- Mitglied seit
- 7 Okt 2015
- Beiträge
- 9,168
- Punkte für Reaktionen
- 1,429
- Punkte
- 113
Keine Probleme gehabt
##### TITLE Version 113.06.88
##### TITLE SubVersion -46101
##### TITLE Produkt Fritz_Box_HW185
##### TITLE Datum Thu Aug 24 11:12:03 CEST 2017
##### BEGIN SECTION Support_Data Supportdata Linux fritz.box 3.10.73 #1 SMP Tue Aug 22 12:29:55 CEST 2017 mips GNU/Linux Version 113.06.88 -46101
Support Data
3.10.73
DMC 9.00.205.537/3000
HWRevision 185
HWSubRevision 6
ProductID Fritz_Box_HW185
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 1.3179
firmware_info 113.06.88
firmware_version avm
urlader-version 4179
DSL SUPPORT DATA
VERSIONS:
DSL_SDK_VERSION: 1552
VINAX_TOOLS_VERSION: 769
DSL_ARCH_VERSION: 1333
DSL_ARCH_VERSION: 29
cat /var/flash/xdslmode
cat /var/dsl/*
File: /var/dsl/dsl_versions.txt
5.9.0.C.1.7
5.9.0.A.0.2
1.100.135.17
1.100.8.23
File: /var/dsl/vdsl_init.cfg
#AVM VDSL Annex B
[WaitForLinkActivate]={
avmcw cnfg 45 0 c
}[WaitForLinkActivate]={
avmcrmr info 99 8 0x0010
avmcw optn 5 0 3
avmdsmmcs
dsmcs 1
avmcw moni 5 0 0x240B
avmcw moni 5 1 0x0000
avmcrms dsl 13 0 0x0008
avmcrms cnfg 44 0 0x0100
avmcw test 51 0 0x0013
File: /var/dsl/adsl_init.cfg
#AVM ADSL Annex B
avmcrms info 103 1 0x2000
avmcrmr info 111 8 0x0010
avmcrms test 0 0 0x4000
avmcrms dsl 13 0 0x0002
avmcw cnfg 46 0 0xe
File: /var/dsl/vdsl.cfg
#AVM VDSL Annex B
avmcw cnfg 45 0 c
avmcw optn 5 0 3
avmdsmmcs
dsmcs 1
File: /var/dsl/adsl.cfg
#AVM ADSL Annex B
avmcw cnfg 46 0 0xe
File: /var/dsl/notify.log
[Thu Jan 1 01:00:32 CET 1970] [E40-dsl] invoke /sbin/notify_avmnet --broadband_type DSL hw_start_tm_ptm
[Thu Jan 1 01:00:36 CET 1970] [DSL_INTERFACE_STATUS] DSL_INTERFACE_STATUS: READY / DSL_TC_LAYER_STATUS:
cat /var/log/dsl_monitor.txt
[LOG] started..
[LOG] DSL STARTUP SCRIPT is set to: /etc/init.d/E40-dsl
[LOG] DSL SHUTDOWN SCRIPT is set to: /etc/init.d/e40-dsl
[LOG] Daemon is not running
[LOG] Start deamon now
[LOG] Start as daemon
[LOG] register watchdog
[LOG] into arch_vr9_init
[WARN] port 0 state 0 didn't change
[LOG] DSL ARCH INTERFACE READY!
[LOG] arch_interface_ready set to 1
[WARN] dsl_mgr_check_params_set_required: dsl params set not required
[WARN] dsl_mgr_check_dsl_dr_set_required: dsl dr set not required
[WARN] dsl_mgr_check_dsl_smart_set_required: dsl smart set not required
[LOG] switch to ATA MODE
[LOG] DSL ARCH INTERFACE DOWN! (forced by dsl_manager ATA MODE)
[LOG] arch_interface_ready set to 0
[LOG] execute: /etc/init.d/e40-dsl ata
cat /var/log/dsl_ui.txt
cat /var/log/dsl_libremotemgmt.txt
[RMGMT MAIN][FORCE]avmDslRemoteMgmtIf_Init
[WARN DSL SUPPORTDATA] arch drv not ready
DSL Line Test
Calibrate Echo : 3
Measure Echo : 0
Cable NOK Distance (m) : 0
DSL Configs
Max Downstream Rate : 0
Max Upstream Rate : 0
RFI : 0
DownstreamBlackoutBandStart : 0
DownstreamBlackoutBandEnd : 0
ControlBitfield : 0x00000000
Extra DownstreamMarginOffset: 0
Extra DownstreamPcbOffset : 0
Extra UpstreamPcbOffset : 0
DiagControlBitfield : 0x00000000
DiagnosticEnabled : 0
Annex : B
IsAnnexSet : 0
DSLMode : 0
IsDSLModeSet : 0
XTSE Octet 1 : 0x00
XTSE Octet 2 : 0x00
XTSE Octet 3 : 0x00
XTSE Octet 4 : 0x00
XTSE Octet 5 : 0x00
XTSE Octet 6 : 0x00
XTSE Octet 7 : 0x00
XTSE Octet 8 : 0x00
VDSL2 Profiles Octet 1 : 0x00
UsNoiseBits : 0
RFI_mode : 0
DsINP : 0
IsLastReleasedDP : 0
DSL Disabled (ATA) : 1
Fullbridge : 0
DSL is Disabled (ATA)! Skip Platform specific support data!
##### BEGIN SECTION DSL_APPS AP stats
apstats
/bin/supportdata: line 145: apstats: not found
apbridgetbl
/bin/supportdata: line 145: apbridgetbl: not found
aproutetbl
aproutetbl 1
/bin/supportdata: line 145: aproutetbl: not found
aproutetbl 2
aproutetbl 3
aproutetbl 4
aproutetbl 5
aproutetbl 6
aproutetbl 7
aproutetbl 8
##### END SECTION DSL_APPS
End Of Support Data
20454 Zeilen
