[FLASH:] MACRONIX Uniform-Flash 16MB 64 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 128 sectors a 128kB)
[SYSTEM:] AR9 on 393MHz/393MHz/196MHz
Atheros 8030/35 detected
Eva_AVM >..........................
Lantiq xDSL CPE AR9
[ 0.000000] Linux version 2.6.32.61 (hjortmann@EmbeddedVM) (gcc version 4.8.1 (Buildroot 2013.05) ) #1 Wed Nov 5 16:32:37 CET 2014
[ 0.000000] phym = 04000000, mem = 04000000, max_pfn = 00004000
[ 0.000000] Reserving memory for CP1 @0xa4000000, size 0x00000000
[ 0.000000] wlan_mem_start = 0x03f9e000
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config (ptr 804cd000)
[ 0.000000] [init_avm_kernel_config] AVM Kernel Config: module memory entry
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 0001954c (MIPS 34Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00003f9e
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00003f9e
[ 0.000000] [c55] c55_mem_start = 0xfc0000
[ 0.000000] [module-alloc-by-name] 'modulemem' not in use, use AVM Kernel Config (7417856 bytes, reserved for module mem)
[ 0.000000] [module-alloc] use 0x713000 bytes at 0x81081000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16158
[ 0.000000] Kernel command line: console=ttyS1,115200n8r nor_size=16MB ethaddr=C0:25:06:83:09:1F
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] [avm_cache_set_coherency]: setting cache coherency for HWRevision=188 to write through
[ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=0007369d
[ 0.000000] Readback ErrCtl register=0007369d
[ 0.000000] Memory: 51544k/65144k available (3392k kernel code, 13528k reserved, 1519k data, 180k init, 0k highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:181
[ 0.000000] [mips_cpu_irq_init] irq_base 0
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [ttyS1] enabled, bootconsole disabled
[ 0.020000] Calibrating delay loop... 261.32 BogoMIPS (lpj=1306624)
[ 0.230000] Security Framework initialized
[ 0.230000] Mount-cache hash table entries: 512
[ 0.230000] kernel_init: started
[ 0.240000] kernel_init: kernel locked
[power_managment_setup] reset 'DSL, DFE, AFE, VOICE, DSLTC, ARC'
[power_managment_setup] reset 'LDO'
[power_managment_setup] power down 'PPE TC, PPE EMA, LEDC, DFEV1, DFEV0'
[power_managment_setup] power down 'MSI1, PDI1 PCIE1 PCIE1_PHY'
[power_managment_setup] power down 'USB CTRL'
[power_managment_setup] power down 'GPHY'
[power_managment_setup] disable power domain 'DSL + DFE'
[ 0.280000] NET: Registered protocol family 16
[ 0.290000] Lantiq GPIO driver, version 1.3.2, (c) 2001-2013 Lantiq Deutschland GmbH
[ 0.290000] Reboot Status is: Power-On
[ 0.300000] [avmnet] [avmnet_cfg_init] Driver version: 6.137 - Revision 1496:2714 - Mo 27. Okt 15:52:55 CET 2014
[ 0.310000] Lantiq PCI host controller driver, version 1.2.0, (c) 2001-2013 Lantiq Deutschland GmbH
[ 0.320000] bio: create slab <bio-0> at 0
[ 0.320000] pci 0000:00:00.0: PME# supported from D1 D2
[ 0.330000] pci 0000:00:00.0: PME# disabled
[ 0.330000] NET: Registered protocol family 8
[ 0.330000] NET: Registered protocol family 20
[ 0.340000] NET: Registered protocol family 2
