is not set
# CONFIG_SLOW_WORK is not set
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
# CONFIG_IOSCHED_AS is not set
# CONFIG_IOSCHED_DEADLINE is not set
# CONFIG_IOSCHED_CFQ is not set
# CONFIG_DEFAULT_AS is not set
# CONFIG_DEFAULT_DEADLINE is not set
# CONFIG_DEFAULT_CFQ is not set
CONFIG_DEFAULT_NOOP=y
CONFIG_DEFAULT_IOSCHED="noop"
# CONFIG_FREEZER is not set
# Bus options (PCI, PCMCIA, EISA, ISA, TC)
CONFIG_HW_HAS_PCI=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
# CONFIG_PCIEPORTBUS is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCI_LEGACY is not set
# CONFIG_PCI_INIT_IN_MONITOR is not set
# CONFIG_PCI_DEBUG is not set
# CONFIG_PCI_STUB is not set
# CONFIG_PCI_DISABLE_COMMON_QUIRKS is not set
# CONFIG_PCI_IOV is not set
CONFIG_MMU=y
# CONFIG_PCCARD is not set
# CONFIG_HOTPLUG_PCI is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_HAVE_AOUT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_TRAD_SIGNALS=y
# Power management options
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# CONFIG_ARCH_SUSPEND_POSSIBLE is not set
# CONFIG_PM is not set
# CONFIG_CPU_FREQ is not set
# CONFIG_CPU_IDLE is not set
CONFIG_NET=y
# CONFIG_NET_DEV_LOAD is not set
# Networking options
CONFIG_AVM_PA=y
# CONFIG_KSPEEDTEST is not set
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IFX_IPQOS is not set
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
CONFIG_INET_TUNNEL=m
# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET_XFRM_MODE_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_BEET is not set
CONFIG_INET_LRO=y
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IP_MULTICAST_FASTFORWARD=y
CONFIG_IPV6=y
# CONFIG_IPV6_PRIVACY is not set
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
# CONFIG_INET6_XFRM_TUNNEL is not set
# CONFIG_INET6_TUNNEL is not set
# CONFIG_INET6_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET6_XFRM_MODE_TUNNEL is not set
# CONFIG_INET6_XFRM_MODE_BEET is not set
# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
CONFIG_IPV6_SIT=m
# CONFIG_IPV6_SIT_6RD is not set
CONFIG_IPV6_NDISC_NODETYPE=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_IPV6_MULTIPLE_TABLES is not set
CONFIG_IPV6_MROUTE=y
# CONFIG_IPV6_PIMSM_V2 is not set
# CONFIG_IFX_IGMP_PROXY is not set
# CONFIG_IFX_IGMP_SNOOPING is not set
# CONFIG_IFX_MCAST_FASTPATH is not set
CONFIG_GENERIC_CONNTRACK=y
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_NETFILTER_ADVANCED=y
# CONFIG_BRIDGE_NETFILTER is not set
# Core Netfilter Configuration
CONFIG_NETFILTER_NETLINK=m
# CONFIG_NETFILTER_NETLINK_QUEUE is not set
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NF_CONNTRACK=y
CONFIG_NF_CT_ACCT=y
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_EVENTS=y
# CONFIG_NF_CT_PROTO_DCCP is not set
CONFIG_NF_CT_PROTO_ESP=y
# CONFIG_NF_CT_PROTO_SCTP is not set
# CONFIG_NF_CT_PROTO_UDPLITE is not set
# CONFIG_NF_CONNTRACK_AMANDA is not set
# CONFIG_NF_CONNTRACK_FTP is not set
# CONFIG_NF_CONNTRACK_IPSEC_IKE is not set
# CONFIG_NF_CONNTRACK_H323 is not set
# CONFIG_NF_CONNTRACK_IRC is not set
# CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
# CONFIG_NF_CONNTRACK_PPTP is not set
# CONFIG_NF_CONNTRACK_SANE is not set
# CONFIG_NF_CONNTRACK_SIP is not set
# CONFIG_NF_CONNTRACK_TFTP is not set
# CONFIG_NF_CONNTRACK_RTSP is not set
# CONFIG_NF_CT_NETLINK is not set
# CONFIG_NETFILTER_TPROXY is not set
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
# CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
# CONFIG_NETFILTER_XT_TARGET_IMQ is not set
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
# CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
# CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
# CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
# CONFIG_NETFILTER_XT_MATCH_HELPER is not set
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
# CONFIG_NETFILTER_XT_MATCH_RECENT_PROC_COMPAT is not set
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
# CONFIG_NETFILTER_XT_MATCH_LAYER7 is not set
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
# CONFIG_NETFILTER_XT_MATCH_OSF is not set
# CONFIG_IP_VS is not set
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=y
CONFIG_NF_CONNTRACK_IPV4=y
CONFIG_NF_CONNTRACK_PROC_COMPAT=y
# CONFIG_IP_NF_QUEUE is not set
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_ADDRTYPE=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
# CONFIG_NF_NAT is not set
CONFIG_IP_NF_TARGET_NATTYPE=m
CONFIG_IP_NF_MANGLE=m
# CONFIG_IP_NF_TARGET_CLUSTERIP is not set
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# IPv6: Netfilter Configuration
# CONFIG_NF_CONNTRACK_IPV6 is not set
# CONFIG_IP6_NF_QUEUE is not set
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_TARGET_LOG=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
# CONFIG_IP6_NF_RAW is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
CONFIG_ATM=y
# CONFIG_ATM_CLIP is not set
# CONFIG_ATM_LANE is not set
CONFIG_ATM_BR2684=y
CONFIG_ATM_BR2684_IPFILTER=y
CONFIG_STP=y
CONFIG_BRIDGE=y
# CONFIG_BRIDGE_SNOOPING is not set
# CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=m
# CONFIG_VLAN_8021Q_GVRP is not set
# CONFIG_DECNET is not set
CONFIG_LLC=y
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
# CONFIG_NET_SCH_MULTIQ is not set
# CONFIG_NET_SCH_WRR is not set
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_ESFQ=m
# CONFIG_NET_SCH_ESFQ_NFCT is not set
# CONFIG_NET_SCH_TEQL is not set
CONFIG_NET_SCH_TBF=m
# CONFIG_NET_SCH_GRED is not set
# CONFIG_NET_SCH_DSMARK is not set
# CONFIG_NET_SCH_NETEM is not set
# CONFIG_NET_SCH_DRR is not set
CONFIG_NET_SCH_LLQ=m
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
# CONFIG_NET_CLS_ROUTE4 is not set
CONFIG_NET_CLS_ROUTE=y
# CONFIG_NET_CLS_FW is not set
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
# CONFIG_CLS_U32_MARK is not set
# CONFIG_NET_CLS_RSVP is not set
# CONFIG_NET_CLS_RSVP6 is not set
# CONFIG_NET_CLS_FLOW is not set
# CONFIG_NET_EMATCH is not set
# CONFIG_NET_CLS_ACT is not set
# CONFIG_NET_CLS_IND is not set
CONFIG_NET_SCH_FIFO=y
# CONFIG_DCB is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
CONFIG_BT=m
CONFIG_BT_L2CAP=m
# CONFIG_BT_SCO is not set
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
# CONFIG_BT_CMTP is not set
# Bluetooth device drivers
CONFIG_BT_HCIBTUSB=m
# CONFIG_BT_HCIUART is not set
# CONFIG_BT_HCIBCM203X is not set
# CONFIG_BT_HCIBPA10X is not set
CONFIG_BT_HCIBFUSB=m
# CONFIG_BT_HCIVHCI is not set
# CONFIG_BT_MRVL is not set
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
CONFIG_CFG80211_DEFAULT_PS_VALUE=0
# CONFIG_WIRELESS_OLD_REGULATORY is not set
CONFIG_WIRELESS_EXT=y
CONFIG_WIRELESS_EXT_SYSFS=y
# CONFIG_LIB80211 is not set
# CONFIG_LIB80211_CRYPT_WEP is not set
# CONFIG_LIB80211_CRYPT_CCMP is not set
# CONFIG_LIB80211_CRYPT_TKIP is not set
# CFG80211 needs to be enabled for MAC80211
# Some wireless drivers require a rate control algorithm
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH=""
# CONFIG_DEVTMPFS is not set
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=m
