compiling the kernel for fritzbox
arnevt
29 Mrz 2006
Hi
I downloaden the src package from ftp.avm.de/develpr. I whish to complile that kernel so i will get an ipv6 module which I can include in the kernel. How would I do that? running make in the kernel-src directory isn't as smooth as a standard kernel compilation :(
arne
This is not so easy. You also need an uClibc which supports ipv6. Perhaps you should have a look at dsmod.
There you can build a toolchain, compile the kernel + modules and also uclibc with ipv6 support.
Greets, Oliver
