##### TITLE Version 148.06.83##### TITLE SubVersion
##### TITLE Produkt Fritz_Box_HW220x
##### TITLE Datum Sat Jan 1 01:05:01 CET 2000
##### BEGIN SECTION Support_Data Supportdata Linux router 2.6.39.3 #1 SMP PREEMPT Fri Mar 17 14:46:17 CET 2017 i686 GNU/Linux Version 148.06.83
Support Data
Sat Jan 1 01:05:02 CET 2000
2.6.39.3
DMC RTL=y
HWRevision 220
HWSubRevision 4
ProductID Fritz_Box_HW220a
SerialNumber XXXXXXXXXXXXXX0
annex Kabel
autoload yes
bootloaderVersion 1.3125
bootserport tty0
country 049
cpufrequency 1200000000
firstfreeaddress 0x4A092684
firmware_info 148.06.83
firmware_version avm
flashsize nor_size=0MB sflash_size=2MB nand_size=4096MB
language de
maca XX:XX:XX:XX:XX:1D
macb XX:XX:XX:XX:XX:1E
macwlan XX:XX:XX:XX:XX:1F
macwlan2 XX:XX:XX:XX:XX:20
macdsl XX:XX:XX:XX:XX:1A
memsize 0x10000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
modulemem 10754340
mtd0 0x0,0x4000000
mtd1 0x4000000,0x4800000
mtd2 0xa0000,0xc0000
mtd3 0xc0000,0x100000
mtd4 0x100000,0x140000
mtd5 0x140000,0x1e0000
mtd6 0x4800000,0x8800000
mtd7 0x8800000,0x9000000
mtd8 0x0,0x80000
mtd9 0x80000,0x90000
mtd10 0x90000,0xa0000
mtd11 0x9000000,0xd000000
mtd12 0xd000000,0xd800000
mtd13 0xd800000,0x11800000
mtd14 0x11800000,0x12000000
my_ipaddress 192.168.178.1
prompt Eva_AVM
req_fullrate_freq 100000000
sysfrequency 100000000
tr069_passphrase SECRET
tr069_serial 00040E-XXXXXXXXXX1D
urlader-version 4125
usb_board_mac XX:XX:XX:XX:XX:1B
usb_device_id 0x0000
usb_device_name USB DSL Device
usb_manufacturer_name AVM
usb_revision_id 0x0000
usb_rndis_mac XX:XX:XX:XX:XX:1C
webgui_pass SECRET
wlan_key SECRET
wlan_ssid FRITZ!Box#6590#Cable#HN
GATEWAY_INTERFACE=CGI/1.1
CONTENT_TYPE=multipart/form-data; boundary=----WebKitFormBoundaryOpTubluV16ql8PEe
CONFIG_FON_HD=y
CONFIG_TIMERCONTROL=y
CONFIG_USB_STORAGE_USERS=n
CONFIG_WLAN=y
CONFIG_WLAN_RADIOSENSOR=y
CONFIG_AB_COUNT=2
CONFIG_EWETEL_SMARTMETER=n
CONFIG_FON_IPPHONE=y
CONFIG_I2C=n
CONFIG_LFS=y
CONFIG_LTE=n
CONFIG_PERL=n
CONFIG_TCPDUMP=n
CONFIG_USB_HOST_AVM=n
CONFIG_UTF8_FULL=y
CONFIG_VPN_CERTSRV=n
CONFIG_WLAN_TXPOWER=y
CONFIG_BETA_RELEASE=0
CONFIG_ATA_NOPASSTHROUGH=y
CONFIG_CAPI_NT=y
CONFIG_JFFS2=n
CONFIG_NFS_CLI=n
CONFIG_ONLINEHELP_URL=https://help.avm.de/fritzbox.php?hardware=220&oem=avm&language=de&country=049&version=148.06.83&subversion=
CONFIG_T38=y
CONFIG_UDEV=y
CONFIG_WLAN_OPENWIFI=n
CONFIG_CODECS_IN_PCMROUTER=y
CONFIG_KIDS_CONTENT=n
CONFIG_LED_EVENTS=y
CONFIG_NFS=n
CONFIG_STOREUSRCFG=y
CONFIG_USB_TETHERING=y
CONFIG_CAPI_XILINX=n
CONFIG_NEUERUL=y
CONFIG_SQLITE=y
CONFIG_UBIK2=n
CONFIG_WLAN_ATH_NM_MAGPIE=n
CONFIG_YAFFS2=n
REMOTE_ADDR=192.168.178.2
CONFIG_CHRONY=y
CONFIG_CONFIGD=y
CONFIG_DSL_UR8=n
CONFIG_FONGUI2=y
CONFIG_WEBGUI_PASS=y
CONFIG_FONQUALITY=y
CONFIG_FTP=y
CONFIG_GPS=n
CONFIG_SQLITE_VIDEO=y
CONFIG_TAM_ONRAM=n
CONFIG_USB=n
CONFIG_WLAN_WDS_NO_SLAVE=y
OEM=avm
CONFIG_ENVIRONMENT_PATH=/proc/sys/urlader
CONFIG_MULTI_COUNTRY=y
CONFIG_PRODUKT_NAME=FRITZ!Box 6590 Cable
CONFIG_VDSL=n
REMOTE_PORT=17358
HTTP_USER_AGENT=Mozilla/5.0
CONFIG_DECT_AUDIOD=y
CONFIG_DECT_NO_EMISSION=y
CONFIG_OPENSSL=y
CONFIG_USB_HOST_TI=n
CONFIG_ASSIST=y
CONFIG_AVMIPC_REMOTE_IP=169.254.1.2
CONFIG_HOME_AUTO=y
CONFIG_LED_NO_DSL_LED=y
CONFIG_NTFS=y
CONFIG_PROV_DEFAULT=n
CONFIG_SWAP=y
CLIENTCONNECTION=192.168.178.2:17358
HTTP_ACCEPT=text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
CONFIG_CAPI_POTS=n
CONFIG_DIAGNOSE_LEVEL=0
CONFIG_USB_INTERNAL_HUB=n
CONFIG_USB_STORAGE=y
CONFIG_VERSION=06.83
CONFIG_SUBVERSION=
CONFIG_MANUAL_URL=https://assets.avm.de/manual/?hardware=220&oem=avm&language=de&country=049&version=148.06.83&subversion=
WEBDIR_PATH=/usr/www/html
CONTENT_LENGTH=248
CONFIG_LIB_RESOLV=y
CONFIG_SAMBA=y
CONFIG_USB_XHCI=n
CONFIG_WEBSRV=y
PATH_TRANSLATED=/usr/www/html/cgi-bin/firmwarecfg
CONFIG_BLUETOOTH_CTP=n
CONFIG_DECT_MONI_EX=y
CONFIG_RELEASE=1
CONFIG_BUILDNUMBER=43781
HTTP_HOST=192.168.178.1
CONFIG_DECT_FW_ULE=y
CONFIG_FIRMWARE_URL=https://www.avm.de/fritzbox-firmware-update.php?hardware=220&oem=avm&language=de&country=049
CONFIG_FLASH_DOUBLE=y
CONFIG_PRODUKT=Fritz_Box_HW220x
CONFIG_SERVICEPORTAL_URL=https://www.avm.de/fritzbox-service-portal.php?hardware=220&oem=avm&language=de&country=049&version=148.06.83&subversion=
CONFIG_ROMSIZE=0-sflash_size=2MB-nand_size=4096MB
HWRevision=220
CONFIG_ACCESSORY_URL=https://www.avm.de/fritzbox_apps.php?hardware=220&oem=avm&language=de&country=049&version=148.06.83&subversion=
CONFIG_BUTTON=n
CONFIG_MAILD=y
CONFIG_NO_EXTENDED_CODECS=n
CONFIG_TR064=y
CONFIG_VERSION_MAJOR=148
CONFIG_XILINX=y
ANNEX=Kabel
CONFIG_BOXLOWRESSOURCES=n
CONFIG_CXX=n
CONFIG_DOCSIS_PCD_NO_REBOOT=n
CONFIG_FIBER=n
CONFIG_MEDIASRV_MOUNT=n
CONFIG_NQOS=y
CONFIG_ONLINEHELP=y
CONFIG_WLAN_ATH_NM_COMBO=n
CONFIG_GDB=n
CONFIG_USB_PRINT_SERV=y
CONFIG_VPN=y
SERVER_SOFTWARE=AVM websrv
CONFIG_ETH_COUNT=4
CONFIG_UPNP=y
CONFIG_CAPI=y
CONFIG_USB_LTE=n
CONFIG_WEBDAV=y
CONFIG_DSL_2DP=n
CONFIG_MAILER=n
CONFIG_TR069=y
CONFIG_WLAN_GUEST=y
CONFIG_WLAN_STANDALONE_MODE=n
CONFIG_CDROM_FALLBACK=n
CONFIG_DECT_HOME_HANFUN=y
CONFIG_FAXSEND=y
CONFIG_ONLINEPB=y
CONFIG_PLC_DETECTION=y
CONFIG_PLUGINV2=n
CONFIG_USB_GSM=y
CONFIG_WLAN_WEATHER_CAC=n
CONFIG_DECT=y
CONFIG_FHEM=n
CONFIG_USB_GSM_VOICE=y
CONFIG_WLAN_WDS=n
PATH=/bin:/usr/bin:/sbin:/usr/sbin
HTTP_ACCEPT_LANGUAGE=de-DE,de;q=0.8,en-US;q=0.6,en;q=0.4
CONFIG_CAPI_UBIK=n
CONFIG_DECT_PICTURED=y
CONFIG_DSL_BONDING=n
CONFIG_FAXSUPPORT=y
CONFIG_INSTALL_TYPE=arm_2GB_xilinx_4eth_2ab_isdn_nt_usb_host_dect_wlan11ac4x4_kabel_31385
CONFIG_MTD_MAILSEND=y
CONFIG_NAND=y
CONFIG_RAMDISK=n
CONFIG_TELEKOM_KOFFER=n
CONFIG_WLAN_1130TNET=n
HTTP_REFERER=https://192.168.178.1/
CONFIG_CONFIGSPACE_ONNAND=n
CONFIG_DECT_HOME=y
CONFIG_HOME_AUTO_NET=y
CONFIG_IGD=y
CONFIG_MULTI_LANGUAGE=y
CONFIG_QOS_METER=y
CONFIG_SRTP=n
CONFIG_WLAN_ATH_NM_PCI=y
CONFIG_WLAN_MADWIFI=y
SERVER_PROTOCOL=HTTP/1.1
CONFIG_DECT_ONOFF=n
CONFIG_EXT2=y
CONFIG_FAX2MAIL=y
CONFIG_MEDIASRV=y
CONFIG_OEM_DEFAULT=avm
CONFIG_PLUGINV2_WEBCM_INTERPRETER=n
CONFIG_UNIQUE_PASSWD=n
CONFIG_WLAN_WMM=y
HTTP_ACCEPT_ENCODING=gzip, deflate, br
CONFIG_ATA=y
CONFIG_AUDIO=n
CONFIG_BASIS=y
CONFIG_BOX_FEEDBACK=n
CONFIG_ERR_FEEDBACK=y
CONFIG_EXT3=y
CONFIG_HOMEI2C=n
CONFIG_MYFRITZ=y
PATH_INFO=/cgi-bin/firmwarecfg
CONFIG_DSL_MULTI_ANNEX=n
CONFIG_ECO=y
CONFIG_EXT4=y
CONFIG_IPV6=y
CONFIG_RETAIL=y
CONFIG_SQLITE_BILDER=y
CONFIG_URLADER_UPDATE=n
CONFIG_VLYNQ=n
CONFIG_VOIP_ENUM=n
CONFIG_WLAN_1350TNET=n
CONFIG_DOCSIS_MODEM=y
CONFIG_INETD=y
CONFIG_LOGD=n
CONFIG_STRACE=n
CONFIG_USB_HOST_INTERNAL=n
CONFIG_CDROM=n
CONFIG_GDB_FULL=n
CONFIG_GFAST=n
CONFIG_HOSTNAME=fritz.box
CONFIG_MEDIACLI=y
CONFIG_NOTELNETD=y
CONFIG_REMOTE_HTTPS=y
CONFIG_SPEEDSTEP=n
CONFIG_USB_WLAN_AUTH=y
CONFIG_UTF8=y
CONFIG_VOL_COUNTER=y
CONFIG_WLAN_EACS=n
CONFIG_WLAN_IPTV=y
CONFIG_AUTOUPDATE=y
CONFIG_DOCSIS_CLI=n
CONFIG_ECO_SYSSTAT=y
CONFIG_LIB_MATH=y
CONFIG_PLUGINV2_TAM=n
CONFIG_USB_HOST=y
CONFIG_USB_STORAGE_SPINDOWN=y
REQUEST_METHOD=POST
CONFIG_AURA=y
CONFIG_DOCSIS=n
CONFIG_MAILER2=y
CONFIG_PLUGINV2_WLAN=n
CONFIG_WLAN_TCOM_PRIO=n
Language=de
SERVER_ADDR=192.168.178.1
CONFIG_CAPI_TE=n
CONFIG_DECT2=y
CONFIG_KIDS=y
CONFIG_MTD_RSS=y
CONFIG_SESSIONID=y
CONFIG_WEBCM_INTERPRETER=y
CONFIG_WLAN_HOTSPOT=y
CONFIG_WLAN_WDS2=y
CONFIG_UPDATEFEATURE_URL=https://www.avm.de/fritzbox_firmware-features.php?hardware=220&oem=avm&language=de&country=049&version=148.06.83&subversion=
CONFIG_ANNEX=Kabel
CONFIG_DECT_MONI=y
CONFIG_SOCAT=n
CONFIG_WEBUSB=y
CONFIG_WLAN_WPS=y
CONFIG_BUILDTYPE=1
CONFIG_NEWSLETTER_URL=https://www.avm.de/newsletter?hardware=220&oem=avm&language=de&country=049&version=148.06.83&subversion=
PWD=/
Country=049
CONFIG_DSL_VENDORID=
CONFIG_LINEARTV=y
CONFIG_MINI=n
CONFIG_PLC=n
HTTPS=on
SERVER_PORT=443
CONFIG_ETH_GBIT=y
CONFIG_TAM_MODE=1
CONFIG_VLYNQ0=0
CONFIG_WLAN_GREEN=n
SCRIPT_NAME=/cgi-bin/firmwarecfg
TZ=CET-1CEST-2,M3.5.0/02:00:00,M10.5.0/03:00:00
CONFIG_CAPI_MIPS=n
CONFIG_FONBOOK2=y
CONFIG_GDB_SERVER=n
CONFIG_MTD_MAIL=y
CONFIG_VLYNQ1=0
CONFIG_WLAN_BRCM=n
CONFIG_WLAN_SAVEMEM=n
CONFIG_ATA_FULL=n
CONFIG_BLUETOOTH=n
CONFIG_LLTD=n
CONFIG_LUA=y
CONFIG_MORPHSTICK=n
CONFIG_NAS=y
CONFIG_NFS_SRV=n
CONFIG_SDK=n
CONFIG_SPEECH_FEEDBACK=y
CONFIG_TAM=y
CONFIG_WLAN_ATH_NM_OFFLOAD=n
CONFIG_WLAN_ATH_NM_USB=n
CONFIG_DECT_CATIQ20=n
CONFIG_DSL=n
CONFIG_FON=y
CONFIG_IPTV_4THOME=n
CONFIG_LIBZ=y
CONFIG_RAMSIZE=128
reset_status=poweron
##### BEGIN SECTION Processes_Memory Processes and Memory
S UID PID PPID VSZ RSS TTY STIME TIME CMD
S 0 1 0 1288 356 0:0 01:00 00:00:04 init
S 0 2 0 0 0 0:0 01:00 00:00:00 [kthreadd]
S 0 3 2 0 0 0:0 01:00 00:00:00 [ksoftirqd/0]
S 0 4 2 0 0 0:0 01:00 00:00:00 [kworker/0:0]
S 0 5 2 0 0 0:0 01:00 00:00:00 [kworker/u:0]
S 0 6 2 0 0 0:0 01:00 00:00:00 [migration/0]
S 0 7 2 0 0 0:0 01:00 00:00:00 [watchdog/0]
S 0 8 2 0 0 0:0 01:00 00:00:00 [migration/1]
S 0 9 2 0 0 0:0 01:00 00:00:00 [kworker/1:0]
S 0 10 2 0 0 0:0 01:00 00:00:00 [ksoftirqd/1]
S 0 11 2 0 0 0:0 01:00 00:00:00 [kworker/0:1]
S 0 12 2 0 0 0:0 01:00 00:00:00 [watchdog/1]
S 0 13 2 0 0 0:0 01:00 00:00:00 [cpuset]
S 0 14 2 0 0 0:0 01:00 00:00:00 [khelper]
S 0 15 2 0 0 0:0 01:00 00:00:00 [kworker/u:1]
S 0 142 2 0 0 0:0 01:00 00:00:00 [sync_supers]
S 0 144 2 0 0 0:0 01:00 00:00:00 [bdi-default]
S 0 145 2 0 0 0:0 01:00 00:00:00 [kintegrityd]
S 0 147 2 0 0 0:0 01:00 00:00:00 [kblockd]
S 0 249 2 0 0 0:0 01:00 00:00:00 [ata_sff]
S 0 259 2 0 0 0:0 01:00 00:00:00 [khubd]
S 0 294 2 0 0 0:0 01:00 00:00:01 [kworker/1:1]
S 0 318 2 0 0 0:0 01:00 00:00:00 [khungtaskd]
S 0 323 2 0 0 0:0 01:00 00:00:00 [kswapd0]
S 0 324 2 0 0 0:0 01:00 00:00:00 [fsnotify_mark]
S 0 326 2 0 0 0:0 01:00 00:00:00 [crypto]
S 0 365 2 0 0 0:0 01:00 00:00:00 [avm_debugd]
S 0 366 2 0 0 0:0 01:00 00:00:00 [avm_event_node]
S 0 433 2 0 0 0:0 01:00 00:00:00 [0000:01:17.0]
S 0 439 2 0 0 0:0 01:00 00:00:00 [mtdblock0]
S 0 445 2 0 0 0:0 01:00 00:00:00 [mtdblock1]
S 0 451 2 0 0 0:0 01:00 00:00:00 [mtdblock2]
S 0 457 2 0 0 0:0 01:00 00:00:00 [mtdblock3]
S 0 463 2 0 0 0:0 01:00 00:00:00 [mtdblock4]
S 0 469 2 0 0 0:0 01:00 00:00:00 [mtdblock5]
S 0 475 2 0 0 0:0 01:00 00:00:00 [mtdblock6]