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_CONCAT is not set
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_ROOTFS_ROOT_DEV is not set
# CONFIG_MTD_ROOTFS_SPLIT is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_MTD_OOPS is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_NOSWAP=y
# CONFIG_MTD_CFI_BE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_LE_BYTE_SWAP is not set
CONFIG_MTD_CFI_GEOMETRY=y
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_OTP is not set
# CONFIG_MTD_CFI_INTELEXT is not set
CONFIG_MTD_CFI_AMDSTD=y
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
CONFIG_MTD_RAM=y
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP=y
# CONFIG_MTD_PHYSMAP_COMPAT is not set
# CONFIG_MTD_PCI is not set
# CONFIG_MTD_GPIO_ADDR is not set
# CONFIG_MTD_INTEL_VR_NOR is not set
CONFIG_MTD_PLATRAM=y
# CONFIG_MTD_PLATNOR is not set
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
CONFIG_MTD_BLOCK2MTD=m
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
# CONFIG_MTD_AR7240_SPI_FLASH is not set
# CONFIG_MTD_ATH_FLASH is not set
# CONFIG_MTD_AR7100_SPI_FLASH is not set
# CONFIG_MTD_AR9100_PARALLEL_FLASH is not set
# CONFIG_MTD_NAND is not set
# CONFIG_MTD_ONENAND is not set
# LPDDR flash memory drivers
# CONFIG_MTD_LPDDR is not set
# UBI - Unsorted block images
# CONFIG_MTD_UBI is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
CONFIG_COMPCACHE=m
# CONFIG_BLK_DEV_VIRTUAL_FAT is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=m
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_SX8 is not set
# CONFIG_BLK_DEV_UB is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_HD is not set
# CONFIG_MISC_DEVICES is not set
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_TGT is not set
# CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
CONFIG_CHR_DEV_SG=y
# CONFIG_CHR_DEV_SCH is not set
CONFIG_SCSI_MULTI_LUN=y
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
CONFIG_SCSI_SCAN_ASYNC=y
CONFIG_SCSI_WAIT_SCAN=m
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_SCSI_BNX2_ISCSI is not set
# CONFIG_BE2ISCSI is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC7XXX_OLD is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_AIC94XX is not set
# CONFIG_SCSI_MVSAS is not set
# CONFIG_SCSI_DPT_I2O is not set
# CONFIG_SCSI_ADVANSYS is not set
# CONFIG_SCSI_ARCMSR is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
# CONFIG_MEGARAID_SAS is not set
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_SCSI_HPTIOP is not set
# CONFIG_LIBFC is not set
# CONFIG_LIBFCOE is not set
# CONFIG_FCOE is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_FUTURE_DOMAIN is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_STEX is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_QLA_FC is not set
# CONFIG_SCSI_QLA_ISCSI is not set
# CONFIG_SCSI_LPFC is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_DC390T is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_PMCRAID is not set
# CONFIG_SCSI_SRP is not set
# CONFIG_SCSI_BFA_FC is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
CONFIG_MD=y
# CONFIG_BLK_DEV_MD is not set
CONFIG_BLK_DEV_DM=m
# CONFIG_DM_DEBUG is not set
CONFIG_DM_CRYPT=m
# CONFIG_DM_SNAPSHOT is not set
# CONFIG_DM_MIRROR is not set
# CONFIG_DM_ZERO is not set
# CONFIG_DM_MULTIPATH is not set
# CONFIG_DM_DELAY is not set
# CONFIG_DM_UEVENT is not set
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# You can enable one or both FireWire driver stacks.
