olistudent
IPPF-Urgestein
- Mitglied seit
- 19 Okt 2004
- Beiträge
- 14,787
- Punkte für Reaktionen
- 13
- Punkte
- 38
Kannst du bitte mal einen etwas größeren Ausschnitt posten? Normalerweise leiten wir die Ausgabe von depmod um. Oder hab ich das unabsichtlich entfernt?
31. Momentum Ocelot board (MOMENCO_OCELOT)
32. Momentum Ocelot-3 board (MOMENCO_OCELOT_3)
33. Momentum Ocelot-C board (MOMENCO_OCELOT_C)
34. Momentum Ocelot-G board (MOMENCO_OCELOT_G)
35. MyCable XXS1500 board (MIPS_XXS1500)
36. Philips PNX8550 based Viper2-PCI board (PNX8550_V2PCI)
37. Philips PNX8550 based JBS board (PNX8550_JBS)
38. NEC DDB Vrc-5477 (DDB5477)
39. NEC VR41XX-based machines (MACH_VR41XX)
40. PMC-Sierra Yosemite eval board (PMC_YOSEMITE)
41. Qemu (QEMU)
42. Support for NEC EMMA2RH Mark-eins (MARKEINS)
43. SGI IP22 (Indy/Indigo2) (SGI_IP22)
44. SGI IP27 (Origin200/2000) (SGI_IP27)
45. SGI IP32 (O2) (EXPERIMENTAL) (SGI_IP32)
46. Sibyte BCM91480B-BigSur (SIBYTE_BIGSUR)
47. Sibyte BCM91250A-SWARM (SIBYTE_SWARM)
48. Sibyte BCM91250E-Sentosa (SIBYTE_SENTOSA)
49. Sibyte BCM91125E-Rhone (SIBYTE_RHONE)
50. Sibyte BCM91120x-Carmel (SIBYTE_CARMEL)
51. Sibyte BCM91250PT-PTSWARM (SIBYTE_PTSWARM)
52. Sibyte BCM91250C2-LittleSur (SIBYTE_LITTLESUR)
53. Sibyte BCM91120C-CRhine (SIBYTE_CRHINE)
54. Sibyte BCM91125C-CRhone (SIBYTE_CRHONE)
55. SNI RM200 PCI (SNI_RM200_PCI)
56. Toshiba JMR-TX3927 board (TOSHIBA_JMR3927)
57. Toshiba TBTX49[23]7 board (TOSHIBA_RBTX4927)
58. Toshiba RBTX4938 board (TOSHIBA_RBTX4938)
choice[1-58]: 17
* *** AVM Board PCI Configuration ***
PCI INT_A pin is used as PCI function (AVM_PCI_INT_A) [Y/n] y
PCI INT_B pin is used as PCI function (AVM_PCI_INT_B) [N/y] n
PCI INT_C pin is used as PCI function (AVM_PCI_INT_C) [N/y] n
PREQ_0 and PGRANT_0 are used as PCI functions (AVM_PCI_REQ_AND_GNT_0) [Y/n] y
PREQ_1 and PGRANT_1 are used as PCI functions (AVM_PCI_REQ_AND_GNT_1) [N/y] n
PREQ_2 and PGRANT_2 are used as PCI functions (AVM_PCI_REQ_AND_GNT_2) [N/y] n
Device#1 uses PCI Slot [0..15] (AVM_PCI_DEV1_SLOT) [14] 14
Device#1 uses INT Line [A..C] (type 0..2) (AVM_PCI_DEV1_INT) [0] 0
Fusiv platform selection
> 1. Fusiv vox 180 (FUSIV_VX180)
choice[1]: 1
Enable Ikanos Fusiv Configuration (MIPS_FUSIV) [Y/n] y
* FUSIV Source Kernel Configuration
Fusiv library files (FUSIV_LIBRARY) [M/n/y/?] m
Timers (FUSIV_TIMERS) [M/n/y/?] m
AP to AP Fastpath (FUSIV_KERNEL_AP_2_AP) [M/n/?] m
AP Support for Multicast (MCAST_AP_SUPPORT) [N/y/?] n
Buffer Manager (FUSIV_BMDRIVER) [M/n/?] m
Ethernet Driver (FUSIV_KERNEL_ETHERNET) [M/n/?] m
ATM Driver (FUSIV_KERNEL_ATM) [M/n/?] m
ACL Driver (FUSIV_KERNEL_ACL) [M/n/?] m
ACL AP support
1. ACL Support on EMAC3 (FUSIV_KERNEL_ACL_EMAC3)
> 2. ACL Support on SPA (FUSIV_KERNEL_ACL_SPA)
choice[1-2]: 2
PPP over Ethernet Relay (FUSIV_KERNEL_PPPOE_RELAY) [N/m/?] (NEW)
manfred@Stinky:~/freetz/7390$ make precompiled
mkdir -p /home/manfred/freetz/7390/source/toolchain-mipsel_gcc-3.4.6
tar -C /home/manfred/freetz/7390/source/toolchain-mipsel_gcc-3.4.6 -xjf dl/binutils-2.18.tar.bz2
set -e; \
for i in toolchain/make/kernel/binutils/2.18/*.patch; do \
tools/freetz_patch /home/manfred/freetz/7390/source/toolchain-mipsel_gcc-3.4.6/binutils-2.18 $i; \
done
applying patch file toolchain/make/kernel/binutils/2.18/100-makeinfo-version.patch
patching file configure
patching file configure.ac
applying patch file toolchain/make/kernel/binutils/2.18/110-arm-eabi-conf.patch
applying patch file toolchain/make/kernel/binutils/2.18/300-001_ld_makefile_patch.patch
patching file ld/Makefile.am
patching file ld/Makefile.in
applying patch file toolchain/make/kernel/binutils/2.18/300-012_check_ldrunpath_length.patch
patching file ld/emultempl/elf32.em
applying patch file toolchain/make/kernel/binutils/2.18/999-999_missing.patch
patching file missing
touch /home/manfred/freetz/7390/source/toolchain-mipsel_gcc-3.4.6/binutils-2.18/.unpacked
---> library/gmp: preparing... tar -C source/target-mipsel_uClibc-0.9.29 -xjf dl/gmp-5.0.1.tar.bz2
tar: gmp-5.0.1/tune: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpf: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpbsd: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpq: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/demos: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/doc: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/printf: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/cxx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpz: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/scanf: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/cray: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/pyr: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/alpha: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/pa32: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/i960: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/pa64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/m68k: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/generic: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sparc32: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/thumb: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/a29k: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sparc64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/ia64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/lisp: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/s390: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/ns32k: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc32: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/minithres: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/m88k: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/mips32: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/vax: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/mips64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