S 0 481 2 0 0 0:0 01:00 00:00:00 [mtdblock7]
S 0 506 2 0 0 0:0 01:00 00:00:00 [ACC work thread]
S 0 534 2 0 0 0:0 01:00 00:00:00 [kpsmoused]
S 0 549 2 0 0 0:0 01:00 00:00:00 [kworker/u:2]
S 0 551 2 0 0 0:0 01:00 00:00:00 [mmcqd/0]
S 0 569 2 0 0 0:0 01:00 00:00:00 [eventsink_wq]
S 0 570 2 0 0 0:0 01:00 00:00:00 [eventsink_wq]
S 0 571 2 0 0 0:0 01:00 00:00:00 [pm_info]
S 0 572 2 0 0 0:0 01:00 00:00:00 [tffsd]
S 0 573 2 0 0 0:0 01:00 00:00:00 [avmnet_workqueu]
S 0 574 2 0 0 0:0 01:00 00:00:00 [ar8337_worker]
S 0 588 2 0 0 0:0 01:00 00:00:00 [avmnet_timer]
S 0 792 2 0 0 0:0 01:00 00:00:00 [jbd2/mmcblk0p10]
S 0 793 2 0 0 0:0 01:00 00:00:00 [ext4-dio-unwrit]
S 0 809 2 0 0 0:0 01:00 00:00:00 [capi_pipew]
S 0 810 2 0 0 0:0 01:00 00:00:00 [capi_schedw]
S 0 811 2 0 0 0:0 01:00 00:00:00 [pcmlink_ctrl/1]
S 0 812 2 0 0 0:0 01:00 00:00:00 [flush-179:0]
S 0 813 2 0 0 0:0 01:00 00:00:00 [capitransp]
S 0 818 2 0 0 0:0 01:00 00:00:00 [avm_dect_thread]
S 0 896 2 0 0 0:0 01:00 00:00:00 [jbd2/mmcblk0p9-]
S 0 897 2 0 0 0:0 01:00 00:00:00 [ext4-dio-unwrit]
S 0 922 1 1204 576 0:0 01:00 00:00:00 /sbin/udevd --daemon
S 0 931 1 1284 292 0:0 01:00 00:00:00 tail -f /nohup.out
S 0 932 1 1648 748 0:0 01:00 00:00:00 /usr/bin/ptestd -c1
S 0 986 932 1656 352 0:0 01:00 00:00:00 /usr/bin/ptestd -c1
S 0 987 1 1284 292 0:0 01:00 00:00:00 tail -f /var/ptestd/ptest
S 0 1005 1 1800 732 0:0 01:00 00:00:00 /bin/configd
S 0 1007 1 2372 844 0:0 01:00 00:00:00 avmipcd
S 0 1142 2 0 0 0:0 01:00 00:00:00 [flush-254:0]
S 0 1158 1 2764 1108 0:0 01:00 00:00:00 l2tpv3d
S 0 1165 1 16216 10144 0:0 01:00 00:00:05 ctlmgr
S 0 1166 1 16216 10144 0:0 01:00 00:00:00 ctlmgr
S 0 1308 1 16216 10144 0:0 01:00 00:00:00 ctlmgr
S 0 1309 1 16216 10144 0:0 01:00 00:00:00 ctlmgr
S 0 1171 1 7184 3864 0:0 01:00 00:00:01 upnpd
S 0 2327 1 7184 3864 0:0 01:01 00:00:00 upnpd
S 0 2328 1 7184 3864 0:0 01:01 00:00:00 upnpd
S 0 1177 1 3964 2196 0:0 01:00 00:00:00 multid
S 0 1181 2 0 0 0:0 01:00 00:00:00 [kworker/0:2]
S 0 1230 2 0 0 0:0 01:00 00:00:00 [kworker/1:2]
S 0 1240 1 2548 1120 0:0 01:00 00:00:00 pcpd
S 0 1244 1 3016 1056 0:0 01:00 00:00:00 upnpdevd
S 0 1255 1 5216 2856 0:0 01:00 00:00:02 wland -B
S 0 1267 2 0 0 0:0 01:00 00:00:00 [kspeedtest]
S 0 1268 2 0 0 0:0 01:00 00:00:00 [kspeedtest]
D 0 1269 2 0 0 0:0 01:00 00:00:00 [kspeedtest_tcp]
S 0 1271 1 3796 1924 0:0 01:00 00:00:00 dsld -i -n
S 0 1305 1 2780 780 0:0 01:00 00:00:00 pbd
S 0 1338 1 6800 2568 0:0 01:00 00:00:00 telefon a127.0.0.1
S 0 1341 1 6800 2568 0:0 01:00 00:00:00 telefon a127.0.0.1
S 0 1346 1 5480 1564 0:0 01:00 00:00:00 /usr/bin/faxd -a
S 0 1350 1 6160 6156 0:0 01:00 00:00:00 voipd
S 0 1381 1 3220 888 0:0 01:00 00:00:00 aurad
S 0 1382 1 3220 888 0:0 01:00 00:00:00 aurad
S 0 1383 1 3220 888 0:0 01:00 00:00:00 aurad
S 0 1806 922 1172 512 0:0 01:00 00:00:00 /sbin/udevd --daemon
S 0 1807 922 1172 528 0:0 01:00 00:00:00 /sbin/udevd --daemon
S 0 1993 1 1288 324 0:0 01:00 00:00:00 /usr/sbin/inetd
S 0 2119 1 9176 3108 0:0 01:00 00:00:00 /usr/bin/aha
S 0 2121 1 9176 3108 0:0 01:00 00:00:00 {upper_conn} /usr/bin/aha
S 0 2122 1 9176 3108 0:0 01:00 00:00:00 {dectule} /usr/bin/aha
S 0 2123 1 9176 3108 0:0 01:00 00:00:00 {clt:upnp} /usr/bin/aha
S 0 2124 1 9176 3108 0:0 01:00 00:00:00 {clt:upnp} /usr/bin/aha
S 0 2125 1 9176 3108 0:0 01:00 00:00:00 {sRX} /usr/bin/aha
S 0 2388 1 9176 3108 0:0 01:01 00:00:00 {svr:upnp} /usr/bin/aha
S 0 2389 1 9176 3108 0:0 01:01 00:00:00 {svr:upnp} /usr/bin/aha
S 0 2143 1 1616 488 0:0 01:00 00:00:00 /usr/bin/boxnotifyd
S 0 2175 1165 1660 756 0:0 01:00 00:00:00 capiotcp_server -p5031 -m
S 0 2177 2 0 0 0:0 01:00 00:00:00 [ksock tcp worke]
S 0 2178 2 0 0 0:0 01:00 00:00:00 [ksock tcp serve]
S 0 2213 2 0 0 0:0 01:00 00:00:00 [SEC int]
S 0 2249 2 0 0 0:0 01:00 00:00:03 [Clock_ISR]
S 0 2269 2 0 0 0:0 01:00 00:00:00 [TSI_ISR]
S 0 2270 2 0 0 0:0 01:00 00:00:00 [Demux_ISR]
S 0 2281 2 0 0 0:0 01:00 00:00:02 [Demux_IO]
S 0 2289 1 5464 2420 0:0 01:00 00:00:01 cableinfo -N
S 0 2307 1 5464 2420 0:0 01:00 00:00:00 cableinfo -N
S 0 2308 1 5464 2420 0:0 01:00 00:00:00 cableinfo -N
S 0 2297 1 916 144 0:0 01:00 00:00:00 /bin/run_clock -c /dev/tf
S 0 2303 1 1292 376 0:0 01:00 00:00:00 sh -c echo "$0[$$]: ++++f
S 0 2305 1 1288 176 ttyS0 01:00 00:00:00 init
S 0 2306 2303 1276 260 0:0 01:00 00:00:00 sleep 600
S 0 2354 1 1604 688 0:0 01:01 00:00:00 hostapd -B -g /var/run/ho
S 0 2357 1 1856 276 0:0 01:01 00:00:00 wpa_supplicant -B -g /var
S 0 2362 1 1404 616 0:0 01:01 00:00:00 /sbin/lbd
S 0 2412 1165 1292 336 0:0 01:05 00:00:00 sh -c /bin/supportdata
S 0 2413 2412 1292 372 0:0 01:05 00:00:00 {supportdata} /bin/sh /bi
R 0 2600 2413 1280 344 0:0 01:05 00:00:00 ps -lT
Processes sorted by CPU time:
Mem: 129476K used, 104724K free, 0K shrd, 18256K buff, 38516K cached
CPU: 4.3% usr 4.3% sys 0.0% nic 91.3% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 1.00 0.68 0.30 1/125 2601
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
1165 1 root S 16216 6.8 0 0.0 ctlmgr
2119 1 root S 9176 3.8 1 0.0 /usr/bin/aha
1171 1 root S 7184 3.0 0 0.0 upnpd
1338 1 root S 6800 2.8 1 0.0 telefon a127.0.0.1
1350 1 root S < 6160 2.6 0 0.0 voipd
1346 1 root S 5480 2.3 1 0.0 /usr/bin/faxd -a
2289 1 root S 5464 2.3 0 0.0 cableinfo -N
1255 1 root S 5216 2.2 1 0.0 wland -B
1177 1 root S 3964 1.6 1 0.0 multid
1271 1 root S 3796 1.6 0 0.0 dsld -i -n
1381 1 root S 3220 1.3 1 0.0 aurad
1244 1 root S 3016 1.2 1 0.0 upnpdevd
1305 1 root S 2780 1.1 1 0.0 pbd
1158 1 root S 2764 1.1 0 0.0 l2tpv3d
1240 1 root S 2548 1.0 0 0.0 pcpd
1007 1 root S 2372 1.0 0 0.0 avmipcd
2357 1 root S 1856 0.7 0 0.0 wpa_supplicant -B -g /var/run/wpa_supplicant/global -D athr
1005 1 root S 1800 0.7 1 0.0 /bin/configd
2175 1165 root S 1660 0.7 0 0.0 capiotcp_server -p5031 -m1
986 932 root S 1656 0.7 1 0.0 /usr/bin/ptestd -c1
932 1 root S 1648 0.7 0 0.0 /usr/bin/ptestd -c1
2143 1 root S 1616 0.6 0 0.0 /usr/bin/boxnotifyd
2354 1 root S 1604 0.6 0 0.0 hostapd -B -g /var/run/hostapd/global
2362 1 root S 1404 0.6 0 0.0 /sbin/lbd
2412 1165 root S 1292 0.5 0 0.0 sh -c /bin/supportdata
2413 2412 root S 1292 0.5 1 0.0 {supportdata} /bin/sh /bin/supportdata
2303 1 root S 1292 0.5 0 0.0 sh -c echo "$0[$$]: ++++fork set_modulemen, sleep 600++++" > /dev/console ; sleep 600; echo "$0[$$]: ++++do set_modulemen++++" > /dev/console; /bin/set_modulemem;
1 0 root S 1288 0.5 1 0.0 init
2305 1 root S 1288 0.5 1 0.0 init
2601 2413 root R 1288 0.5 1 0.0 top -b -n1
1993 1 root S 1288 0.5 0 0.0 /usr/sbin/inetd
931 1 root S 1284 0.5 0 0.0 tail -f /nohup.out
987 1 root S 1284 0.5 1 0.0 tail -f /var/ptestd/ptestd.log
2306 2303 root S 1276 0.5 0 0.0 sleep 600
922 1 root S 1204 0.5 0 0.0 /sbin/udevd --daemon
1806 922 root S 1172 0.5 1 0.0 /sbin/udevd --daemon
1807 922 root S 1172 0.5 0 0.0 /sbin/udevd --daemon
2297 1 root S 916 0.3 0 0.0 /bin/run_clock -c /dev/tffs -d
2249 2 root SW 0 0.0 0 0.0 [Clock_ISR]
2281 2 root SW 0 0.0 1 0.0 [Demux_IO]
294 2 root SW 0 0.0 1 0.0 [kworker/1:1]
818 2 root SW< 0 0.0 0 0.0 [avm_dect_thread]
15 2 root SW 0 0.0 0 0.0 [kworker/u:1]
551 2 root SW 0 0.0 0 0.0 [mmcqd/0]
5 2 root SW 0 0.0 0 0.0 [kworker/u:0]
366 2 root SW 0 0.0 0 0.0 [avm_event_node]
1230 2 root SW 0 0.0 1 0.0 [kworker/1:2]
11 2 root SW 0 0.0 0 0.0 [kworker/0:1]
811 2 root SW 0 0.0 1 0.0 [pcmlink_ctrl/1]
506 2 root SW 0 0.0 0 0.0 [ACC work thread]
792 2 root SW 0 0.0 1 0.0 [jbd2/mmcblk0p10]
571 2 root SW 0 0.0 1 0.0 [pm_info]
445 2 root SW 0 0.0 0 0.0 [mtdblock1]
13 2 root SW< 0 0.0 0 0.0 [cpuset]
12 2 root SW 0 0.0 1 0.0 [watchdog/1]
3 2 root SW 0 0.0 0 0.0 [ksoftirqd/0]
144 2 root SW 0 0.0 0 0.0 [bdi-default]
145 2 root SW< 0 0.0 1 0.0 [kintegrityd]
6 2 root SW 0 0.0 0 0.0 [migration/0]
7 2 root SW 0 0.0 0 0.0 [watchdog/0]
8 2 root SW 0 0.0 1 0.0 [migration/1]
475 2 root SW 0 0.0 1 0.0 [mtdblock6]
481 2 root SW 0 0.0 0 0.0 [mtdblock7]
809 2 root SW< 0 0.0 1 0.0 [capi_pipew]
810 2 root SW< 0 0.0 1 0.0 [capi_schedw]
326 2 root SW< 0 0.0 0 0.0 [crypto]
14 2 root SW< 0 0.0 1 0.0 [khelper]
2 0 root SW 0 0.0 1 0.0 [kthreadd]
142 2 root SW 0 0.0 1 0.0 [sync_supers]
439 2 root SW 0 0.0 1 0.0 [mtdblock0]
1181 2 root SW 0 0.0 0 0.0 [kworker/0:2]
451 2 root SW 0 0.0 1 0.0 [mtdblock2]
457 2 root SW 0 0.0 0 0.0 [mtdblock3]
463 2 root SW 0 0.0 1 0.0 [mtdblock4]
469 2 root SW 0 0.0 0 0.0 [mtdblock5]
10 2 root SW 0 0.0 1 0.0 [ksoftirqd/1]
1268 2 root SW 0 0.0 0 0.0 [kspeedtest]
1269 2 root DW 0 0.0 0 0.0 [kspeedtest_tcp]
534 2 root SW< 0 0.0 0 0.0 [kpsmoused]
549 2 root SW 0 0.0 1 0.0 [kworker/u:2]
813 2 root SW 0 0.0 1 0.0 [capitransp]
433 2 root SW< 0 0.0 1 0.0 [0000:01:17.0]
570 2 root SW< 0 0.0 1 0.0 [eventsink_wq]
4 2 root SW 0 0.0 0 0.0 [kworker/0:0]
572 2 root SW 0 0.0 0 0.0 [tffsd]
573 2 root SW< 0 0.0 0 0.0 [avmnet_workqueu]
574 2 root SW 0 0.0 1 0.0 [ar8337_worker]
588 2 root SW< 0 0.0 1 0.0 [avmnet_timer]
1267 2 root SW 0 0.0 0 0.0 [kspeedtest]
793 2 root SW< 0 0.0 1 0.0 [ext4-dio-unwrit]
2177 2 root SW 0 0.0 1 0.0 [ksock tcp worke]
2178 2 root SW 0 0.0 1 0.0 [ksock tcp serve]
2213 2 root SW 0 0.0 1 0.0 [SEC int]
812 2 root SW 0 0.0 1 0.0 [flush-179:0]
569 2 root SW< 0 0.0 1 0.0 [eventsink_wq]
2270 2 root SW 0 0.0 1 0.0 [Demux_ISR]
896 2 root SW 0 0.0 0 0.0 [jbd2/mmcblk0p9-]
897 2 root SW< 0 0.0 0 0.0 [ext4-dio-unwrit]
147 2 root SW< 0 0.0 0 0.0 [kblockd]
249 2 root SW< 0 0.0 1 0.0 [ata_sff]
259 2 root SW 0 0.0 1 0.0 [khubd]
9 2 root SW 0 0.0 1 0.0 [kworker/1:0]
318 2 root SW 0 0.0 1 0.0 [khungtaskd]
323 2 root SW 0 0.0 0 0.0 [kswapd0]
324 2 root SW 0 0.0 1 0.0 [fsnotify_mark]
1142 2 root SW 0 0.0 0 0.0 [flush-254:0]
365 2 root SWN 0 0.0 1 0.0 [avm_debugd]
2269 2 root SW 0 0.0 0 0.0 [TSI_ISR]
Processes sorted by Memory used:
Mem total:234200 anon:17532 map:13556 free:104664
slab:32192 buf:18256 cache:38516 dirty:0 write:0
Swap total:16380 free:16380
PID VSZ^VSZRW RSS (SHR) DIRTY (SHR) STACK COMMAND
1165 16216 7284 10144 3160 4400 216 136 ctlmgr
2119 9176 5980 3108 1260 1224 0 212 /usr/bin/aha
1171 7184 2716 3864 2292 1364 16 136 upnpd
1338 6800 2196 2568 980 1248 64 136 telefon a127.0.0.1