[ 0.340000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.350000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.350000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.360000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.370000] TCP reno registered
[ 0.370000] NET: Registered protocol family 1
[ 0.370000] IFX DMA driver, version ifxmips_dma_core.c:v1.0.17 ,(c)2009 Infineon Technologies AG
[ 0.370000] skb_shared_size:344
[ 0.390000] [bcu_control_interrupt] 'FPI Slave BCU0' Error Interrupt
[ 0.390000] Slave BCU[sBCU_EADD]: Error Address Register: 0x17000004
[ 0.390000] Slave BCU[sBCU_EDAT]: Error Data Capture Register: 0x0290030f
[ 0.390000] Slave BCU[sBCU_CON] : Control Register: 0x4009ffff
[ 0.390000] Slave BCU[sBCU_ECON]: Error Register (0x21be0030):
[ 0.390000] FPI Bus Operation Code 0x2
[ 0.390000] FPI Bus Tag Number 0x1
[ 0.390000] FPI Bus Read Signal: passive
[ 0.390000] FPI Bus Write Signal: active
[ 0.390000] FPI Bus Supervisor Mode: active
[ 0.390000] FPI Bus Acknowladge Signal: 0x3
[ 0.390000] FPI Bus Abort: passive
[ 0.390000] FPI Bus Ready: active
[ 0.390000] FPI Bus Timeout: not pressed
[ 0.390000] FPI Bus Error Counter: 48
[ 0.460000] [bcu_control_init] interrupts for BCU installed
[ 0.460000] Lantiq CGU driver, version 1.1.32, (c) 2001-2013 Lantiq Deutschland GmbH
[ 0.470000] clk-timing: timing:16, ram_refresh_timing:1524, base_ram_refresh_timing:7775
[ 0.480000] smvp_tc_init: tc 0 tcbind 00020000 tcstatus 18102000
[ 0.480000] smvp_tc_init: tc 1 tcbind 00200001 tcstatus 00000400
[ 0.480000] smvp_tc_init: tc 2 tcbind 00400001 tcstatus 00000400
[ 0.480000] smvp_tc_init: tc 3 tcbind 00600001 tcstatus 00000400
[ 0.480000] config3 0x424 MT 1
[ 0.480000] MVPControl 0x2, STLB 0 VPC 1 EVP 0
[ 0.480000] mvpconf0 0xb8008403, PVPE 1 PTC 3 M 1
[ 0.510000] initcall 0x804d4cdc returned with disabled interrupts
[ 0.520000] audit: initializing netlink socket (disabled)
[ 0.520000] type=2000 audit(0.523:1): initialized
[ 0.530000] squashfs: version 3.4 (2008/08/26) Phillip Lougher
[ 0.540000] JFFS2 version 2.2 (NAND) (ZLIB) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.540000] fuse init (API version 7.13)
[ 0.550000] msgmni has been set to 100
[ 0.550000] io scheduler noop registered (default)
[ 0.560000] [avm_membench_init]
[ 0.860000] avm_net_trace: Up and running.
[ 0.860000] [loadcontrol] set auto - scale=1
[ 0.870000] [avm] configured: watchdog event debug
[ 0.870000] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Nov 5 2014 16:31:46)
[ 0.880000] ifx_pmu_init: Major 245
[ 0.890000] Lantiq PMU driver, version 1.2.6, (c) 2001-2013 Lantiq Deutschland GmbH
[ 0.890000] Infineon Technologies RCU driver version 1.0.7
[ 0.900000] ttyS0 at MMIO 0x1e100400 (irq = 100) is a PORT_IFX_ASC
[ 0.910000] ttyS1 at MMIO 0x1e100c00 (irq = 107) is a PORT_IFX_ASC
[ 0.920000] loop: module loaded
[ 0.920000] nbd: registered device at major 43
[ 0.940000] Generic platform RAM MTD, (c) 2004 Simtec Electronics
[ 0.940000] Platform NOR MTD, (c) AVM 2010
[ 0.950000] [plat_nor_probe]start probe
[ 0.950000] [do_map_probe] driver_name=cfi_probe
[ 0.960000] mtd-nor: Found 1 x16 devices at 0x0 in 16-bit bank
[ 0.960000] Amd/Fujitsu Extended Query Table at 0x0040
[ 0.970000] mtd-nor: CFI does not contain boot bank location. Assuming top.
