Sun Nov 17 12:06:52 2013 VERIFY OK: nsCertType=SERVER
Sun Nov 17 12:06:52 2013 VERIFY OK: depth=0, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=openvpn.ivacy.com, [email protected]
Sun Nov 17 12:06:58 2013 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun Nov 17 12:06:58 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Nov 17 12:06:58 2013 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sun Nov 17 12:06:58 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sun Nov 17 12:06:58 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Sun Nov 17 12:06:58 2013 [openvpn.ivacy.com] Peer Connection Initiated with [AF_INET]213.232.200.172:1194
Sun Nov 17 12:07:00 2013 SENT CONTROL [openvpn.ivacy.com]: 'PUSH_REQUEST' (status=1)
Sun Nov 17 12:07:00 2013 PUSH: Received control message: 'PUSH_REPLY,route 1.0.0.0 255.0.0.0,dhcp-option DNS 1.254.2.2,dhcp-option DNS 1.254.2.3,dhcp-option DOMAIN vpn,explicit-exit-notify 2,route-gateway 1.2.112.1,topology subnet,ping 10,ping-restart 60,ifconfig 1.2.112.102 255.255.252.0'
Sun Nov 17 12:07:00 2013 Options error: Unrecognized option or missing parameter(s) in [PUSH-OPTIONS]:5: explicit-exit-notify (2.3.2)
Sun Nov 17 12:07:00 2013 OPTIONS IMPORT: timers and/or timeouts modified
Sun Nov 17 12:07:00 2013 OPTIONS IMPORT: --ifconfig/up options modified
Sun Nov 17 12:07:00 2013 OPTIONS IMPORT: route options modified
Sun Nov 17 12:07:00 2013 OPTIONS IMPORT: route-related options modified
Sun Nov 17 12:07:00 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Sun Nov 17 12:07:00 2013 TUN/TAP device tun0 opened
Sun Nov 17 12:07:00 2013 TUN/TAP TX queue length set to 100
Sun Nov 17 12:07:00 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sun Nov 17 12:07:00 2013 /sbin/ifconfig tun0 1.2.112.102 netmask 255.255.252.0 mtu 1500 broadcast 1.2.115.255
Sun Nov 17 12:07:01 2013 /sbin/route add -net 213.232.200.172 netmask 255.255.255.255 gw 192.168.10.1
Sun Nov 17 12:07:01 2013 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 1.2.112.1
Sun Nov 17 12:07:01 2013 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 1.2.112.1
Sun Nov 17 12:07:01 2013 /sbin/route add -net 1.0.0.0 netmask 255.0.0.0 gw 1.2.112.1
Sun Nov 17 12:07:01 2013 Initialization Sequence Completed
Mon Nov 18 05:22:09 2013 [openvpn.ivacy.com] Inactivity timeout (--ping-restart), restarting
Mon Nov 18 05:22:09 2013 SIGUSR1[soft,ping-restart] received, process restarting
Mon Nov 18 05:22:09 2013 Restart pause, 2 second(s)
Mon Nov 18 05:22:11 2013 Socket Buffers: R=[110592->131072] S=[110592->131072]
Mon Nov 18 05:22:11 2013 UDPv4 link local: [undef]
Mon Nov 18 05:22:11 2013 UDPv4 link remote: [AF_INET]213.232.200.172:1194
Mon Nov 18 05:22:11 2013 TLS: Initial packet from [AF_INET]213.232.200.172:1194, sid=d5f24630 baecec68
Mon Nov 18 05:22:12 2013 VERIFY OK: depth=1, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=ivacy.com CA, [email protected]
Mon Nov 18 05:22:12 2013 VERIFY OK: nsCertType=SERVER
Mon Nov 18 05:22:12 2013 VERIFY OK: depth=0, C=RU, ST=MR, L=Moscow, O=ivacy.com, CN=openvpn.ivacy.com, [email protected]
Mon Nov 18 05:22:17 2013 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Nov 18 05:22:17 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Nov 18 05:22:17 2013 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Mon Nov 18 05:22:17 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mon Nov 18 05:22:17 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mon Nov 18 05:22:17 2013 [openvpn.ivacy.com] Peer Connection Initiated with [AF_INET]213.232.200.172:1194
Mon Nov 18 05:22:19 2013 SENT CONTROL [openvpn.ivacy.com]: 'PUSH_REQUEST' (status=1)
Mon Nov 18 05:22:19 2013 AUTH: Received control message: AUTH_FAILED
Mon Nov 18 05:22:19 2013 /sbin/route del -net 1.0.0.0 netmask 255.0.0.0
Mon Nov 18 05:22:19 2013 /sbin/route del -net 213.232.200.172 netmask 255.255.255.255
Mon Nov 18 05:22:19 2013 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Mon Nov 18 05:22:19 2013 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Mon Nov 18 05:22:19 2013 Closing TUN/TAP interface
Mon Nov 18 05:22:19 2013 /sbin/ifconfig tun0 0.0.0.0
Mon Nov 18 05:22:20 2013 SIGTERM[soft,auth-failure] received, process exiting
