Linux version 2.6.19.2 (2328) (gcc version 3.4.6) #1 Wed Jul 15 15:58:33 CEST 2009
cpu-probe: Manufacturer MIPS
mips-config1: JTAG pressent
mips-config1: TLB size 16
mips-config3: Vectored interrupts implmented
CPU revision is: 00019068
[mips_clock] default 360000000 MHz
[ur8_clk_set_emif] SDRAM Refresh 0x3a8 Timing 0x2214717 Bank 0x21 Async 0xc42c301
[ur8_pci_init]
[pci] default: 33 MHz
[setup_pci_master]
[setup_pci_slave]
Exposing 67108864 memory over PCI
Setup Complete, Enabling PCI Interface
PCI Interface Running
PCI controller initialized
[ur8_vbus_set_prio] instance vbus_nwss_dma level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_sar_pdsp level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_buffer_manager level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_usb level 5 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_vlynq level 7 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_pci level 5 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_c55 level 3 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_tdm level 0 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_mips level 3 escalator disabled (count 255, floor 7)
Determined physical RAM map:
memory: 03fc0000 @ 14000000 (usable)
memory: 00040000 @ 17fc0000 (reserved)
[init_bootmem]
[free_bootmem]
[reserve_bootmem]
On node 0 totalpages: 98240
[mem_map-hack]: reduce size from 3145728 524288 Bytes
[mem_map-hack]: move map base from 0x94328000 to 0x940a8000
DMA zone: 767 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 97473 pages, LIFO batch:31
Normal zone: 0 pages used for memmap
[request_resource] Kernel code: start 0x14000000 < root->start 0x17fc0000
[request_resource] Kernel data: start 0x14207790 < root->start 0x17fc0000
Built 1 zonelists. Total pages: 97473
Kernel command line: console=ttyS0,38400n8r
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
CPU frequency 360.00 MHz
Using 180.000 MHz high precision timer.
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[free_all_bootmem]
Memory: 61056k/65280k available (2077k kernel code, 4136k reserved, 642k data, 140k init, 0k highmem)
Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
[ur8_mtd_init]
[ur8_mtd_init] flashsize = 0x01000000 Byte 16 MBytes
[ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
[ur8_mtd_init] mtd[1] = 0x90020000,0x90F80000
[ur8_mtd_init] mtd[2] = 0x90000000,0x90020000
[ur8_mtd_init] mtd[3] = 0x90F80000,0x90FC0000
[ur8_mtd_init] mtd[4] = 0x90FC0000,0x91000000
[ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
Master and Slave Enabled
pktsched: using high resolution timer
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
squashfs: version 3.2 (2007/01/02) Phillip Lougher
Installing knfsd (copyright (C) 1996 [email protected]).
fuse init (API version 7.8)
io scheduler noop registered (default)
avm_net_trace: Up and running.
[avm] configured: watchdog event debug enable direct gpio
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jul 15 2009 15:56:06)
Serial: 8250/16550 driver $Revision: 1.3 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 15) is a UR8_UART
[cpmac] Version: URL: svn://EmbeddedVM/home/SVN/drivers/cpmac/tags/1.110-r820-trunk-VLAN_Fix_ADM_und_Tantos - Revision 538:821 - Mi 15. Jul 15:57:
16 CEST 2009
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
physmap platform flash device: 01000001 at 10000000
physmap-flash.1: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
physmap-flash.1: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
RedBoot partition parsing not available
[ur8_jffs2_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f6243c
[ur8_jffs2_parser_function] try partition kernel (offset 0x20000 len 16121856)
[ur8_jffs2_parser_function] magic 20031985 found @pos 0x840000, size 7602176
[ur8_squashfs_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f6243c
[ur8_squashfs_parser_function] *p_mtd_pat->name filesystem
[ur8_squashfs_parser_function] try partition kernel (offset 0x20000 len 16121856 blocksize=20000)
[ur8_squashfs_parser_function] magic found @pos 0x103200
6 find_squashfs partitions found on MTD device physmap-flash.1
Creating 6 MTD partitions on "physmap-flash.1":
0x00103200-0x00f80000 : "rootfs"
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
[ur8_mtd_add_notifier] name rootfs
[ur8_mtd_add_notifier] use rootfs
[ur8_mtd_add_notifier] root device: /dev/mtdblock0 (rootfs)
0x00020000-0x00103200 : "kernel"
mtd: partition "kernel" doesn't end on an erase block -- force read-only
[ur8_mtd_add_notifier] name kernel
[ur8_mtd_add_notifier] skip kernel
0x00000000-0x00020000 : "urlader"
[ur8_mtd_add_notifier] name urlader
[ur8_mtd_add_notifier] skip urlader
0x00f80000-0x00fc0000 : "tffs (1)"
[ur8_mtd_add_notifier] name tffs (1)
[ur8_mtd_add_notifier] skip tffs (1)
0x00fc0000-0x01000000 : "tffs (2)"
[ur8_mtd_add_notifier] name tffs (2)
[ur8_mtd_add_notifier] skip tffs (2)
0x00840000-0x00f80000 : "jffs2"
[ur8_mtd_add_notifier] name jffs2
[ur8_mtd_add_notifier] skip jffs2
Generic platform RAM MTD, (c) 2004 Simtec Electronics
mtd-ram mtd-ram.2: no memory resource specified
[ur8_ram_mtd_set_rw] PLATRAM_RO
mtd-ram: probe of mtd-ram.2 failed with error -2
CAPI Subsystem Rev 1.1.2.8
TCP cubic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
MUSB UR8 pdev active!
PCI_STATUS_SET: 40000
PCI_STATUS_CLR: 40000
PCI_HOST_INT_EN: 0
PCI_HOST_INT_CLR: 0
PCI_BE_INT_En: 0
PCI_BE_INT_CLR: 0
[pci_int_init] done
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
Time: MIPS clocksource has been installed.
mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
[avm_new] push_button_gpio=25 value=0 enabled
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 140k freed
AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
TFFS Name Table F
led_modul_Fritz_Box_3270: module license '
(C) Copyright 2008 by AVM
' taintskernel.
[led_gpio_bit_driver_init] gpio 1 name power
[led_gpio_bit_driver_init] gpio 9 name lan_all
[led_gpio_bit_driver_init] gpio 27 name wlan
[led_gpio_bit_driver_init] gpio 28 name pppoe
[led_gpio_bit_driver_init] gpio 17 name dual1
[led_gpio_bit_driver_init] gpio 35 name dual2
[BUTTON] no buttons defined - disable new button controls
[LED] "wyatt_earp_turn_off_leds" (0x00000000) not loaded
JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
[avm_debug]redirect kernel-messages (/dev/debug)
[avm_debug]standard kernel-messages
mcfw: group 0.0.0.0: query ath0:0 10sec
mcfw: group 0.0.0.0: query cpmac:0,1,2,3 10sec