[ 0.970000] number of CFI chips: 1
[ 0.980000] cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
[ 0.980000] [ifx_jffs2_parser_function] mtd_info->name mtd-nor mtd_info->index 0 param=0 p_mtd_pat=0x83a0c754
[ 0.980000] [0]system-load 1 loadavg 0.0 0.0 0.0 - 14 tasks:0 % curr:swapper(0 %) max:swapper(0 %, pid:1), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
[ 1.010000] [ifx_jffs2_parser_function] try partition kernel (offset 0x20000 len 16121856)
[ 1.020000] [ifx_jffs2_parser_function] magic 19852003 found @pos 0xe80000, size 1048576
[ 1.020000] [ifx_squashfs_parser_function] mtd_info->name mtd-nor mtd_info->index 0 param=0 p_mtd_pat=0x83a0c754
[ 1.050000] [ifx_squashfs_parser_function:320] pos: 0x17e100 | offs[0]: 0x17e100 | size[0]: 14688000 | offs[1]: 0x20000 | size[1]: 1433856
[ 1.060000] [ifx_squashfs_parser_function] magic found @pos 0x17e100
[ 1.060000] 6 find_squashfs partitions found on MTD device mtd-nor
[ 1.070000] Creating 6 MTD partitions on "mtd-nor":
[ 1.070000] 0x00000017e100-0x000000f80000 : "rootfs"
[ 1.080000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 1.090000] {ifx_mtd_add_notifier} name rootfs
[ 1.100000] 0x000000020000-0x00000017e100 : "kernel"
[ 1.100000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[ 1.120000] {ifx_mtd_add_notifier} name kernel
[ 1.120000] 0x000000000000-0x000000020000 : "urlader"
[ 1.130000] {ifx_mtd_add_notifier} name urlader
[ 1.130000] 0x000000f80000-0x000000fc0000 : "tffs (1)"
[ 1.140000] {ifx_mtd_add_notifier} name tffs (1)
[ 1.140000] 0x000000fc0000-0x000001000000 : "tffs (2)"
[ 1.140000] {ifx_mtd_add_notifier} name tffs (2)
[ 1.150000] 0x000000e80000-0x000000f80000 : "jffs2"
[ 1.150000] {ifx_mtd_add_notifier} name jffs2
[ 1.160000] {ifx_mtd_add_notifier} name mtd-nor
[ 1.160000] mtd-nor mtd-nor: registered mtd device
[ 1.170000] Lantiq SSC driver, version 2.4.1, (c) 2001-2013 Lantiq Deutschland GmbH
[ 1.170000] Unknown SPI device: 0xFF 0xFF 0xFF
[ 1.180000] ifx_spi_flash_init: Found no serial flash device
[ 1.180000] tun: Universal TUN/TAP device driver, 1.6
[ 1.190000] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 1.200000] IFX SWITCH API, Version 1.1.8.5
[ 1.200000] SWAPI: Registered character device [switch_api] with major no [81]
[ 1.310000] mice: PS/2 mouse device common for all mice
[ 1.310000] i2c /dev entries driver
[ 1.320000] CAPI Subsystem Rev 1.1.2.8
[ 1.320000] AVM PA 4.3.10 2014-09-21
[ 1.320000] AVM PA skb pktinfo at offset 128 size 196
[ 1.330000] [loadcontrol]module avm_pa registered
[ 1.330000] IPv4 over IPv4 tunneling driver
[ 1.340000] TCP cubic registered
[ 1.340000] mcfw: IGMPv3 fast forwarding
[ 1.350000] NET: Registered protocol family 10
[ 1.350000] IPv6 over IPv4 tunneling driver
[ 1.350000] NET: Registered protocol family 17
[ 1.360000] NET: Registered protocol family 8
[ 1.360000] atmpvc_init() failed with -17
[ 1.370000] KOAM is loaded successfully.
[ 1.370000] l2tp_core: L2TP core driver, V2.0
[ 1.370000] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 1.380000] l2tp_netlink: L2TP netlink interface
[ 1.380000] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 1.390000] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[ 1.400000] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
[ 1.410000] mount on mtd3 and mtd4 (double buffering)
[ 1.410000] Adam2 environment variables API installed.
[ 1.420000] [simple-profiling]: 4 performance counters implemented, OLD_34K
[ 1.420000] Enable Performance Counter 0 for Data cache load/stores (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[ 1.440000] Setup tcs=0x1 current_tc_mask=0x1, reg=0
[ 1.440000] [simple-profiling]: 4 performance counters implemented, OLD_34K
[ 1.450000] Enable Performance Counter 1 for Data cache load/store misses (User-Mode enabled Supervisor-Mode enabled Kernel-Mode enabled Exeption-Mode disable)
[ 1.460000] Setup tcs=0x1 current_tc_mask=0x1, reg=1
[ 1.470000] AVM Simple Profiling enabled Version 3.0
[ 1.470000] {avmnet_cfg_netinit}
[ 1.480000] [avmnet] No config found for HWRev 188, HWSubRev 2, Profile-ID 0, trying base config for HWSubRev
[ 1.490000] [avmnet] No config found for HWRev 188, HWSubRev 2, trying base config for HWRev
[ 1.490000] {avmnet_mac_ar9_init} Init on module mac_ar9_0 called.
