FritzBox 7590 in bootloop
DramaQueen
5 Jul 2022
Hi to all,
I purchased recently a Fritzbox 7590 which apparently is in bootloop: the POWER / DSL light comes on, in flashed some seconds, then becomes steady, then suddenly everything goes out, all the lights flash briefly, and it starts all over again.
The seller refunded me and told me to throw it away, but I'm not so pleased with that solution. Connected to the PC it is not detected, so I was unable to deal with the recovery image; I also tried with the phone number method with no luck.
I am completely new to this world, but after some online search I managed to open the serial console, these are the results:
ROM VER: 2.1.0
CFG 09
B
Detected PXB4583el V1.2-2000
.[piglet] Suceeded
(AVM) EVA Revision: 1.3258
(C) Copyright 2005 AVM Date: Mar 10 2017 Time: 12:11:34 (1) 3 0x0-0x46409
[NAND:] 512MB TOSHIBA 4096 Pagesize 256k Blocksize 2048 Blocks
[SYSTEM:] GRX5 (ID 0x24 Revision 2) on 1000MHz/600MHz/666MHz
#Loading compressed kernel to 0x852852B0
............................................................................................................................Device Tree Blob for SubRevision 4 not found.
Using Device Tree Blob of SubRevision 0
      Switching to Bootcore Console
[    0.000000] Linux version 4.9.198 (jenkins@wxtagsxVersionx72206xPSQ19xgrxB5) (gcc version 8.3.0 (Buildroot 2018.11.4-gb80f08fe4) ) #1 Tue Jun 16 21:08:00 CEST 2020
[    0.000000] avm_check_isa_features: isa_level 0x00000031
[    0.000000] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000000c00059638b ases 0x00000001
[    0.000000] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[    0.000000] SoC: GRX500 rev 1.2
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019074 (MIPS 4KEc)
[    0.000000] MIPS: machine is GRX550 ANYWAN BOOTCORE (MIPS 4Kec)
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 02000000 @ 0e000000 (usable)
[    0.000000]  memory: 00001ab8 @ 0e781030 (reserved)
[    0.000000]  memory: 00040000 @ 0dfc0000 (reserved)
[    0.000000] Initial ramdisk at: 0x8e000000 (4194304 bytes)
[    0.000000] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000000c0005d638b icache.flags 0x00000000 dcache.flags 0x00000004
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 16 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 16 bytes
[    0.000000] avm_check_scache_features: mips-options: 0x000000c0005d638b
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x000000000e000000-0x000000000fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x000000000e000000-0x000000000fffffff]
[    0.000000] Initmem setup node 0 [mem 0x000000000e000000-0x000000000fffffff]
[    0.000000] On node 0 totalpages: 8192
[    0.000000] free_area_init_node: node 0, pgdat 8e780620, node_mem_map 8f005620
[    0.000000]   Normal zone: 64 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 8192 pages, LIFO batch:0
[    0.000000] [fw-info] Version 07.20
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line: console=ttyLTQ0,115200n8r root=/dev/ram rw loglevel=8
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Memory: 24076K/32768K available (2649K kernel code, 395K rwdata, 736K rodata, 180K init, 258K bss, 8692K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:527
[    0.000000] grx500_bootcore_register_static_irq: irq_in = 0x0000001f, irq_out = 0x0000001f
[    0.000000] grx500_bootcore_register_static_irq: mapper_reg = 0x0000015c, mapper_offset = 0x00000000
[    0.000000] EXCEP_remap_line: int_line = 0x0000001f, map_address = 0x0000015c, num = 0x00000000
[    0.000000] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x0000001f
[    0.000000] CPU Clock: 300MHz
[    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns
[    0.000022] sched_clock: 32 bits at 150MHz, resolution 6ns, wraps every 14316557820ns
[    0.015344] : grx500_bootcore_console_init: call register
[    0.025725] console [ttyLTQ0] enabled
[    0.036200] bootconsole [early0] disabled
[    0.047719] bootconsole [early0] disabled
[    0.055698] Calibrating delay loop... 299.26 BogoMIPS (lpj=598528)
[    0.094120] pid_max: default: 32768 minimum: 301
[    0.099198] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.105641] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.121470] devtmpfs: initialized
[    0.129266] ngi: Protecting Bootcore: [0x2e000000, 0x2fffffff]
[    0.134939] ngi: 512MB attached. Protecting: [0x40000000, 0x9fffffff]
[    0.141290] ngi: Unattached: [0x60000000, 0x9fffffff]
[    0.146296] ngi: Unattached: [0x40000000, 0x5fffffff]
[    0.151903] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.161524] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.167790] pinctrl core: initialized pinctrl subsystem
[    0.174357] NET: Registered protocol family 16
[    0.192672] irq: no irq domain found for /interrupt-controller@0x14900140 !
[    0.282929] clocksource: Switched to clocksource MIPS
[    0.310201] NET: Registered protocol family 2
[    0.316633] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.323627] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.329865] TCP: Hash tables configured (established 1024 bind 1024)
[    0.336718] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.342534] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.349207] NET: Registered protocol family 1
[    0.357473] Unpacking initramfs...
[    1.106939] random: fast init done
[    1.257489] Freeing initrd memory: 4096K
[    1.268365] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[    1.332368] Serial: grx500_bootcore driver init
[    1.340366] libphy: Fixed MDIO Bus: probed
[    1.347888] NET: Registered protocol family 10
[    1.362130] NET: Registered protocol family 17
[    1.373667] Serial: grx500_bootcore driver startup
[    1.378419] grx500_bootcore_register_static_irq: irq_in = 0x0000001c, irq_out = 0x00000008
[    1.386494] grx500_bootcore_register_static_irq: mapper_reg = 0x00000158, mapper_offset = 0x00000003
[    1.395585] EXCEP_remap_line: int_line = 0x00000008, map_address = 0x00000158, num = 0x00000003
[    1.404292] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00040000
[    1.416034] Freeing unused kernel memory: 180K
[    1.420389] This architecture does not have kernel memory protection.
[    1.597827] eip123_hw: module license 'Proprietary' taints kernel.
