Freetz 1.1.4 für 7570 (W920V)
mircsicz
1 Nov 2006
Hi Leute,
ich wollte gestern meine w920v mit ner 1.1.4 version flashen, denn ich möchte gerne dtmfbox als sip-registrar einsetzen. 1.2-preview hab ich schon drauf, aber da es mit dieser Version wohl prob's mit dtmfbox gibt...
leider bricht make mit folgendem Fehler ab:
make[3]: Betrete Verzeichnis '/home/mirco/Desktop/freetz-1.1.4/source/uClibc++-0.2.2/src/abi/libgcc_eh'
mipsel-linux-uclibc-ar x
mipsel-linux-uclibc-gcc: Success
make[3]: Betrete Verzeichnis '/home/mirco/Desktop/freetz-1.1.4/source/uClibc++-0.2.2/src/abi/libsupc'
Usage: mipsel-linux-uclibc-ar [emulation options] [-]{dmpqrstx}[abcfilNoPsSuvV] [member-name] [count] archive-file file...
       mipsel-linux-uclibc-ar -M [<mri-script]
 commands:
  d            - delete file(s) from the archive
  m[ab]        - move file(s) in the archive
  p            - print file(s) found in the archive
  q[f]         - quick append file(s) to the archive
  r[ab][f][u]  - replace existing or insert new file(s) into the archive
  t            - display contents of archive
  x[o]         - extract file(s) from the archive
 command specific modifiers:
  [a]          - put file(s) after [member-name]
  [b]          - put file(s) before [member-name] (same as [i])
  [N]          - use instance [count] of name
  [f]          - truncate inserted file names
  [P]          - use full path names when matching
  [o]          - preserve original dates
  [u]          - only replace files that are newer than current archive contents
 generic modifiers:
  [c]          - do not warn if the library had to be created
  [s]          - create an archive index (cf. ranlib)
  [S]          - do not build a symbol table
  [v]          - be verbose
  [V]          - display the version number
  @<file>      - read options from <file>
 emulation options:
  No emulation specific options
mipsel-linux-uclibc-ar: supported targets: elf32-tradlittlemips elf32-tradbigmips ecoff-littlemips ecoff-bigmips elf32-ntradlittlemips elf64-tradlittlemips elf32-ntradbigmips elf64-tradbigmips elf64-little elf64-big elf32-little elf32-big srec symbolsrec tekhex binary ihex
make[3]: *** [unwind-c.o] Fehler 1
make[3]: Verlasse Verzeichnis '/home/mirco/Desktop/freetz-1.1.4/source/uClibc++-0.2.2/src/abi/libgcc_eh'
make[2]: *** [libgcc_eh] Fehler 2
make[2]: *** Warte auf noch nicht beendete Prozesse...
 commands:
 generic modifiers:
  [v]          - be verbose
 emulation options:
make[3]: *** [libsupc] Fehler 1
make[3]: Verlasse Verzeichnis '/home/mirco/Desktop/freetz-1.1.4/source/uClibc++-0.2.2/src/abi/libsupc'
make[2]: *** [libsupc] Fehler 2
make[2]: Verlasse Verzeichnis '/home/mirco/Desktop/freetz-1.1.4/source/uClibc++-0.2.2/src'
make[1]: *** [all] Fehler 2
make[1]: Verlasse Verzeichnis '/home/mirco/Desktop/freetz-1.1.4/source/uClibc++-0.2.2'
make: *** [source/uClibc++-0.2.2/src/libuClibc++-0.2.2.so] Fehler 2
folgende .config soll gebaut werden:
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_7570_04_82=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5124 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
# FREETZ_TYPE_FON_WLAN_7170 is not set
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_FON_WLAN_7270_V3 is not set
FREETZ_TYPE_FON_WLAN_7570=y
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_WLAN_3270_V3 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_ALIEN_HARDWARE=y
# FREETZ_TYPE_SPEEDPORT_W701V_7170 is not set
# FREETZ_TYPE_SPEEDPORT_W900V_7170 is not set
FREETZ_TYPE_SPEEDPORT_W920V_7570=y
FREETZ_AVM_VERSION_STRING="7570_04.82"
# FREETZ_TYPE_LANG_DE is not set
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_STRING="7570"
FREETZ_TYPE_STRING2="W920V_"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_KERNEL_MTD_SIZE=246
FREETZ_HAS_PHONE=y
FREETZ_HAS_TAM=y
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
FREETZ_HAS_AVM_INETD=y
FREETZ_HAS_LIBSSL=y
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# Remove Brandings
# avm and tcom branding can't be removed
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_PATCH_ENUM is not set
# FREETZ_PATCH_SIGNED is not set
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
# FREETZ_AUTOMOUNT_EXT3 is not set
# FREETZ_AUTOMOUNT_NTFS is not set
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTORUN_AUTOEND is not set
FREETZ_PATCH_MAXDEVCOUNT=y
# FREETZ_PATCH_GETCONS is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_USERMAN is not set
FREETZ_REMOVE_FTPD=y
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_SMBD is not set
# FREETZ_REMOVE_AVM_VPN is not set
# FREETZ_REMOVE_DSLD is not set
FREETZ_REMOVE_CAPIOVERTCP=y
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# FREETZ_REMOVE_WLAN is not set
# Package selection
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
FREETZ_PACKAGE_CALLMONITOR=y
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
FREETZ_PACKAGE_DNSMASQ=y
FREETZ_PACKAGE_DROPBEAR=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB=y
FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER=y
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC=y
# FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC is not set
# Misc
FREETZ_PACKAGE_DTMFBOX_SVN=y
FREETZ_PACKAGE_DTMFBOX_SVN_FORCE_LATEST_REV=y
FREETZ_PACKAGE_DTMFBOX_USE_DIFF_PATCH=y
FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE=y
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
# FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FUSE is not set
FREETZ_PACKAGE_INETD=y
FREETZ_PACKAGE_KNOCK=y
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
FREETZ_PACKAGE_NANO=y
# Nano additional features
FREETZ_NANO_TINY=y
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
FREETZ_PACKAGE_OPENVPN=y
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
# FREETZ_PACKAGE_OPENVPN_WITH_MGMNT is not set
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
FREETZ_PACKAGE_RCAPID=y
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
FREETZ_PACKAGE_RRDSTATS=y
FREETZ_PACKAGE_SPINDOWN_CGI=y
FREETZ_PACKAGE_SG3UTILS=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_PACKAGE_VIRTUALIP_CGI=y
FREETZ_PACKAGE_WOL_CGI=y
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_GROUP_APACHE_PHP is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_OBEXFTP is not set
FREETZ_PACKAGE_OPENSSH=y
# FREETZ_PACKAGE_OPENSSH_STATIC is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_QUAGGA is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
FREETZ_PACKAGE_WGET=y
# FREETZ_WGET_WITH_SSL is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
FREETZ_SHOW_UNSTABLE_PACKAGES=y
# Unstable
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_IPTABLES is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_USBIP is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7570/x_misc/opensrc"
FREETZ_DL_KERNEL_SOURCE="fritzbox7570-source-files-04.78-82.tar.gz"
FREETZ_DL_KERNEL_SOURCE_MD5="d5f0320bbc4c86a79870ed87ef3650e4"
FREETZ_DL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7570/firmware/english"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7570_vDSL.en-de-fr.75.04.82.image"
FREETZ_DL_SOURCE_MD5="6cfef46ebae2c6d173e266d8f75b72f7"
FREETZ_DL_SITE2="http://hilfe.telekom.de/dlp/eki/downloads/Speedport/Speedport%20W%20920V/"
FREETZ_DL_SOURCE2="Speedport_W_920V.AnnexB.65.04.78.image"
FREETZ_DL_SOURCE2_MD5="829972b62ae54bd4e526fe727c5c460b"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=0
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
# FREETZ_SUBVERSION_STRING is not set
# FREETZ_STATUS_STYLE is not set
# External
# EXTERNAL_ENABLED is not set
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
FREETZ_BUSYBOX_DIFF=y
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_IP is not set
FREETZ_BUSYBOX_PATCH=y
FREETZ_BUSYBOX_START_STOP_DAEMON=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_MDEV_RENAME is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Kernel modules
# FREETZ_MODULES_ALL is not set
# crypto
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_blkcipher is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_musb_hdrc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext3 is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_fat is not set
FREETZ_MODULE_fuse=y
# FREETZ_MODULE_jbd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
# FREETZ_LIB_libavmhmac is not set
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Graphics & fonts
FREETZ_LIB_libfreetype=y
FREETZ_LIB_libart_lgpl_2=y
# FREETZ_LIB_libjpeg is not set
FREETZ_LIB_libpng12=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# FREETZ_LIB_libuClibc__ is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libglib_1 is not set
# GLib2
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# ncurses
FREETZ_LIB_libncurses=y
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_SHARE_terminfo=y
# FREETZ_SHARE_terminfo_showall is not set
FREETZ_SHARE_terminfo_ansi=y
FREETZ_SHARE_terminfo_gnome=y
FREETZ_SHARE_terminfo_konsole=y
FREETZ_SHARE_terminfo_linux=y
FREETZ_SHARE_terminfo_putty=y
FREETZ_SHARE_terminfo_rxvt=y
FREETZ_SHARE_terminfo_screen=y
FREETZ_SHARE_terminfo_screenMINUSw=y
FREETZ_SHARE_terminfo_sun=y
FREETZ_SHARE_terminfo_vt100=y
FREETZ_SHARE_terminfo_vt102=y
FREETZ_SHARE_terminfo_vt102MINUSnsgr=y
FREETZ_SHARE_terminfo_vt102MINUSw=y
FREETZ_SHARE_terminfo_vt200=y
FREETZ_SHARE_terminfo_vt220=y
FREETZ_SHARE_terminfo_vt52=y
FREETZ_SHARE_terminfo_xterm=y
FREETZ_SHARE_terminfo_xtermMINUScolor=y
FREETZ_SHARE_terminfo_xtermMINUSxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
FREETZ_LIB_libcapi20=y
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
FREETZ_LIB_libpcap=y
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
# Compiler options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
# FREETZ_KERNEL_VERSION_2_6_13_1 is not set
FREETZ_KERNEL_VERSION_2_6_19_2=y
FREETZ_KERNEL_VERSION="2.6.19.2"
# FREETZ_TARGET_UCLIBC_VERSION_0_9_28 is not set
FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.29"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
Ich hoffe Ihr könnt mir helfen, würde mich nämlich sehr gerne über's WE dem Setup meines * widmen. Und das sollte dann nächste Woche auch laufen, denn meine Freundin arbeitet von zu Hause aus ...
Greetz
Mircsicz
Da stimmt was mit deiner Toolchain nicht. Kannst du bitte nochmal von vorne anfangen.
Nimm am besten den stable branch 1.1 aus dem svn und nicht das 1.1.4 Release.
Oliver
Danke Oliver,
ich werde dann heute Abend mal nen svn checkout machen und schauen ob das baut...
meinst Du mit von vorne dass ich auch die .config nochmal neu erstellen soll?
Greetz
Mircsicz