1350 6160 1484 6156 2760 1216 144 136 voipd
1346 5480 1008 1564 948 592 12 136 /usr/bin/faxd -a
2289 5464 2336 2420 744 1132 4 136 cableinfo -N
1255 5216 1852 2856 872 1188 0 136 wland -B
1177 3964 1244 2196 1168 832 60 136 multid
1271 3796 1144 1924 1144 664 64 136 dsld -i -n
1381 3220 1396 888 456 396 0 136 aurad
1244 3016 1016 1056 716 324 16 136 upnpdevd
1305 2780 648 780 408 304 4 136 pbd
1158 2764 508 1108 764 312 8 136 l2tpv3d
1240 2548 484 1120 812 292 4 136 pcpd
1007 2372 420 844 540 292 0 136 avmipcd
2357 1856 220 276 144 104 0 136 wpa_supplicant -B -g /var/run/wpa_supplicant/global -D athr
1005 1800 428 732 416 308 0 136 /bin/configd
2175 1660 364 756 536 208 0 136 capiotcp_server -p5031 -m1
986 1656 340 352 276 208 132 136 /usr/bin/ptestd -c1
932 1648 332 748 648 208 132 136 /usr/bin/ptestd -c1
2143 1616 328 488 292 184 0 136 /usr/bin/boxnotifyd
2354 1604 264 688 224 156 0 136 hostapd -B -g /var/run/hostapd/global
2362 1404 276 616 220 144 0 136 /sbin/lbd
2413 1292 208 392 312 80 0 136 {supportdata} /bin/sh /bin/supportdata
2303 1292 208 376 300 76 0 136 sh -c echo "$0[$$]: ++++fork set_modulemen, sleep 600++++" > /dev/console ; sleep 600; echo "$0[$$]: ++++do set_modulemen++++" > /dev/console; /bin/set_modulemem;
2412 1292 208 336 264 72 0 136 sh -c /bin/supportdata
1993 1288 204 324 232 76 0 136 /usr/sbin/inetd
2602 1288 204 364 280 76 0 136 top -b -n1 -m
1 1288 204 356 324 68 40 132 init
2305 1288 204 176 148 68 40 132 init
931 1284 200 292 228 64 0 136 tail -f /nohup.out
987 1284 200 292 228 64 0 136 tail -f /var/ptestd/ptestd.log
2306 1276 192 260 196 60 0 136 sleep 600
922 1204 400 576 308 304 40 136 /sbin/udevd --daemon
1807 1172 368 528 296 276 44 136 /sbin/udevd --daemon
1806 1172 368 512 288 272 48 136 /sbin/udevd --daemon
2297 916 196 144 72 64 0 136 /bin/run_clock -c /dev/tffs -d
Module Size Used by Tainted: P
ath_pktlog 13888 0
ismddemux_v3 465187 0
ismdfw_manager 9582 0
ismdclock_recovery 24601 1 ismddemux_v3
ismdclock 223766 0
ismdcore 3309768 4 ismddemux_v3,ismdfw_manager,ismdclock_recovery,ismdclock
ioctl_module 2408 5 ismddemux_v3,ismdfw_manager,ismdclock_recovery,ismdclock,ismdcore
sec_kernel 131164 2 ismddemux_v3,ismdfw_manager
system_utils_linux 1670 3 ismddemux_v3,ismdfw_manager,sec_kernel
intel_ce_pm 39495 3 ismddemux_v3,ismdcore,sec_kernel
clock_control 17729 3 ismdclock,sec_kernel,intel_ce_pm
iosf_wrap 1366 3 ismdclock,sec_kernel,intel_ce_pm
sven_linux 26888 6 ismddemux_v3,ismdclock_recovery,ismdclock,ismdcore,sec_kernel,clock_control
platform_config 12154 10 ismddemux_v3,ismdfw_manager,ismdclock_recovery,ismdclock,ismdcore,sec_kernel,system_utils_linux,intel_ce_pm,clock_control,sven_linux
idl_i2c 2210 1 clock_control
idl_gpio_shim 1401 0
pal_linux 10018 6 ismddemux_v3,ismdclock,ismdcore,intel_ce_pm,clock_control,sven_linux
osal_linux 13088 10 ismddemux_v3,ismdfw_manager,ismdclock_recovery,ismdclock,ismdcore,sec_kernel,system_utils_linux,intel_ce_pm,clock_control,sven_linux
ehci_hcd 31688 0
umac 1960478 2 ath_pktlog
krtp 113316 0
ath_dev 297357 2 ath_pktlog,umac
hst_tx99 8495 2 umac,ath_dev
ath_spectral 33884 3 umac,ath_dev
ath_dfs 56841 1 umac
ath_rate_atheros 34612 3 ath_pktlog,umac,ath_dev
ath_hal 646516 5 ath_pktlog,umac,ath_dev,hst_tx99,ath_rate_atheros
adf 14148 4 umac,ath_dev,hst_tx99,ath_hal
asf 5553 6 ath_pktlog,umac,ath_dev,ath_spectral,ath_dfs,ath_hal
aae 78078 3 umac,ath_dev,ath_hal
kspeedtest 12924 0
kdsldmod 1316492 4
zram 7241 1
lzo_compress 1589 1 zram
dect_io 9399 0
avm_dect 226395 1 dect_io
capi_codec 369093 0
isdn_fbox_fon5 673648 8 krtp
pcmlink 356279 4 avm_dect,capi_codec,isdn_fbox_fon5
Piglet_noemif 23380 0
led_modul_Fritz_Box_HW220x 2615 8
01:05:02 up 4 min, load average: 1.00, 0.68, 0.30
total used free shared buffers
Mem: 234200 129536 104664 0 18256
-/+ buffers: 111280 122920
Swap: 16380 0 16380
slabinfo
slabinfo - version: 2.1
# name <active_objs> <num_objs> <objsize> <objperslab> <pagesperslab> : tunables <limit> <batchcount> <sharedfactor> : slabdata <active_slabs> <num_slabs> <sharedavail>
pcpitem 0 0 284 14 1 : tunables 54 27 8 : slabdata 0 0 0
pcp_item_cfg 16 18 212 18 1 : tunables 120 60 8 : slabdata 1 1 0
qos_neighbour 3 67 56 67 1 : tunables 120 60 8 : slabdata 1 1 0
qos_ethaddr 1 84 44 84 1 : tunables 120 60 8 : slabdata 1 1 0
timercb 3 78 48 78 1 : tunables 120 60 8 : slabdata 1 1 0
lisp_prefix 0 0 44 84 1 : tunables 120 60 8 : slabdata 0 0 0
lisp_locator 0 0 48 78 1 : tunables 120 60 8 : slabdata 0 0 0
lisp_record 0 0 220 18 1 : tunables 120 60 8 : slabdata 0 0 0
lisp_mr 0 0 184 21 1 : tunables 120 60 8 : slabdata 0 0 0
lisp_address 0 0 36 101 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_routeset 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_pingerwaiter 0 0 28 127 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_pingerentry 0 0 40 92 1 : tunables 120 60 8 : slabdata 0 0 0
pcp66 0 0 252 15 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_ct_appldatacache 0 0 8 339 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_ct_addrinfo 0 0 28 127 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_ct_extern 0 0 108 36 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_ct_intern 0 0 84 46 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_neighbour 0 0 72 53 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_ndisc_router 0 0 44 84 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_ndisc_prefix 0 0 36 101 1 : tunables 120 60 8 : slabdata 0 0 0
ip6_destination 0 0 44 84 1 : tunables 120 60 8 : slabdata 0 0 0
etherarp 0 0 60 63 1 : tunables 120 60 8 : slabdata 0 0 0
iprouteset 0 0 168 23 1 : tunables 120 60 8 : slabdata 0 0 0
pingerentry 0 0 28 127 1 : tunables 120 60 8 : slabdata 0 0 0
dnsstaticentry 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
dnsmasqentry 0 0 80 48 1 : tunables 120 60 8 : slabdata 0 0 0
ipsecconnection 0 0 132 29 1 : tunables 120 60 8 : slabdata 0 0 0
ipsecencap 0 0 2100 3 2 : tunables 24 12 8 : slabdata 0 0 0
ipsecsa 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
pcp44 0 0 176 22 1 : tunables 120 60 8 : slabdata 0 0 0
ipmasqaddrinfo 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
ipmasqmcsource 0 0 8 339 1 : tunables 120 60 8 : slabdata 0 0 0
ipmasqmcgroup 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
ipmasqappldata 0 0 24 145 1 : tunables 120 60 8 : slabdata 0 0 0
ipmasqentry 0 0 100 39 1 : tunables 120 60 8 : slabdata 0 0 0
ipmasqmapping 0 0 80 48 1 : tunables 120 60 8 : slabdata 0 0 0
ipfragid 0 0 108 36 1 : tunables 120 60 8 : slabdata 0 0 0
ipaccessrule 9 50 76 50 1 : tunables 120 60 8 : slabdata 1 1 0
ipaccessset 4 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
datapipe_enotifier 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
datapipe_flow 0 0 36 101 1 : tunables 120 60 8 : slabdata 0 0 0
datapipe_notifier 44 203 16 203 1 : tunables 120 60 8 : slabdata 1 1 0
datapipe_mod 40 46 84 46 1 : tunables 120 60 8 : slabdata 1 1 0
datapipe 1 1 9000 1 4 : tunables 8 4 0 : slabdata 1 1 0
ext4_groupinfo_1k 24 40 96 40 1 : tunables 120 60 8 : slabdata 1 1 0
jbd2_1k 0 0 1024 4 1 : tunables 54 27 8 : slabdata 0 0 0
ext4_groupinfo_4k 26 37 104 37 1 : tunables 120 60 8 : slabdata 1 1 0
SCTPv6 1 4 960 4 1 : tunables 54 27 8 : slabdata 1 1 0
SCTP 0 0 832 9 2 : tunables 54 27 8 : slabdata 0 0 0
sctp_chunk 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
sctp_bind_bucket 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
L2TP/IPv6 0 0 640 6 1 : tunables 54 27 8 : slabdata 0 0 0
L2TP/IP 1 7 512 7 1 : tunables 54 27 8 : slabdata 1 1 0
bridge_fdb_cache 9 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
fib6_nodes 23 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
ip6_dst_cache 25 60 192 20 1 : tunables 120 60 8 : slabdata 3 3 0
ndisc_cache 7 40 192 20 1 : tunables 120 60 8 : slabdata 2 2 0
ip6_mrt_cache 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
RAWv6 6 11 704 11 2 : tunables 54 27 8 : slabdata 1 1 0
UDPLITEv6 0 0 704 11 2 : tunables 54 27 8 : slabdata 0 0 0
UDPv6 32 33 704 11 2 : tunables 54 27 8 : slabdata 3 3 0
tw_sock_TCPv6 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
request_sock_TCPv6 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
TCPv6 28 30 1280 3 1 : tunables 24 12 8 : slabdata 10 10 0
sd_ext_cdb 2 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
cfq_io_context 59 59 64 59 1 : tunables 120 60 8 : slabdata 1 1 0
cfq_queue 52 52 148 26 1 : tunables 120 60 8 : slabdata 2 2 0
bsg_cmd 0 0 284 14 1 : tunables 54 27 8 : slabdata 0 0 0
mqueue_inode_cache 2 7 576 7 1 : tunables 54 27 8 : slabdata 1 1 0
fuse_request 0 0 376 10 1 : tunables 54 27 8 : slabdata 0 0 0
fuse_inode 0 0 448 9 1 : tunables 54 27 8 : slabdata 0 0 0
jffs2_inode_cache 0 0 24 145 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_node_frag 0 0 24 145 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_refblock 0 0 248 16 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_tmp_dnode 0 0 32 113 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_raw_inode 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_raw_dirent 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_full_dnode 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
jffs2_i 0 0 392 10 1 : tunables 54 27 8 : slabdata 0 0 0
fat_inode_cache 0 0 400 10 1 : tunables 54 27 8 : slabdata 0 0 0
fat_cache 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
squashfs_inode_cache 1008 1008 448 9 1 : tunables 54 27 8 : slabdata 112 112 0
jbd2_inode 1 145 24 145 1 : tunables 120 60 8 : slabdata 1 1 0
jbd2_journal_handle 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
jbd2_journal_head 7 59 64 59 1 : tunables 120 60 8 : slabdata 1 1 0
jbd2_revoke_table 4 254 12 254 1 : tunables 120 60 8 : slabdata 1 1 0
jbd2_revoke_record 0 0 32 113 1 : tunables 120 60 8 : slabdata 0 0 0
journal_head 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
revoke_table 0 0 12 254 1 : tunables 120 60 8 : slabdata 0 0 0
revoke_record 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
