Hi guys...
I am using elastix 1.1-7, asterisk 1.4.19 and misdn 1.1.7.2
When I do a call from extension X to outside and begin to talk, if other extension (for example Y), try to call to outside, in a few seconds the extension Y heards the first call from the extesion X, and X lost your call.
What can I do ?
Thanks.
The misdn.log shows:
My misdn.conf:
My /etc/asterisk/misdn.conf
I can do calls and receive calls, but with the above problem.
I need a miracle!! (Excuse me but I am gonna crazy)!
Thanks from Spain!
What can I do ?
Thanks.
Mon Jul 21 23:28:19 2008: P[ 1] read_config: Getting Config
Mon Jul 21 23:28:19 2008: P[ 1] * CALL: g:out1/968937299
Mon Jul 21 23:28:19 2008: P[ 1] I SEND:SETUP oad:968898420 dad:968937299 pid:5
Mon Jul 21 23:28:19 2008: P[ 1] I IND :NEW_CHANNEL oad:968898420 dad:968937299 pid:5 state:CALLING
Mon Jul 21 23:28:19 2008: P[ 1] I IND :SETUP_ACKNOWLEDGE oad:968898420 dad:968937299 pid:5 state:CALLING
Mon Jul 21 23:28:21 2008: P[ 1] I IND :CONNECT oad:968898420 dad:968937299 pid:5 state:CALLING_ACKNOWLEDGE
Mon Jul 21 23:28:21 2008: P[ 1] I SEND:CONNECT_ACKNOWLEDGE oad:968898420 dad:968937299 pid:5
Mon Jul 21 23:28:21 2008: P[ 1] --> * Unknown Indication:20 pid:5
Mon Jul 21 23:28:44 2008: P[ 1] read_config: Getting Config
Mon Jul 21 23:28:44 2008: P[ 1] * CALL: g:out1/655052415
Mon Jul 21 23:28:44 2008: P[ 1] I SEND:SETUP oad:968898420 dad:655052415 pid:6
Mon Jul 21 23:28:44 2008: P[ 1] I IND :NEW_CHANNEL oad:968898420 dad:655052415 pid:6 state:CALLING
Mon Jul 21 23:28:44 2008: P[ 1] I IND :SETUP_ACKNOWLEDGE oad:968898420 dad:655052415 pid:6 state:CALLING
Mon Jul 21 23:28:51 2008: P[ 1] * IND : HANGUP pid:6 ctx:from-pstn dad:655052415 oad:0655052415 State:CALLING_ACKNOWLEDGE
Mon Jul 21 23:28:51 2008: P[ 1] I SEND:DISCONNECT oad:968898420 dad:655052415 pid:6
Mon Jul 21 23:28:51 2008: P[ 1] I IND :RELEASE oad:968898420 dad:655052415 pid:6 state:CLEANING
Mon Jul 21 23:28:51 2008: P[ 1] Cannot hangup chan, no ast
Mon Jul 21 23:28:51 2008: P[ 1] I IND :DISCONNECT oad:968898420 dad:968937299 pid:5 state:CONNECTED
Mon Jul 21 23:28:51 2008: P[ 1] I SEND:RELEASE oad:968898420 dad:968937299 pid:5
Mon Jul 21 23:28:51 2008: P[ 1] * IND : HANGUP pid:5 ctx:from-pstn dad: oad:0968937299 State:CONNECTED
Mon Jul 21 23:28:51 2008: P[ 1] I IND :RELEASE_COMPLETE oad:968898420 dad:968937299 pid:5 state:CLEANING
My misdn.conf:
<mISDNconf>
<module poll="128" debug="0" timer="no">hfcmulti</module>
<module debug="0" options="0">mISDN_dsp</module>
<devnode user="asterisk" group="asterisk" mode="660">mISDN</devnode>
<card type="BN4S0" master-clock="yes">
<port mode="te" link="ptp">1</port>
<port mode="te" link="ptp">2</port>
<port mode="te" link="ptmp">3</port>
<port mode="te" link="ptmp">4</port>
</card>
</mISDNconf>
; here you can define which bearers should be allowed
allowed_bearers=all
; Prefixes for national and international, those are put before the
; oad if an according dialplan is set by the other end.
; default values: nationalprefix : 0
; internationalprefix : 00
nationalprefix=0
internationalprefix=00
; set rx/tx gains between -8 and 8 to change the RX/TX Gain
; default values: rxgain: 0
; txgain: 0
rxgain=0
txgain=0
; some telcos especially in NL seem to need this set to yes, also in
; switzerland this seems to be important
; default value: no
te_choose_channel=no
; This option defines, if chan_misdn should check the L1 on a PMP
; before making a group call on it. The L1 may go down for PMP Ports
; so we might need this.
; But be aware! a broken or plugged off cable might be used for a group call
; as well, since chan_misdn has no chance to distinguish if the L1 is down
; because of a lost Link or because the Provider shut it down...
