/var/mod/root # dmesg
Linux version 2.6.19.2 (1655) (gcc-Version 3.4.6) #1 Tue Jun 17 11:34:41 CEST 2008
CPU revision is: 00019068
[ur8_pci_init]
[setup_pci_master]
[setup_pci_slave]
Exposing 67108864 memory over PCI
Setup Complete, Enabling PCI Interface
PCI Interface Running
PCI controller initialized
[ur8_vbus_set_prio] instance vbus_nwss_dma level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_sar_pdsp level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_buffer_manager level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_usb level 5 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_vlynq level 7 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_pci level 5 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_c55 level 3 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_tdm level 0 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_mips level 3 escalator disabled (count 255, floor 7)
Determined physical RAM map:
memory: 00313000 @ 14000000 (reserved)
memory: 03ced000 @ 14313000 (usable)
[init_bootmem]
[free_bootmem]
[reserve_bootmem]
On node 0 totalpages: 98304
DMA zone: 768 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 97536 pages, LIFO batch:31
Normal zone: 0 pages used for memmap
Built 1 zonelists. Total pages: 97536
Kernel command line: init=/etc/init.d/rc.usbroot usbroot=/dev/sda1:/usbroot console=ttyS0,38400n8r
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
CPU frequency 360.00 MHz
Using 180.000 MHz high precision timer.
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[free_all_bootmem]
Memory: 58880k/62388k available (2022k kernel code, 3476k reserved, 637k data, 136k init, 0k highmem)
Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
[ur8_mtd_init]
[ur8_mtd_init] flashsize = 0x00800000 Byte 8 MBytes
[ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
[ur8_mtd_init] mtd[1] = 0x90010000,0x90780000
[ur8_mtd_init] mtd[2] = 0x90000000,0x90010000
[ur8_mtd_init] mtd[3] = 0x90780000,0x907C0000
[ur8_mtd_init] mtd[4] = 0x907C0000,0x90800000
[ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
Master and Slave Enabled
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
squashfs: version 3.2 (2007/01/02) Phillip Lougher
Installing knfsd (copyright (C) 1996 [email protected]).
io scheduler noop registered (default)
avm_net_trace: Up and running.
[avm] configured: watchdog event debug led enable direct gpio
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jun 17 2008 11:34:05)
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 15) is a UR8_UART
[cpphy_ar8216] <no switch found>
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
physmap platform flash device: 00800001 at 10000000
physmap-flash.1: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.1: Swapping erase regions for broken CFI table.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
RedBoot partition parsing not available
[ur8_jffs2_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x9478253c
[ur8_jffs2_parser_function] try partition kernel (offset 0x10000 len 7798784)
[ur8_squashfs_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x9478253c
[ur8_squashfs_parser_function] *p_mtd_pat->name filesystem
[ur8_squashfs_parser_function] try partition kernel (offset 0x10000 len 7798784 blocksize=10000)
[ur8_squashfs_parser_function] magic found @pos 0xecf00
[ur8_squashfs_parser_function]: not enough space for JFFS2!
Using physmap partition information
Creating 6 MTD partitions on "physmap-flash.1":
0x000ecf00-0x00780000 : "rootfs"
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
[ur8_mtd_add_notifier]
[ur8_mtd_add_notifier] use rootfs
[ur8_mtd_add_notifier] root device: /dev/mtdblock0 (rootfs)
0x00010000-0x000ecf00 : "kernel"
mtd: partition "kernel" doesn't end on an erase block -- force read-only
[ur8_mtd_add_notifier] skip kernel
0x00000000-0x00010000 : "urlader"
[ur8_mtd_add_notifier] skip urlader
0x00780000-0x007c0000 : "tffs (1)"
[ur8_mtd_add_notifier] skip tffs (1)
0x007c0000-0x00800000 : "tffs (2)"
[ur8_mtd_add_notifier] skip tffs (2)
0x00000000-0x00800000 : "reserved"
[ur8_mtd_add_notifier] skip reserved
Generic platform RAM MTD, (c) 2004 Simtec Electronics
mtd-ram mtd-ram.2: no memory resource specified
[ur8_ram_mtd_set_rw] PLATRAM_RO
mtd-ram: probe of mtd-ram.2 failed with error -2
CAPI Subsystem Rev 1.1.2.8
TCP cubic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
MUSB UR8 pdev active!
PCI_STATUS_SET: 40000
PCI_STATUS_CLR: 40000
PCI_HOST_INT_EN: 0
PCI_HOST_INT_CLR: 0
PCI_BE_INT_En: 0
PCI_BE_INT_CLR: 0
[pci_int_init] done
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
[avm_new] push_button_gpio=25 value=0 enabled
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 136k freed
[avm_led_gpio_bit_driver_init] gpio 1 pos 0 name power
[avm_led_gpio_bit_driver_init] gpio 9 pos 1 name internet
[avm_led_gpio_bit_driver_init] gpio 27 pos 2 name festnetz
[avm_led_gpio_bit_driver_init] gpio 28 pos 3 name wlan
[avm_led_gpio_bit_driver_init] gpio 17 pos 4 name info
[avm_led_gpio_bit_driver_init] gpio 35 pos 5 name rot1
[avm_led_gpio_bit_driver_init] gpio 36 pos 6 name rot2
[avm_led_gpio_bit_driver_init] gpio 32 pos 7 name rot3
[avm_led_gpio_bit_driver_init] gpio 22 pos 8 name rot4
[avm_led_gpio_bit_driver_init] gpio 21 pos 9 name rot5
Failed to execute /etc/init.d/rc.usbroot. Attempting defaults...
AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
TFFS Name Table B
Piglet_noemif: module license '
(C) Copyright 2007 by AVM
' taintskernel.
patch_dectfw: patch_adress: 4d58 max_len: 19 with Version 2 Len: 16
patch_dectfw: c0047000, datalen = 22415,
dect_file_process: upload of '/lib/modules/dectfw_secondlevel.hex' successfull
[avm_new]push_button_ctrl: gpio=23 value=1 enabled
[avm_new]push_button_ctrl:'Taster_4': enable=2 gpio=23 regaddr=00000000 button_type=0
[piglet]bitfile '/lib/modules/microvoip_isdn_top.bit'
[avm_new]push_button 'Taster_4', released: GPIO=23 presses=0 key=button_key_10
[piglet] Read 169291 bytes total from file
[piglet]TDM: FS: 7990 Hz CLK:2047805 Hz
[avm_debug]redirect kernel-messages (/dev/debug)