ext4_inode_cache 26 42 568 7 1 : tunables 54 27 8 : slabdata 6 6 0
ext4_free_data 0 0 36 101 1 : tunables 120 60 8 : slabdata 0 0 0
ext4_allocation_context 0 0 112 35 1 : tunables 120 60 8 : slabdata 0 0 0
ext4_prealloc_space 2 56 68 56 1 : tunables 120 60 8 : slabdata 1 1 0
ext4_system_zone 0 0 24 145 1 : tunables 120 60 8 : slabdata 0 0 0
ext4_io_end 0 0 572 7 1 : tunables 54 27 8 : slabdata 0 0 0
ext4_io_page 0 0 8 339 1 : tunables 120 60 8 : slabdata 0 0 0
ext2_inode_cache 0 0 488 8 1 : tunables 54 27 8 : slabdata 0 0 0
ext2_xattr 0 0 48 78 1 : tunables 120 60 8 : slabdata 0 0 0
ext3_inode_cache 0 0 500 8 1 : tunables 54 27 8 : slabdata 0 0 0
ext3_xattr 0 0 48 78 1 : tunables 120 60 8 : slabdata 0 0 0
kioctx 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
kiocb 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
fanotify_response_event 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
fsnotify_mark 0 0 72 53 1 : tunables 120 60 8 : slabdata 0 0 0
inotify_event_private_data 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
inotify_inode_mark 39 50 76 50 1 : tunables 120 60 8 : slabdata 1 1 0
dnotify_mark 0 0 76 50 1 : tunables 120 60 8 : slabdata 0 0 0
dnotify_struct 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
fasync_cache 0 0 28 127 1 : tunables 120 60 8 : slabdata 0 0 0
nsproxy 0 0 24 145 1 : tunables 120 60 8 : slabdata 0 0 0
posix_timers_cache 0 0 96 40 1 : tunables 120 60 8 : slabdata 0 0 0
uid_cache 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
UNIX 120 120 512 8 1 : tunables 54 27 8 : slabdata 15 15 0
ip_mrt_cache 4 30 128 30 1 : tunables 120 60 8 : slabdata 1 1 0
UDP-Lite 0 0 576 7 1 : tunables 54 27 8 : slabdata 0 0 0
tcp_bind_bucket 32 226 32 113 1 : tunables 120 60 8 : slabdata 2 2 0
inet_peer_cache 16 20 192 20 1 : tunables 120 60 8 : slabdata 1 1 0
ip_fib_trie 21 127 28 127 1 : tunables 120 60 8 : slabdata 1 1 0
ip_fib_alias 24 145 24 145 1 : tunables 120 60 8 : slabdata 1 1 0
ip_dst_cache 212 220 192 20 1 : tunables 120 60 8 : slabdata 11 11 0
arp_cache 11 20 192 20 1 : tunables 120 60 8 : slabdata 1 1 0
RAW 7 7 512 7 1 : tunables 54 27 8 : slabdata 1 1 0
UDP 28 28 576 7 1 : tunables 54 27 8 : slabdata 4 4 0
tw_sock_TCP 4 30 128 30 1 : tunables 120 60 8 : slabdata 1 1 0
request_sock_TCP 7 30 128 30 1 : tunables 120 60 8 : slabdata 1 1 0
TCP 9 14 1152 7 2 : tunables 24 12 8 : slabdata 2 2 0
eventpoll_pwq 234 303 36 101 1 : tunables 120 60 8 : slabdata 3 3 0
eventpoll_epi 234 300 128 30 1 : tunables 120 60 8 : slabdata 10 10 0
sgpool-128 2 3 2560 3 2 : tunables 24 12 8 : slabdata 1 1 0
sgpool-64 2 3 1280 3 1 : tunables 24 12 8 : slabdata 1 1 0
sgpool-32 2 6 640 6 1 : tunables 54 27 8 : slabdata 1 1 0
sgpool-16 2 12 320 12 1 : tunables 54 27 8 : slabdata 1 1 0
sgpool-8 2 20 192 20 1 : tunables 120 60 8 : slabdata 1 1 0
scsi_data_buffer 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
blkdev_integrity 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
blkdev_queue 34 36 944 4 1 : tunables 54 27 8 : slabdata 9 9 0
blkdev_requests 38 68 228 17 1 : tunables 120 60 8 : slabdata 4 4 0
blkdev_ioc 76 78 48 78 1 : tunables 120 60 8 : slabdata 1 1 0
fsnotify_event_holder 0 0 12 254 1 : tunables 120 60 8 : slabdata 0 0 0
fsnotify_event 1 59 64 59 1 : tunables 120 60 8 : slabdata 1 1 0
bio-0 60 60 128 30 1 : tunables 120 60 8 : slabdata 2 2 0
biovec-256 2 2 3072 2 2 : tunables 24 12 8 : slabdata 1 1 0
biovec-128 0 0 1536 5 2 : tunables 24 12 8 : slabdata 0 0 0
biovec-64 0 0 768 5 1 : tunables 54 27 8 : slabdata 0 0 0
biovec-16 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
bip-256 2 2 3136 2 2 : tunables 24 12 8 : slabdata 1 1 0
bip-128 0 0 1600 5 2 : tunables 24 12 8 : slabdata 0 0 0
bip-64 0 0 832 9 2 : tunables 54 27 8 : slabdata 0 0 0
bip-16 0 0 256 15 1 : tunables 120 60 8 : slabdata 0 0 0
bip-4 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
bip-1 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
sock_inode_cache 268 290 384 10 1 : tunables 54 27 8 : slabdata 29 29 0
generic_ct 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
skbuff_fclone_cache 21 32 896 4 1 : tunables 54 27 8 : slabdata 8 8 0
skbuff_head_cache 5098 5382 448 9 1 : tunables 54 27 8 : slabdata 598 598 3
file_lock_cache 16 39 100 39 1 : tunables 120 60 8 : slabdata 1 1 0
shmem_inode_cache 1107 1107 440 9 1 : tunables 54 27 8 : slabdata 123 123 0
Acpi-Operand 556 588 44 84 1 : tunables 120 60 8 : slabdata 7 7 0
Acpi-ParseExt 0 0 48 78 1 : tunables 120 60 8 : slabdata 0 0 0
Acpi-Parse 0 0 32 113 1 : tunables 120 60 8 : slabdata 0 0 0
Acpi-State 0 0 44 84 1 : tunables 120 60 8 : slabdata 0 0 0
Acpi-Namespace 302 435 24 145 1 : tunables 120 60 8 : slabdata 3 3 0
proc_inode_cache 1240 1240 368 10 1 : tunables 54 27 8 : slabdata 124 124 0
sigqueue 9 81 144 27 1 : tunables 120 60 8 : slabdata 1 3 0
bdev_cache 21 35 512 7 1 : tunables 54 27 8 : slabdata 5 5 0
sysfs_dir_cache 9551 9594 48 78 1 : tunables 120 60 8 : slabdata 123 123 0
mnt_cache 24 40 192 20 1 : tunables 120 60 8 : slabdata 2 2 0
filp 1620 1620 128 30 1 : tunables 120 60 8 : slabdata 54 54 240
inode_cache 1672 1672 344 11 1 : tunables 54 27 8 : slabdata 152 152 0
dentry 5550 5550 128 30 1 : tunables 120 60 8 : slabdata 185 185 0
names_cache 12 12 4096 1 1 : tunables 24 12 8 : slabdata 12 12 0
key_jar 1 30 128 30 1 : tunables 120 60 8 : slabdata 1 1 0
buffer_head 14733 14740 56 67 1 : tunables 120 60 8 : slabdata 220 220 0
vm_area_struct 2336 2478 92 42 1 : tunables 120 60 8 : slabdata 59 59 240
mm_struct 89 99 448 9 1 : tunables 54 27 8 : slabdata 11 11 0
fs_cache 109 177 64 59 1 : tunables 120 60 8 : slabdata 3 3 0
files_cache 120 120 256 15 1 : tunables 120 60 8 : slabdata 8 8 0
signal_cache 161 182 512 7 1 : tunables 54 27 8 : slabdata 26 26 0
sighand_cache 128 132 1344 3 1 : tunables 24 12 8 : slabdata 44 44 0
task_xstate 109 144 512 8 1 : tunables 54 27 8 : slabdata 18 18 0
task_struct 168 168 944 4 1 : tunables 54 27 8 : slabdata 42 42 0
cred_jar 283 330 128 30 1 : tunables 120 60 8 : slabdata 11 11 0
anon_vma_chain 2867 3480 24 145 1 : tunables 120 60 8 : slabdata 24 24 360
anon_vma 2306 2704 20 169 1 : tunables 120 60 8 : slabdata 16 16 180
pid 260 295 64 59 1 : tunables 120 60 8 : slabdata 5 5 0
radix_tree_node 650 650 296 13 1 : tunables 54 27 8 : slabdata 50 50 0
idr_layer_cache 246 260 148 26 1 : tunables 120 60 8 : slabdata 10 10 0
size-4194304(DMA) 0 0 4194304 1 1024 : tunables 1 1 0 : slabdata 0 0 0
size-4194304 0 0 4194304 1 1024 : tunables 1 1 0 : slabdata 0 0 0
size-2097152(DMA) 0 0 2097152 1 512 : tunables 1 1 0 : slabdata 0 0 0
size-2097152 0 0 2097152 1 512 : tunables 1 1 0 : slabdata 0 0 0
size-1048576(DMA) 0 0 1048576 1 256 : tunables 1 1 0 : slabdata 0 0 0
size-1048576 0 0 1048576 1 256 : tunables 1 1 0 : slabdata 0 0 0
size-524288(DMA) 0 0 524288 1 128 : tunables 1 1 0 : slabdata 0 0 0
size-524288 4 4 524288 1 128 : tunables 1 1 0 : slabdata 4 4 0
size-262144(DMA) 0 0 262144 1 64 : tunables 1 1 0 : slabdata 0 0 0
size-262144 2 2 262144 1 64 : tunables 1 1 0 : slabdata 2 2 0
size-131072(DMA) 0 0 131072 1 32 : tunables 8 4 0 : slabdata 0 0 0
size-131072 4 4 131072 1 32 : tunables 8 4 0 : slabdata 4 4 0
size-65536(DMA) 0 0 65536 1 16 : tunables 8 4 0 : slabdata 0 0 0
size-65536 14 14 65536 1 16 : tunables 8 4 0 : slabdata 14 14 0
size-32768(DMA) 0 0 32768 1 8 : tunables 8 4 0 : slabdata 0 0 0
size-32768 29 29 32768 1 8 : tunables 8 4 0 : slabdata 29 29 0
size-16384(DMA) 0 0 16384 1 4 : tunables 8 4 0 : slabdata 0 0 0
size-16384 84 85 16384 1 4 : tunables 8 4 0 : slabdata 84 85 0
size-8192(DMA) 0 0 8192 1 2 : tunables 8 4 0 : slabdata 0 0 0
size-8192 76 76 8192 1 2 : tunables 8 4 0 : slabdata 76 76 0
size-4096(DMA) 0 0 4096 1 1 : tunables 24 12 8 : slabdata 0 0 0
size-4096 2811 2811 4096 1 1 : tunables 24 12 8 : slabdata 2811 2811 0
size-2048(DMA) 0 0 2048 2 1 : tunables 24 12 8 : slabdata 0 0 0
size-2048 586 604 2048 2 1 : tunables 24 12 8 : slabdata 302 302 0
size-1024(DMA) 0 0 1024 4 1 : tunables 54 27 8 : slabdata 0 0 0
size-1024 2333 2344 1024 4 1 : tunables 54 27 8 : slabdata 586 586 0
size-512(DMA) 0 0 512 8 1 : tunables 54 27 8 : slabdata 0 0 0
size-512 928 928 512 8 1 : tunables 54 27 8 : slabdata 116 116 0
size-256(DMA) 0 0 256 15 1 : tunables 120 60 8 : slabdata 0 0 0
size-256 396 420 256 15 1 : tunables 120 60 8 : slabdata 28 28 0
size-192(DMA) 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
size-192 200 200 192 20 1 : tunables 120 60 8 : slabdata 10 10 0
size-128(DMA) 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
size-128 1980 1980 128 30 1 : tunables 120 60 8 : slabdata 66 66 0
size-64(DMA) 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
size-32(DMA) 0 0 32 113 1 : tunables 120 60 8 : slabdata 0 0 0
size-64 5015 5015 64 59 1 : tunables 120 60 8 : slabdata 85 85 0
size-32 10718 10735 32 113 1 : tunables 120 60 8 : slabdata 95 95 0
kmem_cache 229 240 128 30 1 : tunables 120 60 8 : slabdata 8 8 0
meminfo
MemTotal: 234200 kB
MemFree: 104664 kB
Buffers: 18256 kB
Cached: 38516 kB
SwapCached: 0 kB
Active: 29700 kB
Inactive: 38388 kB
Active(anon): 16696 kB
Inactive(anon): 2404 kB
Active(file): 13004 kB
Inactive(file): 35984 kB
Unevictable: 6156 kB
Mlocked: 6156 kB
SwapTotal: 16380 kB
SwapFree: 16380 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 17480 kB
Mapped: 13556 kB
Shmem: 3144 kB
Slab: 32192 kB
SReclaimable: 3536 kB
SUnreclaim: 28656 kB
KernelStack: 2272 kB
PageTables: 648 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 133480 kB
Committed_AS: 37692 kB
VmallocTotal: 515640 kB
VmallocUsed: 97100 kB
VmallocChunk: 403964 kB
DirectMap4k: 32768 kB
DirectMap2M: 491520 kB
buddyinfo
Node 0, zone DMA 0 0 1 1 1 0 0 0 1 1 3
Node 0, zone Normal 130 68 53 33 3 6 7 3 0 2 19
killall: ddnsd: no process killed
killall: usermand: no process killed
killall: mediasrv: no process killed
killall: avmike: no process killed
killall: tr069discover: no process killed
drwxr-xr-x 15 root root 2120 Jan 1 01:05 .
drwxr-xr-x 15 root root 275 Mar 17 2017 ..
