Bei Anruf startet Asterisk neu
Andy123
16 Nov 2006
ich hab folgendes Problem:
Ich hab eine HFC Karte mit misdn zum laufen gebracht. Leider startet laut dem Logfile bei einem Anruf die Asterisk neu. Beim Telefon leutet es ganz normal kommt aber nicht durch.
hier mal ein paar logs
Vieleicht weiß einer von euch Rat :).
Danke schonmal im vorraus
full Logfile
Nov 24 09:11:18 DEBUG[7003] chan_sip.c: Stopping retransmission on '[email protected]' of Request 102: Match Found
Nov 24 09:11:24 DEBUG[7003] chan_sip.c: Setting NAT on RTP to 0
Nov 24 09:11:24 DEBUG[7003] chan_sip.c: Stopping retransmission on '[email protected]' of Response 1414798642: Match Found
Nov 24 09:11:24 DEBUG[7003] chan_sip.c: Checking SIP call limits for device 12
Nov 24 09:11:24 DEBUG[7003] chan_sip.c: build_route: Contact hop: Andy <sip:[email protected]>
Nov 24 09:11:24 DEBUG[7297] pbx.c: Expression result is '1'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Expression result is '0'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Not taking any branch
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is '12'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is 'Andy'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is '"Andy" <12>'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is '0'
Nov 24 09:11:24 VERBOSE[7297] logger.c:   recordingcheck|20061124-091124|1164355884.2: Outbound recording not enabled
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is ''
Nov 24 09:11:24 DEBUG[7297] db.c: Unable to find key '12/emergency_cid' in family 'DEVICE'
Nov 24 09:11:24 DEBUG[7297] func_db.c: DB: DEVICE/12/emergency_cid not found in database.
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is '1'
Nov 24 09:11:24 WARNING[7297] ast_expr2.fl: ast_yyerror(): syntax error: syntax error, unexpected $end, expecting TOK_MINUS or TOK_COMPL or TOK_LP or TOKEN; Input:
 1 >
Nov 24 09:11:24 WARNING[7297] ast_expr2.fl: If you have questions, please refer to doc/README.variables in the asterisk source.
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is 'AMP'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is 'AMP:misdn/1/'
Nov 24 09:11:24 DEBUG[7297] pbx.c: Function result is 'OUTNUM'
Nov 24 09:11:28 VERBOSE[7321] logger.c: Asterisk Event Logger Started /var/log/asterisk/event_log
Nov 24 09:11:28 VERBOSE[7321] logger.c: Asterisk Dynamic Loader loading preload modules:
Nov 24 09:11:28 WARNING[7321] config.c: Unknown directive 'permit=192.168.1.0/255.255.255.0' at line 18 of manager_custom.conf
Nov 24 09:11:28 VERBOSE[7321] logger.c: Asterisk Management interface listening on port 5038
Nov 24 09:11:28 NOTICE[7321] cdr.c: CDR simple logging enabled.
Nov 24 09:11:28 VERBOSE[7321] logger.c: Asterisk PBX Core Initializing
Nov 24 09:11:28 VERBOSE[7321] logger.c: Registering builtin applications:
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [AbsoluteTimeout]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Answer]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [BackGround]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Busy]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Congestion]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [DigitTimeout]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Goto]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [GotoIf]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [GotoIfTime]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [ExecIfTime]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Hangup]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [NoOp]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Progress]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [ResetCDR]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [ResponseTimeout]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Ringing]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SayNumber]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SayDigits]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SayAlpha]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SayPhonetic]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SetAccount]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SetAMAFlags]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SetGlobalVar]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SetLanguage]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Set]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [SetVar]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [ImportVar]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [Wait]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [WaitExten]
Nov 24 09:11:28 VERBOSE[7321] logger.c: Asterisk Dynamic Loader Starting:
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_wav.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_wav.so] => (Microsoft WAV format (8000hz Signed Linear))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_pcm.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_pcm.so] => (Raw uLaw 8khz Audio support (PCM))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_au.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_au.so] => (Sun Microsystems AU format (signed linear))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_mp3.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_mp3.so] => (MP3 format [Any rate but 8000hz mono optimal])
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_musiconhold.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_musiconhold.so] => (Music On Hold Resource)
Nov 24 09:11:28 WARNING[7321] res_musiconhold.c: The old musiconhold.conf syntax has been deprecated!  Please refer to the sample configuration for information on the new syntax.