[    1.604016] Disabling lock debugging due to kernel taint
[    1.616091] eip123 1e000000.eip123: Detected hardware version 2.2.2
[    1.622337] eip123 1e000000.eip123: my_id=0 master_id=0 num_mailboxes=4 mailbox_size=256
[    1.630231] eip123 1e000000.eip123: Configured mailbox lockout: 0x00000000
[    1.637046] eip123 1e000000.eip123: Linked mailbox number 1
[    1.666989] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=0 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0
[    1.902931] eip123 1e000000.eip123: eip123_hw init successful
[    1.935717] random: crng init done
[    1.962963] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c
[    1.971349] eip123 1e000000.eip123: Could not find rootkey in OTP
[    1.978027] eip123 1e000000.eip123: Unlinked mailboxes
[    2.027932] cpunet 1f107400.cpunet: slots=16 mtu=8192 mailbox_size=0x4c mempool_size=0x20000
[    2.036413] cpunet 1f107400.cpunet: Initialized mailbox: rx=0xbf201100 tx=0xbf201000
[    2.044509] cpunet 1f107400.cpunet: Initialized mempool: rx=0x8dfe0000 tx=0x8dfc0000 min_align=64
[    2.053202] grx500_bootcore_register_static_irq: irq_in = 0x00000016, irq_out = 0x0000000b
[    2.061373] grx500_bootcore_register_static_irq: mapper_reg = 0x00000154, mapper_offset = 0x00000003
[    2.070447] EXCEP_remap_line: int_line = 0x0000000b, map_address = 0x00000154, num = 0x00000003
[    2.079181] EXCEP_remap_line: org_map = 0x00000000, result_map = 0x00058000
[    2.086297] cpunet 1f107400.cpunet: hw init successful
jC��������������������������������������������H�H�H��ݥэ�����to Interaptiv Console
Using Device Tree Blob of SubRevision 1
[    0.000000] Linux version 4.9.198 (jenkins@haredxbuildxjplxpsq19p1xgrx5xnws) (gcc version 8.3.0 (Buildroot 2018.11.4-gd0078a7b1) ) #1 SMP Mon Jun 22 16:45:20 CEST 2020
[    0.000000] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e69638b ases 0x00000030
[    0.000000] CPU0 revision is: 0001a120 (MIPS interAptiv (multi))
[    0.000000] Enhanced Virtual Addressing (EVA Legacy 512MB) activated
[    0.000000] MIPS: machine is AVM7590 (GRX550, HW226) Main model
[    0.000000] Coherence Manager IOCU detected
[    0.000000] Hardware DMA cache coherency disabled
[    0.000000] OF: fdt:Reserved memory (avm): reserved region for property 'urlader': base 0x20010000, size 0x00030000
[    0.000000] OF: fdt:Reserved memory (avm): reserved region for property 'VMB': base 0x20000000, size 0x00001000
[    0.000000] OF: fdt:Reserved memory (avm): reserved region for property 'avm_reboot_string': base 0x20001000, size 0x00000200
[    0.000000]  memory: 10000000 @ 30000000 (usable)
[    0.000000]  memory: 0e000000 @ 20000000 (usable)
[    0.000000]  memory: 0000bd17 @ 21038038 (reserved)
[    0.000000]  memory: 00040000 @ 2dfc0000 (reserved)
[    0.000000]  memory: 00400000 @ 20100000 (reserved)
[    0.000000]  memory: 00030000 @ 20010000 (reserved)
[    0.000000]  memory: 00001200 @ 20000000 (reserved)
[    0.000000] cma: Reserved 64 MiB at 0x24000000
[    0.000000] SMPCMP: CPU0: cmp_smp_setup
[    0.000000] VPE topology {2,2} total 4
[    0.000000] Detected 3 available secondary CPU(s)
[    0.000000] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.000000] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[    0.000000] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[    0.000000]   DMA      [mem 0x0000000020000000-0x0000000027ffffff]
[    0.000000]   Normal   [mem 0x0000000028000000-0x000000003fffffff]
[    0.000000]   node   0: [mem 0x0000000020000000-0x000000002dffffff]
[    0.000000]   node   0: [mem 0x0000000030000000-0x000000003fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000020000000-0x000000003fffffff]
[    0.000000] [module-mem] Use 0x284a6000-0x28e34fff (mapped at 884a6000-88e34fff) for 80 modules
[    0.000000] percpu: Embedded 12 pages/cpu s18096 r8192 d22864 u49152
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 121728
[    0.000000] Kernel command line: console=ttyLTQ0,115200 audit=1
[    0.000000] audit: enabled (after initialization)
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 388116K/491520K available (7744K kernel code, 2042K rwdata, 1700K rodata, 344K init, 6113K bss, 37868K reserved, 65536K cma-reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] EIC is off
[    0.000000] VINT is on
[    0.000000] CPU Clock: 1000000000Hz  mips_hpt_frequency 500000000Hz
[    0.000000] clocksource: gptc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302233 ns
[    0.000010] sched_clock: 32 bits at 200MHz, resolution 5ns, wraps every 10737418237ns
[    0.008423] Calibrating delay loop... 718.84 BogoMIPS (lpj=1437696)
[    0.040922] pid_max: default: 32768 minimum: 301
[    0.045748] Security Framework initialized
[    0.049819] AppArmor: AppArmor initialized
[    0.054008] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060643] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.069226] CCA is coherent, multi-core is fine
[    0.073672] avm_register_cpuid: cpu_id=0: LINUX core=0 tc=0
[    0.079350] Performance counters: mips/interAptiv PMU enabled, 2 32-bit counters available to each CPU, irq 9
GOT IPI to launch from CPU 1
GOT IPI to launch from CPU 2
GOT IPI to launch from CPU 3
[    0.092690] avm_check_isa_features: isa_level 0x00000031
[    0.092730] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030
[    0.092734] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[    0.092755] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[    0.092762] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.092768] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.092780] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[    0.092784] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[    0.093077] CPU1 revision is: 0001a120 (MIPS interAptiv (multi))
[    0.120675] avm_register_cpuid: cpu_id=1: LINUX core=0 tc=1
[    0.122947] avm_check_isa_features: isa_level 0x00000031
[    0.122986] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030
[    0.122990] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[    0.123009] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[    0.123016] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.123022] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.123033] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[    0.123037] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[    0.123186] CPU2 revision is: 0001a120 (MIPS interAptiv (multi))
[    0.150954] avm_register_cpuid: cpu_id=2: LINUX core=1 tc=0
[    0.153233] avm_check_isa_features: isa_level 0x00000031
[    0.153272] avm_check_cpu_features: mips-options (cache flags preliminary!): 0x000088c40e6d638b ases 0x00000030
[    0.153275] avm_check_cpu_features: (preliminary flags: MIPS_CPU_CACHE_CDEX_P MIPS_CPU_PREFETCH MIPS_CPU_INCLUSIVE_CACHES MIPS_CPU_CACHE_CDEX_S)
[    0.153295] avm_check_pcache_features: mips-options (preliminary MIPS_CPU_CACHE_CDEX_S flag): 0x000088c40e6d638b icache.flags 0x00000000 dcache.flags 0x00000020
[    0.153302] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.153308] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[    0.153319] MIPS secondary cache 256kB, 8-way, linesize 32 bytes.
[    0.153323] avm_check_scache_features: mips-options: 0x000088c40e6d638b
[    0.153450] CPU3 revision is: 0001a120 (MIPS interAptiv (multi))
[    0.181256] avm_register_cpuid: cpu_id=3: LINUX core=1 tc=1
[    0.181555] Brought up 4 CPUs
[    0.430211] avm_yield_setup: YIELD_PCMFRAME_ID       : id=0x0004000f: cpu=0 tc=4 prio=3 signal=15
[    0.439144] avm_yield_setup: YIELD_PCMLINK_ID        : id=0x0003000c: cpu=0 tc=3 prio=2 signal=12
[    0.448086] avm_yield_setup: YIELD_MONITOR_IPI0_ID   : id=0x0002000e: cpu=0 tc=2 prio=1 signal=14
[    0.449563] random: fast init done
Following in next post
I think it could be similar to this but I can't see burns or any kind of damage on the board, but I will check again if necessary.
Thanks in advance
[    0.460498] avm_yield_setup: YIELD_PROFILE_IPI0_ID   : id=0x0002000d: cpu=0 tc=2 prio=1 signal=13
[    0.469887] [0][yield_context_init] cpu=0 tc=2 mask=6000 tc_prio=1
[    0.476353] [0][yield_context_init] cpu=0 tc=3 mask=1000 tc_prio=2
[    0.482809] [0][yield_context_init] cpu=0 tc=4 mask=8000 tc_prio=3
[    0.489043] avm_yield_setup: YIELD_MONITOR_IPI1_ID   : id=0x0202000e: cpu=2 tc=2 prio=1 signal=14
[    0.497809] avm_yield_setup: YIELD_PROFILE_IPI1_ID   : id=0x0202000d: cpu=2 tc=2 prio=1 signal=13
[    0.506743] avm_yield_setup: YIELD_GPTC_ID           : id=0x02030002: cpu=2 tc=3 prio=3 signal= 2
[    0.516005] [2][yield_context_init] cpu=2 tc=2 mask=6000 tc_prio=1
[    0.522414] [2][yield_context_init] cpu=2 tc=3 mask=0004 tc_prio=3
[    0.529438] devtmpfs: initialized
[    0.542971] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.552971] futex hash table entries: 1024 (order: 3, 32768 bytes)
[    0.564124] pinctrl core: initialized pinctrl subsystem
[    0.570596] NET: Registered protocol family 16
[    0.578481] dma-grx500 1e300000.dma: dma3 base address be300000 chained_irq 24 irq_base 25
[    0.589415] dma-grx500 1e300000.dma: Init done - rev: a, ports: 1, channels: 64
[    0.599417] dma-grx500 1c100000.dma: dma2tx base address bc100000 chained_irq 100 irq_base 101
[    0.609518] dma-grx500 1c100000.dma: Init done - rev: a, ports: 1, channels: 16
[    0.617252] dma-grx500 1c200000.dma: dma2rx base address bc200000 chained_irq 117 irq_base 118
[    0.627730] dma-grx500 1c200000.dma: Init done - rev: a, ports: 1, channels: 32
[    0.636004] dma-grx500 1a100000.dma: dma1tx base address ba100000 chained_irq 150 irq_base 151
[    0.646056] dma-grx500 1a100000.dma: Init done - rev: a, ports: 1, channels: 16
[    0.653753] dma-grx500 1a200000.dma: dma1rx base address ba200000 chained_irq 167 irq_base 168
[    0.663721] dma-grx500 1a200000.dma: Init done - rev: a, ports: 1, channels: 12
[    0.677326] dma0-grx500 16e00000.dma: base address b6e00000 chained_irq 215 irq_base 216
[    0.685349] dma0-grx500 16e00000.dma: Init done - hw rev: A, ports: 4, channels: 16
[    0.693313] intel-pinctrl 16c80000.pinctrl: pinbank id: 0, reg: 0xb6c80000, pinbase: 0, pin number: 32, pinmap: 0xf1efefff
[    0.704268] intel-pinctrl 16c80000.pinctrl: pinbank id: 1, reg: 0xb6c80100, pinbase: 32, pin number: 32, pinmap: 0x3bff0c1f
[    0.715639] intel-pinctrl 16c80000.pinctrl: Total 10 groups, 8 functions
[    0.723063] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00000
[    0.730244] intel-pinctrl 16c80000.pinctrl: gpiochip membase: 0xb6c00100
[    0.746647] gic_timer_probe
[    0.749458] gic_timer_probe: irq=284 freq=1000000000
[    0.792102] avm_alloc_page_extension node_extension_table[0] entries=131072 (size=524288)  alloced
[    0.801082] Reboot Status is: Soft-Reboot(PANIC) Irregular Reboots: SUM(15) - PANIC(15)
[    0.809412] cqm_platdev_init is called
[    0.812977] dev falcon-cqm
[    0.815780] [parse_dts] .. [30]
[    0.819060] Unable to get node cqm for falcon-cqm
[    0.823759] add_cqm_dev(#116): parse_dts fail for falcon-cqm
[    0.829491] dev grx500-cbm
[    0.832262] [parse_dts] .. [30]
[    0.835558] num_res 12
[    0.837928] intr 89
[    0.840091] intr 90
[    0.842240] intr 91
[    0.844437] intr 92
[    0.846580] intr 93
[    0.848764] intr 0
[    0.850826] No rcu reset for cbm
[    0.854179] No syscon phandle specified for wan mux
[    0.859086] parse dts done
[    0.861880] adding resources
[    0.864804] resources added
[    0.867911]  Successfully Registered Platform device grx500-cbm.