# See the help texts for more information.
# CONFIG_FIREWIRE is not set
# CONFIG_IEEE1394 is not set
# CONFIG_I2O is not set
CONFIG_NETDEVICES=y
CONFIG_DUMMY=m
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
# CONFIG_IMQ is not set
CONFIG_TUN=y
# CONFIG_VETH is not set
# CONFIG_ARCNET is not set
# CONFIG_PHYLIB is not set
CONFIG_NET_ETHERNET=y
# CONFIG_MII is not set
CONFIG_AVM_CPMAC=y
CONFIG_AVM_CPMAC_NUM_RX_BUFFERS=256
CONFIG_AVM_CPMAC_SWITCH=y
# CONFIG_AX88796 is not set
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_SMC91X is not set
# CONFIG_DM9000 is not set
# CONFIG_ETHOC is not set
# CONFIG_DNET is not set
# CONFIG_NET_TULIP is not set
# CONFIG_HP100 is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_NET_PCI is not set
# CONFIG_B44 is not set
# CONFIG_KS8842 is not set
# CONFIG_KS8851_MLL is not set
# CONFIG_ATL2 is not set
# CONFIG_NETDEV_1000 is not set
# CONFIG_NETDEV_10000 is not set
# CONFIG_TR is not set
CONFIG_WLAN=y
# CONFIG_WLAN_PRE80211 is not set
# CONFIG_WLAN_80211 is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_USBNET is not set
# CONFIG_WAN is not set
CONFIG_ATM_DRIVERS=y
# CONFIG_ATM_DUMMY is not set
# CONFIG_ATM_TCP is not set
# CONFIG_ATM_LANAI is not set
# CONFIG_ATM_ENI is not set
# CONFIG_ATM_FIRESTREAM is not set
# CONFIG_ATM_ZATM is not set
# CONFIG_ATM_NICSTAR is not set
# CONFIG_ATM_IDT77252 is not set
# CONFIG_ATM_AMBASSADOR is not set
# CONFIG_ATM_HORIZON is not set
# CONFIG_ATM_IA is not set
# CONFIG_ATM_FORE200E is not set
# CONFIG_ATM_HE is not set
# CONFIG_ATM_SOLOS is not set
# CONFIG_IFX_ETHSW_API is not set
# CONFIG_IFX_PPA is not set
# CONFIG_IFX_ETH_FRAMEWORK is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_PPP=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
# CONFIG_PPP_BSDCOMP is not set
CONFIG_PPP_MPPE_MPPC=m
CONFIG_PPPOE=m
CONFIG_PPPOATM=m
# CONFIG_PPPOL2TP is not set
# CONFIG_SLIP is not set
CONFIG_SLHC=m
# CONFIG_NET_FC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
CONFIG_AVM_NET_LINK_AUDIO=m
CONFIG_ISDN=y
# CONFIG_ISDN_I4L is not set
# CONFIG_MISDN is not set
CONFIG_ISDN_CAPI=y
CONFIG_CAPI_OSLIB=y
# CONFIG_CAPI_OSLIB_DEBUG is not set
CONFIG_CAPI_CODEC=m
# CONFIG_CAPI_CODEC_SPEEX is not set
CONFIG_CAPI_CODEC_ILBC=y
CONFIG_CAPI_CODEC_G729=y
CONFIG_CAPI_CODEC_G711=y
CONFIG_CAPI_CODEC_G726=y
CONFIG_CAPI_CODEC_G722=y
CONFIG_CAPI_CODEC_VAD=y
CONFIG_CAPI_CODEC_CNG=y
CONFIG_CAPI_CODEC_FAX=y
CONFIG_AVM_DECT=m
# CONFIG_AVM_DECT_DEBUG is not set
# CONFIG_ISDN_DRV_AVMB1_VERBOSE_REASON is not set
CONFIG_CAPI_TRACE=y
# CONFIG_ISDN_CAPI_MIDDLEWARE is not set
# CONFIG_ISDN_CAPI_CAPI20 is not set
# CAPI hardware drivers
CONFIG_CAPI_AVM=y
# CONFIG_ISDN_DRV_AVMB1_B1PCI is not set
# CONFIG_ISDN_DRV_AVMB1_B1PCMCIA is not set
# CONFIG_ISDN_DRV_AVMB1_T1PCI is not set
# CONFIG_ISDN_DRV_AVMB1_C4 is not set
CONFIG_ISDN_CAPI_ISDN_NT_PCMLINK=m
CONFIG_ISDN_NT_PCMLINK_BLK=m
CONFIG_ISDN_NT_PCMLINK_E1=m
CONFIG_ISDN_NT_PCMLINK_STACK=m
CONFIG_ISDN_NT_PCMLINK_ISDN_AB=m
# CONFIG_ISDN_NT_PCMLINK_DEBUG is not set
# CONFIG_ISDN_NT_PCMLINK_NO_BCHANNEL is not set
# CONFIG_ISDN_NT_PCMLINK_FAX is not set
# CONFIG_ISDN_NT_PCMLINK_COMPRESS is not set
# CONFIG_ISDN_NT_PCMLINK_MODEM is not set
# CONFIG_ISDN_NT_PCMLINK_DTMF is not set
CONFIG_ISDN_NT_PCMLINK_VCTRLS=y
CONFIG_ISDN_NT_PCMLINK_VCTRLS_NUMBER=5
CONFIG_ISDN_NT_PCMLINK_FRITZX=y
# CONFIG_CAPI_EICON is not set
# CONFIG_PHONE is not set
# Input device support
# CONFIG_INPUT is not set
# Hardware I/O ports
# CONFIG_SERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
# CONFIG_VT is not set
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_NOZOMI is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# CONFIG_SERIAL_HORNET is not set
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_JSM is not set
CONFIG_SERIAL_AVM_8250=y
CONFIG_SERIAL_AVM_8250_CONSOLE=y
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=16
