Hallo Zusammen,
ich betreibe auf meinen Asterisk fail2ban.
Ich habe vermehrt verschiedene Login Versuche von Hackern.
Bei folgendem Angriff wird die IP Adresse geblockt und ich bekomme eine E-Mail.
Bei folgenden Zeilen passiert leider gar nichts
Meine asterisk.conf sieht so aus
Hat jemand eine Idee
[2017-02-28 13:59:38] NOTICE[1417]: chan_sip.c:28485 handle_request_register: Registration from '<sip:[email protected]>' failed for '80.137.87.271:5060' - Wrong password
[2017-02-28 14:04:45] NOTICE[1417][C-00000016]: chan_sip.c:26165 handle_request_invite: Failed to authenticate from 89.163.146.59:5073 device 120<sip:[email protected]>;tag=c8ac6676
[2017-02-28 14:10:43] NOTICE[1417][C-0000001e]: chan_sip.c:26165 handle_request_invite: Failed to authenticate from 89.163.146.59:5105 device 104<sip:[email protected]>;tag=f129f0e6
[2017-02-28 14:07:45] NOTICE[1417][C-0000001a]: chan_sip.c:26165 handle_request_invite: Failed to authenticate from 89.163.146.59:5089 device 305<sip:[email protected]>;tag=b70a8b36
# Fail2Ban configuration.#
[INCLUDES]
# Read common prefixes. If any customizations available -- read them from
# common.local
#before = common.conf
[Definition]
#_daemon = asterisk
# Option: failregex
# Notes.: regex to match the password failures messages in the logfile. The
# host must be matched by a group named "host". The tag "<HOST>" can
# be used for standard IP/hostname matching and is only an alias for
# (?:::f{4,6}:)?(?P<host>\S+)
# Values: TEXT
failregex = NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Wrong password
NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - No matching peer found
NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Username/auth name mismatch
NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Device does not match ACL
NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - Peer is not supposed to register
NOTICE.* .*: Registration from '.*' failed for '<HOST>:.*' - ACL error (permit/deny)
NOTICE.* .*: Registration from '".*".*' failed for '<HOST>:.*' - No matching peer found
NOTICE.* .*: Registration from '".*".*' failed for '<HOST>:.*' - Wrong password
NOTICE.* <HOST> failed to authenticate as '.*'$
NOTICE.* .*: No registration for peer '.*' \(from <HOST>\)
NOTICE.* .*: Host <HOST> failed MD5 authentication for '.*' (.*)
NOTICE.* .*: Failed to authenticate user .*@<HOST>.*
NOTICE.* .*: <HOST> failed to authenticate as '.*'
NOTICE.* .*: <HOST> tried to authenticate with nonexistent user '.*'
VERBOSE.*SIP/<HOST>-.*Received incoming SIP connection from unknown peer
# Option: ignoreregex
# Notes.: regex to ignore. If this regex matches, the line is ignored.
# Values: TEXT
ignoreregex =
