Echo im Festnetz
nroej
20 Sep 2004
Hallo zusammen!
Ich habe hier ein Asterisk der sich auf Sipgate anmeldet, soweit klappt auch alles, allerdings haben die Anrufer (bisher nur aus dem Festnetz getestet) ein ziemlich fieses Echo.
Als Client am Asterisk benutze ich Kphone 4.0.3.
Grüße,
Jörn
zapata.conf, sip.conf?
Raffi
sip.conf
[general]
echocancel=yes
port = 1337
bindaddr = 0.0.0.0
externip = 62.143.129.10
Localnet = 192.168.0.0/255.255.255.0
srvlookup = yes
context = default
disallow=all
allow=gsm
register => user:[email protected]/user
canreinvite=no
tos=0x18
insecure=very
nat=yes
dtmfmode=info
qualify=yes
[sipgate]
type=friend
username=user
secret=pass
host=sipgate.de
fromuser=user
fromdomain=sipgate.de
context=default
canreinvite=no
disallow=all
allow=ulaw
allow=alaw
allow=gsm
insecure=very
qualify=yes
nat=never
dtmfmode=info
tos=0x18
[1234]
type=friend
username=1234
secret=geheim
host=dynamic
disallow=all
allow=ulaw
allow=alaw
dtmfmode=rfc2833
context=sipgate
dtmfmode=info
zapata.conf habe ich nicht verändert
; Zapata telephony interface
; Configuration file
[trunkgroups]
; Trunk groups are used for NFAS or GR-303 connections.
; Group: Defines a trunk group.
;        group => <trunkgroup>,<dchannel>[,<backup1>...]
;        trunkgroup  is the numerical trunk group to create
;        dchannel    is the zap channel which will have the
;                    d-channel for the trunk.
;        backup1     is an optional list of backup d-channels.
;trunkgroup => 1,24,48
; Spanmap: Associates a span with a trunk group
;        spanmap => <zapspan>,<trunkgroup>[,<logicalspan>]
;        zapspan     is the zap span number to associate
;        trunkgroup  is the trunkgroup (specified above) for the mapping
;        logicalspan is the logical span number within the trunk group to use.
;                    if unspecified, no logical span number is used.
;spanmap => 1,1,1
;spanmap => 2,1,2
;spanmap => 3,1,3
;spanmap => 4,1,4
[channels]
; Default language
;language=en
; Default context
context=default
; Switchtype:  Only used for PRI.
; national:       National ISDN 2 (default)
; dms100:         Nortel DMS100
; 4ess:           AT&T 4ESS
; 5ess:           Lucent 5ESS
; euroisdn:       EuroISDN
; ni1:            Old National ISDN 1
switchtype=national
; Some switches (AT&T especially) require network specific facility IE
; supported values are currently 'none', 'sdn', 'megacom', 'accunet'
;nsf=none
; PRI Dialplan:  Only RARELY used for PRI.
; unknown:        Unknown
; private:        Private ISDN
; local:          Local ISDN
; international:  International ISDN
;pridialplan=national
; PRI Local Dialplan:  Only RARELY used for PRI (sets the calling number's numbering plan)
; unknown:        Unknown
; local:          Local ISDN
;prilocaldialplan=national
; Overlap dialing mode (sending overlap digits)
;overlapdial=yes
; Signalling method (default is fxs).  Valid values:
; em:      E & M
; em_w:    E & M Wink
; featd:   Feature Group D (The fake, Adtran style, DTMF)
; featdmf: Feature Group D (The real thing, MF (domestic, US))
; featb:   Feature Group B (MF (domestic, US))
; fxs_ls:  FXS (Loop Start)
; fxs_gs:  FXS (Ground Start)
; fxs_ks:  FXS (Kewl Start)
; fxo_ls:  FXO (Loop Start)
; fxo_gs:  FXO (Ground Start)
; fxo_ks:  FXO (Kewl Start)
; pri_cpe: PRI signalling, CPE side
; pri_net: PRI signalling, Network side
; gr303fxoks_net: GR-303 Signalling, FXO Loopstart, Network side
; gr303fxsks_cpe: GR-303 Signalling, FXS Loopstart, CPE side
; sf:         SF (Inband Tone) Signalling
; sf_w:       SF Wink
; sf_featd:   SF Feature Group D (The fake, Adtran style, DTMF)
; sf_featdmf: SF Feature Group D (The real thing, MF (domestic, US))
; sf_featb:   SF Feature Group B (MF (domestic, US))
; The following are used for Radio interfaces:
; fxs_rx:  Receive audio/COR on an FXS kewlstart interface (FXO at the channel bank)
; fxs_tx:  Transmit audio/PTT on an FXS loopstart interface (FXO at the channel bank)
; fxo_rx:  Receive audio/COR on an FXO loopstart interface (FXS at the channel bank)
; fxo_tx:  Transmit audio/PTT on an FXO groundstart interface (FXS at the channel bank)
; em_rx:   Receive audio/COR on an E&M interface (1-way)
; em_tx:   Transmit audio/PTT on an E&M interface (1-way)
; em_txrx: Receive audio/COR AND Transmit audio/PTT on an E&M interface (2-way)