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_GPIO_DEVICE is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
CONFIG_DEVPORT=y
CONFIG_TFFS=y
CONFIG_TFFS_ENV=y
# CONFIG_TFFS_CRYPT is not set
CONFIG_TFFS_MTD_DEVICE_0=3
CONFIG_TFFS_MTD_DEVICE_1=4
CONFIG_TFFS_PANIC_LOG=y
CONFIG_TFFS_PANIC_LOG_ID=96
CONFIG_AVM_NET_TRACE=y
CONFIG_AVM_POWER=y
CONFIG_AVM_POWERMETER=y
CONFIG_AVM_DECT_IO=m
CONFIG_AVM_DECT_SYNC=10
CONFIG_AVM_SAMMEL=y
CONFIG_AVM_EVENT=y
# CONFIG_AVM_PUSH_BUTTON is not set
# CONFIG_AVM_PUSH_BUTTON2 is not set
# CONFIG_AVM_PUSH_BUTTON3 is not set
# CONFIG_AVM_PUSH_BUTTON4 is not set
# CONFIG_AVM_PUSH_BUTTON5 is not set
# CONFIG_AVM_AUDIO is not set
CONFIG_AVM_WATCHDOG=y
CONFIG_AVM_LED_EVENTS=m
# CONFIG_AVM_LED is not set
CONFIG_AVM_DEBUG=y
# CONFIG_AVM_LED_OUTPUT_SHIFT_REGISTER is not set
CONFIG_AVM_LED_OUTPUT_GPIO=y
# CONFIG_AVM_LED_OUTPUT_DUAL_GPIO is not set
CONFIG_AVM_FLASH_UPDATE=m
# CONFIG_AVM_PIGLET is not set
CONFIG_AVM_PIGLET_NOEMIF=m
CONFIG_AVM_PIGLET_DECT=y
CONFIG_UBIK2=m
CONFIG_UBIK2_DEVELOPMENT_SUPPORT=0
# CONFIG_IFXMIPS_DSL_CPE_MEI is not set
# CONFIG_DSL_MEI_CPE_DRV is not set
# CONFIG_I2C is not set
# CONFIG_SPI is not set
# PPS support
# CONFIG_PPS is not set
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
# Multifunction device drivers
# CONFIG_MFD_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEDIA_SUPPORT is not set
# Graphics support
# CONFIG_VGA_ARB is not set
# CONFIG_DRM is not set
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# CONFIG_SOUND is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
# CONFIG_USB_DEVICE_CLASS is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
# CONFIG_USB_EHCI_HCD is not set
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_OHCI_HCD is not set
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_WHCI_HCD is not set
# CONFIG_USB_HWA_HCD is not set
CONFIG_USB_MUSB_HDRC=y
CONFIG_USB_MUSB_SOC=y
CONFIG_USB_MUSB_HOST=y
# CONFIG_USB_MUSB_PERIPHERAL is not set
# CONFIG_USB_MUSB_OTG is not set
CONFIG_USB_MUSB_HDRC_HCD=y
# CONFIG_USB_MUSB_AVM_BOARD_UR8_VBUS_NOT_CONNECTED is not set
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_INVENTRA_DMA is not set
CONFIG_USB_TI_CPPI_DMA=y
# CONFIG_USB_MUSB_DEBUG is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
CONFIG_USB_LIBUSUAL=y
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB port drivers
CONFIG_USB_SERIAL=m
# CONFIG_USB_EZUSB is not set
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_CH341 is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
CONFIG_USB_SERIAL_CP210X=m
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
CONFIG_USB_SERIAL_FTDI_SIO=m
# CONFIG_USB_SERIAL_FUNSOFT is not set
# CONFIG_USB_SERIAL_VISOR is not set
CONFIG_USB_SERIAL_IPAQ=m
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MOTOROLA is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
CONFIG_USB_SERIAL_PL2303=m
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_QUALCOMM is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_HP4X is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SIEMENS_MPI is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_SYMBOL is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
CONFIG_USB_SERIAL_OPTION=m
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_OPTICON is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_BERRY_CHARGE is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_VST is not set
# CONFIG_USB_ATM is not set
# CONFIG_USB_GADGET is not set
# OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
# CONFIG_USB_GPIO_VBUS is not set
CONFIG_NOP_USB_XCEIV=y
# CONFIG_UWB is not set
# CONFIG_MMC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=m
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# SPI RTC drivers
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_RTC7301 is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_AVM_REF_CLOCK=m
