Compiling for Fritz Fon..
spallared
16 Mrz 2006
Hi, i'm thinking to develop some apps for Fritz Box, i've a long experience with C/C++ (used both for work and for fun) under windows and linux (i developed some tools for Dreambox, linux based, satellite receiver).
To create code that runs on Fritz which kind of compiler should i use? Which kind of linux binaries should i create?
Thanks for your help
Luca
the fritzbox runs on a MIPS Processor, so you have to build a Crosscompiler.
A very easy way to create it is the DS-Mod
make menuconfig
make toolchain
creates the Crosscompiler, there is also already a Thread about it: http://www.ip-phone-forum.de/showthread.php?t=94569