; em_rxtx: same as em_txrx (for our dyslexic friends)
; sf_rx:   Receive audio/COR on an SF interface (1-way)
; sf_tx:   Transmit audio/PTT on an SF interface (1-way)
; sf_txrx: Receive audio/COR AND Transmit audio/PTT on an SF interface (2-way)
; sf_rxtx: same as sf_txrx (for our dyslexic friends)
signalling=fxo_ls
; A variety of timing parameters can be specified as well
; Including:
;    prewink:     Pre-wink time (default 50ms)
;    preflash:    Pre-flash time (default 50ms)
;    wink:        Wink time (default 150ms)
;    flash:       Flash time (default 750ms)
;    start:       Start time (default 1500ms)
;    rxwink:      Receiver wink time (default 300ms)
;    rxflash:     Receiver flashtime (default 1250ms)
;    debounce:    Debounce timing (default 600ms)
rxwink=300              ; Atlas seems to use long (250ms) winks
; Whether or not to do distinctive ring detection on FXO lines
;usedistinctiveringdetection=yes
; Whether or not to use caller ID
usecallerid=yes
; Whether or not to hide outgoing caller ID (Override with *67 or *82)
hidecallerid=no
; Whether or not to enable call waiting on FXO lines
callwaiting=yes
; Whether or not restrict outgoing caller ID (will be sent as ANI only, not available for the user)
; Mostly use with FXS ports
;restrictcid=no
; Whether or not use the caller ID presentation for the outgoing call that the calling switch is sending
usecallingpres=yes
; Support Caller*ID on Call Waiting
callwaitingcallerid=yes
; Support three-way calling
threewaycalling=yes
; Support flash-hook call transfer (requires three way calling)
transfer=yes
; Support call forward variable
cancallforward=yes
; Whether or not to support Call Return (*69)
callreturn=yes
; Stutter dialtone support: If a mailbox is specified without a voicemail
; context, then when voicemail is received in a mailbox in the default
; voicemail context in voicemail.conf, taking the phone off hook will
; cause a stutter dialtone instead of a normal one.
; If a mailbox is specified *with* a voicemail context, the same will
; result if voicemail recieved in mailbox in the specified voicemail
; context
; for default voicemail context, the example below is fine:
;mailbox=1234
; for any other voicemail context, the following will produce the
; stutter tone:
;mailbox=1234@context
; Enable echo cancellation
; Use either "yes", "no", or a power of two from 32 to 256 if you wish
; to actually set the number of taps of cancellation.
echocancel=yes
; Generally, it is not necessary (and in fact undesirable) to echo cancel
; when the circuit path is entirely TDM.  You may, however, reverse this
; behavior by enabling the echo cancel during pure TDM bridging below.
echocancelwhenbridged=yes
; In some cases, the echo canceller doesn't train quickly enough and there
; is echo at the beginning of the call.  Enabling echo training will cause
; asterisk to briefly mute the channel, send an impulse, and use the impulse
; response to pre-train the echo canceller so it can start out with a much
; closer idea of the actual echo.  Value may be "yes", "no", or a number of
; milliseconds to delay before training (default = 400)
;echotraining=yes
;echotraining=800
; If you are having trouble with DTMF detection, you can relax the
; DTMF detection parameters.  Relaxing them may make the DTMF detector
; more likely to have "talkoff" where DTMF is detected when it
; shouldn't be.
;relaxdtmf=yes
; You may also set the default receive and transmit gains (in dB)
rxgain=0.0
txgain=0.0
; Logical groups can be assigned to allow outgoing rollover.  Groups
; range from 0 to 31, and multiple groups can be specified.
group=1
; Ring groups (a.k.a. call groups) and pickup groups.  If a phone is ringing
; and it is a member of a group which is one of your pickup groups, then
; you can answer it by picking up and dialing *8#.  For simple offices, just
; make these both the same
callgroup=1
pickupgroup=1
; Specify whether the channel should be answered immediately or
; if the simple switch should provide dialtone, read digits, etc.
immediate=no
; CallerID can be set to "asreceived" or a specific number
; if you want to override it.  Note that "asreceived" only
; applies to trunk interfaces.
;callerid=2564286000
; AMA flags affects the recording of Call Detail Records.  If specified
; it may be 'default', 'omit', 'billing', or 'documentation'.