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# TI VLYNQ
CONFIG_VLYNQ=y
# CONFIG_VLYNQ_DEBUG is not set
CONFIG_STAGING=y
# CONFIG_STAGING_EXCLUDE_BUILD is not set
CONFIG_USB_IP_COMMON=m
CONFIG_USB_IP_VHCI_HCD=m
CONFIG_USB_IP_HOST=m
# CONFIG_PRISM2_USB is not set
# CONFIG_ECHO is not set
# CONFIG_COMEDI is not set
# CONFIG_ASUS_OLED is not set
# CONFIG_ALTERA_PCIE_CHDMA is not set
# CONFIG_RTL8187SE is not set
# CONFIG_RTL8192SU is not set
# CONFIG_RTL8192E is not set
# CONFIG_TRANZPORT is not set
# Android
# Qualcomm MSM Camera And Video
# Camera Sensor Selection
# CONFIG_INPUT_GPIO is not set
# CONFIG_DST is not set
# CONFIG_POHMELFS is not set
# CONFIG_B3DFG is not set
# CONFIG_PLAN9AUTH is not set
# CONFIG_USB_SERIAL_QUATECH2 is not set
# CONFIG_USB_SERIAL_QUATECH_USB2 is not set
# CONFIG_VT6655 is not set
# CONFIG_VT6656 is not set
# CONFIG_VME_BUS is not set
# RAR Register Driver
# CONFIG_RAR_REGISTER is not set
# CONFIG_IIO is not set
# AVM UR8 DSL support
CONFIG_UR8_DSL=m
# CONFIG_DSL_AVM_MITSCHNEIDER is not set
# CONFIG_DSL_AVM_DEBUG is not set
CONFIG_MIPS_AVALANCHE_INTC=y
CONFIG_AVALANCHE_INTC_TYPE=y
CONFIG_MIPS_YAMUNA=y
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_DEFAULTS_TO_ORDERED is not set
CONFIG_EXT3_FS_XATTR=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
CONFIG_EXT4_FS=m
# CONFIG_EXT4_FS_XATTR is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD=y
CONFIG_JBD2=m
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
# CONFIG_REISERFS_FS_XATTR is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_YAFFS_FS is not set
CONFIG_FILE_LOCKING=y
CONFIG_FSNOTIFY=y
# CONFIG_DNOTIFY is not set
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=m
CONFIG_FUSE_FS=m
# CONFIG_CUSE is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
# CONFIG_ZISOFS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
# CONFIG_JFFS2_SUMMARY is not set
# CONFIG_JFFS2_FS_XATTR is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
# CONFIG_JFFS2_LZO is not set
# CONFIG_JFFS2_LZMA is not set
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_EMBEDDED=y
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
CONFIG_MINI_FO=m
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=m
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
# CONFIG_NFS_V4 is not set
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
# CONFIG_NFSD_V3_ACL is not set
# CONFIG_NFSD_V4 is not set
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=m
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=m
# CONFIG_RPCSEC_GSS_KRB5 is not set
# CONFIG_RPCSEC_GSS_SPKM3 is not set
# CONFIG_SMB_FS is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS is not set
# CONFIG_CIFS_WEAK_PW_HASH is not set
# CONFIG_CIFS_XATTR is not set
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_CIFS_EXPERIMENTAL is not set
# CONFIG_NCP_FS is not set
CONFIG_CODA_FS=m
# CONFIG_AFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=y
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
CONFIG_NLS_ISO8859_15=y
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=y
# CONFIG_DLM is not set
# Kernel hacking
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
# CONFIG_PRINTK_TIME is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
CONFIG_MAGIC_SYSRQ=y
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
CONFIG_DEBUG_KERNEL=y
# CONFIG_DEBUG_SHIRQ is not set
# CONFIG_DETECT_SOFTLOCKUP is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_SCHED_DEBUG is not set
# CONFIG_SCHEDSTATS is not set
# CONFIG_TIMER_STATS is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_DEBUG_SLAB is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_RT_MUTEX_TESTER is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_DEBUG_KOBJECT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_WRITECOUNT is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_CPU_STALL_DETECTOR is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
# CONFIG_PAGE_POISONING is not set
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
