nach eurem "Update", geht bei mir nix mehr. Alle Telefone sind besetzt.
bei meinem Versuch von der 12 auf die 100 intern anzurufen, kommt das (im Log):
-- Executing Macro("SIP/12-c4c5", "exten-vm|novm|100") in new stack
-- Executing Macro("SIP/12-c4c5", "user-callerid") in new stack
-- Executing DBget("SIP/12-c4c5", "AMPUSER=DEVICE/12/user") in new stack
-- DBget: varname=AMPUSER, family=DEVICE, key=12/user
-- DBget: set variable AMPUSER to 12
-- Executing DBget("SIP/12-c4c5", "AMPUSERCIDNAME=AMPUSER/12/cidname") in new stack
-- DBget: varname=AMPUSERCIDNAME, family=AMPUSER, key=12/cidname
-- DBget: set variable AMPUSERCIDNAME to Rene Ettling
-- Executing GotoIf("SIP/12-c4c5", "0?5") in new stack
-- Executing SetCallerID("SIP/12-c4c5", ""Rene Ettling" <12>") in new stack
-- Executing NoOp("SIP/12-c4c5", "Using CallerID "Rene Ettling" <12>") in new stack
-- Executing SetVar("SIP/12-c4c5", "FROMCONTEXT=exten-vm") in new stack
-- Executing Macro("SIP/12-c4c5", "record-enable|100|IN") in new stack
-- Executing GotoIf("SIP/12-c4c5", "0 > 0?2:4") in new stack
-- Goto (macro-record-enable,s,4)
-- Executing AGI("SIP/12-c4c5", "recordingcheck|20060118-170709|asterisk-2673-1137600428.21") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
recordingcheck|20060118-170709|asterisk-2673-1137600428.21: Inbound recording not enabled
-- AGI Script recordingcheck completed, returning 0
-- Executing NoOp("SIP/12-c4c5", "No recording needed") in new stack
-- Executing Macro("SIP/12-c4c5", "dial|15|tr|100") in new stack
-- Executing GotoIf("SIP/12-c4c5", "0?4:2") in new stack
-- Goto (macro-dial,s,2)
-- Executing GotoIf("SIP/12-c4c5", "0?5:4") in new stack
-- Goto (macro-dial,s,4)
-- Executing AGI("SIP/12-c4c5", "dialparties.agi") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
-- AGI Script dialparties.agi completed, returning 0
-- Executing NoOp("SIP/12-c4c5", "Returned from dialparties with no extensions to call") in new stack
-- Executing SetVar("SIP/12-c4c5", "DIALSTATUS=BUSY") in new stack
-- Executing GotoIf("SIP/12-c4c5", "0?s-BUSY|1") in new stack
-- Executing GotoIf("SIP/12-c4c5", "1?s-BUSY|1") in new stack
-- Goto (macro-exten-vm,s-BUSY,1)
-- Executing NoOp("SIP/12-c4c5", "Extension is reporting BUSY and has no Voicemail") in new stack
-- Executing Busy("SIP/12-c4c5", "") in new stack
== Spawn extension (macro-exten-vm, s-BUSY, 2) exited non-zero on 'SIP/12-c4c5' in macro 'exten-vm'
== Spawn extension (from-internal, 100, 1) exited non-zero on 'SIP/12-c4c5'
-- Executing Macro("SIP/12-c4c5", "hangupcall") in new stack
-- Executing ResetCDR("SIP/12-c4c5", "w") in new stack
-- Executing NoCDR("SIP/12-c4c5", "") in new stack
-- Executing Wait("SIP/12-c4c5", "5") in new stack
== Spawn extension (macro-hangupcall, s, 3) exited non-zero on 'SIP/12-c4c5' in macro 'hangupcall'
== Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/12-c4c5'
Rene