Nov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_1 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_2 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_3 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_4 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_5 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_6 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_7 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_8 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_9 or dir does not existNov 24 09:11:28 WARNING[7321] res_musiconhold.c: Cannot open dir mp3:/var/lib/asterisk/mohmp3/acc_10 or dir does not existNov 24 09:11:28 VERBOSE[7321] logger.c:  [res_config_mysql.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_config_mysql.so] => (MySQL RealTime Configuration Driver)
Nov 24 09:11:28 WARNING[7321] res_config_mysql.c: MySQL RealTime: No database port found, using 3306 as default.
Nov 24 09:11:28 WARNING[7321] res_config_mysql.c: MySQL RealTime: No database socket found, using '/tmp/mysql.sock' as default.
Nov 24 09:11:28 DEBUG[7321] res_config_mysql.c: MySQL RealTime Host: 127.0.0.1
Nov 24 09:11:28 DEBUG[7321] res_config_mysql.c: MySQL RealTime Port: 3306
Nov 24 09:11:28 DEBUG[7321] res_config_mysql.c: MySQL RealTime User: asteriskuser
Nov 24 09:11:28 DEBUG[7321] res_config_mysql.c: MySQL RealTime Password: amp109
Nov 24 09:11:28 DEBUG[7321] res_config_mysql.c: MySQL RealTime: Successfully connected to database.
Nov 24 09:11:28 NOTICE[7321] config.c: Registered Config Engine mysql
Nov 24 09:11:28 VERBOSE[7321] logger.c: MySQL RealTime driver loaded.
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_crypto.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_crypto.so] => (Cryptographic Digital Signatures)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_monitor.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_monitor.so] => (Call Monitoring Resource)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_speech.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_speech.so] => (Generic Speech Recognition API)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_features.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_features.so] => (Call Features Resource)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_indications.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_indications.so] => (Indications Configuration)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_odbc.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_odbc.so] => (ODBC Resource)
Nov 24 09:11:28 NOTICE[7321] res_odbc.c: res_odbc loaded.
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_config_odbc.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_config_odbc.so] => (ODBC Configuration)
Nov 24 09:11:28 NOTICE[7321] config.c: Registered Config Engine odbc
Nov 24 09:11:28 VERBOSE[7321] logger.c: res_config_odbc loaded.
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_adsi.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_adsi.so] => (ADSI Resource)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_agi.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [res_agi.so] => (Asterisk Gateway Interface (AGI))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_dundi.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_dundi.so] => (Distributed Universal Number Discovery (DUNDi))
Nov 24 09:11:28 DEBUG[7321] pbx_dundi.c: Seeding global EID '00:11:d8:31:ba:f9' from 'eth0'
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_spool.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_spool.so] => (Outgoing Spool Support)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_config.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_config.so] => (Text Extension Configuration)
Nov 24 09:11:28 WARNING[7321] pbx_config.c: The use of '_.' for an extension is strongly discouraged and can have unexpected behavior.  Please use '_X.' instead at line 643
Nov 24 09:11:28 WARNING[7321] pbx_config.c: The use of '_.' for an extension is strongly discouraged and can have unexpected behavior.  Please use '_X.' instead at line 644
Nov 24 09:11:28 WARNING[7321] pbx_config.c: The use of '_.' for an extension is strongly discouraged and can have unexpected behavior.  Please use '_X.' instead at line 645
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-did-direct' tries includes nonexistent context 'ext-findmefollow'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-pstn' tries includes nonexistent context 'from-pstn-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-pstn' tries includes nonexistent context 'ext-findmefollow'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-pstn' tries includes nonexistent context 'ext-did-direct'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'custom-meetme' tries includes nonexistent context 'ext-meetme'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-internal-additional' tries includes nonexistent context 'from-internal-additional-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-internal-additional' tries includes nonexistent context 'ext-group'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-internal-additional' tries includes nonexistent context 'ext-queues'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'from-internal-additional' tries includes nonexistent context 'ext-meetme'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'outrt-002-ISDN outside' tries includes nonexistent context 'outrt-002-ISDN outside-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'outrt-001-9_outside' tries includes nonexistent context 'outrt-001-9_outside-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'outbound-allroutes' tries includes nonexistent context 'outbound-allroutes-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'ext-local' tries includes nonexistent context 'ext-local-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'ext-did' tries includes nonexistent context 'ext-did-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'ext-test' tries includes nonexistent context 'ext-test-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-zapbarge' tries includes nonexistent context 'app-zapbarge-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-userlogonoff' tries includes nonexistent context 'app-userlogonoff-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-vmmain' tries includes nonexistent context 'app-vmmain-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-dialvm' tries includes nonexistent context 'app-dialvm-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-recordings' tries includes nonexistent context 'app-recordings-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-dnd-on' tries includes nonexistent context 'app-dnd-on-custom'
