- Mitglied seit
- 1 Mai 2007
- Beiträge
- 44
- Punkte für Reaktionen
- 0
- Punkte
- 0
I have tried both english and german recover images from avm.de, however none of them work. Box was originally german version (no annex), it died after trying to patch to english.
ftp.log
Any help would be appreciated
FRITZ!Box Fon WLAN suchen an: 192.168.178.2
Eine Anlage gefunden! - Ermitteln der aktuellen Version.
Version erfolgreich ermittelt!
Hardware: FRITZ!Box Fon WLAN
Urlader: 0
Firmware: 10.04.26
Firmware der FRITZ!Box Fon WLAN ist mit der Recover-Firmware inkompatibel
ftp.log
1:23:179: AVM Berlin recover-tool-version:[RECOVER:126][IO_CSP:47] compiled at Jul 26 2006 on 15:06:51
1:23:179: Registry: SYSTEM\CurrentControlSet\Services\TcpIp\Parameters\DisableDHCPMediaSense=1
1:23:179: recover-firmware-id: 61
1:23:179: recover-firmware-version: 08.04.15
1:23:189: recover-urloader-version: 99
1:23:219: check adapter(Realtek RTL8185 54M Wireless LAN Network Adapter - Packet Scheduler Miniport) adapter 0x3: Ip: 192.168.1.100(255.255.255.0) (dhcp)
1:23:219: check adapter(Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport) adapter 0x2: Ip: 192.168.178.2(255.255.255.0) (static)
1:23:219: compatible ipaddress (static) found: 192.168.178.2 on adapter 0x2
1:24:231: search on addr: 192.168.178.3
2:24:457: search on addr: 192.168.178.3
2:35:533: ---> read environment <---
2:35:633: open ftp 192.168.178.3 port 21
2:35:633: recv: 220 ADAM2 FTP Server ready.
2:35:633: send: USER adam2
2:35:633: recv: 331 Password required for adam2.
2:35:633: send: PASS adam2
2:35:633: recv: 230 User adam2 successfully logged in.
2:35:633: send: SYST
2:35:633: recv: 215 UNIX emulated bye ADAM2's FTP Server.
2:35:643: send: TYPE I
2:35:643: recv: 200 Type set to I.
2:35:643: send: MEDIA SDRAM
2:35:643: recv: 200 Media set to SDRAM.
2:35:643: send: P@SW
2:35:643: recv: 227 Entering Passive Mode (192,168,178,3,202,247).
2:35:643: open ftp data 192.168.178.3 port 51959
2:35:643: send: RETR env
2:35:643: recv: 150 Opening BINARY mode data connection for file transfer.
2:35:663: recv: 226 Transfer complete.
2:35:763: environment successfully readed(1373 bytes)
2:35:763: send: BYE
2:35:763: recv: 221-Thank you for using the FTP service on ADAM2.
2:35:763: hardware-revision: 61
2:35:763: firmware-version: 10.04.26
2:35:763: urloader-version:
2:35:763: oem: avme
2:35:874: incompatible oem ('avme' - supported oem-list 'avm 1und1 aol')
2:35:974: exit: errorcode=-1
2:35:974: ----EOF---
