chan_capi_cm 0.6.1 Rufnummernübermittlung am Anlagenanschluß
hohausal
25 Nov 2005
ich habe auf Asterisk 1.2.0 und die chan_capi_cm 0.6.1 umgestellt. Jetzt funktioniert die Rufnummernübermittlung nicht mehr. Es kommt immer die zentrale Nummer an.
Die Asterisk hängt über eine AVM b1 Karte am Anlagenanschluß.
Hat jemand eine Idee. Anbei das Dial-Command und die capi.conf
; Dial-Command
exten => _0.,1,Dial(Capi/contr1/123456${CALLERIDNUM}:${EXTEN:1}/b)
;capi.conf
; CAPI config
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
[ISDN1]
;overlapdial=yes
msn=123456
ntmode=no       ;if isdn card operates in nt mode, set this to yes
isdnmode=DID    ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
                 ;when using NT-mode, 'DID' should be set in any case
incomingmsn=*    ;allow incoming calls to this list of MSNs/DIDs, * = any
outgoingmsn=*
;defaultcid=123  ;set a default caller id to that interface for dial-out,
                 ;this caller id will be used when dial option 'd' is set.
controller=1     ;capi controller number to use
group=1          ;dialout group
;prefix=0        ;set a prefix to calling number on incoming calls
softdtmf=on      ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on     ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode=     ;Asterisk accountcode to use in CDRs
context=outside  ;context for incoming calls
holdtype=hold    ;when Asterisk puts the call on hold, ISDN HOLD will be used. If
                 ;set to 'local' (default value), no hold is done and Asterisk may
                 ;play MOH.
immediate=yes   ;DID: immediate start of pbx with extension 's' if no digits were
                 ;     received on incoming call (no destination number yet)
                 ;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
                 ;     info like REDIRECTINGNUMBER may be lost, but this is necessary for
                 ;     drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
;echosquelch=1   ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes  ;EICON DIVA SERVER (CAPI) echo cancelation
                 ;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64     ;echo cancel tail setting
;bridge=yes      ;native bridging (CAPI line interconnect) if available
callgroup=1     ;Asterisk call group
devices=2        ;number of concurrent calls on this controller
                 ;(2 makes sense for single BRI, 30 for PRI)
pickupgroup=1
Beim Anlagenanschluss setzt man nur die Durchwahl als CalerId, ohne Hauptnummer.
Armin
Hallo Armin,
vielen Dank für die schnelle Hilfe. So funktioniert es.
Vielleicht noch als Hinweis für Anwender mit ähnlichen Probleme.
Wir haben einen Anlagenanschluß, der nicht die 0 sondern die 6 als zentrale Durchwahl hat. Das heisst den Nummernbereich von 60 - 89
Wir haben diese Nummern um eine Stelle verlängert.
Mit der Nummer 123456 in der capi.conf und der Durchwahl 11 in der extensions.conf funktioniert es nicht.
Ich muss in der capi.conf 12345 und in der extensions.conf im Dial Befehl die 611 verwenden.
Gruß Axel
YPLCRP