Nov 24 09:11:28 WARNING[7321] pbx.c: Context 'app-dnd-off' tries includes nonexistent context 'app-dnd-off-custom'
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_realtime.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_realtime.so] => (Realtime Switch)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_loopback.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_loopback.so] => (Loopback Switch)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_ael.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_ael.so] => (Asterisk Extension Language Compiler)
Nov 24 09:11:28 WARNING[7321] pbx_ael.c: Unable to open '/etc/asterisk/extensions.ael': No such file or directory
Nov 24 09:11:28 WARNING[7321] pbx.c: Requested contexts didn't get merged
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_functions.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [pbx_functions.so] => (Builtin dialplan functions)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_iax2.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_iax2.so] => (Inter Asterisk eXchange (Ver 2))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_skinny.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_skinny.so] => (Skinny Client Control Protocol (Skinny))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_zap.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_zap.so] => (Zapata Telephony w/PRI)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_misdn.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_misdn.so] => (Channel driver for mISDN Support (Bri/Pri))
Nov 24 09:11:28 WARNING[7321] misdn_config.c: misdn.conf: "ports=(null)" (section: intern) invalid or out of range. Please edit your misdn.conf and then do a "misdn reload".
Nov 24 09:11:28 WARNING[7321] misdn_config.c: misdn.conf: "ports=(null)" (section: internPP) invalid or out of range. Please edit your misdn.conf and then do a "misdn reload".
Nov 24 09:11:28 WARNING[7321] misdn_config.c: misdn.conf: "ports=(null)" (section: first_extern) invalid or out of range. Please edit your misdn.conf and then do a "misdn reload".
Nov 24 09:11:28 WARNING[7321] misdn_config.c: misdn.conf: "ports=(null)" (section: second_extern) invalid or out of range. Please edit your misdn.conf and then do a "misdn reload".
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_phone.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_phone.so] => (Linux Telephony API Support)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_local.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_local.so] => (Local Proxy Channel)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_sip.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_sip.so] => (Session Initiation Protocol (SIP))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [skipping chan_oss.so]
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_features.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_features.so] => (Feature Proxy Channel)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_agent.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_agent.so] => (Agent Proxy Channel)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_h323.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_h323.so] => (Objective Systems H323 Channel)
Nov 24 09:11:28 NOTICE[7321] src/chan_h323.c: Unable to load config ooh323.conf, OOH323 disabled
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_mgcp.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [chan_mgcp.so] => (Media Gateway Control Protocol (MGCP))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_g726.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_g726.so] => (ITU G.726-32kbps G726 Transcoder)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_db.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_db.so] => (Database Access Functions)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_txtcidname.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_txtcidname.so] => (TXTCIDName)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_flash.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_flash.so] => (Flash zap trunk application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_g729.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_g729.so] => (Raw G729 data)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_v110.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_v110.so] => (v.110 dialin Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_txfax.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_txfax.so] => (Trivial FAX Transmit Application - AsterFax adaption v1.1)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_addon_mysql.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_addon_mysql.so] => (MySQL CDR Backend)
Nov 24 09:11:28 WARNING[7321] cdr_addon_mysql.c: MySQL database sock file not specified.  Using default
Nov 24 09:11:28 NOTICE[7321] cdr_addon_mysql.c: MySQL database table not specified.  Assuming "cdr"
Nov 24 09:11:28 NOTICE[7321] cdr_addon_mysql.c: MySQL spool file not specified. Will not catch lost database queries.
