Hallo Zusammen,
beim Image erstellen kommen bei mir folgende errors:
Trotzdem ist irgendwie ein Kernelimage rausgekommen:
Ist das normal? Ich befürchte nicht und trau mich von daher aktuell nicht, das image auf meinen Speedport zu schieben..
Linux Version ist Ubuntu Karmic (9.10) unter Virtualbox.
gruesse..
ERROR: ld.so: object 'libfakeroot.so' from LD_PRELOAD cannot be preloaded: ignored.
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/run/.dummy': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/run': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/lock/.dummy': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/lock': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp/nohup.out': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp/group': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp/hosts': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp/shadow': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp/resolv.conf': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp/passwd': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tmp': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/log/.dummy': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/log': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/tam': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/post_install': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/rpc/.dummy': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var/rpc': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar/var': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/var.tar': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/nohup.out': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/avm_net_trace21': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/avm_net_trace138': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/urandom': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/sdl5': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/sde5': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/sdf7': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/sdg8': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/sdl3': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/sdg11': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/mem': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/avm_net_trace12': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/avm_power': Operation not permitted
chown: changing ownership of `/home/bastian/speed-to-fritz/FBDIR/squashfs-root/dev/kdsld': Operation not permitted
ERROR OCCURED !!! - Push 'Q' to get back.
bastian@bastian-desktop:~/speed-to-fritz/Firmware.new$ ls -al
total 20
drwxr-xr-x 2 bastian bastian 4096 2010-01-06 16:44 .
drwxr-xr-x 16 bastian bastian 16384 2010-01-06 16:49 ..
-rw-r--r-- 1 bastian bastian 8437760 2010-01-06 16:44 fw_C_Speedport_721_64.04.74-0_Fritz_Box_SpeedportW721V_29.04.76-0-sp2fr-10.01.06-r-751M-847_OEM-tcom_annexB_de.image
-rwxrwxrwx 1 bastian bastian 7658504 2010-01-06 16:44 kernel.image
gruesse..
