# $Id: ser.cfg,v 1.21.4.1 2003/11/10 15:35:15 andrei Exp $
# simple quick-start config script
# ----------- global configuration parameters ------------------------
#debug=3 # debug level (cmd line: -dddddddddd)
#fork=yes
#log_stderror=no # (cmd line: -E)
#/* Uncomment these lines to enter debugging mode
debug=7
#fork=no
log_stderror=yes
check_via=no # (cmd. line: -v)
dns=no # (cmd. line: -r)
rev_dns=no # (cmd. line: -R)
#port=5060
#children=4
fifo="/tmp/ser_fifo"
# ------------------ module loading ----------------------------------
# Uncomment this if you want to use SQL database
#loadmodule "/usr/local/lib/ser/modules/mysql.so"
loadmodule "/usr/local/lib/ser/modules/sl.so"
loadmodule "/usr/local/lib/ser/modules/tm.so"
loadmodule "/usr/local/lib/ser/modules/rr.so"
loadmodule "/usr/local/lib/ser/modules/maxfwd.so"
loadmodule "/usr/local/lib/ser/modules/usrloc.so"
loadmodule "/usr/local/lib/ser/modules/registrar.so"
#++++++++++ jimmy added ++++++++++++++++++
loadmodule "/usr/local/lib/ser/modules/textops.so"
loadmodule "/usr/local/lib/ser/modules/nathelper.so"
# Uncomment this if you want digest authentication
# mysql.so must be loaded !
#loadmodule "/usr/local/lib/ser/modules/auth.so"
#loadmodule "/usr/local/lib/ser/modules/auth_db.so"
# ----------------- setting module-specific parameters ---------------
#we will you flag 6 to mark NATed contacts
modparam("registrar","nat_flag",6)
#Enable NAT pinging
modparam("nathelper","natping_interval",3)
#ping only contacts that are known to be behind NAT
modparam("nathelper","ping_nated_only",1)
# -- usrloc params --
modparam("usrloc", "db_mode", 0)
# for persistent storage and comment the previous line
#modparam("usrloc", "db_mode", 2)
# -- auth params --
# Uncomment if you are using auth module
#modparam("auth_db", "calculate_ha1", yes)
# If you set "calculate_ha1" parameter to yes (which true in this config),
# uncomment also the following parameter)
#modparam("auth_db", "password_column", "password")
# -- rr params --
# add value to ;lr param to make some broken UAs happy
modparam("rr", "enable_full_lr", 1)
# ------------------------- request routing logic -------------------
# main routing logic
route{
if(nat_uac_test("3"))
if((method == "REGISTER") || !(search("^Record-Route:")))
log("LOG:Someone trying to register from private IP, rewriting\n");
fix_nated_contact();
if(method == "INVITE")
fix_nated_sdp("3");
force_rport();
setflag(6);
# initial sanity checks -- messages with
# max_forwards==0, or excessively long requests
if (!mf_process_maxfwd_header("10")) {
sl_send_reply("483","Too Many Hops");
break;
if ( msg:len > max_len ) {
sl_send_reply("513", "Message too big");
break;
# we record-route all messages -- to make sure that
# subsequent messages will go through our proxy; that's
# particularly good if upstream and downstream entities
# use different transport protocol
record_route();
# loose-route processing
if (loose_route()) {
t_relay();
break;
# if the request is for other domain use UsrLoc
# (in case, it does not work, use the following command
# with proper names and addresses in it)
if (uri==myself) {
if (method=="REGISTER") {
# Uncomment this if you want to use digest authentication
# if (!www_authorize("iptel.org", "subscriber")) {
# www_challenge("iptel.org", "0");
# break;
save("location");
break;
# native SIP destinations are handled using our USRLOC DB
if (!lookup("location")) {
sl_send_reply("404", "Not Found");
break;
# forward to current uri now; use stateful forwarding; that
# works reliably even if we forward from TCP to UDP
if (!t_relay()) {
sl_reply_error();
#++++++++++ jimmy added +++++++++++++++++++++
route[1]
if(uri=~"[@:](192\.168\.|10\.|172\.16)" && !search("^Route:"))
sl_send_reply("479","we don't forward to private IP address");
break;
if(isflagset(6))
force_rtp_proxy();
t_on_reply("1");
append_hf("P-Behind-NAT: Yes\r\n");
if(!t_relay())
sl_reply_error();
break;
onreply_route[1]
if(status =~ "(183)|2[0-9][0-9]")
force_rtp_proxy();
