der neu bristuf ist unter http://www.junghanns.net/asterisk/downloads/bristuff-0.2.0-RC5.tar.gz
zu bekommen
zu bekommen
depmod: *** Unresolved symbols in /lib/modules/2.4.27-2-686/misc/wcusb.o
depmod: *** Unresolved symbols in /lib/modules/2.4.27-2-686/misc/zaptel.o
depmod: *** Unresolved symbols in /lib/modules/2.4.27-2-686/misc/ztd-eth.o
[ `id -u` = 0 ] && /sbin/depmod -a || :
[ -f /etc/zaptel.conf ] || install -D -m 644 zaptel.conf.sample /etc/zaptel.conf
eiclinde:/usr/src/bristuff-0.2.0-RC5/zaptel-1.0.4# make loadNT
make: *** No rule to make target `loadNT'. Stop.
eiclinde:/usr/src/bristuff-0.2.0-RC5/zaptel-1.0.4# cd ../zaphfc/
eiclinde:/usr/src/bristuff-0.2.0-RC5/zaphfc# make loadNT
sync
modprobe zaptel
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol __pollwait_R2549b257
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol devfs_register_R4a8220e0
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol proc_mkdir_Rca0d18d3
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol devfs_unregister_R285087ec
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol remove_proc_entry_R4956bdbf
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol add_wait_queue_Re3f4bce6
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol devfs_register_chrdev_Rbca8f0a8
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol devfs_mk_symlink_R67df0cb2
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol remove_wait_queue_Rab9c4c0c
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol devfs_generate_path_R0ee791a7
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol create_proc_entry_R68edd003
/lib/modules/2.4.27-2-686/misc/zaptel.o: /lib/modules/2.4.27-2-686/misc/zaptel.o: unresolved symbol devfs_mk_dir_Rf5b8789d
/lib/modules/2.4.27-2-686/misc/zaptel.o: insmod /lib/modules/2.4.27-2-686/misc/zaptel.o failed
/lib/modules/2.4.27-2-686/misc/zaptel.o: insmod zaptel failed
make: *** [loadlinux24NT] Error 255
Hat jemand das selbe Prob, oder ne Lösung parat?
Mit bristuff0.2.0-RC3a geht es ohne probs
jui schrieb:Ich verwende RC5 mit Kernel 2.4 auf einem SuSE 9.0 derzeit ohne weitere Probleme, lediglich eine Korrektur in zaphfc.c war erforderlich (damit make loadNT läuft), da hat wohl kpj nicht ganz aufgepasst.
Aber trotzdem wäre es nett, wenn Du mir sagen würdest, was Du im zaphfc.c geändert hast. Ich bin da nich so frisch. :wink:depmod: *** Unresolved symbols in /lib/modules/2.4.27-2-686/misc/wcusb.o
