Freetz questions in english
I didn't have time to look at it. We know where it comes from but not how to solve it... ;-)
Regards
Oliver
tnx for the answer. May I help in any way? I have some knowledge in CS
This is caused by the "XFRM" modules, selected by the ipsec support. This leads to a different case during compilation of iptables (which has to take care wether ipsec is active in kernel). For w/o "replace kernel" only the iptables modules are build, but the kernel uses no ipsec, this leads to a missing symbol in iptables modules.
As a "workaround" you may try two approaches:
1. select "Show advanced options" and "Replace kernel"
2. call "make kernel-menuconfig" and in "Networking --> Networking options" deselect the following entries:
IPsec user configuration interface
PF_KEY sockets
IP: AH transformation
IP: ESP transformation
IP: IPComp transformation
IP: tunnel transformation
IPv6: AH transformation
IPv6: ESP transformation
IPv6: IPComp transformation
IPv6: tunnel transformation
hope that's all. Afterward, searching "XFRM" in kernels menuconfig (hit "/" and you will be prompted a search field) should report that "XFRM" is not selected.
Rebuild iptables aftwerwards.
Jörg
Thank you for the description.
I tried "Replace kernel" option but my Freetz needed recovery!
Is there any special think I must do to use this option?
Must I do *both* the operations you described?
No, both "options" should work on their own.
The first one would rebuild the kernel, and therefore include all the ipsec-stuff making the iptables modules work, when they reffer to this part.
The second one should build the kernel modules w/o ipsec, so the iptables modules will not reffer to this part.
Jörg
Dear all,
My questions are most probably not about Freetz problems, but I haven't found a topic like "General FB questions in English" :) Can I hope for you help pls?
The first thing is the message appears in the log every time I start my FB:
"cat: can't open '/etc/default.Fritz_Box_7170/avme/ar7.cfg': No such file or directory"
Nevertheless, FB works fine, it finds the default config somewhere else :))
I know, what's the problem: I have switched my FB from Annex B to A, so there is directory /etc/default.Fritz_Box_7170_Annex_A instead of mentioned.
Can I just ignore that message?
Another one is lot of messages in the syslog:
Aug 14 01:31:01 fritz user.debug kernel: mcfw: group 0.0.0.0: query tiwlan:0 25sec
Aug 14 01:31:01 fritz user.debug kernel: mcfw: group 0.0.0.0: query cpmac:0 25sec
Aug 14 01:31:20 fritz user.debug kernel: mcfw: group 0.0.0.0: query tiwlan:0 10sec
Aug 14 01:31:20 fritz user.debug kernel: mcfw: group 0.0.0.0: query cpmac:0 10sec
Aug 14 01:33:03 fritz user.debug kernel: mcfw: group 0.0.0.0: query tiwlan:0 25sec
Aug 14 01:33:03 fritz user.debug kernel: mcfw: group 0.0.0.0: query cpmac:0 25sec
Aug 14 01:33:25 fritz user.debug kernel: mcfw: group 0.0.0.0: query tiwlan:0 10sec
Aug 14 01:33:25 fritz user.debug kernel: mcfw: group 0.0.0.0: query cpmac:0 10sec
Aug 14 01:35:04 fritz user.debug kernel: mcfw: group 0.0.0.0: query tiwlan:0 25sec
Aug 14 01:35:04 fritz user.debug kernel: mcfw: group 0.0.0.0: query cpmac:0 25sec
Aug 14 01:35:30 fritz user.debug kernel: mcfw: group 0.0.0.0: query tiwlan:0 10sec
Aug 14 01:35:30 fritz user.debug kernel: mcfw: group 0.0.0.0: query cpmac:0 10sec
So, every two minutes some process changes some paramater(s) to "25sec" for tiwlan:0 and cpmac:0 ifaces,
and every two minutes something forces the same parameter(s) to "10sec".
What could that mean?
Thanks.
You can just create an English thread for your question.
I don't think anybody wanted all English questions in one thread, it's just that this thread got a bad title. We don't keep all other questions together in a single thread named "Freetz questions in German".
thank you MaxMuster
Anyway the problem was fixed by Rev 5553
I mounted Rev.5573 and it works fine!
many thanks to Oliver for the fix!!
I tried Rev. 6096 and a problem arises again in vpnc:
# /etc/init.d/rc.vpnc start
# Starting vpnc ... vpnc: can't resolve symbol 'index'
# failed.
partial output of sh -x /etc/init.d/rc.vpnc start
Starting vpnc ... + config
+ modlib_config
+ local in_files=vpnc
+ local out_file=/mod/etc/vpnc.conf
+ [ -x /tmp/flash/vpnc_conf ]
+ [ -x /tmp/flash/vpnc/vpnc_conf ]
+ /mod/etc/default.vpnc/vpnc_conf
+ cat /tmp/flash/vpnc.extra /tmp/flash/vpnc/vpnc.extra
+ env - PATH=/sbin:/bin:/usr/sbin:/usr/bin:/mod/sbin:/mod/bin:/mod/usr/sbin:/mod/usr/bin vpnc --script /etc/default.vpnc/vpnc-script /mod/etc/vpnc.conf
+ local rv=1
+ [ 1 -ne 0 ]
+ echo failed.
failed.
+ exit 1
any hint?
[Edit frank_m24: Fullquote deleted, please observe the Forum rules.]
I tried again with version 6143 but the problem is still the same....
yes I selected vpnc in menuconfig, I did no config modifications with respect to the working version build.
I can try a patch like this you referenced, but I didn't understand in which file
And do you use the whole firmware? When vpnc is selected in menuconfig. I can't imagine how this failure can happen.
Regards
Oliver
Yes I use whole firmware
In my menuconfig are selected:
  • Vpnc 0.5.3
  • Hybrid auth
  • NAT support
Actually the linker should not even create the binary if there is no definition for the symbol. Can you try with a complete new checkout?
Ok I will try this evening. tnx for the help
I saved my configuration, delete and redo the svn checkout, loong time making ;-) but now (rev 6145) everything is working well!
Thank you again for your support!
again a problem, with build 6440, again starting vpnc: I got the message
Ohhhh jeeee: cipher 2 not found
I solved including ALL the crypto library in the build:
Advanced Options->Shared libraries ->Crypto & SSL-> GnuPG crypoto library/Configuration-> (select all)
(may be some are not required, but I cannot state which)
I solved an other (little) bug:
IPTABLES:
image on "Action" column is missing:
http://192.168.178.1:8181/cgi-bin/images/ACCEPT.gif
The correct link should be
http://192.168.178.1:8181/images/ACCEPT.gif
that is /usr/mww/images/ACCEPT.gif
I modified file ./make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables.cgi
line 183:
- echo "<td align='center'><img src='../images/"$IMAGE".gif' title='"$IMAGE"'></td>"
+ echo "<td align='center'><img src='/images/"$IMAGE".gif' title='"$IMAGE"'></td>"