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: cdr_mysql: got hostname of localhost
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: cdr_mysql: got port of 0
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: cdr_mysql: got a timeout of 0
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: cdr_mysql: got user of asteriskuser
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: cdr_mysql: got dbname of asteriskcdrdb
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: cdr_mysql: got password of amp109
Nov 24 09:11:28 DEBUG[7321] cdr_addon_mysql.c: Successfully connected to MySQL database.
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_externalivr.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_externalivr.so] => (External IVR Interface Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_nv_faxdetect.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_nv_faxdetect.so] => (Newman's fax detection application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_directory.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_directory.so] => (Extension Directory)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_talkdetect.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_talkdetect.so] => (Playback with Talk Detection)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_ulaw.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_ulaw.so] => (Mu-law Coder/Decoder)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_disa.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_disa.so] => (DISA (Direct Inward System Access) Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_playback.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_playback.so] => (Sound File Playback Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_adsiprog.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_adsiprog.so] => (Asterisk ADSI Programming Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_lpc10.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_lpc10.so] => (LPC10 2.4kbps (signed linear) Voice Coder)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_sms.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_sms.so] => (SMS/PSTN handler)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_pcm_alaw.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_pcm_alaw.so] => (Raw aLaw 8khz PCM Audio support)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_pgsql.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_pgsql.so] => (PostgreSQL CDR Backend)
Nov 24 09:11:28 WARNING[7321] cdr_pgsql.c: Unable to load config for PostgreSQL CDR's: cdr_pgsql.conf
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_adpcm.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_adpcm.so] => (Adaptive Differential PCM Coder/Decoder)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_odbc.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_odbc.so] => (ODBC CDR Backend)
Nov 24 09:11:28 WARNING[7321] cdr_odbc.c: cdr_odbc: Unable to load config for ODBC CDR's: cdr_odbc.conf
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_realtime.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_realtime.so] => (Realtime Data Lookup/Rewrite)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_test.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_test.so] => (Interface Test Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_mixmonitor.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_mixmonitor.so] => (Mixed Audio Monitoring Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_forkcdr.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_forkcdr.so] => (Fork The CDR into 2 separate entities.)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_authenticate.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_authenticate.so] => (Authentication Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcidname.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcidname.so] => (Set CallerID Name)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_read.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_read.so] => (Read Variable Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_sln.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_sln.so] => (Raw Signed Linear Audio support (SLN))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_enumlookup.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_enumlookup.so] => (ENUM Lookup)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_curl.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_curl.so] => (Load external URL)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_flite.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_flite.so] => (Flite Text-to-Speech Interface)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_verbose.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_verbose.so] => (Send verbose output)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_page.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_page.so] => (Page Multiple Phones)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [func_uri.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [func_uri.so] => (URI encode/decode functions)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_festival.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_festival.so] => (Simple Festival Interface)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_gsm.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_gsm.so] => (Raw GSM data)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapateller.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapateller.so] => (Block Telemarketers with Special Information Tone)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_parkandannounce.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_parkandannounce.so] => (Call Parking and Announce Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_mp3.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_mp3.so] => (Silly MP3 Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_gsm.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_gsm.so] => (GSM/PCM16 (signed linear) Codec Translator)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_exec.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_exec.so] => (Executes applications)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_custom.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_custom.so] => (Customizable Comma Separated Values CDR Backend)
Nov 24 09:11:28 WARNING[7321] cdr_custom.c: Failed to load configuration file. Module not activated.