[    0.873783] device added
[    0.946034] [cbm] { cbm_xrx500_probe : 5555 }reserving 18874368 bytes @ 84000000 for CBM
[    0.985228] [cbm] { cbm_xrx500_probe : 5565 }reserving 8388608 bytes @ 85200000 for CBM
[    0.993188] [cbm] { cbm_xrx500_probe : 5573 }89 irq
[    0.998218] [cbm] { cbm_xrx500_probe : 5596 }2
[    1.002651] [drv_tmu_ll] { get_cbm_clock : 7605 }CBM Clock: 600000000Hz=600MHZ
[    1.009925] Initializing TMU with Base Address=be700000: ...
[    1.018497] TMU Initialization Done
[    1.021847] 0x84000000 0x1200000 0x800
[    1.025660] 0x84000000 0x1200000
[    1.028927] 0x85200000 0x800000 0x2000
[    1.032765] 0x85200000 0x800000
[    1.036278] [cbm] { init_fsqm_buf_std : 1140 }init fsqm std successfully
[    1.042849] [cbm] { init_fsqm_buf_jumbo : 1180 }init fsqm jbo successfully
[    1.049756] [cbm] { init_fsqm : 1203 }fsqm init successfully
[    1.055490] [cbm] { init_cbm_basic : 1238 }PHY ADDR STD 0x24000000
[    1.061735] [cbm] { init_cbm_basic : 1239 }PHY ADDR JBO 0x25200000
[    1.068209] [cbm] { init_cbm_basic : 1257 }init basic CBM successfully
[    1.074585] [cbm] { cbm_hw_init : 2158 }CBM HW init
[    1.079642] [cbm] { setup_DMA_p2p : 4994 }setup_DMA_p2p executed
[    1.085612] [cbm] { reserved_ports_highest : 5053 }2 2 19 35
[    1.091342] [cbm] { init_cbm_dqm_cpu_port : 1404 }2
[    1.096307] [cbm] { assign_port_from_DT : 631 }0x0 2
[    1.101331] [cbm] { assign_port_from_DT : 631 }0x20 2
[    1.106632] [cbm] { cbm_add_to_list : 427 }1
[    1.110788] [cbm] { reserved_ports_highest : 5053 }1 1 18 34
[    1.116515] [cbm] { init_cbm_dqm_cpu_port : 1404 }1
[    1.121474] [cbm] { assign_port_from_DT : 631 }0x80 1
[    1.126580] [cbm] { reserved_ports_highest : 5053 }3 3 20 36
[    1.132313] [cbm] { init_cbm_dqm_cpu_port : 1404 }3
[    1.137264] [cbm] { assign_port_from_DT : 631 }0x2000000 3
[    1.142814] [cbm] { cbm_add_to_list : 427 }1
[    1.147151] [cbm] { reserved_ports_highest : 5053 }6 6 0 16
[    1.152801] [cbm] { dma_port_enable : 4562 }6 0x4
[    1.157578] [cbm] { reserved_ports_highest : 5053 }7 7 1 17
[    1.163215] [cbm] { dma_port_enable : 4562 }7 0x4
[    1.167992] [cbm] { reserved_ports_highest : 5053 }8 8 2 18
[    1.173636] [cbm] { dma_port_enable : 4562 }8 0x4
[    1.178421] [cbm] { reserved_ports_highest : 5053 }9 9 3 19
[    1.184047] [cbm] { dma_port_enable : 4562 }9 0x4
[    1.188825] [cbm] { reserved_ports_highest : 5053 }10 10 4 20
[    1.194636] [cbm] { dma_port_enable : 4562 }10 0x4
[    1.199502] [cbm] { reserved_ports_highest : 5053 }11 11 5 21
[    1.205315] [cbm] { dma_port_enable : 4562 }11 0x4
[    1.210178] [cbm] { reserved_ports_highest : 5053 }12 12 6 22
[    1.215989] [cbm] { dma_port_enable : 4562 }12 0x4
[    1.220856] [cbm] { reserved_ports_highest : 5053 }13 13 7 23
[    1.226668] [cbm] { dma_port_enable : 4562 }13 0x4
[    1.231532] [cbm] { reserved_ports_highest : 5053 }14 14 8 24
[    1.237342] [cbm] { dma_port_enable : 4562 }14 0x4
[    1.242209] [cbm] { reserved_ports_highest : 5053 }15 15 9 25
[    1.248026] [cbm] { dma_port_enable : 4562 }15 0x4
[    1.252899] [cbm] { reserved_ports_highest : 5053 }16 16 10 26
[    1.258785] [cbm] { dma_port_enable : 4562 }16 0x4
[    1.263650] [cbm] { reserved_ports_highest : 5053 }17 17 11 27
[    1.269541] [cbm] { dma_port_enable : 4562 }17 0x4
[    1.274415] [cbm] { reserved_ports_highest : 5053 }18 18 -16 0
[    1.280304] [cbm] { dma_port_enable : 4562 }18 0x4
[    1.285194] [cbm] { reserved_ports_highest : 5053 }19 19 12 28
[    1.291068] [cbm] { dma_port_enable : 4562 }19 0x4
[    1.295942] [cbm] { reserved_ports_highest : 5053 }20 20 13 29
[    1.301831] [cbm] { dma_port_enable : 4562 }20 0x4
[    1.306704] [cbm] { init_special_ports : 5060 }20
[    1.311467] [cbm] { cbm_add_to_list : 427 }1
[    1.315812] [cbm] { reserved_ports_highest : 5053 }21 21 14 30
[    1.321709] [cbm] { dma_port_enable : 4562 }21 0x4
[    1.326582] [cbm] { init_special_ports : 5060 }21
[    1.331344] [cbm] { cbm_add_to_list : 427 }1
[    1.335688] [cbm] { reserved_ports_highest : 5053 }22 22 25 41
[    1.341587] [cbm] { dma_port_enable : 4562 }22 0x4
[    1.346461] [cbm] { reserved_ports_highest : 5053 }23 23 15 31
[    1.352351] [cbm] { init_cbm_dqm_ldma_port : 1443 }23
[    1.357485] [cbm] { reserved_ports_highest : 5053 }5 5 21 37
[    1.363202] [cbm] { init_cbm_dqm_scpu_port : 1424 }5
[    1.368420] [cbm] { reserved_ports_highest : 5053 }4 4 16 32
[    1.373964] [cbm] { init_cbm_dqm_cpu_port : 1404 }4
[    1.378923] [cbm] { assign_port_from_DT : 631 }0x8 4
[    1.383948] [cbm] { reserved_ports_highest : 5053 }24 24 22 38
[    1.389850] [cbm] { init_cbm_dqm_cpu_port : 1404 }24
[    1.394893] [cbm] { assign_port_from_DT : 631 }0x8 24
[    1.400010] [cbm] { reserved_ports_highest : 5053 }25 25 23 39
[    1.405907] [cbm] { init_cbm_dqm_cpu_port : 1404 }25
[    1.410956] [cbm] { assign_port_from_DT : 631 }0x8 25
[    1.416066] [cbm] { reserved_ports_highest : 5053 }26 26 24 40
[    1.421969] [cbm] { init_cbm_dqm_cpu_port : 1404 }26
[    1.427009] [cbm] { assign_port_from_DT : 631 }0x8 26
[    1.432125] [cbm] { init_cbm_eqm_cpu_port : 1264 }0
[    1.437069] [cbm] { init_cbm_eqm_cpu_port : 1264 }1
[    1.442020] [cbm] { init_cbm_eqm_cpu_port : 1264 }2
[    1.446972] [cbm] { init_cbm_eqm_cpu_port : 1264 }3
[    1.451916] [cbm] { dma_port_enable : 4562 }5 0x1
[    1.456694] [cbm] { dma_port_enable : 4562 }5 0x2
[    1.461466] [cbm] { dma_port_enable : 4562 }6 0x1
[    1.466237] [cbm] { dma_port_enable : 4562 }6 0x2
[    1.471012] [cbm] { dma_port_enable : 4562 }7 0x1
[    1.475785] [cbm] { dma_port_enable : 4562 }7 0x2
[    1.480562] [cbm] { dma_port_enable : 4562 }8 0x1
[    1.485333] [cbm] { dma_port_enable : 4562 }8 0x2
[    1.490110] [cbm] { dma_toe_port_enable : 4589 }9 0x1
[    1.495230] [cbm] { dma_vrx318_port_enable : 4601 }15 0x1