;amaflags=default
; Channels may be associated with an account code to ease
; billing
;accountcode=lss0101
; ADSI (Analog Display Services Interface) can be enabled on a per-channel
; basis if you have (or may have) ADSI compatible CPE equipment
;adsi=yes
; On trunk interfaces (FXS) and E&M interfaces (E&M, Wink, Feature Group D
; etc, it can be useful to perform busy detection either in an effort to
; detect hangup or for detecting busies
;busydetect=yes
; If busydetect is enabled, is also possible to specify how many
; busy tones to wait before hanging up. The default is 4, but
; better results can be achieved if set to 6 or even 8. Mind that
; higher the number, more time is needed to hangup a channel, but
; lower is probability to get random hangups
;busycount=4
; On trunk interfaces (FXS) it can be useful to attempt to follow the progress
; of a call through RINGING, BUSY, and ANSWERING.   If turned on, call
; progress attempts to determine answer, busy, and ringing on phone lines.
; This feature is HIGHLY EXPERIMENTAL and can easily detect false answers,
; so don't count on it being very accurate.
; Few zones are supported at the time of this writing, but may
; be selected with "progzone"
; This feature can also easily detect false hangups. The symptoms of this
; is being disconnected in the middle of a call for no reason.
;callprogress=yes
;progzone=us
; For fax detection, uncomment one of the following lines.  The default is *OFF*
;faxdetect=both
;faxdetect=incoming
;faxdetect=outgoing
;faxdetect=no
; Select which class of music to use for music on hold.  If not specified
; then the default will be used.
;musiconhold=default
; PRI channels can have an idle extension and a minunused number.  So long
; as at least "minunused" channels are idle, chan_zap will try to call
; "idledial" on them, and then dump them into the PBX in the "idleext"
; extension (which is of the form exten@context).  When channels are needed
; the "idle" calls are disconnected (so long as there are at least "minidle"
; calls still running, of course) to make more channels available.  The
; primary use of this is to create a dynamic service, where idle channels
; are bundled through multilink PPP, thus more efficiently utilizing
; combined voice/data services than conventional fixed mappings/muxings.
;idledial=6999
;idleext=6999@dialout
;minunused=2
;minidle=1
; Configure jitter buffers in zapata (each one is 20ms, default is 4)
;jitterbuffers=4
; You can define your own custom ring cadences here.  You can define up to
; 8 pairs.  If the silence is negative, it indicates where the callerid
; spill is to be placed.  Also, if you define any custom cadences, the
; default cadences will be turned off.
; Syntax is:  cadence=ring,silence[,ring,silence[...]]
; These are the default cadences:
;cadence=125,125,2000,-4000
;cadence=250,250,500,1000,250,250,500,-4000
;cadence=125,125,125,125,125,-4000
;cadence=1000,500,2500,-5000
; Each channel consists of the channel number or range.  It
; inherits the parameters that were specified above its declaration
; For GR-303, CRV's are created like channels except they must start
; with the trunk group followed by a colon, e.g.:
; crv => 1:1
; crv => 2:1-2,5-8
;callerid="Green Phone"<(256) 428-6121>
;channel => 1
;callerid="Black Phone"<(256) 428-6122>
;channel => 2
;callerid="CallerID Phone" <(256) 428-6123>
;callerid="CallerID Phone" <(630) 372-1564>
;callerid="CallerID Phone" <(256) 704-4666>
;channel => 3
;callerid="Pac Tel Phone" <(256) 428-6124>
;channel => 4
;callerid="Uniden Dead" <(256) 428-6125>
;channel => 5
;callerid="Cortelco 2500" <(256) 428-6126>
;channel => 6
;callerid="Main TA 750" <(256) 428-6127>
;channel => 44
; For example, maybe we have some other channels
; which start out in a different context and use
; E & M signalling instead.
;context=remote
;sigalling=em
;channel => 15
;channel => 16
;signalling=em_w
; All those in group 0 I'll use for outgoing calls
; Strip most significant digit (9) before sending
;stripmsd=1
;callerid=asreceived
;group=0
;signalling=fxs_ls
;channel => 45
;signalling=fxo_ls
;group=1
;callerid="Joe Schmoe" <(256) 428-6131>
;channel => 25
;callerid="Megan May" <(256) 428-6132>
;channel => 26
;callerid="Suzy Queue" <(256) 428-6233>
;channel => 27
;callerid="Larry Moe" <(256) 428-6234>
;channel => 28
; Sample PRI (CPE) config:  Specify the switchtype, the signalling as
; either pri_cpe or pri_net for CPE or Network termination, and generally
; you will want to create a single "group" for all channels of the PRI.
; switchtype = national
; signalling = pri_cpe
; group = 2
; channel => 1-23
;  Used for distintive ring support for x100p.
;  You can see the dringX patterns is to set any one of the dringXcontext fields
;  and they will be printed on the console when an inbound call comes in.
;dring1=95,0,0
;dring1context=internal1
;dring2=325,95,0
;dring2context=internal2
; If no pattern is matched here is where we go.
;context=default
;channel => 1
Barron Johnstown