; default: no
pmp_l1_check=no
; in PMP this option defines which cause should be sent out to
; the 3. caller. chan_misdn does not support callwaiting on TE
; PMP side. This allows to modify the RELEASE_COMPLETE cause
; at least.
reject_cause=16
; Send Setup_Acknowledge on incoming calls anyway (instead of PROCEEDING),
; this requests additional Infos, so we can waitfordigits
; without much issues. This works only for PTP Ports
; default value: no
need_more_infos=no
; set this to yes if you want to disconnect calls when a timeout occurs
; for example during the overlapdial phase
nttimeout=no
; set the method to use for channel selection:
; standard - always choose the first free channel with the lowest number
; round_robin - use the round robin algorithm to select a channel. use this
; if you want to balance your load.
; default value: standard
method=standard
; specify if chan_misdn should collect digits before going into the
; dialplan, you can choose yes=4 Seconds, no, or specify the amount
; of seconds you need;
overlapdial=yes
; dialplan means Type Of Number in ISDN Terms (for outgoing calls)
; there are different types of the dialplan:
; dialplan -> outgoing Number
; localdialplan -> callerid
; cpndialplan -> connected party number
; dialplan options:
; 0 - unknown
; 1 - International
; 2 - National
; 4 - Subscriber
; This setting is used for outgoing calls
; default value: 0
dialplan=0
localdialplan=0
cpndialplan=0
; turn this to no if you don't mind correct handling of Progress Indicators
early_bconnect=no
; turn this on if you like to send Tone Indications to a Incoming
; isdn channel on a TE Port. Rarely used, only if the Telco allows
; you to send indications by yourself, normally the Telco sends the
; indications to the remote party.
; default: no
incoming_early_audio=no
; uncomment the following to get into s extension at extension conf
; there you can use DigitTimeout if you can't or don't want to use
; isdn overlap dial.
; note: This will jump into the s exten for every exten!
; default value: no
;always_immediate=no
; set this to yes if you want to generate your own dialtone
; with always_immediate=yes, else chan_misdn generates the dialtone
; default value: no
nodialtone=no
; uncomment the following if you want callers which called exactly the
; base number (so no extension is set) jump to the s extension.
; if the user dials something more it jumps to the correct extension
; instead
; default value: no
;immediate=no
; uncomment the following to have hold and retrieve support
; default value: no
;hold_allowed=yes
; Pickup and Callgroup
; default values: not set = 0
; range: 0-63
callgroup=1
pickupgroup=1
; these are the exact isdn screening and presentation indicators
; if -1 is given for both values the presentation indicators are used
; from asterisks SetCallerPres application.
; s=0, p=0 -> callerid presented not screened
; s=1, p=1 -> callerid presented but screened (the remote end does not see it!)
; default values s=-1, p=-1
; estaba en -1 y -1
presentation=1
screen=1
; this enables echocancellation, with the given number of taps
; be aware, move this setting only to outgoing portgroups!
; A value of zero turns echocancellation off.
; possible values are: 0,32,64,128,256,yes(=128),no(=0)
; default value: no
; cambio a no
echocancel=yes
; Set this to no to disable echotraining. You can enter a number > 10
; the value is a multiple of 0.125 ms.
; default value: no
; yes = 2000
; no = 0
echotraining=no
; chan_misdns jitterbuffer, default 4000
jitterbuffer=4000
; change this threshold to enable dejitter functionality
jitterbuffer_upper_threshold=0
; change this to yes, if you want to bridge a mISDN data channel to
; another channel type or to an application.
hdlc=no
; defines the maximum amount of incoming calls per port for
; this group. Calls which exceed the maximum will be marked with
; the channel variable MAX_OVERFLOW. It will contain the amount of
; overflowed calls
max_incoming=2
; defines the maximum amount of outgoing calls per port for this group
; exceeding calls will be rejected
max_outgoing=2
; quito esto
[intern]
; define your ports, e.g. 1,2 (depends on mISDN-driver loading order)
;ports=1,2
; context where to go to when incoming Call on one of the above ports
;context=Intern
;[internPP]
; adding the postfix 'ptp' to a port number is obsolete now, chan_misdn
; parses /etc/misdn-init.conf and sets the ptp mode to the corresponding
; configs. For backwards compatibility you can still set ptp here.
;ports=3
;[first_extern]
; again port defs
;ports=4
; again a context for incoming calls
;context=Extern1
; msns for te ports, listen on those numbers on the above ports, and
; indicate the incoming calls to asterisk
; here you can give a comma separated list or simply an '*' for
; any msn.
;msns=*
; here an example with given msns
;[second_extern]
;ports=5
;context=Extern2
;callerid=15
;msns=102,144,101,10
; hasta aqui
[out1]
ports=1ptp
context=from-pstn
msns=*
[out2]
ports=2ptp
context=from-pstn
Thanks from Spain!