CONFIG_CMDLINE=""
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_RUNTIME_DEBUG is not set
CONFIG_BDI_SWITCH=y
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
# CONFIG_SECURITY_FILE_CAPABILITIES is not set
CONFIG_CRYPTO=y
# Crypto core or helper
# CONFIG_CRYPTO_FIPS is not set
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=m
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=m
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=m
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=m
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP=y
CONFIG_CRYPTO_MANAGER=m
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_MANAGER_NO_TESTS is not set
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_AUTHENC=m
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
CONFIG_CRYPTO_CBC=m
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=m
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
CONFIG_CRYPTO_HMAC=m
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
# CONFIG_CRYPTO_CRC32C is not set
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=m
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=m
CONFIG_CRYPTO_SHA256=m
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=m
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=m
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=m
CONFIG_CRYPTO_ZLIB=y
# CONFIG_CRYPTO_UNLZMA is not set
# CONFIG_CRYPTO_LZO is not set
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=m
# OCF Configuration
# CONFIG_OCF_OCF is not set
# CONFIG_CRYPTO_HW is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_GENERIC_FIND_LAST_BIT=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16=m
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=m
CONFIG_LZO_DECOMPRESS=m
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_NLATTR=y
Leider erscheint im menuconfig das Modul xt_time nicht zur Auswahl - kann ich dieses händisch bauen und auf die Box transferieren ? Bisher ist es dort natürlich nicht:
root@fritz:/var/mod/root# find / -iname '*.ko' | grep netfilter
/lib/modules/2.6.32.41/kernel/net/ipv4/netfilter/ip_tables.ko
/lib/modules/2.6.32.41/kernel/net/ipv4/netfilter/ipt_LOG.ko
/lib/modules/2.6.32.41/kernel/net/ipv4/netfilter/ipt_REJECT.ko
/lib/modules/2.6.32.41/kernel/net/ipv4/netfilter/iptable_filter.ko
/lib/modules/2.6.32.41/kernel/net/ipv4/netfilter/iptable_mangle.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/x_tables.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_MARK.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_iprange.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_length.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_limit.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_mac.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_mark.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_multiport.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_pkttype.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_state.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_statistic.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_string.ko
/lib/modules/2.6.32.41/kernel/net/netfilter/xt_tcpudp.ko
Grüße,
JD.
In der Kernel Config steht CONFIG_NETFILTER_XT_MATCH_TIME=m, also muss das Modul auch erstellt werden. Du musst nur noch dafür sorgen, dass es auf die Box kopiert wird. Das geht entweder von Hand, oder Du schaust mal in make/iptables/Config.in rein und machst dort noch einen Abschnitt für xt_time hinein.
Welche Kernel-Versionen haben denn xt_time? Sieht aus, als wäre es ab 2.6.28 drin.
Dann sollte es für eine 7270v3 (2.6.32.41) ja passen.
Ich werde die make/iptables/Config.in bearbeiten und wieder berichten.
Interessant wäre noch zu wissen, warum es im menuconfig nicht angeboten wird.
