--- make/davfs2/files/root/etc/default.davfs2/webdav_mount (revision 4437)
+++ make/davfs2/files/root/etc/default.davfs2/webdav_mount (working copy)
@@ -20,6 +20,7 @@
if [ "$DAVFS2_SERVERCERT1" == "yes" ]; then
echo "servercert /var/tmp/flash/davfs_servercrt1.pem" >> /var/davfs2/davfs2_1.conf
fi
+ echo "askauth 0" >> /var/davfs2/davfs2_1.conf
chmod 0600 /var/davfs2/secrets_1
echo "mount $DAVFS2_HOST1..."
mkdir -p $DAVFS2_MOUNTPOINT1 2>/dev/null
@@ -31,6 +32,7 @@
if [ "$DAVFS2_SERVERCERT2" == "yes" ]; then
echo "servercert /var/tmp/flash/davfs_servercrt2.pem" >> /var/davfs2/davfs2_2.conf
fi
+ echo "askauth 0" >> /var/davfs2/davfs2_2.conf
chmod 0600 /var/davfs2/secrets_2
echo "mount $DAVFS2_HOST2..."
mkdir -p $DAVFS2_MOUNTPOINT2 2>/dev/null
@@ -42,6 +44,7 @@
if [ "$DAVFS2_SERVERCERT3" == "yes" ]; then
echo "servercert /var/tmp/flash/davfs_servercrt3.pem" >> /var/davfs2/davfs2_3.conf
fi
+ echo "askauth 0" >> /var/davfs2/davfs2_3.conf
chmod 0600 /var/davfs2/secrets_3
echo "mount $DAVFS2_HOST3..."
mkdir -p $DAVFS2_MOUNTPOINT3 2>/dev/null
