Hello,
Sorry if I this topic was discussed on forum, but my german is not good, so i couldn't find any info.
Here is my problem.
Something "burned" in my FBF.
Actulaly i "almost" know that this is module that generate 60V voltage for phone ring (signal that rings when the phone call "arrive/is incoming")
I have NO incoming phone signal (ringing).
My fritzbox work correct, if i call myself to me from my mobile to my landline number and i pick up the phone when diode "landline" is green, i can talk and the phone call is correct, but i don't have signal of incaming call.
I can also call out from home over VoIP or Landline, so fritzbox works good.
Day ago i had some troubles with my home telephone and i changed ports in FBF from FON1 to FON2 and after that it crashed - as i realized later, the pin 1 and pin 2 in port FON2 (RJ 11) were connected - so it is hardware error on 99%.
Here is my question.
If anybody have description of the FBF 7050 mainboard because i could posibly repair it myself if i would have it.
or
Do you have any other ideas how to repair it ( i foget to mantion - it has nothing to do with "react to all numbers setting in "extention - it is checked")
or
Have you got idea what would be the cost of sending it to AVM for repair?
Thanks in advance for all your ideas
sirkubax
Here is my problem.
or
or
sirkubax