-rw-r--r-- 1 root root 404 Jan 1 01:00 .CRWWLANMAP
-rw-r--r-- 1 root root 22752 Jan 1 01:01 .IKEAPI-CSTAT
-rw-r--r-- 1 root root 7200 Jan 1 01:01 .IKEAPI-NSTAT
-rw-r--r-- 1 root root 23760 Jan 1 01:01 .IKEAPI-SSTAT
-rw-r--r-- 1 root root 3640 Jan 1 01:00 .SHMUSBDEVICES
-rw-rw-r-- 1 root root 40000 Jan 1 01:01 .ar7events
-rw-r--r-- 1 root root 134044 Jan 1 01:00 .dsld_statsimple
-rw-r--r-- 1 root root 216 Jan 1 01:00 .inetstat
-rw-r--r-- 1 root root 8192 Jan 1 01:00 .srb_avm_reporting
-rw-rw-rw- 1 root root 16384 Jan 1 01:00 .srb_avmdb
-rw-r--r-- 1 root root 12288 Jan 1 01:00 .srb_cloudmsgd
-rw-r--r-- 1 root root 4096 Jan 1 01:00 .srb_dnsd
-rw-r--r-- 1 root root 16384 Jan 1 01:00 .srb_invite
-rw-r--r-- 1 root root 8192 Jan 1 01:00 .srb_l2tpv3
-rw-r--r-- 1 root root 8192 Jan 1 01:01 .srb_landevicesupnp
-rw-r--r-- 1 root root 65536 Jan 1 01:00 .srb_log
-rw-r--r-- 1 root root 32768 Jan 1 01:03 .srb_mailbuilder
-rw-r--r-- 1 root root 8192 Jan 1 01:00 .srb_pcp
-rw-r--r-- 1 root root 16384 Jan 1 01:00 .srb_sip
-rw-r--r-- 1 root root 65536 Jan 1 01:05 .srb_sson
-rw-r--r-- 1 root root 4096 Jan 1 01:00 .srb_voipbackup
-rw-r--r-- 1 root root 108 Jan 1 01:00 .umtscfg
-rw-r--r-- 1 root root 2836 Jan 1 01:00 .umtsstat
-rw-r--r-- 1 root root 32 Jan 1 01:00 .var.tmp.cableinfo.log-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 .var.tmp.cloudcds.log-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 .var.tmp.msrv4.log-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 .var.tmp.tcloud.log-crwlock
-rw-r--r-- 1 root root 212380 Jan 1 01:00 .voipd_statsimple
-rw-r--r-- 1 root root 32 Jan 1 01:01 CRWWLANMAP-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 IKEAPI-CSTAT-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 IKEAPI-NSTAT-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 IKEAPI-SSTAT-crwlock
lrwxrwxrwx 1 root root 14 Jan 1 01:00 InternerSpeicher -> /var/media/ftp
-rw-r--r-- 1 root root 32 Jan 1 01:00 SHMUSBDEVICES-crwlock
lrwxrwxrwx 1 root root 19 Jan 1 01:05 TZ -> /etc/default.049/TZ
-rw-r--r-- 1 root root 1 Jan 1 01:00 USB-proc-bus-usb-001-001-hub
-rw-r--r-- 1 root root 1 Jan 1 01:00 USB-proc-bus-usb-002-001-hub
srwxr-xr-x 1 root root 0 Jan 1 01:00 auradcntl
-rw-r--r-- 1 root root 6128 Jan 1 01:00 config.def
lrwxrwxrwx 1 root root 29 Jan 1 01:00 default -> /etc/default.Fritz_Box_HW220x
drwxr-xr-x 2 root root 40 Mar 17 2017 dev
lrwxrwxrwx 1 root root 19 Jan 1 01:00 devices -> /var/tmp/usbdevices
-rw-r--r-- 1 root root 32 Jan 1 01:01 dsld_statsimple-crwlock
-rwx------ 1 root root 1732 Jan 1 01:05 ec_stats_act
-rwx------ 1 root root 1747 Jan 1 01:05 ec_stats_indtr
-rw-r--r-- 1 root root 1330 Jan 1 01:05 env
-rw-r--r-- 1 root root 9824 Jan 1 01:00 env.cache
drwxr-xr-x 2 root root 1020 Jan 1 01:00 flash
lrwxrwxrwx 1 root root 31 Jan 1 01:00 flash.html -> /var/html/html/tools/flash.html
lrwxrwxrwx 1 root root 31 Jan 1 01:00 fx_moh -> /etc/default.049/fx_moh.default
drwxr-xr-x 2 root root 40 Jan 1 01:00 gcov
lrwxrwxrwx 1 root root 12 Jan 1 01:00 html -> /usr/www/avm
lrwxrwxrwx 1 root root 20 Jan 1 01:00 html.myfritz -> /usr/www.myfritz/avm
lrwxrwxrwx 1 root root 16 Jan 1 01:00 html.nas -> /usr/www.nas/avm
lrwxrwxrwx 1 root root 19 Jan 1 01:05 htmltext.db -> /etc/htmltext_de.db
-rw-r--r-- 1 root root 32 Jan 1 01:00 inetstat-crwlock
-rw-r--r-- 1 root root 362 Jan 1 01:00 jason_boxinfo.xml
-rw-r--r-- 1 root root 504 Jan 1 01:00 juis_boxinfo.xml
-rw-r--r-- 1 root root 9 Jan 1 01:01 lanifaces
drwxr-xr-x 2 root root 60 Jan 1 01:00 lock
drwxr-xr-x 2 root root 100 Jan 1 01:01 log
drwxr-xr-x 3 root root 80 Jan 1 01:00 media
lrwxrwxrwx 1 root root 15 Jan 1 01:00 mediapath -> /var/media/ftp/
-rwxrwxrwx 1 root root 9771 Mar 17 2017 post_install
drwxr-xr-x 2 root root 60 Jan 1 01:00 ptestd
drwxrwxr-x 3 root root 1024 Jan 1 01:00 remote
drwxr-xr-x 2 root root 100 Jan 1 01:00 rpc
drwxr-xr-x 4 root root 380 Jan 1 01:01 run
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem..IKEAPI-CSTAT
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem..IKEAPI-NSTAT
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem..IKEAPI-SSTAT
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..SHMUSBDEVICES
-rw-rw-r-- 1 root root 16 Jan 1 01:00 sem..ar7events
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem..dsld_statsimple
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..inetstat
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_avm_reporting
-rw-rw-rw- 1 root root 16 Jan 1 01:00 sem..srb_avmdb
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_dnsd
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_invite
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_l2tpv3
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem..srb_landevicesupnp
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_log
-rw-r--r-- 1 root root 16 Jan 1 01:03 sem..srb_mailbuilder
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_pcp
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_sip
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem..srb_sson
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..srb_voipbackup
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..umtscfg
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..umtsstat
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem..voipd_statsimple
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem.Changelist_Sema
-rw-r--r-- 1 root root 16 Jan 1 01:01 sem.UPNPAPI_DATA_aha
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem.UPNPAPI_DATA_aura
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem.fc_config
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem.notifyd
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem.ontel
-rw-r--r-- 1 root root 16 Jan 1 01:00 sem.pbd
-rw-r--r-- 1 root root 29 Jan 1 01:00 signal.EXIT
drwxr-xr-x 2 root root 80 Jan 1 01:00 tam
drwxrwxrwx 6 root root 2260 Jan 1 01:05 tmp
-rw-r--r-- 1 root root 32 Jan 1 01:00 umtscfg-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:00 umtsstat-crwlock
-rw-r--r-- 1 root root 32 Jan 1 01:01 voipd_statsimple-crwlock
drwxr-xr-x 2 root root 40 Mar 17 2017 wpa2
/var/tmp:
drwxrwxrwx 6 root root 2260 Jan 1 01:05 .
drwxr-xr-x 15 root root 2120 Jan 1 01:05 ..
-rw-rw-rw- 1 root root 4 Jan 1 01:02 .upnpstationcfg
-rw-r--r-- 1 root root 2705 Jan 1 01:01 MediaServerDevDesc-xbox.xml
-rw-r--r-- 1 root root 3170 Jan 1 01:01 MediaServerDevDesc.xml
-rw-r--r-- 1 root root 1185 Jan 1 01:02 aha.xml
-rw-r--r-- 1 root root 166 Jan 1 01:00 apps.map
-rw-r--r-- 1 root root 910 Jan 1 01:01 aura.xml
-rw-r--r-- 1 root root 21 Jan 1 01:05 avm-resolv.conf
srwxr-xr-x 1 root root 0 Jan 1 01:00 boxnotify
-rw-r--r-- 1 root root 0 Jan 1 01:00 cableinfo.log
-rw-r--r-- 1 root root 457 Jan 1 01:00 cableinfo.status
-rw-r--r-- 1 root root 19099 Jan 1 01:00 cableinfo.table2
-rw-r--r-- 1 root root 6 Jan 1 01:00 chrony.keys
-rw-r--r-- 1 root root 412 Jan 1 01:01 cloudcds.log
lrwxrwxrwx 1 root root 41 Jan 1 01:00 crossdomain.xml -> /etc/default/avm/crossdomain-template.xml
drwxr-xr-x 2 root root 60 Jan 1 01:00 csem
-rw-r--r-- 1 root root 1778 Jan 1 01:05 ctlmgr1.slab
-rw-r--r-- 1 root root 0 Jan 1 01:00 ddnsdomains.txt
-rw-r--r-- 1 root root 0 Jan 1 01:05 dnsd_servers
-rw-r--r-- 1 root root 3883 Jan 1 01:00 dnsddebug.txt
-rw-r--r-- 1 root root 136 Jan 1 01:01 dnsddyns.default.cfg
-rw-r--r-- 1 root root 1524 Jan 1 01:05 dsld0.slab
-rw-r--r-- 1 root root 47 Jan 1 01:00 edocsis.state.avmipc
srwxrwxrwx 1 root root 0 Jan 1 01:00 faxd_ipc
-rw-r--r-- 1 root root 1077 Jan 1 01:01 fboxdesc.xml
-rw------- 1 root root 0 Jan 1 01:05 firmwarecfg.lockfile
srwxr-xr-x 1 root root 0 Jan 1 01:00 foncontrol
-rw-rw-r-- 1 root root 6144 Jan 1 01:01 fritznasdb_main.db3
-rwxrwxrwx 1 root root 10 Mar 17 2017 group
srwxr-xr-x 1 root root 0 Jan 1 01:00 homeauto
-rwxrwxrwx 1 root root 20 Mar 17 2017 hosts
-rw-r--r-- 1 root root 3486 Jan 1 01:01 igd2desc.xml
-rw-r--r-- 1 root root 3449 Jan 1 01:03 igddesc.xml
-rw-r--r-- 1 root root 1539 Jan 1 01:00 igdfwrules register0.slab
-rw-r--r-- 1 root root 55 Jan 1 01:00 inetd.conf
-rw-r--r-- 1 root root 12 Jan 1 01:00 l2tpstat
-rw-r--r-- 1 root root 1070 Jan 1 01:01 l2tpv3.xml
srwxr-xr-x 1 root root 0 Jan 1 01:01 lbd_requests
-rw-r--r-- 1 root root 29960 Jan 1 01:04 lbdout.log
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_L2TPV3.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_SATIP.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_TR064.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me__anony1165-2424164924.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:01 me_aha.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_aura.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_avm_home_external.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_avmipc_state.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_cableinfo.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_ctlmgr-pcp-1163.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_ctlmgr.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_ddnsd.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_dsld-pcp-1257.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_dsld.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_dvbif.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_igd.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_igd2.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_kpi_name_receiver.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_l2tpv3d.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_libgsm.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_logic.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_multid-pcp-1177.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_multid.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_pcpd-pcp-1240.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_pcpd.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_remote.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_tfa_dtmf.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_tr064srv.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_upnp_usb.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:01 me_upnpd.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:01 me_upnpd_authcb.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_upnpdevd.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_upnpfboxdesc.ctl
srwxr-xr-x 1 root root 0 Jan 1 01:00 me_voipd.ctl
-rw-r--r-- 1 root root 317 Jan 1 01:01 msrv4.log
-rw-r--r-- 1 root root 1650 Jan 1 01:05 multid0.slab
-rw-r--r-- 1 root root 0 Mar 17 2017 nohup.out
srwxr-xr-x 1 root root 0 Jan 1 01:00 notifyd_msg
-rw-r--r-- 1 root root 515 Jan 1 01:00 passwd
srwxr-xr-x 1 root root 0 Jan 1 01:00 pb_event
srwxr-xr-x 1 root root 0 Jan 1 01:00 pbctrl
srwxr-xr-x 1 root root 0 Jan 1 01:00 pbmsg
-rw-r--r-- 1 root root 17 Jan 1 01:00 pcpserver
-rw-r--r-- 1 root root 0 Jan 1 01:00 pd_routes
srwxr-xr-x 1 root root 0 Jan 1 01:00 plc_sock_if
srwxr-xr-x 1 root root 0 Jan 1 01:00 ptestd_pipe
-rwxrwxrwx 1 root root 21 Jan 1 01:00 resolv.conf
drwxrwxrwx 5 root root 100 Jan 1 01:00 samba
-rw-r--r-- 1 root root 1065 Jan 1 01:01 satipdesc.xml
-rwxrwxrwx 1 root root 26 Mar 17 2017 shadow
srwxr-xr-x 1 root root 0 Jan 1 01:00 tamlua
-rw-r--r-- 1 root root 178 Jan 1 01:01 tcloud.log
srwxr-xr-x 1 root root 0 Jan 1 01:00 tel_ipc
-rw-r--r-- 1 root root 12898 Jan 1 01:01 tr64desc.xml
drwxr-xr-x 2 root root 3360 Jan 1 01:00 tv
-rw-r--r-- 1 root root 1693 Jan 1 01:05 upnpd0.slab
-rw-r--r-- 1 root root 1447 Jan 1 01:05 upnpdevd0.slab
drwxr-xr-x 2 root root 80 Jan 1 01:01 upnpwebsrv
-rw-r--r-- 1 root root 1037 Jan 1 01:01 usbdesc.xml
-rw-r--r-- 1 root root 1255 Jan 1 01:00 usbdevices
-rw-r--r-- 1 root root 0 Jan 1 01:00 usbhostup
-rw-r--r-- 1 root root 146 Jan 1 01:00 users.acl
-rw-r--r-- 1 root root 128 Jan 1 01:00 users.map
-rw-r--r-- 1 root root 1628 Jan 1 01:05 voipd0.slab
-rw-r--r-- 1 root root 1289 Jan 1 01:00 websrv_ssl_cert.pem
-rw-r--r-- 1 root root 8938 Jan 1 01:01 wlan_dynamic.cfg
-rw-r--r-- 1 root root 4354 Jan 1 01:01 wlan_roles
srwxr-xr-x 1 root root 0 Jan 1 01:00 wlancsi_async.socket
srwxr-xr-x 1 root root 0 Jan 1 01:01 wlancsi_listener_48db78976a0391d9b03e6.socket
srwxr-xr-x 1 root root 0 Jan 1 01:01 wland_lbd_ctrl_socket
srwxr-xr-x 1 root root 0 Jan 1 01:01 wland_lbd_events
srwxr-xr-x 1 root root 0 Jan 1 01:01 wland_lbd_response
-rw-r--r-- 1 root root 215 Jan 1 01:01 wland_support.log
/var/tmp/csem:
drwxr-xr-x 2 root root 60 Jan 1 01:00 .
drwxrwxrwx 6 root root 2260 Jan 1 01:05 ..
-rw-r--r-- 1 root root 0 Jan 1 01:00 calllog
/var/tmp/samba:
drwxrwxrwx 5 root root 100 Jan 1 01:00 .
drwxrwxrwx 2 root root 60 Jan 1 01:00 lib
drwxr-xr-x 2 root root 60 Jan 1 01:00 private
drwxrwxrwx 2 root root 60 Jan 1 01:00 var
/var/tmp/samba/lib:
drwxrwxrwx 2 root root 60 Jan 1 01:00 .
drwxrwxrwx 5 root root 100 Jan 1 01:00 ..
-rwxrwxrwx 1 root root 0 Jan 1 01:00 smb.conf
/var/tmp/samba/private:
-rw------- 1 root root 109 Jan 1 01:00 smbpasswd
/var/tmp/samba/var:
-rwxrwxrwx 1 root root 6 Mar 17 2017 dummy
/var/tmp/tv:
drwxr-xr-x 2 root root 3360 Jan 1 01:00 .