[    1.500710] [cbm] { init_cbm_dqm_cpu_port : 1404 }0
[    1.505643] [cbm] { init_cbm_dqm_cpu_port : 1404 }1
[    1.510594] [cbm] { init_cbm_dqm_cpu_port : 1404 }2
[    1.515539] [cbm] { init_cbm_dqm_cpu_port : 1404 }3
[    1.520491] Load spreader init successfully
[    1.524887] [cbm] { cbm_xrx500_probe : 5652 }CBM Clock: 600000000Hz
[    1.531084] [cbm] { cbm_xrx500_probe : 5654 }EQM delay Enabled
[    1.536981] [cbm] { igp_delay_set : 4674 }port0 delay16
[    1.542277] [cbm] { igp_delay_set : 4674 }port1 delay16
[    1.547570] [cbm] { igp_delay_set : 4674 }port2 delay16
[    1.552867] [cbm] { igp_delay_set : 4674 }port3 delay16
[    1.558159] [cbm] { igp_delay_set : 4674 }port4 delay16
[    1.563457] [cbm] { igp_delay_set : 4674 }port5 delay16
[    1.568749] [cbm] { igp_delay_set : 4674 }port6 delay16
[    1.574046] [cbm] { igp_delay_set : 4674 }port7 delay16
[    1.579339] [cbm] { igp_delay_set : 4674 }port8 delay16
[    1.584637] [cbm] { igp_delay_set : 4674 }port9 delay16
[    1.589929] [cbm] { igp_delay_set : 4674 }port10 delay16
[    1.595313] [cbm] { igp_delay_set : 4674 }port11 delay16
[    1.600692] [cbm] { igp_delay_set : 4674 }port12 delay16
[    1.606076] [cbm] { igp_delay_set : 4674 }port13 delay16
[    1.611456] [cbm] { igp_delay_set : 4674 }port14 delay16
[    1.616841] [cbm] { igp_delay_set : 4674 }port15 delay16
[    1.622222] [cbm] { dequeue_dma_port_init : 4528 }6 0x0 2 1
[    1.627875] [cbm] { dequeue_dma_port_init : 4528 }7 0x0 2 2
[    1.633508] [cbm] { dequeue_dma_port_init : 4528 }8 0x0 2 3
[    1.639156] [cbm] { dequeue_dma_port_init : 4528 }9 0x0 2 4
[    1.644793] [cbm] { dequeue_dma_port_init : 4528 }10 0x0 2 5
[    1.650526] [cbm] { dequeue_dma_port_init : 4528 }11 0x0 2 6
[    1.656250] [cbm] { dequeue_dma_port_init : 4528 }12 0x0 2 9
[    1.661982] [cbm] { dequeue_dma_port_init : 4528 }13 0x0 2 10
[    1.667796] [cbm] { dequeue_dma_port_init : 4528 }14 0x0 2 11
[    1.673614] [cbm] { dequeue_dma_port_init : 4528 }15 0x0 2 12
[    1.679427] [cbm] { dequeue_dma_port_init : 4528 }16 0x0 2 13
[    1.685246] [cbm] { dequeue_dma_port_init : 4528 }17 0x0 2 14
[    1.691059] [cbm] { dequeue_dma_port_init : 4528 }18 0x0 1 13
[    1.696879] [cbm] { dequeue_dma_port_init : 4528 }19 0x0 1 15
[    1.702690] [cbm] { dequeue_dma_port_init : 4528 }20 0x0 1 5
[    1.708421] [cbm] { dequeue_dma_port_init : 4528 }21 0x0 1 6
[    1.714147] [cbm] { dequeue_dma_port_init : 4528 }22 0x0 1 11
[    1.719977] [cbm] { enqueue_dma_port_init : 4473 }5 0x2 2 0 30
[    1.725874] [cbm] { enqueue_dma_port_init : 4473 }5 0x1 2 14 0
[    1.731772] [cbm] { enqueue_dma_port_init : 4473 }6 0x2 2 0 31
[    1.737673] [cbm] { enqueue_dma_port_init : 4473 }6 0x1 2 15 0
[    1.743577] [cbm] { enqueue_dma_port_init : 4473 }7 0x2 1 0 6
[    1.749392] [cbm] { enqueue_dma_port_init : 4473 }7 0x1 1 0 0
[    1.755208] [cbm] { enqueue_dma_port_init : 4473 }8 0x2 1 0 11
[    1.761109] [cbm] { enqueue_dma_port_init : 4473 }8 0x1 1 5 0
[ 1.766959] [cbm] { cbm_xrx500_probe : 5713 }CBM: Init Done !! [ 1.773771] pstore: using zlib compression
[    1.777869] pstore: Registered ramoops as persistent store backend
[    1.784064] ramoops: attached 0x400000@0x20100000, ecc: 0/0
[    1.820676] SCSI subsystem initialized
[    1.824969] usbcore: registered new interface driver usbfs
[    1.830547] usbcore: registered new interface driver hub
[    1.835862] usbcore: registered new device driver usb
[    1.841635] mp8864 0-0068: MP8864 probe started.
[    1.851223] mp8864 0-0068: [MP8864 Init] Status is 0x11 Vsel is 0x37 Syscntl is 0xe5
[    1.858863] i2c-gpio i2c: using pins 501 (SDA) and 502 (SCL)
[    1.864774] try to register spd_mon driver[    1.868745] spdmon 16080110.speedm: base address: 0xb6080110
[    1.874368] spdmon 16080110.speedm: PHY base address: 0x16080110
[    1.880410] device number :253
[    1.884203] spdmon 16080110.speedm: spd_mon driver : init done !!
[    1.894807] spd_mon driver registered
[    1.899266] AVM PA for Linux version 4.9.198 (jenkins@haredxbuildxjplxpsq19p1xgrx5xnws) (gcc version 8.3.0 (Buildroot 2018.11.4-gd0078a7b1) ) #1 SMP Mon Jun 22 16:45:20 CEST 2020
[    1.899266]  (early init)
[    1.918331] NET: Registered protocol family 8
[    1.922602] NET: Registered protocol family 20
[    1.927502] clocksource: Switched to clocksource gptc
[    1.955243] AppArmor: AppArmor Filesystem Enabled
[    1.962663] NET: Registered protocol family 2
[    1.991727] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    1.998716] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    2.005223] TCP: Hash tables configured (established 4096 bind 4096)
[    2.011684] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    2.017504] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    2.024211] avm_pa: try to activate hw accelaration for pid 1 (ipv4) called from avm_pa_dev_pidhandle_register_with_ingress
[    2.035267] NET: Registered protocol family 1
[    2.041049] yield_probe: cpu 0 irq 272
[    2.044887] yield_probe: cpu 1 irq 273
[    2.048859] yield_probe: cpu 2 irq 274
[    2.052543] yield_probe: cpu 3 irq 275
[    2.056574] yield_probe: interrupts set up
[    2.062695] audit: initializing netlink subsys (enabled)
[    2.068070] audit: type=2000 audit(1.520:1): initialized
[    2.074158] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    2.097427] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.103154] ANTFS Modules: Version 2.46
[    2.107165] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    2.117600] fuse init (API version 7.26)
[    2.128874] io scheduler noop registered
[    2.132676] io scheduler deadline registered (default)
[    2.138297] bthelper_probe: core 0 initialized
[    2.142595] bthelper_probe: core 1 initialized
[    2.147936] intel-pcie-slim-phy 18500000.pciephy: PCIe slim phy[0] init success!