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_waitforring.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_waitforring.so] => (Waits until first ring after time)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_dictate.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_dictate.so] => (Virtual Dictation Machine)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_math.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_math.so] => (Basic Math Functions)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setrdnis.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setrdnis.so] => (Set RDNIS Number)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_nv_backgrounddetect.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_nv_backgrounddetect.so] => (Newman's playback with talk and fax detection)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_controlplayback.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_controlplayback.so] => (Control Playback Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_cdr.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_cdr.so] => (Tell Asterisk to not maintain a CDR for the current call)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_vox.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_vox.so] => (Dialogic VOX (ADPCM) File Format)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_speech_utils.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_speech_utils.so] => (Dialplan Speech Applications)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_meetme.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_meetme.so] => (MeetMe conference bridge)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_ices.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_ices.so] => (Encode and Stream via icecast and ices)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapbarge.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapbarge.so] => (Barge in on Zap channel application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcidnum.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcidnum.so] => (Set CallerID Number)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_milliwatt.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_milliwatt.so] => (Digital Milliwatt (mu-law) Test Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcdruserfield.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcdruserfield.so] => (CDR user field apps)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [func_enum.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [func_enum.so] => (ENUM Related Functions)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_privacy.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_privacy.so] => (Require phone number to be entered, if no CallerID sent)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapscan.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapscan.so] => (Scan Zap channels application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_softhangup.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_softhangup.so] => (Hangs up the requested channel)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [func_callerid.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [func_callerid.so] => (Caller ID related dialplan function)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_wav_gsm.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_wav_gsm.so] => (Microsoft WAV format (Proprietary GSM))
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_csv.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_csv.so] => (Comma Separated Values CDR Backend)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_h263.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_h263.so] => (Raw h263 data)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_transfer.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_transfer.so] => (Transfer)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_hasnewvoicemail.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_hasnewvoicemail.so] => (Indicator for whether a voice mailbox has messages in a given folder.)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_waitforsilence.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_waitforsilence.so] => (Wait For Silence)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_stack.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_stack.so] => (Stack Routines)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_nbscat.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_nbscat.so] => (Silly NBS Stream Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_voicemail.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_voicemail.so] => (Comedian Mail (Voicemail System))
Nov 24 09:11:28 DEBUG[7321] app_voicemail.c: VM CID Info before msg disabled globally
Nov 24 09:11:28 DEBUG[7321] app_voicemail.c: Send Voicemail msg disabled globally
Nov 24 09:11:28 DEBUG[7321] app_voicemail.c: ENVELOPE before msg enabled globally
Nov 24 09:11:28 DEBUG[7321] app_voicemail.c: Duration info before msg enabled globally
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_g723.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_g723.so] => (G.723.1 Simple Timestamp File Format)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_alarmreceiver.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_alarmreceiver.so] => (Alarm Receiver for Asterisk)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_jpeg.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_jpeg.so] => (JPEG (Joint Picture Experts Group) Image Format)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_sayunixtime.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_sayunixtime.so] => (Say time)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapras.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_zapras.so] => (Zap RAS Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_ilbc.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_ilbc.so] => (Raw iLBC data)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_random.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_random.so] => (Random goto)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_dial.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_dial.so] => (Dialing Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_record.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_record.so] => (Trivial Record Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_echo.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_echo.so] => (Simple Echo Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_addon_sql_mysql.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_addon_sql_mysql.so] => (Simple Mysql Interface)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_pipe.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_pipe.so] => (Pipe Chan Data into forked terminal)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_dumpchan.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_dumpchan.so] => (Dump Info About The Calling Channel)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcallerid.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_setcallerid.so] => (Set CallerID Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_userevent.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_userevent.so] => (Custom User Event Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_getcpeid.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_getcpeid.so] => (Get ADSI CPE ID)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_eval.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_eval.so] => (Reevaluates strings)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_readfile.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_readfile.so] => (Stores output of file into a variable)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_senddtmf.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_senddtmf.so] => (Send DTMF digits Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_rxfax.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_rxfax.so] => (Trivial FAX Receive Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_chanspy.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_chanspy.so] => (Listen to the audio of an active channel
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_sendtext.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_sendtext.so] => (Send Text Applications)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_ilbc.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_ilbc.so] => (iLBC/PCM16 (signed linear) Codec Translator)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_settransfercapability.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_settransfercapability.so] => (Set ISDN Transfer Capability)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_a_mu.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_a_mu.so] => (A-law and Mulaw direct Coder/Decoder)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_alaw.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [codec_alaw.so] => (A-law Coder/Decoder)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_lookupblacklist.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_lookupblacklist.so] => (Look up Caller*ID name/number from blacklist database)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_macro.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_macro.so] => (Extension Macros)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_g726.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_g726.so] => (Raw G.726 (16/24/32/40kbps) data)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_manager.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [cdr_manager.so] => (Asterisk Call Manager CDR Backend)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_image.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_image.so] => (Image Transmission Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_url.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_url.so] => (Send URL Applications)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_groupcount.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_groupcount.so] => (Group Management Routines)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_chanisavail.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_chanisavail.so] => (Check channel availability)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_waitfordigits.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_waitfordigits.so] => (Waits for overlap dialed digits)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_ogg_vorbis.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [format_ogg_vorbis.so] => (OGG/Vorbis audio)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_saycountpl.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_saycountpl.so] => (Say polish counting words)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_lookupcidname.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_lookupcidname.so] => (Look up CallerID Name from local database)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_md5.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_md5.so] => (MD5 checksum applications)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_cut.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_cut.so] => (Cut out information from a string)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_directed_pickup.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_directed_pickup.so] => (Directed Call Pickup Application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_queue.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_queue.so] => (True Call Queueing)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_system.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_system.so] => (Generic System() application)
Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_while.so]Nov 24 09:11:28 VERBOSE[7321] logger.c:  [app_while.so] => (While Loops and Conditional Execution)
Nov 24 09:11:28 VERBOSE[7321] logger.c: Asterisk Ready.
