Dear all,
I have a FRITZ!Box SL WLAN, Firmware-Version 09.04.34 at home and using it with a Kabel Deutschland cable Arris modem.
The internet speed when I use the LAN cable direct is 30 MBPS, but when I connect it via WLAN with Fritz box the speed reduces to 2 MBPS!
Can anyone please help and tell me how to solve this and make the speed same as with direct LAN connection?
Thanks a lot for your help in advance!
Best regards.
Best regards.
