-- Executing [s@macro-dialout-trunk:25] Set("SIP/100-00000002", "pre_num=AMP:dongle/dongle0/") in new stack
-- Executing [s@macro-dialout-trunk:26] Set("SIP/100-00000002", "the_num=OUTNUM") in new stack
-- Executing [s@macro-dialout-trunk:27] Set("SIP/100-00000002", "post_num=") in new stack
-- Executing [s@macro-dialout-trunk:28] GotoIf("SIP/100-00000002", "1?outnum:skipoutnum") in new stack
-- Goto (macro-dialout-trunk,s,29)
-- Executing [s@macro-dialout-trunk:29] Set("SIP/100-00000002", "the_num=0232560119") in new stack
-- Executing [s@macro-dialout-trunk:30] Dial("SIP/100-00000002", "dongle/dongle0/0232560119,300,") in new stack
[2013-05-29 12:37:25] WARNING[3179][C-00000002]: channel.c:180 channel_request: [dongle0] Request to call on device which can not make call at this moment
[2013-05-29 12:37:25] WARNING[3179][C-00000002]: app_dial.c:2437 dial_exec_full: Unable to create channel of type 'dongle' (cause 44 - Requested channel not available)
== Everyone is busy/congested at this time (1:0/0/1)
-- Executing [s@macro-dialout-trunk:31] NoOp("SIP/100-00000002", "Dial failed for some reason with DIALSTATUS = CHANUNAVAIL and HANGUPCAUSE = 44") in new stack
-- Executing [s@macro-dialout-trunk:32] GotoIf("SIP/100-00000002", "0?continue,1:s-CHANUNAVAIL,1") in new stack
-- Goto (macro-dialout-trunk,s-CHANUNAVAIL,1)
-- Executing [s-CHANUNAVAIL@macro-dialout-trunk:1] Set("SIP/100-00000002", "RC=44") in new stack
-- Executing [s-CHANUNAVAIL@macro-dialout-trunk:2] Goto("SIP/100-00000002", "44,1") in new stack
-- Goto (macro-dialout-trunk,44,1)
-- Executing [44@macro-dialout-trunk:1] Goto("SIP/100-00000002", "continue,1") in new stack
-- Goto (macro-dialout-trunk,continue,1)
-- Executing [continue@macro-dialout-trunk:1] NoOp("SIP/100-00000002", "TRUNK Dial failed due to CHANUNAVAIL HANGUPCAUSE: 44 - failing through to other trunks") in new stack
-- Executing [continue@macro-dialout-trunk:2] Set("SIP/100-00000002", "CALLERID(number)=100") in new stack
-- Executing [20232560119@from-internal:6] Macro("SIP/100-00000002", "outisbusy,") in new stack
-- Executing [s@macro-outisbusy:1] Progress("SIP/100-00000002", "") in new stack
-- Executing [s@macro-outisbusy:2] GotoIf("SIP/100-00000002", "0?emergency,1") in new stack
-- Executing [s@macro-outisbusy:3] GotoIf("SIP/100-00000002", "0?intracompany,1") in new stack
-- Executing [s@macro-outisbusy:4] Playback("SIP/100-00000002", "all-circuits-busy-now&pls-try-call-later, noanswer") in new stack