Hat geklapt, das Modul ist auf der Box:
Module                  Size  Used by    Tainted: P
xt_tcpudp               1886 21
xt_MARK                  574  0
xt_mark                  574  0
xt_mac                   638  0
ipt_REJECT              2088  0
ipt_LOG                 6133  4
iptable_filter           899  1
ip_tables              10502  1 iptable_filter
sch_sfq                 5404  4
sch_llq                 8436  1
sch_tbf                 4290  1
wlan_scan_ap            7537  1
wlan_acl                3184  1
wlan_wep                4375  0
wlan_tkip               9408  2
wlan_ccmp               6137  2
wlan_xauth               601  0
ath_pci               149400  0
ath_spectral           93193  1 ath_pci
ath_rate_atheros       59649  1 ath_pci
wlan                  220606  9 wlan_scan_ap,wlan_acl,wlan_wep,wlan_tkip,wlan_ccmp,wlan_xauth,ath_pci,ath_rate_atheros
ath_dfs                40072  3 wlan_scan_ap,ath_pci,wlan
ath_hal               299091  5 ath_pci,ath_spectral,ath_rate_atheros,ath_dfs
avm_ath_extensions     41416  6 wlan_scan_ap,ath_pci,ath_rate_atheros,wlan,ath_dfs,ath_hal
kdsldmod             1090914  4
dsl_ur8               191113  2
ramzswap               18434  1
lzo_compress            1898  1 ramzswap
lzo_decompress          2031  1 ramzswap
xt_time                 1709  0
xt_limit                1187  1
xt_string                958  0
xt_multiport            1982 20
xt_iprange              1134  0
xt_state                 883  3
x_tables               11462 13 xt_tcpudp,xt_MARK,xt_mark,xt_mac,ipt_REJECT,ipt_LOG,ip_tables,xt_time,xt_limit,xt_string,xt_multiport,xt_iprange,xt_state
vfat                    8730  0
fat                    49584  1 vfat
capi_codec            417508  0
isdn_fbox_fon5        792793  4
pcmlink               383288  2 capi_codec,isdn_fbox_fon5
loop                   13767  2
Piglet_noemif          48115  0
rtc_avm                 5237  1 pcmlink
rtc_core               15336  1 rtc_avm
led_modul_Fritz_Box_7270plus    73611  2
Vermutlich hat es bisher keiner gebraucht. Ich habe gestern noch eine Änderung an make/iptables/Config.in gemacht (#11203), damit sollte es direkt funktionieren.
Hab' 's gesehen, danke.
Leider klappt die Benutzung noch nicht so, wie ich mir das vorstelle:
Eine Regel dergestalt
iptables -A INPUT -p tcp -s *.*.*.* -m time --timestart 10:00 --timestop 18:00 --weekdays Mon,Tue,Wed,Thu,Fri -m multiport --dport 22 -j ACCEPT
schlägt leider fehl, sprich: es greift die DROP-Policy am Ende:
Nov  8 10:57:49 fritz kern.warn kernel: [IPT] DENY-FRITZ-ACCESS IN=dsl OUT= MAC= SRC=*.*.*.* DST=192.168.178.1 LEN=52 TOS=0x00 PREC=0x00 TTL=56 ID=62773 DF PROTO=TCP SPT=52313 DPT=22 WINDOW=49640 RES=0x00 SYN URGP=0
Hat jemand einen Tip, woran das liegen könnte ? Die IP-Adressen sind natürlich identisch, und ein
date -R
führt zu folgendem:
Fri, 08 Nov 2013 11:08:31 +0100
Ich glaube, die Ursache für das Problem gefunden zu haben: Die Zeitfenster in meiner Regel scheinen von iptables als UTC gewertet zu werden. D.h. beispielsweise, daß meine o.g. Regel nach 11:00 Uhr den Datenverkehr zuläßt (obwohl eigentlich ab 10:00 beabsichtigt war).
Ich habe xt_time noch nie verwendet, aber manchmal hilft ein Blick ins Manual:
All times are interpreted as UTC by default.
Das heißt, der Eintrag von 10:57:49 ist 09:57:49 UTC und somit vor 10:00.
PS:
Ich würde für SSH einen abweichenden Port verwenden, statt die Zeiten einzuschränken.
Darf ich fragen, wo Du das gefunden hast ?
Würde ich tun, allerdings stehen da einige per (Firewall-)default geschlossene Ports entgegen.
Okay, hab' das Manual gefunden.
Die einfachste Möglichkeit ist, auf einem Linux System (zum Beispiel das Build System) das Programm "man" zu verwenden. Wenn dort die Information nicht vorhanden ist, habe ich mit Google "man xxx" meistens etwas passendes gefunden. Wenn nicht, existiert wahrscheinlich keine man-page dazu, dann ist die Homepage zum Programm der beste Anlaufpunkt, auch über Google zu finden.