/arm: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/z8000x: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/clipper: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sh: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/power: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/z8000: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sh/sh2: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/m88k/mc88110: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/i486: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/k6: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/fat: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/pentium: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/pentium4: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/p6: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/k7: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/k7/mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/p6/p3mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/p6/sse2: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/p6/mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/pentium4/mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/pentium/mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/k6/k62mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86/k6/mmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc32/vmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc32/750: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64/mode64: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64/vmx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64/mode32: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64/mode64/p3: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64/mode64/p4: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/powerpc64/mode64/p5: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sparc64/ultrasparc34: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sparc32/v9: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sparc32/v8: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/sparc32/v8/supersparc: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/m68k/mc68020: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64/fat: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64/atom: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64/nano: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64/corei: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64/core2: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/x86_64/pentium4: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/pa32/hppa1_1: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/pa32/hppa1_1/pa7100: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/alpha/ev6: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/alpha/ev5: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/alpha/ev67: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/alpha/ev6/nails: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/cray/ieee: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/mpn/cray/cfp: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/demos/calc: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/demos/perl: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/demos/expr: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/mpbsd: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/mpz: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/mpn: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/cxx: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/mpf: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/misc: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/rand: Kann utime nicht ausführen: No such file or directory
tar: gmp-5.0.1/tests/mpq: Kann utime nicht ausführen: No such file or directory
tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
make: *** [source/target-mipsel_uClibc-0.9.29/gmp-5.0.1/.unpacked] Fehler 2
Ist das AVM WebIF bei euch auch so langsam?
vnstat zeigt die Werte richtig an. Habe so eben mit "vnstat -l -i <interface>", auf der Konsole getestet. Evtl. liegt es bei dir an der Konfiguration/Anwendung von vnstat.Ich habe eben übrigens gemerkt, dass die Werte, die mir "vnstat" anzeigt, nicht stimmen können. ...
installing mod base
installing libs
WARNING: Library libneon_WITH_SSL selected, but no files found
WARNING: Library libneon_WITH_ZLIB selected, but no files found
installing terminfos
replacing busybox
replacing busybox-16mb_26
installing symlinks
installing modules
generating modules.dep
unresolved symbol AtmUpdateVCIPAddr_ptr in file /lib/modules/2.6.19.2/kernel/fusiv_src/kernel/drivers/atm/atmdriver_lkm.ko
unresolved symbol AtmUpdateVCInterface_ptr in file /lib/modules/2.6.19.2/kernel/fusiv_src/kernel/drivers/atm/atmdriver_lkm.ko
unresolved symbol updateEncapsulation_ptr in file /lib/modules/2.6.19.2/kernel/fusiv_src/kernel/drivers/atm/atmdriver_lkm.ko
unresolved symbol getPhysicalIfName in file /lib/modules/2.6.19.2/kernel/fusiv_src/kernel/drivers/ap2ap/ap2ap_lkm.ko
installing packages
Wann Traffic bzw. welcher Traffic über welches Interface der Box geht, kannst Du mit dem BWM (siehe Patch in Anhang) feststellen. Evtl. muss das BWM-Paket für die 7390 angepasst werden.I..."eth0" ist als Interface doch richtig, oder?
Bandwidth Monitor 1.1.0
Iface RX(KB/sec) TX(KB/sec) Total(KB/sec)
cpmac0 0.000 0.000 0.000
lo 0.000 0.000 0.000
tiwlan0 0.026 0.631 0.657
tiwlan1 0.000 0.000 0.000
tiwlan2 0.000 0.000 0.000
tiwlan3 0.000 0.000 0.000
wdsup0 0.000 0.000 0.000
wdsdw0 0.000 0.000 0.000
wdsdw1 0.000 0.000 0.000
wdsdw2 0.000 0.000 0.000
wdsdw3 0.000 0.000 0.000
wan 0.000 0.000 0.000
eth0 0.000 0.000 0.000
lan 0.026 0.631 0.657
dsl 0.000 0.000 0.000
Total 716387433.715817736 4444390.715816730 720831824.1431633466
Hit CTRL-C to end this madness.
