ds-mod and 14.04.03-3452
arnevt
29 Mrz 2006
Hi
Yesterday I tried to compile ds-mod against 14.04.03-3452 (downloaded it manually and changed only Config.in to the .03-3452 version).
The FBF 7050 refused to boot. Luckely I saved the config and could use the restore tool included in the beta firmware).
Does the current ds-mod only work with stable firmware releases and the specific beta release mentioned in Config.in?
arne
Hi.
danisahne schrieb:
RELEASE NOTES: Beta firmwares do not run well with the mod, because kernel sources are not available yet.
AVM has changed something in the kernel. To get the mod running with the new firmware we need new sources from AVM.
Greets, Oliver