Nov 24 09:11:29 DEBUG[7339] chan_sip.c: Stopping retransmission on '[email protected]' of Request 102: Match Found
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'Challenge'
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'Login'
Nov 24 09:11:33 WARNING[7343] config.c: Unknown directive 'permit=192.168.1.0/255.255.255.0' at line 18 of manager_custom.conf
Nov 24 09:11:33 DEBUG[7343] acl.c: 0.0.0.0/0.0.0.0/0.0.0.0 appended to acl for peer
Nov 24 09:11:33 DEBUG[7343] acl.c: 127.0.0.1/255.255.255.0/255.255.255.0 appended to acl for peer
Nov 24 09:11:33 DEBUG[7343] acl.c: ##### Testing 127.0.0.1 with 0.0.0.0
Nov 24 09:11:33 DEBUG[7343] acl.c: ##### Testing 127.0.0.1 with 127.0.0.0
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'Command'
Nov 24 09:11:33 DEBUG[7343] db.c: Unable to find key 'SIP/12' in family 'cfb'
Nov 24 09:11:33 DEBUG[7343] db.c: Unable to find key 'SIP/11' in family 'cfb'
Nov 24 09:11:33 DEBUG[7343] db.c: Unable to find key 'SIP/12' in family 'dnd'
Nov 24 09:11:33 DEBUG[7343] db.c: Unable to find key 'SIP/11' in family 'dnd'
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'QueueStatus'
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'Status'
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'ZapShowChannels'
Nov 24 09:11:33 DEBUG[7343] manager.c: Manager received command 'MailboxStatus'
Nov 24 09:11:35 DEBUG[7343] manager.c: Manager received command 'Command'
misdn Logfile:
 recordingcheck|20061124-091558|1164356158.0: Outbound recording not enabled
P[ 1] * CALL: 1/76758549
P[ 1]  --> * dad:76758549 tech:mISDN/1-u0 ctx:Intern
P[ 1] update_config: Getting Config
P[ 1] I SEND:SETUP oad:12 dad:76758549 pid:2
P[ 1]  --> bc_state:BCHAN_CLEANED
enc_ie_bearer: ERROR: capability(65535) is out of range.
P[ 1]  --> * SEND: State Dialing pid:2
P[ 1] I IND :RELEASE_COMPLETE oad: dad: pid:2 state:CALLING
P[ 1] hangup_chan
P[ 1] -> queue_hangup
P[ 1] release_chan: bc with l3id: 30001
P[ 1] * RELEASING CHANNEL pid:2 ctx:Intern dad:76758549 oad:076758549 state: CALLING
/usr/sbin/safe_asterisk: line 51:  7321 Segmentation fault      (core dumped) ${ASTSBINDIR}/asterisk ${CLIARGS} ${ASTARGS}
Asterisk exited on signal 11.
Automatically restarting Asterisk.