-rw-r--r-- 1 root root 190 Jan 1 01:00 11400_10355.m3u
-rw-r--r-- 1 root root 197 Jan 1 01:00 11400_11120.m3u
-rw-r--r-- 1 root root 172 Jan 1 01:00 12200_52034.m3u
-rw-r--r-- 1 root root 187 Jan 1 01:00 12200_53601.m3u
-rw-r--r-- 1 root root 179 Jan 1 01:00 12200_53626.m3u
-rw-r--r-- 1 root root 185 Jan 1 01:00 33000_10304.m3u
-rw-r--r-- 1 root root 208 Jan 1 01:00 33000_11100.m3u
-rw-r--r-- 1 root root 188 Jan 1 01:00 33000_28325.m3u
-rw-r--r-- 1 root root 192 Jan 1 01:00 33000_28486.m3u
-rw-r--r-- 1 root root 200 Jan 1 01:00 33000_28487.m3u
-rw-r--r-- 1 root root 183 Jan 1 01:00 33000_28721.m3u
-rw-r--r-- 1 root root 182 Jan 1 01:00 33000_28722.m3u
-rw-r--r-- 1 root root 179 Jan 1 01:00 33000_28724.m3u
-rw-r--r-- 1 root root 182 Jan 1 01:00 33000_28725.m3u
-rw-r--r-- 1 root root 196 Jan 1 01:00 33800_10325.m3u
-rw-r--r-- 1 root root 188 Jan 1 01:00 33800_10329.m3u
-rw-r--r-- 1 root root 190 Jan 1 01:00 33800_10352.m3u
-rw-r--r-- 1 root root 193 Jan 1 01:00 33800_28106.m3u
-rw-r--r-- 1 root root 201 Jan 1 01:00 33800_28107.m3u
-rw-r--r-- 1 root root 188 Jan 1 01:00 33800_28108.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 33800_28111.m3u
-rw-r--r-- 1 root root 196 Jan 1 01:00 33800_28113.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 33800_28400.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 33800_28401.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 33800_28402.m3u
-rw-r--r-- 1 root root 181 Jan 1 01:00 33800_28403.m3u
-rw-r--r-- 1 root root 176 Jan 1 01:00 33800_28404.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 33800_28405.m3u
-rw-r--r-- 1 root root 170 Jan 1 01:00 33800_28406.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 33800_28408.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 36200_17.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 37800_18.m3u
-rw-r--r-- 1 root root 184 Jan 1 01:00 39400_53602.m3u
-rw-r--r-- 1 root root 181 Jan 1 01:00 39400_53603.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 39400_53604.m3u
-rw-r--r-- 1 root root 179 Jan 1 01:00 39400_53606.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 39400_53624.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 40200_50110.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 40200_53001.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 40200_53007.m3u
-rw-r--r-- 1 root root 179 Jan 1 01:00 40200_00010.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 40200_53220.m3u
-rw-r--r-- 1 root root 168 Jan 1 01:00 40200_53326.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 40200_53613.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 40200_53620.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53211.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53213.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53215.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53216.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53217.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53218.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53514.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 41000_53619.m3u
-rw-r--r-- 1 root root 168 Jan 1 01:00 41000_53625.m3u
-rw-r--r-- 1 root root 184 Jan 1 01:00 42600_50101.m3u
-rw-r--r-- 1 root root 166 Jan 1 01:00 42600_50401.m3u
-rw-r--r-- 1 root root 167 Jan 1 01:00 42600_50407.m3u
-rw-r--r-- 1 root root 161 Jan 1 01:00 42600_00002.m3u
-rw-r--r-- 1 root root 172 Jan 1 01:00 42600_53327.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 42600_53403.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 42600_53614.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 44200_50700.m3u
-rw-r--r-- 1 root root 168 Jan 1 01:00 44200_53002.m3u
-rw-r--r-- 1 root root 176 Jan 1 01:00 44200_53607.m3u
-rw-r--r-- 1 root root 184 Jan 1 01:00 44200_53621.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 44200_53622.m3u
-rw-r--r-- 1 root root 168 Jan 1 01:00 44200_53627.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 45000_10351.m3u
-rw-r--r-- 1 root root 192 Jan 1 01:00 45000_11110.m3u
-rw-r--r-- 1 root root 185 Jan 1 01:00 45000_28006.m3u
-rw-r--r-- 1 root root 186 Jan 1 01:00 45000_28007.m3u
-rw-r--r-- 1 root root 182 Jan 1 01:00 45000_28008.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 45000_28011.m3u
-rw-r--r-- 1 root root 164 Jan 1 01:00 45000_28012.m3u
-rw-r--r-- 1 root root 157 Jan 1 01:00 45000_28013.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 45000_28014.m3u
-rw-r--r-- 1 root root 162 Jan 1 01:00 45000_28017.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 45800_10327.m3u
-rw-r--r-- 1 root root 188 Jan 1 01:00 45800_28206.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 45800_28226.m3u
-rw-r--r-- 1 root root 198 Jan 1 01:00 45800_28229.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 45800_28419.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 45800_28420.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 45800_28421.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 45800_28422.m3u
-rw-r--r-- 1 root root 172 Jan 1 01:00 45800_28423.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 45800_28424.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 45800_28428.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 45800_28429.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 45800_28430.m3u
-rw-r--r-- 1 root root 181 Jan 1 01:00 45800_28431.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 45800_28432.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28433.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28434.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28435.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28437.m3u
-rw-r--r-- 1 root root 176 Jan 1 01:00 45800_28438.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 45800_28439.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28440.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 45800_28441.m3u
-rw-r--r-- 1 root root 179 Jan 1 01:00 45800_28442.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 45800_28443.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 45800_28444.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 45800_28445.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28448.m3u
-rw-r--r-- 1 root root 179 Jan 1 01:00 45800_28449.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28450.m3u
-rw-r--r-- 1 root root 175 Jan 1 01:00 45800_28452.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28453.m3u
-rw-r--r-- 1 root root 185 Jan 1 01:00 45800_28454.m3u
-rw-r--r-- 1 root root 182 Jan 1 01:00 45800_28455.m3u
-rw-r--r-- 1 root root 175 Jan 1 01:00 45800_28456.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28457.m3u
-rw-r--r-- 1 root root 182 Jan 1 01:00 45800_28461.m3u
-rw-r--r-- 1 root root 182 Jan 1 01:00 45800_28462.m3u
-rw-r--r-- 1 root root 184 Jan 1 01:00 45800_28463.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 45800_28465.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 45800_28466.m3u
-rw-r--r-- 1 root root 175 Jan 1 01:00 45800_28467.m3u
-rw-r--r-- 1 root root 170 Jan 1 01:00 45800_28468.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 45800_28469.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 45800_28470.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 45800_28471.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28472.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28475.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28476.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28477.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28478.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28479.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 45800_28480.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 45800_28481.m3u
-rw-r--r-- 1 root root 172 Jan 1 01:00 45800_28482.m3u
-rw-r--r-- 1 root root 175 Jan 1 01:00 45800_28483.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 46600_53006.m3u
-rw-r--r-- 1 root root 196 Jan 1 01:00 46600_53609.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 46600_53616.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 46600_53617.m3u
-rw-r--r-- 1 root root 175 Jan 1 01:00 46600_53630.m3u
-rw-r--r-- 1 root root 178 Jan 1 01:00 49800_50026.m3u
-rw-r--r-- 1 root root 176 Jan 1 01:00 49800_50027.m3u
-rw-r--r-- 1 root root 174 Jan 1 01:00 53800_50714.m3u
-rw-r--r-- 1 root root 181 Jan 1 01:00 53800_53015.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 53800_00011.m3u
-rw-r--r-- 1 root root 172 Jan 1 01:00 53800_53323.m3u
-rw-r--r-- 1 root root 180 Jan 1 01:00 53800_53324.m3u
-rw-r--r-- 1 root root 168 Jan 1 01:00 53800_53612.m3u
-rw-r--r-- 1 root root 184 Jan 1 01:00 61000_50122.m3u
-rw-r--r-- 1 root root 172 Jan 1 01:00 61000_51037.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 61000_51043.m3u
-rw-r--r-- 1 root root 188 Jan 1 01:00 61800_108.m3u
-rw-r--r-- 1 root root 187 Jan 1 01:00 62600_11150.m3u
-rw-r--r-- 1 root root 171 Jan 1 01:00 62600_50411.m3u
-rw-r--r-- 1 root root 165 Jan 1 01:00 62600_50412.m3u
-rw-r--r-- 1 root root 181 Jan 1 01:00 62600_51030.m3u
-rw-r--r-- 1 root root 189 Jan 1 01:00 62600_53009.m3u
-rw-r--r-- 1 root root 173 Jan 1 01:00 62600_53011.m3u
-rw-r--r-- 1 root root 190 Jan 1 01:00 62600_53012.m3u
-rw-r--r-- 1 root root 169 Jan 1 01:00 62600_53018.m3u
-rw-r--r-- 1 root root 167 Jan 1 01:00 62600_00003.m3u
-rw-r--r-- 1 root root 176 Jan 1 01:00 64200_10331.m3u
-rw-r--r-- 1 root root 184 Jan 1 01:00 64200_11130.m3u
-rw-r--r-- 1 root root 177 Jan 1 01:00 64200_11160.m3u
-rw-r--r-- 1 root root 175 Jan 1 01:00 82600_50078.m3u
-rw-r--r-- 1 root root 11139 Jan 1 01:00 radio.m3u
-rw-r--r-- 1 root root 3409 Jan 1 01:00 tvhd.m3u
-rw-r--r-- 1 root root 13185 Jan 1 01:00 tvsd.m3u
/var/tmp/upnpwebsrv:
drwxr-xr-x 2 root root 80 Jan 1 01:01 .
-rw-r--r-- 1 root root 2034 Jan 1 01:01 MediaReceiverRegistrar.xml
-rw-r--r-- 1 root root 5258 Jan 1 01:01 MediaServerConnectionManager.xml
ctlmgr1.slab Sat Jan 1 01:05:02 2000 ctlmgr
SLAB $Revision: 30711 $ FLAGS -
pagesize 4096 offlimit 50
ncaches 23 nallocpages 889 (max=895) nreappages 291 current=3556KByte
objalloc slabs npages alloc free
slab_cache : 22 30 0 1 0 1 1 22 0
size-16 : 17195 17574 83 3 1 87 87 99124 81929
size-32 : 9900 10080 86 4 0 90 90 30720 20820
size-64 : 3031 3127 50 3 0 53 53 23019 19988
size-128 : 4213 4230 140 1 0 141 141 13240 9027
size-256 : 167 225 10 2 3 15 15 2845 2678
size-512 : 95 104 11 2 0 13 13 49619 49524
size-1024 : 54 60 13 1 1 15 15 1777 1723
size-2048 : 19 20 9 1 0 10 10 248 229
size-4096 : 8 9 8 0 1 9 19 836 828
size-8192 : 7 12 7 0 5 24 24 550 543
size-16384 : 4 5 4 0 1 20 20 55 51
size-32768 : 14 23 14 0 9 184 192 329 315
size-65536 : 9 9 9 0 0 144 144 9 0
size-131072 :
size-256*1024 : 1 1 1 0 0 64 64 1 0
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
csock : 57 60 14 1 0 15 15 220 163
pcpitem :
cbdata : 154 288 1 1 0 2 2 1917 1763
timercb : 50 118 0 2 0 2 2 1009 959
multid0.slab Sat Jan 1 01:05:02 2000 multid
ncaches 23 nallocpages 117 (max=119) nreappages 4 current=468KByte
size-16 : 756 808 3 1 0 4 4 1941 1185
size-32 : 514 784 4 3 0 7 7 1678 1164
size-64 : 275 295 4 1 0 5 5 607 332
size-128 : 69 90 2 1 0 3 3 595 526
size-256 : 441 450 29 1 0 30 30 443 2
size-512 : 6 8 0 1 0 1 1 284 278
size-1024 : 1 4 0 1 0 1 1 16 15
size-2048 : 4 4 2 0 0 2 3 14 10
size-4096 : 7 8 7 0 1 8 9 408 401
size-8192 : 1 1 1 0 0 2 2 1 0
size-16384 : 3 3 3 0 0 12 12 3 0
size-32768 :
size-65536 : 2 2 2 0 0 32 32 2 0
size-131072 :
size-256*1024 :
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
csock : 26 28 6 1 0 7 7 28 2
pcpitem :
timercb : 12 59 0 1 0 1 1 71 59
cbdata : 31 144 0 1 0 1 1 71 40
/var/tmp/ddnsd*.slab: No such file or directory
upnpdevd0.slab Sat Jan 1 01:05:02 2000 upnpdevd
ncaches 22 nallocpages 17 (max=18) nreappages 9 current=68KByte
slab_cache : 21 30 0 1 0 1 1 21 0
size-16 : 46 202 0 1 0 1 1 222 176
size-32 : 91 112 0 1 0 1 1 186 95
size-64 : 13 59 0 1 0 1 1 105 92
size-128 : 6 30 0 1 0 1 1 61 55
size-256 : 1 15 0 1 0 1 1 1 0
size-512 : 1 8 0 1 0 1 1 1 0
size-1024 : 0 4 0 0 1 1 1 30 30
size-2048 :
size-4096 : 2 4 2 0 2 4 4 39 37
size-16384 :
size-32768 :
size-65536 :
size-131072 :
size-256*1024 :
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
csock : 4 4 1 0 0 1 2 5 1
cbdata : 8 144 0 1 0 1 1 34 26
timercb : 2 59 0 1 0 1 1 17 15
upnpd0.slab Sat Jan 1 01:05:02 2000 upnpd
ncaches 22 nallocpages 201 (max=232) nreappages 155 current=804KByte
size-16 : 6688 6868 31 3 0 34 34 66485 59797
size-32 : 5481 5600 47 3 0 50 50 17138 11657
size-64 : 557 590 8 2 0 10 11 12674 12117
size-128 : 1080 1110 35 2 0 37 37 5187 4107
size-256 : 42 60 1 3 0 4 4 762 720
size-512 : 39 56 3 4 0 7 7 56432 56393
size-1024 : 8 12 1 2 0 3 4 122 114
size-2048 : 6 6 3 0 0 3 5 27 21
size-4096 : 6 7 6 0 1 7 15 702 696
size-8192 : 3 3 3 0 0 6 12 534 000
size-16384 : 0 0 0 0 0 0 4 4 4
size-32768 : 2 2 2 0 0 16 48 203 201
size-65536 : 1 1 1 0 0 16 16 1 0
size-131072 :
size-256*1024 :
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
csock : 15 20 3 2 0 5 6 133 118
timercb : 16 59 0 1 0 1 1 704 688
cbdata : 58 144 0 1 0 1 1 1195 1137
size-2048 :
size-16384 :
size-32768 :
size-65536 :
size-131072 :
size-256*1024 :
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
diff upnpd0.slab upnpdevd0.slab:
dsld0.slab Sat Jan 1 01:05:02 2000 dsld
ncaches 23 nallocpages 35 (max=35) nreappages 6 current=140KByte
size-16 : 662 808 1 3 0 4 4 3558 2896
size-32 : 443 784 2 5 0 7 7 1791 1348
size-64 : 164 236 0 4 0 4 4 670 506
size-128 : 61 90 2 1 0 3 3 245 184
size-256 : 8 15 0 1 0 1 1 72 64
size-512 : 5 8 0 1 0 1 1 25 20
size-1024 : 1 4 0 1 0 1 1 4 3
size-2048 :
size-4096 : 4 5 4 0 1 5 5 202 198
size-16384 :
size-32768 :
size-65536 :
size-131072 :
size-256*1024 :
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
csock : 9 12 1 2 0 3 3 10 1
pcpitem : 4 13 0 1 0 1 1 6 2
cbdata : 17 144 0 1 0 1 1 23 6
timercb : 6 59 0 1 0 1 1 83 77