[ 1.510000] {avmnet_mac_ar9_init} Init on module mac_ar9_1 called.
[ 1.530000] [avmnet] [avmnet_mac_ar9_setup] IFX_AR9_ETH_CTL(0): 0x424001
[ 1.530000] [avmnet] [avmnet_mac_ar9_setup] mac_nr: 0, vlan_reg: 0x4070001
[ 1.660000] [avmnet] [avmnet_mac_ar9_setup] IFX_AR9_ETH_CTL(1): 0x424001
[ 1.660000] [avmnet] [avmnet_mac_ar9_setup] mac_nr: 1, vlan_reg: 0x4070001
[ 1.790000] [avm_pa_multiplexer_init] start
[ 1.800000] [avm_pa_multiplexer_init] init complete
[ 1.800000] [avm_pa_multiplexer_register_instance]
[ 1.800000] add:0x80242cb0
[ 1.800000] remove:0x80244504
[ 1.810000] [avmnet_set_macaddr] Setup Mac Addr for Device(eth0): c0:25:06:83:09:1f
[ 1.820000] [avmnet_set_macaddr] Setup Mac Addr for Device(eth1): c0:25:06:83:09:20
[ 1.830000] kernel_init: basic setup done
[ 1.830000] [squashfs] use lzma compression
[ 1.840000] VFS: Mounted root (squashfs filesystem) readonly on device 31:0.
[ 1.850000] Freeing unused kernel memory: 180k freed
[ 1.890000] trying /sbin/init
starting pid 113, tty '/dev/ttyS1': '/etc/init.d/rc.S'
tar: removing leading '/' from member names
source files in group 0 ...
/etc/init.d/S00-signal /etc/init.d/S05-watchdog /etc/init.d/S09-rtc
/etc/init.d/S01-head /etc/init.d/S08-tffs
/etc/init.d/S02-led /etc/init.d/S09-config
[ 2.790000] TFFS Name Table K
[ 4.020000] [module-alloc-by-name] give 0x11000 bytes at 0x81081000 to module 'led_modul_Fritz_Box_HW188' (0x702000 bytes left)
[ 4.030000] led_modul_Fritz_Box_HW188: module license '
[ 4.030000] (C) Copyright 2012 by AVM
[ 4.030000] ' taints kernel.
[ 4.040000] Disabling lock debugging due to kernel taint
[ 4.080000] AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
mknod: /var/flash/ar7.cfg: File exists
checkempty: : No such file or directory
P-Defaults: and action...
P-Defaults: ...done.
[ 5.190000] [module-alloc-by-name] give 0x1000 bytes at 0x81092000 to module 'rtc_avm' (0x701000 bytes left)
[ 5.220000] rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[ 5.220000] [avm-rtc]: avm_rtc_probe: register: ret=0x8311fc00
[ 5.230000] [avm-rtc]: avm_rtc_probe: success
exceute files in group 0 ...
/etc/init.d/E05-basemodules
group 0 done ...
source files in group 1 ...
