Compiling Iptables with Freetz get Siemens firmware
sherifomran
27 Okt 2007
Hello Freeks,
I was trying to build a new firmware for speedport w701v using sp-to-fritz incombination with freetz. I choosed iptables (without any other selection) in addition to wol packet.
Result, the router get 192.168.2.1 IP and shows a Siemens SE 551 Wlan firmware.
I expect to see a fritzbox?
Can somebody guide me to compile iptables for speedport w701v?
thanks
Speed2fritz is not freetz. Please ask the sp2fr-authors, or build a firmware without speed2fritz. A build for sp-w701v is possible with a standalone freetz.
Sp to fritz is based on freetz firmware. In the mean time, i could build the firmware with iptables.
I started the modules through telnet then
iptables -S
Then i tried to test iptables to block a url but it did not work. Could some body help
I know, but with 2 different scripts we couldn'T figur out, which script connection causes the problem. so the support for speed2fritz has to be made by the authors of speed2fritz.
Von hier: klick
modprobe ip_tables
modprobe iptable_filter
iptables -I FORWARD -d 209.222.148.0/24 -j reject
iptables v1.4.1.1: Couldn't load target `reject':File not found
Try `iptables -h' or 'iptables --help' for more information.
/var/mod/root # modprobe ipt_REJECT
modprobe: module ipt_REJECT not found in modules.dep
Evtl. sind die notwendigen Module nicht geladen. Schau mal mit "lsmod" nach. Mit "make kernel-menuconfig" kannst Du die erforderlichen Module automatisch laden lassen.
