FreePBX Module
RayMan1987
28 Feb 2008
Moin,
wie kann ich Module für FreePBX installieren?? Habe mit jetzt welche runtergeladen (ich hoffe richtige), aber kann sie nicht installieren. Ich habe die Files gedownloaded von :
http://rapid.sunsite.dk/rapid/pool/main/f/freepbx-module-conferences/
Asterisk Version: 1.4.18
FreePBX Version: 2.4.0.0
Wenn ich das .tar.gz File runterlade und dann auf Upload gehe in FreePBX bekomme ich folgendes:
The following error(s) occured processing the uploaded file:
    * Filename not in correct format: must be modulename-version.tar.gz (eg. custommodule-0.1.tar.gz)
You should fix the problem or select another file and try again.
Also dachte ich mir, pass ich den blöden Namen doch an, gesagt getan, dann kommt aber der Fehler:
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/i18n/
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/i18n/he_IL/
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/i18n/he_IL/LC_MESSAGES/
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/i18n/he_IL/LC_MESSAGES/conferences.mo
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/i18n/he_IL/LC_MESSAGES/conferences.po
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/prerm
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/copyright
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/dirs
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/install
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/rules
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/compat
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/control
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/postinst
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/debian/changelog
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/module.xml
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/page.conferences.php
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/uninstall.sql
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/functions.inc.php
    * File extracting to invalid location: freepbx-module-conferences-2.2-1.2.1/install.sql
Langsam habe ich keine Idee mehr, kann mir dabei jemand helfen??
Mfg Nico
Warum machst Du es nicht einfach über das Webinterface?
jo
Danke schonmal für die Antwort...
Erstmal wissen wie...wenn ich in die Modul Administration gehe, sehe ich nur die lokal installierten Module und oben hab ich dann die Auswahl "Upload Module", wo ich aber die beschriebenen Probleme habe.
Und wenn ich oben "Check for Updates Online" wähle, bekomm ich folgendes:
Warning: Cannot connect to online repository (mirror.freepbx.org). Online modules are not available.
Ich glaube auch nicht das mir das viel bringen wird, da ich das FreePBX ja gerade vor 2 Tagen erst installiert habe.
Hm keiner mehr eine Idee dazu??
Da ich es grade hatte:
Lösung:
1.Modul runterladen.
2.endung von gz in tgz ändern.
3. unter Module Admin hochladen.
soundworx