/etc/init.d/S10-html /etc/init.d/S12-default
/etc/init.d/S10-vm /etc/init.d/S15-filesys
/etc/init.d/S11-config_def /etc/init.d/S17-capi
/etc/init.d/S11-piglet /etc/init.d/S17-tam
[ 5.440000]
[ 5.440000] [avm_debug] redirecting kernel-messages (/dev/debug)
[ 5.490000] [module-alloc-by-name] give 0x8000 bytes at 0x81093000 to module 'Piglet_noemif' (0x6F9000 bytes left)
[ 5.490000] [module-alloc-by-name] 0x8000 bytes used, 0xADD4 bytes expected
[ 5.510000] [piglet]use default-settings (1 gpio from hw_config)
[ 5.610000] patch_dectfw: C04D7000, totallen = 44879(AF4F)
[ 5.610000] patch_dectfw: patch_adress: A0 max_len: 26 with Version 2 Len: 17
[ 5.610000] patch_dectfw: dectmode 1
[ 5.610000] dect_loader: slow-bootmode
<FE>*
[ 8.910000] dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_441.hex' successfull
[ 10.920000] [piglet]TDM: FS: 8005 Hz CLK: 1023980 Hz
cat /etc/default.049/telefon_misc.default > /var/flash/telefon_misc
cat /etc/default.049/fx_lcr.default > /var/flash/fx_lcr
cat /etc/default.049/fx_conf.default > /var/flash/fx_conf
[jffs2] Mount /data success (mtd5 size 1048576)
[jffs2] write env variable jffs2_size to 16
[ 11.410000] [module-alloc-by-name] give 0x5D000 bytes at 0x8109B000 to module 'pcmlink' (0x69C000 bytes left)
[ 11.410000] [module-alloc-by-name] 0x5D000 bytes used, 0x65EFC bytes expected
[pcmlink]svn: 2047
[ 11.530000] [pcmlink]VPE-Interface: base 0xFC0000, maxsize 131072, host-irq 142
[ 11.910000] [0]system-load 6 loadavg 0.15 0.3 0.1 - 23 tasks:27 % curr:mtdblockd(4 %) max:init(11 %, pid:1), readytorun: 2, pgfault 3842/s (max 1 avg 1.0)
[ 11.950000] [module-alloc-by-name] give 0xB0000 bytes at 0x810F8000 to module 'isdn_fbox_fon5' (0x5EC000 bytes left)
[ 11.950000] [module-alloc-by-name] 0xB0000 bytes used, 0xC4394 bytes expected
[isdn]svn:3113
[ 12.060000] driver params overwritten io_addr=0x0 irq_num=0
[ 12.060000] [pcmlink]chrony-support
[ 12.060000] VPE loader: loading segment 1 to 80FC0000 (14000 bytes)
elf loaded
[ 12.060000] vpe_run: tc 1 start-addr 80FC0000
[ 12.060000] vpe_run: tc 1 tcstatus 18000400 tcbind 00200001
MVPCONTROL 00000002 vpeopt 00000000
PCMLINK: Version 7.505 Codecslots=6 Slics=1 Pots=1 TE=0 NT=0 DECT=4 (IA3222)no HwCross DSP-EC: 2
[ 13.500000] [module-alloc-by-name] give 0x53000 bytes at 0x811A8000 to module 'capi_codec' (0x599000 bytes left)
[ 13.500000] [module-alloc-by-name] 0x53000 bytes used, 0x5BD38 bytes expected
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
[ 13.690000] [module-alloc-by-name] give 0x36000 bytes at 0x811FB000 to module 'avm_dect' (0x563000 bytes left)
[ 13.690000] [module-alloc-by-name] 0x36000 bytes used, 0x3D9A4 bytes expected
[DECTDRV_ERR] avm_dect driver init
[DECTDRV_ERR] [avm_dect]avm_dect_thread: start
[DECTDRV_ERR] EepromInit, failed to load /var/flash/dect_eeprom!!! (use defaults)
[ 13.740000] [module-alloc-by-name] give 0x3000 bytes at 0x81231000 to module 'dect_io' (0x560000 bytes left)
[ 13.740000] [module-alloc-by-name] 0x3000 bytes used, 0x447C bytes expected
TAM: create JFFS2 directory /data/tam
TAM Defaults: /etc/default.Fritz_Box_HW188/1273/config.tam not found!
exceute files in group 1 ...
/etc/init.d/E15-device
mknod led c 242
mknod tffs c 243
mknod avm_power c 252
mknod debug c 248
mknod avm_event c 249
mknod capi_oslib c 68
mknod dect_io c 227
group 1 done ...
source files in group 2 ...
/etc/init.d/S21-udev
exceute files in group 2 ...
group 2 done ...
source files in group 3 ...
/etc/init.d/S30-ledcfg
exceute files in group 3 ...
group 3 done ...
source files in group 4 ...