Fri Nov 24 09:15:58 2006: P[ 1]  * CALL: 1/76758549
Fri Nov 24 09:15:58 2006: P[ 1]   --> * dad:76758549 tech:mISDN/1-u0 ctx:Intern
Fri Nov 24 09:15:58 2006: P[ 1]  update_config: Getting Config
Fri Nov 24 09:15:58 2006: P[ 1]  I SEND:SETUP oad:12 dad:76758549 pid:2
Fri Nov 24 09:15:58 2006: P[ 1]   --> bc_state:BCHAN_CLEANED
Fri Nov 24 09:15:58 2006: P[ 1]   --> * SEND: State Dialing pid:2
Fri Nov 24 09:15:58 2006: P[ 1]  I IND :RELEASE_COMPLETE oad: dad: pid:2 state:CALLING
Fri Nov 24 09:15:58 2006: P[ 1]  hangup_chan
Fri Nov 24 09:15:58 2006: P[ 1]  -> queue_hangup
Fri Nov 24 09:15:58 2006: P[ 1]  release_chan: bc with l3id: 30001
Fri Nov 24 09:15:58 2006: P[ 1]  * RELEASING CHANNEL pid:2 ctx:Intern dad:76758549 oad:076758549 state: CALLING
Set to realtime thread
Running as group 'asterisk'
Running as user 'asterisk'
Asterisk 1.2.12.1, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
usw. dann startet dort auch die Asterisk neu.
zapata.conf
[channels]
switchtype=euroisdn
pridialplan=local
prilocaldialplan=local
internationalprefix=00
nationalprefix=0
usecallingpres=yes
busydetect=no   ; not need on pri
callprogress=no ; was yes but wiki says experimatley could be produce hangups
callwaitingcallerid=yes  ; show callerid on callwaitingcalls
echotraining=no
echocancel=no
echocancelwhenbridged=no
overlapdial=yes
immediate=no
callerid=asreceived
language=de
rxgain=0.0
txgain=0.0
group=1
signalling=pri_cpe
context=pri1
;channel => 1-15,17-31
zaptel.conf --> (brauch man überhaupt zaptel bei misdn?!
dort steht nur die language drin wenn ich
#span=1,1,0,ccs,hdb3,crc4
#bchan=1-15,17-31
#dchan=16
nicht kommentiere dann startet zaptel gar nicht mehr
:noidea:
hhhmmm
also ich hab eine ISDN Anlage und eine Leitung geht in die Asterisk.
Wenn jemand auf der Leitung anruft klingelt mein ISDN Telefon aber die Asterisk gibt aus das ein Anruf kommt bzw. das misdn.log
ich kann aber über mein SIP Telefon immer noch nicht raus telefonieren.
release_chan: Ch not found!
full Logfile bringt:
Nov 24 10:43:00 VERBOSE[6927] logger.c: recordingcheck|20061124-104300|1164361380.0: Outbound recording not enabled
Was für einen "Manager" hast Du denn installiert (schreit alles so nach einer "fertiginstallation, á la TrixBox oder so), oder besser : welche Asterisk Version - welche Pakete noch ? Zaptel ist nicht zwingend, es ist halt das "Timing Interface" von Asterisk - ich würde dazu raten es installiert zu lassen.
Hattest Du bei der Installation Fehler ?
Was sagt lspci -v ?
Was sagt misdn-init ?
Was heisst "Asterisk startet neu?" ? Verwendest Du das safe-asterisk ? Oder startet sich der gesamte Rechner neu ?
Bitte konkreter !
Hardware (relevantes) , Anschlüsse , Versionen , ggf. Installationsfehler , am besten einmalig eine Signatur erstellen und schon weiss jeder sofort worum es geht !