[    2.155450] intel-pcie-slim-phy 18000000.pciephy: PCIe slim phy[1] init success!
[    2.162969] intel-pcie-slim-phy 18a00000.pciephy: PCIe slim phy[2] init success!
[    2.170714] 1a400000.phy supply vbus not found, using dummy regulator
[    2.177401] 1a600000.phy supply vbus not found, using dummy regulator
[    2.291530] OF: PCI: host bridge /pcie@18900000 ranges:
[ 2.296660] OF: PCI: MEM 0xb8000000.. 0xbaffffff > 0xb8000000
[ 2.302604] OF: PCI: IO 0xbb800000.. 0xbb80ffff > 0xbb800000
[    2.310921] intel-pcie-slim-phy 18500000.pciephy: PCIe LCPLL SSC Mode Enabled
[    2.450487] intel-pcie 18900000.pcie: PCI host bridge to bus 0000:00
[    2.456734] pci_bus 0000:00: root bus resource [bus 00-08]
[    2.462249] pci_bus 0000:00: root bus resource [mem 0xb8000000-0xbaffffff]
[    2.469197] pci_bus 0000:00: root bus resource [io  0xbb800000-0xbb80ffff]
[    2.476538] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.485050] pci 0000:00:00.0: PCI bridge to [bus 01-08]
[    2.490379] pci 0000:00:00.0: BAR 8: assigned [mem 0xb8000000-0xb81fffff]
[    2.497019] pci 0000:00:00.0: BAR 9: assigned [mem 0xb8200000-0xb82fffff pref]
[    2.504314] pci 0000:00:00.0: BAR 7: assigned [io  0xbb800000-0xbb800fff]
[    2.511174] pci 0000:01:00.0: BAR 0: assigned [mem 0xb8000000-0xb81fffff 64bit]
[    2.518555] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.523574] pci 0000:00:00.0:   bridge window [io  0xbb800000-0xbb800fff]
[    2.530427] pci 0000:00:00.0:   bridge window [mem 0xb8000000-0xb81fffff]
[    2.537290] pci 0000:00:00.0:   bridge window [mem 0xb8200000-0xb82fffff pref]
[    2.544719] pcieport 0000:00:00.0: enabling device (0000 -> 0003)
[    2.550939] intel-pcie 18900000.pcie: Intel AXI PCIe Root Complex Port 0 Init Done
[    2.663517] OF: PCI: host bridge /pcie@18400000 ranges:
[ 2.668623] OF: PCI: MEM 0xb4000000.. 0xb6ffffff > 0xb4000000
[ 2.674587] OF: PCI: IO 0xb7800000.. 0xb780ffff > 0xb7800000
[    2.681682] intel-pcie-slim-phy 18000000.pciephy: SSC has been enabled, count: 2!
[    2.822420] intel-pcie 18400000.pcie: PCI host bridge to bus 0001:00
[    2.828660] pci_bus 0001:00: root bus resource [bus 00-08]
[    2.834180] pci_bus 0001:00: root bus resource [mem 0xb4000000-0xb6ffffff]
[    2.841123] pci_bus 0001:00: root bus resource [io  0xb7800000-0xb780ffff]
[    2.848479] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.856998] pci 0001:00:00.0: PCI bridge to [bus 01-08]
[    2.862378] pci 0001:00:00.0: BAR 8: assigned [mem 0xb4000000-0xb41fffff]
[    2.869021] pci 0001:00:00.0: BAR 9: assigned [mem 0xb4200000-0xb42fffff pref]
[    2.876315] pci 0001:00:00.0: BAR 7: assigned [io  0xb7800000-0xb7800fff]
[    2.883178] pci 0001:01:00.0: BAR 0: assigned [mem 0xb4000000-0xb41fffff 64bit]
[    2.890558] pci 0001:00:00.0: PCI bridge to [bus 01]
[    2.895576] pci 0001:00:00.0:   bridge window [io  0xb7800000-0xb7800fff]
[    2.902428] pci 0001:00:00.0:   bridge window [mem 0xb4000000-0xb41fffff]
[    2.909291] pci 0001:00:00.0:   bridge window [mem 0xb4200000-0xb42fffff pref]
[    2.916717] pcieport 0001:00:00.0: enabling device (0000 -> 0003)
[    2.922940] intel-pcie 18400000.pcie: Intel AXI PCIe Root Complex Port 1 Init Done
[    3.035518] OF: PCI: host bridge /pcie@18e00000 ranges:
[ 3.040622] OF: PCI: MEM 0xbc000000.. 0xbeffffff > 0xbc000000
[ 3.046589] OF: PCI: IO 0xbf800000.. 0xbf80ffff > 0xbf800000
[    3.053684] intel-pcie-slim-phy 18a00000.pciephy: SSC has been enabled, count: 3!
[    3.181841] intel-pcie 18e00000.pcie: PCI host bridge to bus 0002:00
[    3.188076] pci_bus 0002:00: root bus resource [bus 00-08]
[    3.193596] pci_bus 0002:00: root bus resource [mem 0xbc000000-0xbeffffff]
[    3.200539] pci_bus 0002:00: root bus resource [io  0xbf800000-0xbf80ffff]
[    3.207901] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    3.216419] pci 0002:00:00.0: PCI bridge to [bus 01-08]
[    3.221841] pci 0002:00:00.0: BAR 8: assigned [mem 0xbc000000-0xbc7fffff]
[    3.228480] pci 0002:00:00.0: BAR 9: assigned [mem 0xbc800000-0xbc8fffff pref]
[    3.235774] pci 0002:00:00.0: BAR 7: assigned [io  0xbf800000-0xbf800fff]
[    3.242635] pci 0002:01:00.0: BAR 0: assigned [mem 0xbc000000-0xbc7fffff]
[    3.249488] pci 0002:00:00.0: PCI bridge to [bus 01]
[    3.254508] pci 0002:00:00.0:   bridge window [io  0xbf800000-0xbf800fff]
[    3.261372] pci 0002:00:00.0:   bridge window [mem 0xbc000000-0xbc7fffff]
[    3.268229] pci 0002:00:00.0:   bridge window [mem 0xbc800000-0xbc8fffff pref]
[    3.275659] pcieport 0002:00:00.0: enabling device (0000 -> 0003)
[    3.281882] intel-pcie 18e00000.pcie: Intel AXI PCIe Root Complex Port 2 Init Done
[    3.291169] UMT initialize success on processor: 0 !
[    3.296016] HW MCPY driver: Version: 1.1.0, Init Done!
[    3.302127] 16600000.serial: ttyLTQ0 at MMIO 0x16600000 (irq = 210, base_baud = 0) is a lantiq,asc
[    3.311238] console [ttyLTQ0] enabled
[    3.318431] bootconsole [early0] disabled
[    3.327671] avm_net_trace: Up and running.