/etc/init.d/S40-swap /etc/init.d/S44-hostname /etc/init.d/S48-configd
/etc/init.d/S42-ptest /etc/init.d/S46-usb
Jan 1 01:00:14 udevd[484]: specified group 'tty' unknown
Jan 1 01:00:14 udevd[484]: specified group 'dialout' unknown
Jan 1 01:00:14 udevd[484]: specified group 'kmem' unknown
Jan 1 01:00:14 udevd[484]: specified group 'video' unknown
Jan 1 01:00:14 udevd[484]: specified group 'audio' unknown
Jan 1 01:00:14 udevd[484]: specified group 'lp' unknown
Jan 1 01:00:14 udevd[484]: specified group 'disk' unknown
Jan 1 01:00:14 udevd[484]: specified group 'floppy' unknown
Jan 1 01:00:14 udevd[484]: specified group 'cdrom' unknown
Jan 1 01:00:14 udevd[484]: specified group 'tape' unknown
[ 14.320000] [module-alloc-by-name] give 0x1000 bytes at 0x81234000 to module 'lzo_compress' (0x55F000 bytes left)
[ 14.320000] [module-alloc-by-name] 0x1000 bytes used, 0x1878 bytes expected
[ 14.320000] [module-alloc-by-name] give 0x1000 bytes at 0x81235000 to module 'lzo_decompress' (0x55E000 bytes left)
[ 14.320000] [module-alloc-by-name] 0x1000 bytes used, 0x1938 bytes expected
[ 14.370000] [module-alloc-by-name] give 0x4000 bytes at 0x81236000 to module 'ramzswap' (0x55A000 bytes left)
[ 14.370000] [module-alloc-by-name] 0x4000 bytes used, 0x58E0 bytes expected
[ 14.410000] ramzswap: /dev/ramzswap0 initialized: disksize_kb=8192
[ 14.520000] Adding 8184k swap on /dev/ramzswap0. Priority:-1 extents:1 across:8184k SS
[ 14.660000] ramzswap: Invalid ioctl 21297
[ 14.950000] [module-alloc-by-name] give 0x1D000 bytes at 0x8123A000 to module 'usbcore' (0x53D000 bytes left)
[ 14.950000] [module-alloc-by-name] 0x1D000 bytes used, 0x243E4 bytes expected
[ 15.110000] usbcore: registered new interface driver usbfs
[ 15.110000] usbcore: registered new interface driver hub
[ 15.110000] usbcore: registered new device driver usb
[ 15.290000] [module-alloc-by-name] give 0x14000 bytes at 0x81257000 to module 'ifxusb_host' (0x529000 bytes left)
[ 15.290000] [module-alloc-by-name] 0x14000 bytes used, 0x1ACE8 bytes expected
[ 15.310000] IFXUSB: ifxusb_hcd: version 3.0alpha B100312
[ 15.350000] early VBUS switch
[ 16.920000] IFXUSB: USB core #0 soft-reset
[ 17.130000] IFXUSB: USB core #0 soft-reset
[ 17.130000] ifxusb_hcd ifxusb_hcd: IFX USB Controller
[ 17.130000] ifxusb_hcd ifxusb_hcd: new USB bus registered, assigned bus number 1
[ 17.130000] ifxusb_hcd ifxusb_hcd: irq 56, io mem 0xbe101000
[ 17.130000] IFXUSB: Init: Power Port (0)
[ 17.220000] usb usb1: configuration #1 chosen from 1 choice
grep: /var/default/1273/usbgsm.cfg: No such file or directory
grep: /var/flash/usbgsm.cfg: No such file or directory
[ 17.480000] hub 1-0:1.0: USB hub found
[ 17.480000] hub 1-0:1.0: 1 port detected
[ 17.480000] avm_net_trace: New net trace device 'usb1' registered with minor 161.
[ 18.850000] IFXUSB: USB core #1 soft-reset
[ 19.050000] IFXUSB: USB core #1 soft-reset
[ 19.050000] ifxusb_hcd ifxusb_hcd: IFX USB Controller
[ 19.050000] ifxusb_hcd ifxusb_hcd: new USB bus registered, assigned bus number 2
[ 19.050000] ifxusb_hcd ifxusb_hcd: irq 85, io mem 0xbe106000
[ 19.050000] IFXUSB: Init: Power Port (0)
[ 19.100000] usb usb2: configuration #1 chosen from 1 choice
[ 19.320000] hub 2-0:1.0: USB hub found
[ 19.320000] hub 2-0:1.0: 1 port detected
[ 19.320000] avm_net_trace: New net trace device 'usb2' registered with minor 162.
IFXUSB HOST started
[ 20.540000] ramzswap: Invalid ioctl 21297
exceute files in group 4 ...
/etc/init.d/E40-dsl /etc/init.d/E46-net /etc/init.d/E47-voip
[ 22.550000] [0]system-load 9 loadavg 0.58 0.13 0.4 - 79 tasks:19 % curr:create_handle.s(0 %) max:mtdblockd(2 %, pid:86), readytorun: 4, pgfault 4624/s (max 2 avg 1.0)
[dsl sus] dsl line test calib factory file available
[dsl get xtse] ANNEX=B
[dsl get xtse] setting Annex B and J
[dsl get xtse] 10 00 10 40 00 04 01 00
[dsl sus] starting ar9 dsp...