Grüsse, Stefan
Ich schiess noch einen hinterher :
Meine misdn.conf beinhaltet folgenden Aufbau :
; CHAN_MISDN Konfigurationsdatei
; Genereller Teil der Konfiguration
[general]
misdn_init=/etc/misdn-init.conf                         ; für den ptp Modus der Pfad zur init-Datei
debug=0                                                 ; Debug Modi : 0,1,2,3,4
tracefile=/var/log/asterisk/misdn/misdn.trace           ; Der zusammenfassende TRACE
bridging=no                                             ; yes/no für misdn_dsp Hardware-Bridging (bei YES und ISDN->ISDN kommt es zur Panic)
stop_tone_after_first_digit=yes                         ;
append_digits2exten=yes                                 ; akzeptiere Überlange Nummern (MSNs) zur Base zB statt xx -> xxx
; Kryptografie-Teil
dynamic_crypt=no                                        ; yes/no für dynamische Kryptografie
; crypt_prefix=                                         ; der erwuenschte prefix fue das dyn.krypt (Standard = nix)
; crypt_keys=testpasswort                               ; der schluessel zum krypten im waehlplan
; DEFAULT-Teil, dies gilt fuer alle Waehlgruppen erst einmal sofern es nicht spaeter wieder ueberschrieben wird
[default]
context=isdn                                            ; der zugehoerende Kontext im Waehlplan
language=de                                             ; Die gewuenschte Verarbeitungssprache der indications.conf
musicclass=default                                      ; MOH Klasse
senddtmf=yes                                            ; DTMF Toene erkennen und ueberschreiben ? Standard ist yes
nationalprefix=0                                        ; Die Prefixe werden in der OAD vergeben !
internationalprefix=00                                  ; s.o.
rxgain=-1                                               ; Die eingehende Lautstaerke von 8 bis -8
txgain=0                                                ; Die ausgehende Lautstaerke von 8 bis -8
te_choose_channel=no                                    ; Zwangswahl des B-Kanals um ominoesen Fehlermeldungen zu begegnen (NL,CH)
pmp_l1_check=yes                                        ; Fuer PMP Kanaele und einen Gruppenruf dieses Anschlusstypes
need_more_infos=no                                      ; Sende Setup_Acknowledge anstatt PROCEEDING bei eingehenden Gespraechen (PTP)
method=standard                                         ; Waehle Standard=den ersten freien oder round_robin=einen zufallskanal
dialplan=0                                              ; ausgehende Nummer
localdialplan=0                                         ; caller-id
cpndialplan=0                                           ; CPN = Nummerbereich des verbundenen Teilnehmers
early_bconnect=yes                                      ; Bei Problemen im Verbindung-Fortschritt auf no setzen ?!
incoming_early_audio=no                                 ; Sende Toene bei Verbindungsauf- und Abbau bei seltsamen Telcos ?!
always_immediate=no                                     ; Springe IMMER zur S extension, egal wer anruft (eingehend)
immediate=no                                            ; Springe zur S extension wenn keine "MSN" gewaehlt wurde (eingehend)
hold_allowed=no                                         ; Aktiviere die ISDN "Tools" wie Hold and Retrieve (Std=no)
callgroup=2                                             ; ANrufergruppe
pickupgroup=2                                           ; Gruppe um das Abheben zu ermoeglichen
presentation=-1                                         ; Die CLID/CLIR Einstellungen
screen=-1                                               ; Schaue ins Default misdn.conf fuer eine genauere Erklaerung
echocancel=32                                           ; 0,32,64,128,256,yes(128),no(0) (nur fuer ausgehende anrufe!)
echocancelwhenbridged=32                                ; Bei einem Bridge zwischen misdn und misdn tritt dies hier in Kraft
; echotraining=no                                               ; Trainiere Echos, 0(aus),yes(2000) oder eine Zahl mit 0.125ms
jitterbuffer=4000                                       ; MISDNs Jitterbuffer
; jitterbuffer_upper_threshold=                         ; Ergaenzen !
hdlc=no                                                 ; misdn und andere applikationen bridgen ?
[isdn_raus]                                             ; AUSGEHEND
echocancel=32
language=de
context=isdn_ausgehend
ports=1,2
[fax]
echocancel=no
language=de
context=faxgeraet
jitterbuffer=4000
msns=24
ports=1,2
[isdn]                                                  ; EINGEHEND
echocancel=32
language=de
context=isdn
msns=*
ports=1,2
Wie sieht Deine im Detail aus ?
Ich nutze (wie i.d. Signatur geschrieben) auch 2 HFCs (2 x Acer Surf PCI)
Meine misdn-init.conf sieht bei dieser Konstellation so aus :
card=1,hfcpci
card=2,hfcpci
te_ptp=1,2
poll=128
#pcm=1,1
#dsp_options=0
debug=0
Das ganze funktioniert so - nun bist Du dran ;)