[    3.330941] [loadcontrol] set auto - scale=1
[    3.334608] [avm] configured: watchdog event debug [    3.339262]
[    3.340736] AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0)
[    3.348090] [grx] start on cpu0
[    3.351336] [grx] start on cpu1
[    3.355229] [grx] start on cpu2
[    3.359132] [grx] start on cpu3
[    3.363310] Register push button event to receive the set_factory_kernel event
[    3.389096] zram: Added device: zram0
[    3.393189] nand: device found, Manufacturer ID: 0x98, Chip ID: 0xdc
[ 3.398220] nand: Toshiba NAND 512MiB 3.3V 8-bit
[    3.402701] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 128
[    3.410349] try_avm_ecc_fixup: AVM ecc fixup is not yet implemented - skipping check
[    3.418073] Scanning device for bad blocks
[    3.505801] Bad eraseblock 337 at 0x000005440000
[    3.622120] Bad eraseblock 794 at 0x00000c680000
[    3.660850] Bad eraseblock 938 at 0x00000ea80000
[    3.678735] Bad eraseblock 998 at 0x00000f980000
[    3.682264] Bad eraseblock 1000 at 0x00000fa00000
[    3.735742] Bad eraseblock 1199 at 0x000012bc0000
[    3.822031] Bad eraseblock 1536 at 0x000018000000
[    3.825397] Bad eraseblock 1537 at 0x000018040000
[    3.883920] Bad eraseblock 1757 at 0x00001b740000
[    3.909519] Bad eraseblock 1848 at 0x00001ce00000
[    3.913139] Bad eraseblock 1850 at 0x00001ce80000
[    3.948012] Bad eraseblock 1974 at 0x00001ed80000
[    3.969344] 5 ofpart partitions found on MTD device 17c00000.nand-parts
[    3.974493] Creating 5 MTD partitions on "17c00000.nand-parts":
[ 3.980408] 0x000000500000 0x000000d00000 : "reserved-kernel"
[ 3.988024] 0x000000000000 0x000000100000 : "urlader"
[ 3.993232] 0x000000100000 0x000000500000 : "nand-tffs"
[ 3.998613] 0x000000d00000 0x000001500000 : "kernel"
[ 4.003934] 0x000001500000 0x000020000000 : "ubi"
[    4.011713] [TFFS3_Register_Panic_CB] registering panic callback for mtd 17c00000.nand-parts
[    4.019735] libphy: Fixed MDIO Bus: probed
[    4.023581] Node name /ssx1@1c000000/gswitch@000000
[    4.028735] Node name /ssx2@1a000000/gswitch@000000
[    4.034177] ::::::: SWAPI Reached ::::::
[    4.036773] GSWIP devid = 0
[    4.039517] memres->start = 0x1c000000 memres->end = 0x1c002fff
[    4.045528] addr_gswl = 0xbc000000
[    4.048809] /GU/KERNEL_grx5_build/linux/drivers/net/ethernet/lantiq/switch-api/gsw_init.c:ltq_gsw_api_register:933 (Register l base:0xbc000000)
[    4.061682] SWAPI: Registered char device [switch_api] with major no [81]
[    4.068432] addr_gswl = 0xbc000000
[    4.071811]
[ 4.071811] ########### Switch Core INIT for device = 0 ##########
[    4.079357] Switch Core Base Address = 0xbc000000
[    4.084058]
[    4.084058] GSWIP 3.0 HardWare Capability
[    4.089519] -----------------------------
[    4.089519]
[    4.094981] Switch Version ID                =  0x30
[    4.099931]
[    4.101390] Number of logical port           =  7
[    4.106099] Number of ports including V port =  8
[    4.110781] Number of queues                 =  32
[    4.115566] Number of meter instance         =  16
[    4.120341] Number of shapers                =  32
[    4.125111] Number of PMAC                   =  1
[    4.129795] Number of CPU PORT               =  0
[    4.134482]
[    4.135958] PPPOE table size                 =  16
[    4.140735] IP packet length table size      =  16
[    4.145506] Protocol table size              =  32
[    4.150278] MAC DA/SA table size             =  64
[    4.155060] Application table size           =  64
[    4.159842] IP DA/SA MSB table size          =  64
[    4.164601] IP DA/SA LSB table size          =  64
[    4.169387] Multicast table size             =  64
[    4.174159] Multicast Hw Snoop               =  0
[    4.178847] TFLOW table size                 =  64
[    4.183621] MAC bridge table size            =  2048
[    4.188561] TFLOW RMON counter table Size    =  256
[    4.193425] Payload Table Size               =  64
[    4.198202] Extend VLAN Table Size table     =  0
[    4.202887] VlanFilter table Size            =  0
[    4.202887]
[    4.209050]
[    4.210542] Enter PCE micro-code init
[    4.214421] Exit PCE micro-code init
[    4.217730] Switch API: PCE MicroCode loaded !!
[    4.222358] ::::::: SWAPI Reached ::::::
[    4.226252] GSWIP devid = 1
[    4.229020] memres->start = 0x1a000000 memres->end = 0x1a002fff
[    4.234990] addr_gswr = 0xba000000
[    4.238311] /GU/KERNEL_grx5_build/linux/drivers/net/ethernet/lantiq/switch-api/gsw_init.c:ltq_gsw_api_register:944 (Register r base:0xba000000)
[    4.251159]
[ 4.251159] ########### Switch Core INIT for device = 1 ##########
[    4.258711] Switch Core Base Address = 0xba000000
[    4.263400]
[    4.263400] GSWIP 3.0 HardWare Capability
[    4.268865] -----------------------------
[    4.268865]
[    4.274340] Switch Version ID                =  0x30
[    4.279283]
[    4.280759] Number of logical port           =  2
[    4.285445] Number of ports including V port =  17
[    4.290220] Number of queues                 =  32
[    4.294994] Number of meter instance         =  64
[    4.299769] Number of shapers                =  32
[    4.304543] Number of PMAC                   =  1
[    4.309230] Number of CPU PORT               =  0
[    4.313916]
[    4.315373] PPPOE table size                 =  16
[    4.320173] IP packet length table size      =  16
[    4.324947] Protocol table size              =  32
[    4.329725] MAC DA/SA table size             =  64
[    4.334497] Application table size           =  64
[    4.339265] IP DA/SA MSB table size          =  64
[    4.344039] IP DA/SA LSB table size          =  64
[    4.348813] Multicast table size             =  64
[    4.353595] Multicast Hw Snoop               =  0
[    4.358276] TFLOW table size                 =  512
[    4.363136] MAC bridge table size            =  2048
[    4.368085] TFLOW RMON counter table Size    =  256
[    4.372946] Payload Table Size               =  64
[    4.377720] Extend VLAN Table Size table     =  0
[    4.382408] VlanFilter table Size            =  0
[    4.382408]
[    4.388644]
[    4.390050] Enter PCE micro-code init
[    4.393951] Exit PCE micro-code init
[    4.397253] Switch API: PCE MicroCode loaded !!
[    4.408113] lro_sram_membase_res0 from DT: a2013000
[    4.411918] ltq_toe_membase: e2000000 and lro_sram_membase_res0: e2013000
[    4.419005] TOE Init Done !!
[    5.068105] i2c /dev entries driver
[    5.079233] AVM PA for Linux Linux version 4.9.198 (jenkins@haredxbuildxjplxpsq19p1xgrx5xnws) (gcc version 8.3.0 (Buildroot 2018.11.4-gd0078a7b1) ) #1 SMP Mon Jun 22 16:45:20 CEST 2020
[    5.079233]  (late init)
[    5.097322] Mirror/redirect action on
[    5.100467] u32 classifier
[    5.103063]     Performance counters on
[    5.106916]     input device check on
[    5.110549]     Actions configured
[    5.114242] ipip: IPv4 and MPLS over IPv4 tunneling driver
[    5.120563] Initializing XFRM netlink socket
[    5.123744] IPsec XFRM device driver
[    5.128631] NET: Registered protocol family 10
[    5.133846] avm_pa: try to activate hw accelaration for pid 2 (ipv6) called from avm_pa_dev_pidhandle_register_with_ingress
[    5.143813] NET: Registered protocol family 17
[    5.148155] Bridge flood ratelimiter registered
[    5.152539] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    5.165460] lec:lane_module_init: lec.c: initialized
[    5.170381] mpoa:atm_mpoa_init: mpc.c: initialized
[    5.175184] KOAM is loaded successfully.
[    5.179099] l2tp_core: L2TP core driver, V2.0
[    5.183389] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[    5.189021] l2tp_netlink: L2TP netlink interface
[    5.193632] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[    5.199447] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
[    5.206249] 8021q: 802.1Q VLAN Support v1.8
[    5.211931] audit: type=1400 audit(4.664:2): apparmor="STATUS" info="AppArmor sha1 policy hashing enabled" pid=1 comm="swapper/0"
[    5.222179] AppArmor: AppArmor sha1 policy hashing enabled
[    5.230748] [TFFS3_Init] Called.
[    5.232590] [TFFS3_CACHE_Configure] Setting up caching for backend nand
[    5.239144] [TFFS3-CACHE] Caching module for TFFS 3.x
[    5.244184] [TFFS3-NAND] NAND storage backend for TFFS 3.x
[    5.455434] [TFFS3-NAND] Initialisation successful, 16/16/16 NAND blocks active, fill rate 8%
[    5.462846] TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 3.0)
[    5.470088] Adam2 environment variables API installed.
