Hello! I am using my Fritz!Box 7140 in IP-Client mode connected to a Thomson TG784 Residential Internet Gateway or Router, which provides an IPTV service to my home. Unfortunately, when I connect my Fritz to my Thomson, the IPTV service stops working correctly. I have determined it happens only when multid is started with its igmp proxy daemon, which somehow interferes with the IPTV service (I guess because it's based on IGMP for channel operation). I workaround the problem by stopping multid or starting manually with the igmp proxy disabled (-i command-line option).
However, if the box is restarted for some reason, multid is running again with igmp proxy enabled. I would like to know how to disable multid or simply change its initscript to run with the -i option. I already tried editing /etc/rc.multid with nano, but got the error message read-only filesystem.
Thank you!
Thank you!