voipd0.slab Sat Jan 1 01:05:02 2000 voipd
ncaches 22 nallocpages 74 (max=79) nreappages 8 current=296KByte
size-16 : 218 606 1 2 0 3 3 1200 982
size-32 : 139 224 1 1 0 2 2 351 212
size-64 : 86 118 1 1 0 2 2 183 97
size-128 : 31 60 1 1 0 2 2 75 44
size-256 : 11 15 0 1 0 1 2 21 10
size-512 : 10 16 1 1 0 2 2 18 8
size-1024 : 5 8 1 1 0 2 2 11 6
size-2048 : 1 2 0 1 0 1 1 10 9
size-4096 : 4 4 4 0 0 4 5 28 24
size-8192 : 1 1 1 0 0 2 6 3 2
size-16384 :
size-32768 :
size-131072 : 1 1 1 0 0 32 32 1 0
size-256*1024 :
size-512*1024 :
size-1024*1024 :
size-2048*1024 :
csock : 8 8 2 0 0 2 2 12 4
cbdata : 22 144 0 1 0 1 1 33 11
timercb : 5 59 0 1 0 1 1 24 19
/var/tmp/usermand*.slab: No such file or directory
/var/tmp/mediasrv*.slab: No such file or directory
/var/tmp/avmike*.slab: No such file or directory
/var/tmp/tr069discover*.slab: No such file or directory
##### END SECTION Processes_Memory
##### BEGIN SECTION SYSV_IPC SYSV IPC
SYSV IPC
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x43414c4c 32768 root 0 220836 4
0x464f4e43 65537 root 0 83516 2
0x70626420 98306 root 0 8 6
0x44584146 131075 root 0 1952 2
0x434d4154 163844 root 0 8436 2
0x534d4154 196613 root 0 149 2
0x00051a77 229382 root 666 4096 1
0x73717c7c 262151 root 777 16968 4
0x73717c7d 294920 root 777 5600 4
0x73717c7f 327689 root 777 2400 4
0x73717c82 360458 root 777 1200 4
0x73717c85 393227 root 777 4000 4
0x73717c86 425996 root 777 14000 4
0x73717c88 458765 root 777 16384 1
0x73717c84 491534 root 777 15200 4
0x73717c83 524303 root 777 2600 4
0x73717c81 557072 root 777 4096 4
0x73717c80 589841 root 777 9032 4
0x73717c7b 622610 root 777 12288 4
0x000a6e45 655379 root 666 4372 0
0x00246b18 688148 root 666 4 0
0xacf94b30 720917 root 666 369548 0
0xacf94b31 753686 root 666 369548 0
------ Semaphore Arrays --------
key semid owner perms nsems
0x610c061a 32768 root 600 1
------ Message Queues --------
key msqid owner perms used-bytes messages
##### END SECTION SYSV_IPC
##### BEGIN SECTION Basis Supportdata core
Basis
Support Data Basis
AHA
[Support Data AVM Home Automation]
DECTULE AHA
timestamp: 0
enabled_state 0, ule_socket: -1, device_count 0, locked_cfm_count: 0, xml_store_init 1, savetime: 0, readules_rechecktimer (nil), readrecheckcount: 0, xmlsavetimer (nil), RFPI=02d816e268
infobuf:
conn init_connect device_check en_stateread_ules XML STORE Init !tree --OLD DATA FORMAT-- len<=0 msg socket-rec recv err conn init_connect conn init_connect conn init_connect conn init_connect conn init_connect
Devices
Stubqueue size: 0
ahausr.cfg
* /var/flash/ahausr.cfg
* Mon May 1 01:42:02 2017
meta { encoding = "utf-8"; }
ahausrcfg {
// EOF
ahadect.cfg
ahastat.cfg
Watchdog-Statistic
hdl= 2 l2tpv3d pid 1158 triggered before: 3.924 s(avg 9.676 s) state: S cpu0 pgfault 0 oom_score 1
hdl= 3 ctlmgr pid 1165 triggered before: 3.312 s(avg 8.016 s) state: S cpu1 pgfault 6 oom_score 1
hdl= 3 ctlmgr pid 1166 triggered before: 3.312 s(avg 8.016 s) state: S cpu1 pgfault 6 oom_score 1
hdl= 3 ctlmgr pid 1308 triggered before: 3.312 s(avg 8.016 s) state: S cpu1 pgfault 6 oom_score 1
hdl= 3 ctlmgr pid 1309 triggered before: 3.312 s(avg 8.016 s) state: S cpu1 pgfault 6 oom_score 1
hdl=15 upnpd pid 1171 triggered before: 3.172 s(avg 9.580 s) state: S cpu0 pgfault 0 oom_score 1
hdl=15 upnpd pid 2327 triggered before: 3.172 s(avg 9.580 s) state: S cpu1 pgfault 0 oom_score 1
hdl=15 upnpd pid 2328 triggered before: 3.172 s(avg 9.580 s) state: S cpu1 pgfault 0 oom_score 1
hdl= 4 multid pid 1177 triggered before: 9.496 s(avg 9.632 s) state: S cpu0 pgfault 0 oom_score 1
hdl= 5 pcpd pid 1240 triggered before: 9.228 s(avg 9.632 s) state: S cpu0 pgfault 0 oom_score 1
hdl= 6 upnpdevd pid 1244 triggered before: 9.176 s(avg 9.632 s) state: S cpu0 pgfault 0 oom_score 1
hdl= 8 wland pid 1255 triggered before: 61.304 s(avg 34.112 s) state: S cpu1 pgfault 8 oom_score 1
hdl= 7 dsld pid 1271 triggered before: 8.572 s(avg 9.632 s) state: S cpu1 pgfault 0 oom_score 1
hdl= 9 pbd pid 1305 triggered before: 17.528 s(avg 80.244 s) state: S cpu1 pgfault 0 oom_score 1
hdl=10 telefon pid 1338 triggered before: 76.408 s(avg 21.380 s) state: S cpu0 pgfault 2 oom_score 1
hdl=10 telefon pid 1341 triggered before: 76.408 s(avg 21.380 s) state: S cpu1 pgfault 2 oom_score 1
hdl=11 faxd pid 1346 triggered before: 6.320 s(avg 2.884 s) state: S cpu1 pgfault 0 oom_score 1
hdl=12 voipd pid 1350 triggered before: 5.908 s(avg 9.632 s) state: S cpu0 pgfault 0 oom_score 1
hdl=13 aha pid 2119 triggered before: 10.428 s(avg 30.000 s) state: S cpu1 pgfault 0 oom_score 1
hdl=14 boxnotifyd pid 2143 triggered before: 9.336 s(avg 80.028 s) state: S cpu0 pgfault 0 oom_score 1
Event-Statistic
Summary: 15 user and 0 pending events
[avm_event] list Event Sink
Sink: aha : receive: 0 Functions:
Sink: telefon : receive: 0 Functions: avm_event_id_user_source_notify
Sink: wland_hal : receive: 24 Functions: avm_event_id_wlan_client_status avm_event_id_wlan_event
Sink: plc_ui_module : receive: 0 Functions: avm_event_id_push_button
Sink: ctlmgr_capiotcp : receive: 1 Functions: avm_event_id_capiotcp_startstop avm_event_id_telefon_up avm_event_id_reboot_req
Sink: dect : receive: 0 Functions: avm_event_id_push_button
Sink: wlan : receive: 10 Functions: avm_event_id_wlan_client_status avm_event_id_autoprov avm_event_id_push_button avm_event_id_telefon_wlan_command
Sink: ctlmgr_cpu_stats : receive: 4 Functions: avm_event_id_temperature avm_event_id_cpu_idle
Sink: ctlmgr_button : receive: 0 Functions: avm_event_id_push_button
Sink: ctlmgr_led : receive: 181 Functions: avm_event_id_led_status
Sink: eth_status : receive: 6 Functions: avm_event_id_ethernet_connect_status
Sink: ctlmgr_eth : receive: 7 Functions: avm_event_id_ethernet_connect_status
Sink: ptestd : receive: 0 Functions: avm_event_id_rpc
Sink: powermanagment_remote_sink : receive: 113 Functions: avm_event_id_powermanagment_remote
Sink: avm_event_checkpint_sink : receive: 7 Functions: avm_event_id_checkpoint
[avm_event] list Event Source
Source: avm_event_remotewatchdog sent: 29 notify: avm_event_remote_notify+0x0/0x10 : Function: avm_event_id_remotewatchdog
Source: avm_event_checkpoint sent: 7 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: avm_event_checkpoint sent: 0 notify: avm_event_remote_notify+0x0/0x10 : Function: avm_event_id_checkpoint
Source: temperature sent: 2 notify: avmevent_temperature_notify+0x0/0xd0 : Function: avm_event_id_temperature
Source: powermanagment_status sent: 1 notify: avm_event_powermanagment_status_notify+0x0/0x80 : Function: avm_event_id_powermanagment_status
Source: cpu_idle sent: 0 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: telefonprofile sent: 0 notify: avmevent_telefonprofile_notify+0x0/0x70 : Function: avm_event_id_telefonprofile
Source: cpu_run sent: 0 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: cpu_idle sent: 2 notify: avmevent_cpu_idle_notify+0x0/0x220 : Function: avm_event_id_cpu_idle
Source: powermanagment_remote sent: 113 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: cpu_run sent: 44 notify: avmevent_cpu_run_notify+0x0/0xb0 : Function: avm_event_id_cpu_run
Source: pm_info_stat sent: 0 notify: pm_ressourceinfo_notify+0x0/0xf0 : Function: avm_event_id_pm_ressourceinfo_status
Source: event_log sent: 0 notify: avm_event_log_notify+0x0/0x10 : Function: avm_event_id_log
Source: avm_led_event_notify sent: 97 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: push_button sent: 0 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: Ethernet status sent: 7 notify: avmnet_links_event_notify+0x0/0x40 : Function: avm_event_id_ethernet_connect_status
Source: avm_led_event_notify sent: 96 notify: led_event_notify+0x0/0x10 [led_modul_Fritz_Box_HW220x] : Function: avm_event_id_led_status avm_event_id_led_info
Source: ptestd_source sent: 0 notify: avm_event_remote_notifier_to_send+0x0/0x10 : Function:
Source: pcmlink_remote_source sent: 1 notify: codec_setSharedMemStruct+0x50/0x520 [pcmlink] : Function: avm_event_id_remotepcmlink
Source: ptestd_source sent: 0 notify: avm_event_source_user_mode_notify+0x0/0xa0 : Function: avm_event_id_rpc
Source: wlan sent: 10 notify: (null) : Function: avm_event_id_wlan_client_status
Source: wlan_wland sent: 14 notify: (null) : Function: avm_event_id_wlan_event
Source: telefon sent: 1 notify: avm_event_source_user_mode_notify+0x0/0xa0 : Function: avm_event_id_telefon_wlan_command avm_event_id_capiotcp_startstop avm_event_id_telefon_up avm_event_id_reboot_req avm_event_id_telephony_missed_call avm_event_id_telephony_incoming_call avm_event_id_user_source_notify
Source: aha sent: 0 notify: avm_event_source_user_mode_notify+0x0/0xa0 : Function: avm_event_id_smarthome_switch_status
Unalignment-Statistic
cat: can't open '/proc/cpu/alignment': No such file or directory
Vmalloc-Statistic
0xe0800000-0xe0802000 8192 hpet_enable+0x226/0x245 phys=fed00000 ioremap
0xe0804000-0xe0807000 12288 acpi_os_map_memory+0x89/0xe8 phys=13000 ioremap
0xe0808000-0xe080a000 8192 acpi_os_map_memory+0x89/0xe8 phys=17000 ioremap
0xe080c000-0xe080e000 8192 acpi_os_map_memory+0x89/0xe8 phys=11000 ioremap
0xe0810000-0xe0812000 8192 hw_mutex_probe+0x140/0x214 phys=dffe1000 ioremap
0xe0814000-0xe0816000 8192 mailbox_probe+0x126/0x2a7 phys=c8001000 ioremap
0xe0818000-0xe081a000 8192 mailbox_probe+0x169/0x2a7 phys=c80c0000 ioremap
0xe081c000-0xe081f000 12288 acc_action+0x137/0x210 phys=173d6000 ioremap
0xe0820000-0xe0822000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0823000-0xe0825000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0827000-0xe086a000 274432 jffs2_zlib_init+0x1a/0x99 pages=66 vmalloc
0xe086b000-0xe0877000 49152 jffs2_zlib_init+0x4b/0x99 pages=11 vmalloc
0xe0878000-0xe087a000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe087b000-0xe087d000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe087e000-0xe0880000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0881000-0xe0883000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0884000-0xe0886000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0887000-0xe0889000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe088a000-0xe088c000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe088d000-0xe088f000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0890000-0xe0892000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0893000-0xe0895000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0896000-0xe0898000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe0899000-0xe089b000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe089e000-0xe08a0000 8192 intelce_gpio_probe+0x2c8/0x4fe phys=dffe0000 ioremap
0xe08a2000-0xe08a4000 8192 pci_ioremap_bar+0x36/0x70 phys=dffe0000 ioremap
0xe08a6000-0xe08a8000 8192 e1000_probe+0x578/0xe40 phys=dffe0000 ioremap
0xe08aa000-0xe08ac000 8192 pci_ioremap_bar+0x36/0x70 phys=dffe8000 ioremap
0xe08ae000-0xe08b0000 8192 pci_ioremap_bar+0x36/0x70 phys=dffe8000 ioremap
0xe08b2000-0xe08b4000 8192 pci_ioremap_bar+0x36/0x70 phys=dff00000 ioremap
0xe08b5000-0xe08b7000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe08b8000-0xe08be000 24576 node_action+0x65d/0x760 phys=17390000 ioremap
0xe08c0000-0xe08d1000 69632 pci_ioremap_bar+0x36/0x70 phys=df8c0000 ioremap
0xe08d2000-0xe08d4000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe08d6000-0xe08d8000 8192 REMOTELink_Init+0x176/0x3b0 [pcmlink] phys=160b1000 ioremap
0xe08d9000-0xe08dc000 12288 e1000_setup_all_tx_resources+0x46/0x560 pages=2 vmalloc
0xe08e0000-0xe08f1000 69632 pci_ioremap_bar+0x36/0x70 phys=df8c0000 ioremap
0xe08f2000-0xe08f4000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe08f5000-0xe08f8000 12288 e1000_setup_all_rx_resources+0x48/0x580 pages=2 vmalloc
0xe08f9000-0xe08fe000 20480 module_alloc_update_bounds+0x13/0x60 pages=4 vmalloc
0xe0900000-0xe4901000 67112960 pci_ioremap_bar+0x36/0x70 phys=d8000000 ioremap
0xe4902000-0xe4913000 69632 xz_dec_lzma2_create+0x6f/0x90 pages=16 vmalloc
0xe4914000-0xe4916000 8192 sven_open_header+0xa0/0x2a0 [sven_linux] phys=7fb0000 ioremap
0xe4917000-0xe4919000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe4920000-0xe4922000 8192 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=dffe1000 ioremap
0xe4926000-0xe492a000 16384 module_alloc_update_bounds+0x13/0x60 pages=3 vmalloc
0xe492b000-0xe4935000 40960 module_alloc_update_bounds+0x13/0x60 pages=9 vmalloc
0xe4936000-0xe493c000 24576 module_alloc_update_bounds+0x13/0x60 pages=5 vmalloc
0xe4940000-0xe4961000 135168 pci_ioremap_bar+0x36/0x70 phys=df860000 ioremap
0xe4962000-0xe4964000 8192 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=bfffe000 ioremap
0xe4965000-0xe4970000 45056 module_alloc_update_bounds+0x13/0x60 pages=10 vmalloc
0xe4976000-0xe4985000 61440 module_alloc_update_bounds+0x13/0x60 pages=14 vmalloc
0xe499c000-0xe499e000 8192 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=dfea4000 ioremap
0xe49a0000-0xe49a2000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe49a3000-0xe49a5000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe49a6000-0xe49a8000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe49a9000-0xe49be000 86016 module_alloc_update_bounds+0x13/0x60 pages=20 vmalloc
0xe49bf000-0xe49c7000 32768 module_alloc_update_bounds+0x13/0x60 pages=7 vmalloc
0xe49cd000-0xe49d7000 40960 module_alloc_update_bounds+0x13/0x60 pages=9 vmalloc
0xe49db000-0xe49dd000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe49de000-0xe49e0000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe49e1000-0xe49e3000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe49e4000-0xe49e6000 8192 avm_radioenv_init_tgt+0x11/0xa0 [aae] pages=1 vmalloc
0xe49e7000-0xe49f4000 53248 avm_radioenv_init_hst+0x57/0x130 [aae] pages=12 vmalloc
0xe49f8000-0xe4a31000 233472 module_alloc_update_bounds+0x13/0x60 pages=56 vmalloc
0xe4a32000-0xe4a34000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe4a35000-0xe4a3e000 36864 avm_radioenv_init_hst+0x92/0x130 [aae] pages=8 vmalloc
0xe4a40000-0xe4a47000 28672 module_alloc_update_bounds+0x13/0x60 pages=6 vmalloc
