Es gibt eine neue Firmware fuer die Fritzbox Fon 5050, yippie. Nur leider mag der ds-mod noch nicht.
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking hidden squashfs
Major/Minor mismatch, filesystem on build/original/kernel/kernelsquashfs.raw is (2:76)
I only support Squashfs 3.0 filesystems! Later releases will support older Squashfs filesystems
unpacking filesystem image
Major/Minor mismatch, filesystem on build/original/firmware/var/tmp/filesystem.image is (2:76)
chmod: cannot access `build/original/filesystem': No such file or directory
ERROR: could not unpack the filesystem image
make: *** [firmware] Error 1
Gibts da schon eine Loesung fuer?
STEP 1: UNPACK
