freetz compilation error: /bin/bash: .static: Permission denied make: [dnsmasq-list]
zlotowinfo
5 Nov 2006
make
make: *** [dnsmasq-list] Error 1
Kernel Version 2.6.32-042stab055.10 (SMP)
Distro Name CentOS release 5.8 (Final)
You don't have the permission to access the .static file. This doesn't seem to be a Freetz issue. Fix your permissions.
Regards
Oliver
freetz cant be compiled on root
i created new user
i think problem is in freetz compilator
You are right. Freetz can not be compiled as root. But there is no problem in "freetz compilator" because this is working for many many users except you. ;-)
Please use the supported Virtual Box Image Freetz Linux 1.3 if you are not able to fix this problem by yourself.
Regards
Oliver
this image is unusable, dont know how change keyboard map
when press y=z, cant find : -/ its totally shit ;p
Look for howtos to change the keyboard layout on ubuntu systems. Or should someone google this shit for you?
You are not supposed to use the keyboard anyway, so the keyboard map should be no issue. The physical machine that I use for Freetz doesn't even have a keyboard attached.
Or you may try as a non-root user on your machine in an empty directory, with umask set to 022.
problem self resolve
when i connect as ssh, was normal keyboard