[dsl sus] ANNEX=B DIAGNOSE=
[ 22.880000] [module-alloc-by-name] give 0x9000 bytes at 0x8126B000 to module 'ifxmips_mei' (0x520000 bytes left)
[ 22.880000] [module-alloc-by-name] 0x9000 bytes used, 0xBC1C bytes expected
[dsl mei] Lantiq MEI driver version: 5.03.00
[dsl mei] Lantiq MEI driver global debug_level: 0
[dsl sus] loaded ar9 mei driver: ifxmips_mei.ko with params:
DSP: XDU=1( D1 ) OVR=0 MIPS_OVR=0
[ 23.130000] [module-alloc-by-name] give 0x4D000 bytes at 0x81274000 to module 'drv_dsl_cpe_api' (0x4D3000 bytes left)
[ 23.130000] [module-alloc-by-name] 0x4D000 bytes used, 0x56858 bytes expected
[dsl drv] Lantiq CPE API Driver version: DSL CPE API V4.9.2.1
[dsl drv] Predefined debug level: 4
[dsl drv] dynamically registered major number 239 for drv_dsl_cpe_api
[dsl sus] loaded ar9 dsl driver: drv_dsl_cpe_api.ko with params:
[dsl sus] created ar9 dsl device node /dev/dsl_ar9 (major: 239 , minor: 0)
[dsl sus] created ar9 mei device node /dev/ifx_mei (major: 105 , minor: 0)
[dsl sus] started dsl_control (configuration: -i10_00_10_40_00_04_01_00 -f/lib/modules/dsp_ar9/ar9-B-dsl.bin -n/etc/dsl/notify/dsl_notify.sh )
nohup: appending output to nohup.out
[dsl sus] started dsl_monitor
[dsl sus] ....ar9 dsp started
[ 25.290000] [module-alloc-by-name] give 0x13C000 bytes at 0x812C1000 to module 'kdsldmod' (0x397000 bytes left)
[ 25.290000] [module-alloc-by-name] 0x13C000 bytes used, 0x16D3A0 bytes expected
[ 25.430000] kdsldmod: init start (Feb 2 2015 12:07:03) sizeof(struct sk_buff)=440
[ 25.440000] userman: device registerd (userman_url) with major=233
<6>kdsld: ttychannel: ldisc 8 registered
[ 25.440000] PCP_NL: PCP netlink interface
[ 25.440000] kdsldmod: init done
Jan 1 01:00:26 l2tpv3d[1059]: starting.
Jan 1 01:00:26 l2tpv3d[1059]: verbose: DISABLED
grep: /var/flash/wlan.cfg: No such file or directory
Jan 1 01:00:27 multid[1068]: not running
[DECTDRV_ERR] [avm_dect]avm_dect_thread: exit
[ 27.910000] [avm_power] PowerManagmentRelease(0x831D4680)
[ 28.020000] /proc/tffs: werkseinstellungen request: success
[ 50.750000]
[ 50.750000] ---- start avmdebug(suppress 0 bytes) ----
[ 50.750000] [ 33.240000] [0]system-load 100 % loadavg 1.28 0.29 0.9 - 89 tasks:12 % curr:swapper(0 %) max:mtdblockd(4 %, pid:86), readytorun: 10, pgfault 3637/s (max 2 avg 1.0)
[ 50.750000] [ 43.240000] [0]system-load 100 % loadavg 2.93 0.68 0.22 - 89 tasks:0 % curr:swapper(0 %) max:swapper(0 %, pid:0), readytorun: 11, pgfault 0/s (max 0 avg 0.0)
[ 50.750000]
[ 50.750000] ---- eof avmdebug ----
[ 50.750000]
[ 50.750000] HardwareWatchDog - NMI taken!!!!