[    5.476343] ubi0: attaching mtd4
[    5.855641] ubi0: scanning is finished
[    5.888376] ubi0: attached mtd4 (name "ubi", size 491 MiB)
[ 5.892442] ubi0: PEB size: 262144 bytes (256 KiB), size: 258048 bytes
[    5.899276] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 1024
[    5.906043] ubi0: VID header offset: 1024 (aligned 1024), data offset: 4096
[    5.912989] ubi0: good PEBs: 1952, bad PEBs: 12, corrupted PEBs: 0
[    5.919154] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[    5.926357] ubi0: max/mean erase counter: 3/2, WL threshold: 4096, image sequence number: 792797477
[    5.935385] ubi0: available PEBs: 0, total reserved PEBs: 1952, PEBs reserved for bad PEB handling: 28
[    5.944705] ubi0: background thread "ubi_bgt0d" started, PID 627
[    5.947594] [announce_root] filesystem (/dev/mtdblock6) will be used as [    5.966449] VFS: Mounted root (squashfs filesystem) readonly on device 31:6.
[    5.977348] devtmpfs: mounted
[    5.980036] Freeing unused kernel: 344k freed
[    5.983202] This architecture does not have kernel memory protection.
[    7.233457] eip123_hw: loading out-of-tree module taints kernel.
[    7.238075] eip123_hw: module license 'Proprietary' taints kernel.
[    7.244198] Disabling lock debugging due to kernel taint
[    7.250017] [module-mem] give 0x4000 bytes at 884a8000 to module 'eip123_hw' (0x989000 bytes left)
[    7.260993] [module-mem] give 0x2000 bytes at 884ac000 to module 'eip123' (0x987000 bytes left)
[    7.269357] eip123 1e000000.eip123: Detected hardware version 2.2.2
[    7.274860] eip123 1e000000.eip123: my_id=3 master_id=0 num_mailboxes=4 mailbox_size=256
[    7.282613] eip123 1e000000.eip123: Linked mailbox number 1
[    7.315561] eip123 1e000000.eip123: Sysinfo: FWVersion=2.4.2 HWVersion=2.2.2 MemorySize=32768 HostId=3 Identity=0 NVMAnomaly=0 NVMAnomalyLocation=0
[    7.379541] eip123 1e000000.eip123: Device responded with error_src=0x2 error=0x2 opcode=0x11
[    7.687629] eip123 1e000000.eip123: eip123_hw init successful
[    7.720260] random: crng init done
[    7.747641] eip123 1e000000.eip123: Device responded with error_src=0x0 error=0x1 opcode=0x1c
[    7.754785] eip123 1e000000.eip123: Could not find rootkey in OTP
[    8.068999] [module-mem] give 0x32000 bytes at 884ae000 to module 'led_module' (0x955000 bytes left)
[    8.087718] [LED] use GPIO 14 for 'gpio_avm_led_power'
[    8.092120] [init_ambient_brightness] HWSubRev 4
[    8.096604] [LED] use GPIO 15 for 'gpio_avm_led_wlan'
[    8.101163] [LED] use GPIO 16 for 'gpio_avm_led_fon'
[    8.106082] [LED] use GPIO 17 for 'gpio_avm_led_connect'
[    8.111385] [LED] use GPIO 19 for 'gpio_avm_led_info'
[    8.116418] [LED] use GPIO 18 for 'gpio_avm_led_info_red'
[    8.121790] [LED] use GPIO 20 for 'gpio_avm_ambientbrightness'
[    8.127610] [LED] use GPIO 3 for 'gpio_avm_led_output_enable'
[    8.133482] [BUTTON] use GPIO 12 for 'gpio_avm_button_wlan'
[    8.138890] [BUTTON] use GPIO 11 for 'gpio_avm_button_dect'
[    8.144455] [BUTTON] use GPIO 13 for 'gpio_avm_button_connect'
[    8.150598] [avm_connect][state_machine_init] starting event worker thread
[    8.158173] led_module: Waiting for event system to be ready...
[    8.245320] [TFFS_Cache] Allocate segement buffer cache (size=4072)
[    8.253381] TFFS Name Table N
[    9.577324] [0]system-load  51% loadavg 0.8 0.2 0.1 - pgstat: sum=216495 free=101836 slab=1850 alloc=1018/s fault=365/s ai_sys:0.40/s 0x884a9624 endian_convert_array+0x20/0x38 [eip12 (sleep 2)
[ 12.900619] AVM_WATCHDOG: System Init Monitoring 120 seconds
[   13.367923] udevd[914]: starting version 3.2.5
[   13.451912] udevd[914]: specified group 'tty' unknown
[   13.458668] udevd[914]: specified group 'dialout' unknown
[   13.463671] udevd[914]: specified group 'kmem' unknown
[   13.468648] udevd[914]: specified group 'input' unknown
[   13.473810] udevd[914]: specified group 'video' unknown
[   13.479265] udevd[914]: specified group 'audio' unknown
[   13.484614] udevd[914]: specified group 'lp' unknown
[   13.489318] udevd[914]: specified group 'disk' unknown
[   13.494316] udevd[914]: specified group 'cdrom' unknown
[   13.505375] udevd[914]: starting eudev-3.2.5
[   13.752938] [module-mem] give 0x6000 bytes at 884e0000 to module 'vrx518' (0x94f000 bytes left)
[   13.761832] vrx518: Intel(R) SmartPHY DSL(VRX518) PCIe EP/ACA Driver - version 2.1.0-k
[   13.768427] vrx518: Copyright (c) 2016 Intel Corporation.
[   13.774006] vrx518 0002:01:00.0: enabling device (0000 -> 0002)
[   13.816552] [module-mem] give 0x1000 bytes at 884e6000 to module 'xrx500_phy_fw' (0x94e000 bytes left)
[   13.826516] phy-xrx500 phy-xrx500: requesting ltq_fw_PHY11G_IP_xRx5xx_A21.bin
[   13.830917] [module-mem] give 0x3000 bytes at 884e7000 to module 'cpunet' (0x94b000 bytes left)
[   13.837745] [module-mem] give 0xe000 bytes at 884ea000 to module 'eip97' (0x93d000 bytes left)
[   13.844889] cpunet 1f107400.cpunet: slots=16 mtu=8192 mailbox_size=0x4c mempool_size=0x20000
[   13.845081] cpunet 1f107400.cpunet: Initialized mailbox: rx=0xbf201000 tx=0xbf201100
[   13.845424] cpunet 1f107400.cpunet: Initialized mempool: rx=0x8dfc0000 tx=0x8dfe0000 min_align=64
[   13.845638] cpunet 1f107400.cpunet: hw init successful
[ 13.850237] [module-mem] Modules 'xrx500_phy_fw' already allocated
[   13.948683] phy-xrx500 phy-xrx500: booting GPHY0 firmware at 25A50000 for GRX500
[   13.955086] phy-xrx500 phy-xrx500: booting GPHY1 firmware at 25A50000 for GRX500
[   13.962297] phy-xrx500 phy-xrx500: booting GPHY2 firmware at 25A50000 for GRX500
[   13.969483] phy-xrx500 phy-xrx500: booting GPHY3 firmware at 25A50000 for GRX500
[   13.976866] phy-xrx500 phy-xrx500: booting GPHY4 firmware at 25A50000 for GRX500
[   14.151448] [module-mem] give 0x6000 bytes at 884f8000 to module 'ltq_eth_drv_xrx500' (0x937000 bytes left)
[   14.161277] PMAC_EG_CFG_SET for GSW-L
[   14.163769] PMAC_IG_CFG_SET for GSW-L
[   14.167171] PMAC_EG_CFG_SET for GSW-R
[   14.173811] PMAC_IG_CFG_SET for GSW-R
[   14.176250]
[   14.176250]   GSW PMAC Init Done!!!
