echo problems.
alanbridgestone
1 Jul 2007
Sorry for not writing in English but...
I am trying to understand what options are available to enable echo suppression in Asterisk in fritz.. At the moment if a client is connecting to Fritz with Asterisk 1.2.19 on board from a remote location I am getting lots of echo.
What options are available to reduce echo for an external caller .., ping time between the 2 networks is 53 ms, so it cannot be latency...
Thanks for sharing your ideas.
Alan
Hello Alan,
do the external caller come from PSTN or from Internet?
My callers will all come from ISDN. I have in my capi.conf:
[general]
;rxgain=1.0 ;original ;linear receive gain (1.0 = no change)
;txgain=1.0 ;original ;linear transmit gain (1.0 = no change)
;rxgain=1.5
;txgain=1.5
rxgain=0.8 ;test hall
txgain=0.8 ;test hall
So you can test with r/txgain with that.
But as i understand you have no provider and your friend is calling you via internet directly?
br
waldoo
Please also have a look to this link: http://www.voipuser.org/forum_topic_5099.html and check which codecs you are using