[ 50.750000] Cpu 0
[ 50.750000] $ 0 : 00000000 00000000 00000100 0000004c
[ 50.750000] $ 4 : 00000037 00001054 00000200 00000001
[ 50.750000] $ 8 : 00000200 bf3fb5d4 ffffffff 00000000
[ 50.750000] $12 : 00000001 00000000 00000000 00000000
[ 50.750000] $16 : 00000000 812717f0 00000000 00000000
[ 50.750000] $20 : 00000037 80500000 00000001 80400000
[ 50.750000] $24 : 00000000 00000000
[ 50.750000] $28 : 803f0000 803f3d48 803a051c 80075c58
[ 50.750000] Hi : 0eecfe65
[ 50.750000] Lo : 00000001
[ 50.750000] Status: 1148fc05 KERNEL ERL IE
[ 50.750000] Cause : 00800000 exc_code:0
[ 50.750000] epc : 80075c70 0x80075c70
[ 50.750000] errepc: 80075c74 0x80075c74
[ 50.750000] Tainted: P
[ 50.750000] ra : 80075c58 0x80075c58
[ 50.750000] PrId : 0001954c (MIPS 34Kc)
[ 50.750000] Modules linked in: kdsldmod(P) drv_dsl_cpe_api ifxmips_mei ifxusb_host usbcore ramzswap lzo_decompress lzo_compress capi_codec(P) isdn_fbox_fon5(P) pcmlink(P) Piglet_noemif(P) rtc_avm led_modul_Fritz_Box_HW188(P) [last unloaded: avm_dect before 22.840 s]
[ 50.750000] Process swapper (pid: 0, threadinfo=803f0000, task=803f4600, tls=00000000)
[ 50.750000] Stack : 0000001b 80060728 00000037 803fc394 00000000 80076438 00000000 803f3dc8
[ 50.750000] 0000001b 80060728 803fe818 81272d2c 812717f0 8126d498 00000000 00000001
[ 50.750000] 00000000 0000001b 00000037 8324d780 00000037 8007583c 804fb7c0 00000001
[ 50.750000] 810456bc 0000298d 803fc394 00000037 803fc394 80556eb0 804fb7c0 00000001
[ 50.750000] 810456bc 0000298d 810d0000 80077a78 803fc394 80046c84 810ab280 00000001
[ 50.750000] ...
[ 50.750000] Call Trace:
[ 50.750000] [<80060728>] 0x80060728
[ 50.750000] [<80076438>] 0x80076438
[ 50.750000] [<8126d498>] 0x8126d498 (ifxmips_mei + 0x2498) [ifxmips_mei]
[ 50.750000] [<8007583c>] 0x8007583c
[ 50.750000] [<80077a78>] 0x80077a78
[ 50.750000] [<80046c84>] 0x80046c84
[ 50.750000] [<810ab280>] 0x810ab280 (pcmlink + 0x10280) [pcmlink]
[ 50.750000] [<8000f95c>] 0x8000f95c
[ 50.750000] [<8000f2cc>] 0x8000f2cc
[ 50.750000] [<80002e30>] 0x80002e30
[ 50.750000] [<80003040>] 0x80003040
[ 50.750000] [<8001a858>] 0x8001a858
[ 50.750000] [<800a2230>] 0x800a2230
[ 50.750000] [<8001b18c>] 0x8001b18c
[ 50.750000] [<80003060>] 0x80003060
[ 50.750000] [<800064b8>] 0x800064b8
[ 50.750000] [<804ce8f4>] 0x804ce8f4
[ 50.750000] [<804ce218>] 0x804ce218
[ 50.750000] [<800063b0>] 0x800063b0
[ 50.750000]
[ 50.750000] Code: 30420100 10400004 00000000 <0000000f> 0801d719 8e020020 41626000 30420001 000000c0
[ 50.750000] <current pid 0 name swapper>
[ 50.750000] [<8001fda8>] 0x8001fda8
[ 50.750000] [<800403d8>] 0x800403d8
[ 50.750000] [<80041998>] 0x80041998
[ 50.750000] [<80022288>] 0x80022288
[ 50.750000] [<802172a4>] 0x802172a4
[ 50.750000] [<80003558>] 0x80003558
[ 50.750000] [<8111ad00>] 0x8111ad00 (isdn_fbox_fon5 + 0x22d00) [isdn_fbox_fon5]
[ 50.750000] [<80075c58>] 0x80075c58
[ 50.750000] [<8007639c>] 0x8007639c
[ 50.750000] [<80075c70>] 0x80075c70
[ 50.750000] Kernel panic - not syncing: HardwareWatchDog
[ 50.750000] WARNING: failed to open tffs in panic mode (minor 96)
[ 50.750000] Rebooting in 5 seconds..
ROM VER: 1.1.3