[   14.181010] registering one of MII bus
[   14.184902] libphy: lantiq,xrx500-mdio: probed
[   14.227392] registering one of MII bus
[   14.230033] libphy: lantiq,xrx500-mdio: probed
[   14.236518] [datapath_proc] { dp_sub_proc_install_30 : 3491 }dp_sub_proc_install ok
[   14.242747] Rmon clear for CTP RX/TX --Logical Port 0
[   14.247758] Rmon clear for CTP RX/TX --Logical Port 1
[   14.252797] Rmon clear for CTP RX/TX --Logical Port 2
[   14.257824] Rmon clear for CTP RX/TX --Logical Port 3
[   14.262867] Rmon clear for CTP RX/TX --Logical Port 4
[   14.267894] Rmon clear for CTP RX/TX --Logical Port 5
[   14.272936] Rmon clear for CTP RX/TX --Logical Port 6
[   14.277983] Rmon clear for CTP RX/TX --Logical Port 0
[   14.283007] Rmon clear for CTP RX/TX --Logical Port 1
[   14.288034] Rmon clear for CTP RX/TX --Logical Port 2
[   14.293080] Rmon clear for CTP RX/TX --Logical Port 3
[   14.298103] Rmon clear for CTP RX/TX --Logical Port 4
[   14.303145] Rmon clear for CTP RX/TX --Logical Port 5
[   14.308174] Rmon clear for CTP RX/TX --Logical Port 6
[   14.313215] Rmon clear for CTP RX/TX --Logical Port 7
[   14.318243] Rmon clear for CTP RX/TX --Logical Port 8
[   14.323297] Rmon clear for CTP RX/TX --Logical Port 9
[   14.328314] Rmon clear for CTP RX/TX --Logical Port 10
[   14.333442] Rmon clear for CTP RX/TX --Logical Port 11
[   14.338556] Rmon clear for CTP RX/TX --Logical Port 12
[   14.343684] Rmon clear for CTP RX/TX --Logical Port 13
[   14.348807] Rmon clear for CTP RX/TX --Logical Port 14
[   14.353921] Rmon clear for CTP RX/TX --Logical Port 15
[   14.359050] Rmon clear for CTP RX/TX --Logical Port 16
[   14.364195] [datapath_api] { dp_init_module : 2742 }datapath init done
[   14.370730] [cbm] { dp_port_alloc : 3195 }flags 0x2
[   14.375555] [cbm] { cbm_add_to_list : 427 }2
[   14.379809] [cbm] { dp_port_alloc : 3344 }disabling q 17 port 7
[   14.385706] [cbm] { dp_port_alloc : 3350 }first time LOOKUP prgrm
[   14.392087] [cbm] { dp_port_alloc : 3355 }1024
[   14.396498] xrx500_of_iface: rx csum offload is enabled !
[   14.401620] trying to connect: eth3 to device: 0:02 with irq: 290
[   15.749404] eth3: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:02, irq=290)
[   15.939342] [cbm] { dp_enable : 3659 }ep=2 tmu_port=7 queue=17 sid=1
[   15.944262] [cbm] { dp_enable : 3700 }enable queue 17
[   15.949249] [cbm] { dp_enable : 3701 }flag 1 refcnt 1024
[   15.955859] [setup_avm_pa_eth_dev] dev eth3
[   15.959004] [cbm] { dp_port_alloc : 3195 }flags 0x2
[   15.963675] [cbm] { cbm_add_to_list : 427 }2
[   15.967858] [cbm] { dp_port_alloc : 3344 }disabling q 18 port 8
[   15.973756] [cbm] { dp_port_alloc : 3350 }first time LOOKUP prgrm
[   15.980137] [cbm] { dp_port_alloc : 3355 }1024
[   15.984554] xrx500_of_iface: rx csum offload is enabled !
[   15.989674] trying to connect: eth2 to device: 0:03 with irq: 291
[   17.336955] eth2: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:03, irq=291)
[   17.526890] [cbm] { dp_enable : 3659 }ep=3 tmu_port=8 queue=18 sid=2
[   17.531810] [cbm] { dp_enable : 3700 }enable queue 18
[   17.536798] [cbm] { dp_enable : 3701 }flag 1 refcnt 1024
[   17.543263] [setup_avm_pa_eth_dev] dev eth2
[   17.546596] [cbm] { dp_port_alloc : 3195 }flags 0x2
[   17.551160] [cbm] { cbm_add_to_list : 427 }2
[   17.555396] [cbm] { dp_port_alloc : 3344 }disabling q 19 port 9
[   17.561302] [cbm] { dp_port_alloc : 3350 }first time LOOKUP prgrm
[   17.567691] [cbm] { dp_port_alloc : 3355 }1024
[   17.572135] xrx500_of_iface: rx csum offload is enabled !
[   17.577215] trying to connect: eth1 to device: 0:04 with irq: 292
[   18.828541] eth1: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:04, irq=292)
[   18.936692] [cbm] { dp_enable : 3659 }ep=4 tmu_port=9 queue=19 sid=3
[   18.941601] [cbm] { dp_enable : 3700 }enable queue 19
[   18.946599] [cbm] { dp_enable : 3701 }flag 1 refcnt 1024
[   18.953105] [setup_avm_pa_eth_dev] dev eth1
[   18.956341] [cbm] { dp_port_alloc : 3195 }flags 0x2
[   18.960954] [cbm] { cbm_add_to_list : 427 }2
[   18.965202] [cbm] { dp_port_alloc : 3344 }disabling q 20 port 10
[   18.971189] [cbm] { dp_port_alloc : 3350 }first time LOOKUP prgrm
[   18.977568] [cbm] { dp_port_alloc : 3355 }1024
[   18.982012] xrx500_of_iface: rx csum offload is enabled !
[   18.987093] trying to connect: eth0 to device: 0:05 with irq: 293
[   19.775864] [0]system-load  34% loadavg 0.54 0.12 0.4 - task runtime:23% max:udevd 13%  pgstat: sum=213570 free=99090 slab=2428 alloc=1111/s fault=1001/s (sleep 1)
[   20.199673] [2]system-load  50% loadavg 0.54 0.12 0.4 - task runtime:30% max:udevd 25%  pgstat: sum=213570 free=99090 slab=2428 alloc=2271/s fault=1496/s (sleep 3)
[   20.373502] eth0: attached PHY [Lantiq XWAY VR9 GPHY 11G v1.4] (phy_addr=0:05, irq=293)
[   20.563443] [cbm] { dp_enable : 3659 }ep=5 tmu_port=10 queue=20 sid=4
[   20.568448] [cbm] { dp_enable : 3700 }enable queue 20
[   20.573437] [cbm] { dp_enable : 3701 }flag 1 refcnt 1024
[   20.579985] [setup_avm_pa_eth_dev] dev eth0
[   20.583176] [cbm] { dp_port_alloc : 3195 }flags 0x4
[   20.587834] [cbm] { cbm_add_to_list : 427 }1
[   20.592041] [cbm] { dp_port_alloc : 3344 }disabling q 28 port 19
[   20.598027] [cbm] { dp_port_alloc : 3350 }first time LOOKUP prgrm
[   20.604407] [cbm] { dp_port_alloc : 3355 }1024
[   20.608834] xrx500_of_iface: rx csum offload is enabled !
[   20.613952] xrx500-eth 1e000000.ssx0:eth@a00000 wan (uninitialized): no PHY found
[   20.621389] xrx500-mdio: probing phy of port 1 failed
[   20.626442] [cbm] { dp_enable : 3659 }ep=15 tmu_port=19 queue=28 sid=12
[   20.633029] [cbm] { dp_enable : 3700 }enable queue 28
[   20.638023] [cbm] { dp_enable : 3701 }flag 1 refcnt 1024
[   20.644593] [setup_avm_pa_eth_dev] dev wan
[   20.647701] Lantiq ethernet driver for XRX500 init.
[   20.714800]
[   20.714800] [avm_debug] redirecting kernel-messages (/dev/debug)
[ 63.231672] [0] Kernel panic - not syncing:
[ 63.231672] [0] No answer on upper layer Control channel! PCMLINK probably dead!
[ 63.231672] [0]
[ 63.243401] [0]set_reboot_status: Soft-Reboot(PANIC) - PANIC(16)SUM(16)UP(62)UTC(62)FW(07.20)HW(226)HWS(4)BV(1.3258)
[   63.389338] Rebooting in 1 seconds..
After 20 seconds into the boot, the ethernet physical port 1 is not found.
The ethernet switch is probably dead because of an over-voltage at one of its ports.
No further rescue possible.
This is sad :(
But not unexpected, by reading this. Even an hardware repair attempt, as far as I undestood, it's impossible, right? Further, as long as all ports are under the same device there's nothing doable also by coding (maybe excluding the search on the boot process?).. is this also right?
Anyway, I will disassemble the box again to check better if something has broken, maybe I post pictures of it.
Thanks for now, I'll update.
--EDIT--
Sorry, the physical port 1 is also the "1" marked on the box?
TomTom55
