[Frage] [English] Willy.tel VoIP with Gigaset Hub
agneum
29 Aug 2019
Hey,
Asking in this forum to see if anyone is familiar with with Willy.tel's VoIP service and third party equipment from Gigaset. From willy.tel we have:
SIP-Benutzername, SIP-Passwort, SIP-Registrar, and SIP-Proxy
Unfortunately we cannot use the Fritzbox provided as we have our own router/firewall running pfsense. My thought was to get a Gigaset N510 IP Pro, forward SIP ports in the router and plug the SIP settings to the Gigaset.
Has anyone here tested Gigaset hardware with Willytel with success?
You are free to use every STUN Server you find/want/trust ;)
Examples: stun.ekiga.net or stun.1und1.de ...
Standard port: 3478
No outboundproxy until someone tell something different ;)
PDF ( for Router )
The big difference is - Router makes a NAT and is not in the NAT
LAN clients like an VoIP phone are inside a NAT
... and STUN means:
1. making a connection from inside to outside
( public ip/portnumber in SIP/RTP )
2. hold it open
3. use it for outgoing and incoming signaling
...normaly a firewall allow this ;)
EDIT: Registration Server == SIP Registrar
...not the proxy.