0xe4a48000-0xe4aa4000 376832 module_alloc_update_bounds+0x13/0x60 pages=91 vmalloc
0xe4aa5000-0xe4ac3000 122880 avm_radioenv_init_hst+0x14/0x130 [aae] pages=29 vmalloc
0xe4ac4000-0xe4ae2000 122880 avm_radioenv_init_hst+0x31/0x130 [aae] pages=29 vmalloc
0xe4ae3000-0xe4ae7000 16384 module_alloc_update_bounds+0x13/0x60 pages=3 vmalloc
0xe4ae9000-0xe4aec000 12288 module_alloc_update_bounds+0x13/0x60 pages=2 vmalloc
0xe4aed000-0xe4aef000 8192 hif_completion_thread_startup+0xbd/0x180 [umac] pages=1 vmalloc
0xe4af0000-0xe4af9000 36864 zram_init_device+0xbd/0xf89 [zram] pages=8 vmalloc
0xe4afa000-0xe4b07000 53248 avm_radioenv_init_hst+0x70/0x130 [aae] pages=12 vmalloc
0xe4b08000-0xe4b11000 36864 avm_radioenv_init_hst+0xab/0x130 [aae] pages=8 vmalloc
0xe4b12000-0xe4b16000 16384 module_alloc_update_bounds+0x13/0x60 pages=3 vmalloc
0xe4b19000-0xe4b1f000 24576 hif_completion_thread_startup+0xbd/0x180 [umac] pages=5 vmalloc
0xe4b20000-0xe4b23000 12288 hif_completion_thread_startup+0xbd/0x180 [umac] pages=2 vmalloc
0xe4b26000-0xe4b29000 12288 module_alloc_update_bounds+0x13/0x60 pages=2 vmalloc
0xe4b2a000-0xe4b2c000 8192 hif_completion_thread_startup+0xbd/0x180 [umac] pages=1 vmalloc
0xe4b2d000-0xe4b33000 24576 hif_completion_thread_startup+0xbd/0x180 [umac] pages=5 vmalloc
0xe4b37000-0xe4b3c000 20480 module_alloc_update_bounds+0x13/0x60 pages=4 vmalloc
0xe4b40000-0xe4b51000 69632 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=df8f0000 ioremap
0xe4b52000-0xe4b74000 139264 module_alloc_update_bounds+0x13/0x60 pages=33 vmalloc
0xe4b77000-0xe4b79000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe4b7a000-0xe4b7d000 12288 hif_completion_thread_startup+0xbd/0x180 [umac] pages=2 vmalloc
0xe4b87000-0xe4b89000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe4bb5000-0xe4bb7000 8192 sys_swapon+0x2d3/0xcc0 pages=1 vmalloc
0xe4bc0000-0xe4be1000 135168 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=df920000 ioremap
0xe4be4000-0xe4c09000 151552 hif_completion_thread_startup+0xbd/0x180 [umac] pages=36 vmalloc
0xe4c10000-0xe4c1c000 49152 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=dfe80000 ioremap
0xe4c1f000-0xe4c77000 360448 module_alloc_update_bounds+0x13/0x60 pages=87 vmalloc
0xe4c7f000-0xe4c81000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe4c82000-0xe4ccc000 303104 module_alloc_update_bounds+0x13/0x60 pages=73 vmalloc
0xe4d11000-0xe4db7000 679936 module_alloc_update_bounds+0x13/0x60 pages=165 vmalloc
0xe4dc8000-0xe4dca000 8192 REMOTELink_Init+0x151/0x3b0 [pcmlink] phys=160b2000 ioremap
0xe4def000-0xe4e0c000 118784 module_alloc_update_bounds+0x13/0x60 pages=28 vmalloc
0xe4e60000-0xe4e73000 77824 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=df900000 ioremap
0xe4e7a000-0xe4f19000 651264 module_alloc_update_bounds+0x13/0x60 pages=158 vmalloc
0xe4f27000-0xe4f29000 8192 hif_completion_thread_startup+0xbd/0x180 [umac] pages=1 vmalloc
0xe4f2a000-0xe4f2d000 12288 hif_completion_thread_startup+0xbd/0x180 [umac] pages=2 vmalloc
0xe4f30000-0xe4f32000 8192 avm_event_local_source_register+0xd1/0x1d0 pages=1 vmalloc
0xe4f40000-0xe4f46000 24576 hif_completion_thread_startup+0xbd/0x180 [umac] pages=5 vmalloc
0xe4f47000-0xe4f49000 8192 hif_completion_thread_startup+0xbd/0x180 [umac] pages=1 vmalloc
0xe4f4a000-0xe4f4d000 12288 hif_completion_thread_startup+0xbd/0x180 [umac] pages=2 vmalloc
0xe4f4e000-0xe5091000 1323008 module_alloc_update_bounds+0x13/0x60 pages=322 vmalloc
0xe5092000-0xe50d5000 274432 tffs_open_kern+0x177/0x2d0 pages=66 vmalloc
0xe50d6000-0xe512b000 348160 create_descriptors+0x88/0x110 [ismdcore] pages=84 vmalloc
0xe512c000-0xe5164000 229376 module_alloc_update_bounds+0x13/0x60 pages=55 vmalloc
0xe5165000-0xe516b000 24576 hif_completion_thread_startup+0xbd/0x180 [umac] pages=5 vmalloc
0xe5176000-0xe517b000 20480 module_alloc_update_bounds+0x13/0x60 pages=4 vmalloc
0xe5180000-0xe5201000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7680000 ioremap
0xe526e000-0xe5293000 151552 hif_completion_thread_startup+0xbd/0x180 [umac] pages=36 vmalloc
0xe5295000-0xe529a000 20480 module_alloc_update_bounds+0x13/0x60 pages=4 vmalloc
0xe52a7000-0xe52ab000 16384 module_alloc_update_bounds+0x13/0x60 pages=3 vmalloc
0xe52af000-0xe52b1000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe52bd000-0xe52bf000 8192 module_alloc_update_bounds+0x13/0x60 pages=1 vmalloc
0xe52ca000-0xe52ce000 16384 module_alloc_update_bounds+0x13/0x60 pages=3 vmalloc
0xe52e2000-0xe54c2000 1966080 module_alloc_update_bounds+0x13/0x60 pages=479 vmalloc
0xe54c3000-0xe54cb000 32768 module_alloc_update_bounds+0x13/0x60 pages=7 vmalloc
0xe5500000-0xe5701000 2101248 pci_iomap+0x77/0xd0 phys=bfc00000 ioremap
0xe5702000-0xe5775000 471040 module_alloc_update_bounds+0x13/0x60 pages=114 vmalloc
0xe5780000-0xe5801000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7600000 ioremap
0xe5837000-0xe5840000 36864 module_alloc_update_bounds+0x13/0x60 pages=8 vmalloc
0xe5844000-0xe5846000 8192 usb_hcd_pci_probe+0x1c3/0x460 phys=df810000 ioremap
0xe5848000-0xe584a000 8192 usb_hcd_pci_probe+0x1c3/0x460 phys=df820000 ioremap
0xe584c000-0xe584e000 8192 usb_hcd_pci_probe+0x1c3/0x460 phys=df880000 ioremap
0xe5880000-0xe5981000 1052672 sven_open_header+0x81/0x2a0 [sven_linux] phys=7500000 ioremap
0xe5a00000-0xe5b01000 1052672 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=dfc00000 ioremap
0xe5b02000-0xe5e2c000 3317760 module_alloc_update_bounds+0x13/0x60 pages=809 vmalloc
0xe5e80000-0xe5f01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7700000 ioremap
0xe5f80000-0xe6001000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7780000 ioremap
0xe6080000-0xe6101000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7800000 ioremap
0xe6180000-0xe6201000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7880000 ioremap
0xe6280000-0xe6301000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7900000 ioremap
0xe6380000-0xe6401000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7980000 ioremap
0xe6480000-0xe6501000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7a00000 ioremap
0xe6580000-0xe6601000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7a80000 ioremap
0xe6680000-0xe6701000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7b00000 ioremap
0xe6780000-0xe6801000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7b80000 ioremap
0xe6880000-0xe6901000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7c00000 ioremap
0xe6980000-0xe6a01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7c80000 ioremap
0xe6a80000-0xe6b01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7d00000 ioremap
0xe6b80000-0xe6c01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7d80000 ioremap
0xe6c80000-0xe6d01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7e00000 ioremap
0xe6d80000-0xe6e01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7e80000 ioremap
0xe6e80000-0xe6f01000 528384 os_map_io_to_mem_nocache+0x24/0x30 [osal_linux] phys=7f00000 ioremap
0xe6f80000-0xe7181000 2101248 pci_iomap+0x77/0xd0 phys=bfa00000 ioremap
0xffc00000-0xffe00000 2097152 pcpu_get_vm_areas+0x0/0x490 vmalloc
End Of Support Data Basis
##### END SECTION Basis
##### BEGIN SECTION System_Status System status
System Status
FRITZ!Box 6590 Cable-Kabel-020800-000116-676461-060070-787902-1480683-43781
##### END SECTION System_Status
##### BEGIN SECTION varlogmessages
##### END SECTION varlogmessages
##### BEGIN SECTION DSL Supportdata xDSL
##### END SECTION DSL
##### BEGIN SECTION DOCSIS Supportdata cable
##### BEGIN SECTION DOCSIS Erouter
-rw-r--r-- 1 root root 47 Jan 1 01:00 /var/tmp/edocsis.state.avmipc
/var/tmp/edocsis.state.avmipc: edocsis_set_cred=1 tr069_docsispppoe_notify=1
##### END SECTION DOCSIS Erouter
DOCSIS
DOCSIS DB Info:
CM Mac Status: not synchronized Mode: DOCSIS 3.0
Docsis 1.0 CoS: no Docsis 2.0 Mode: enabled
eRouter Mode: 3 (IPv4+IPv6)
eRouter Enabled: yes
Multiple Dowstreams: no Multiple Upstreams: no
Last frequency: 0 Max CPE: 0
RegReq SID: 0 override SID: 0
UCD on all Downstreams: no
Channel Change Status: No active channel change
Transmit Channel Configuration: no
Upstream Drop Classifiers: no
Multicast DSID Forwarding: not supported
US 1: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 2: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 3: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 4: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 5: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 6: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 7: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
US 8: SID: 0 UCID: 0 DCID: 0 usable: no (reason 1 REJECT_OTHER)
Reinit Mac Reason: Power on
Resets: 0 Invalid Reg-Rsp's: 0 T1-Timeouts: 0
DOCSIS Us Status:
PGA gain code is 65
PGA current is: 0
Current Full Scale: 0.000000
PloadMinSet: -1.000000
Initial PloadMinSet: -1.000000
Power Reporting: No
Digital Att: 9.127320 9.127320 9.127320 9.127320 9.127320 9.127320 9.127320 9.127320
Frquency : 10.000000 10.000000 10.000000 10.000000 10.000000 10.000000 10.000000 10.000000
Symbol rate: Invalid Invalid Invalid Invalid Invalid Invalid Invalid Invalid
modulation : ERR ERR ERR ERR ERR ERR ERR ERR
SCDMA mode : 0 0 0 0 0 0 0 0
Upstream : --- --- --- --- --- --- --- ---
Phigh : 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
PLow : 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
PdrwHigh : 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
PdrwLow : 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
deltaPf : 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
DOCSIS Ds Status:
Number of tuners : 1
Tuner Id # : 1
Frequency(MHz) : 0.000
Tuner Type : Full CBW
Number of receivers: 32
Receiver # : 1 2 3 4 5 6 7 8
Frequency(MHz) : 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000
QAM Lock : YES NO NO NO NO NO NO NO
FEC Lock : NO NO NO NO NO NO NO NO
MPEG Lock : NO NO NO NO NO NO NO NO
CH Enabled : YES YES YES YES YES YES YES YES
MSE : -21.466 -12.688 -19.689 -4.557 -13.372 -7.559 -15.511 -9.762
Receiver # : 9 10 11 12 13 14 15 16
QAM Lock : NO NO NO NO NO NO NO NO
CH Enabled : NO NO NO NO YES YES YES YES
MSE : -inf -inf -inf -inf -16.124 -14.142 -16.718 -14.548
Receiver # : 17 18 19 20 21 22 23 24
MSE : -18.159 -18.390 -16.660 -5.012 -6.006 -10.906 -7.210 -17.251
Receiver # : 25 26 27 28 29 30 31 32
MSE : -19.500 -19.500 -19.500 -19.500 -19.500 -19.500 -19.500 -19.500
DCID : 0 -NA- -NA- -NA- -NA- -NA- -NA- -NA-
: -NA- -NA- -NA- -NA- -NA- -NA- -NA- -NA-
DCID : 0 0 0 0 0 0 0 0
: --- --- --- --- 0 0 0 0
: 0 0 0 0 0 0 0 0
: 0 0 0 0 0 0 0 0
RC index : -NA- -NA- -NA- -NA- -NA- -NA- -NA- -NA-
DOCSIS QOS
Active Downstream Service Flows:
Active Upstream Service Flows:
Classifiers:
HAL statistics:
no errors
DOCSIS US Rates
CPPI Statistics
PP :
DOCSIS :
DOCSIS US :
PCD Reboot Reasons
Older PCD Reboot Reasons
DOCSIS PHY SUPPORT DATA v1.0
DOCSIS Overview
CM PHY FW Version : 4.5.7.60
CM MAC : XX:XX:XX:XX:XX:1a
CMTS Vendor : -
CM Scan Freq Cache : 0,0,0,0,602000
Training State : 0
OpMode : DOCSIS 0
Sync Time : 0
DS Max Traffic Rate : er
US Max Traffic Rate : er
DOCSIS
DS SNMP Oper Index :
DS Channel IDs :
DS Freqs (Hz) :
DS Channel Width (Hz) :
DS Modulation Type :
DS Latency :
DS Power Level (0.1dBmV) :
DS MSE (0.1dB) :
DS Correcteds :
DS Uncorrecteds :
US SNMP Oper Index :
US Channel IDs :
US Freqs (Hz) :
US Channel Width (Hz) :
US Modulation Type :
US Multiplex Type :
US Power Level (0.1dBmV) : 0,0,0,0,0,0,0,0
DOCSIS 24 Hours Stats
Mse k0 : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Mse k1 : 162,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Mse k2 : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
Mse k3 : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
DOCSIS Configs
Manual Scan Freq : 0
IPv4 Rules
0: from all lookup local
10000: from 192.168.100.1 lookup 130
32765: from all fwmark 0x1 lookup 128
32766: from all lookup main
32767: from all lookup default
IPv4 Default routing table
169.254.1.0/30 dev acc0 src 169.254.1.2
IPv4 Docsis routing table
IPv4 PACM routing table
IPv4 lan0 routing table
default dev lan0
192.168.100.0/24 dev lan0 src 192.168.100.1
IPv6 Rules
16383: from all fwmark 0x1 lookup 128
IPv6 Default routing table
unreachable default dev lo metric -1 error -101
IPv6 Docsis routing table
IPv6 PACM routing table
PACM MTA iface
PACM MTA dns
DOCSIS Bridge
Docsis bridge mode is: 2 (0=off; 1=reg; 2=pre reg; 3=standby)
Docsis bridge erouter mode is: 1 (0=disable; 1=ebable)
Docsis bridge lbridge_interface_mask: 0x0
index Interface Type
0 cni0 CABLE
1 lbr0 CMCI
2 lan0 LAN IP
3 wan0 WAN IP
4 esafe0 ESAFE
Esafe configuration
eSafe dev Target dev Type
esafe0 erouter0 EPSI/EROUTER
Address Lookup Table
Max CPEs 1
Index Mac Name Learning Source Cpe num
0 00:50:f1:00:00:00 lbr0 Init NULL 0
1 XX:XX:XX:XX:XX:1c lan0 Init NULL 0
2 XX:XX:XX:XX:XX:1a wan0 Init NULL 0
CPEs List
Max CPEs 1
Mac Name Learning Source Cpe Num
end of DOCSIS SUPPORT
CM certificate: new/new
MFG certificate: new/new
##### BEGIN SECTION UMTS Supportdata UMTS/GSM
umtsd
PIN: empty, allow roaming: 0, home net:
no valid status
##### END SECTION UMTS
##### BEGIN SECTION Ethernet Supportdata ethernet
Ethernet
/bin/supportdata: line 193: cpmactest: not found
cat: can't open '/proc/driver/avm_cpmac/cpmac0/*': No such file or directory
cat: can't open '/proc/driver/avm_cpmac/*/*': No such file or directory
cat: can't open '/proc/eth/*': No such file or directory
bridge name bridge id STP enabled interfaces
lan 8000.XXXXXXXXXX1d no eth0
eth1
eth2
eth3
ath0
ath1
guest 8000.XXXXXXXXXX1d no guest4
guest5
AVMNET
RMON Counter Dump
/proc/driver/avmnet/ar8327/rmon_all
Counters
CPU port Port 1 Port 2 Port 3 Port 4 Port 5
RxBroad 297 301 0 0 0 0
RxPause 0 0 0 0 0 0
RxMulti 1014 611 0 0 0 0
RxFcsErr 0 0 0 0 0 0
RxAlignErr 0 0 0 0 0 0
RxRunt 0 0 0 0 0 0
RxFragment 0 0 0 0 0 0
Rx64Byte 358 1567 0 0 0 0
Rx128Byte 551 2208 0 0 0 0
Rx256Byte 281 255 0 0 0 0
Rx512Byte 1080 373 0 0 0 0
Rx1024Byte 83 339 0 0 0 0
Rx1518Byte 78 314 0 0 0 0
RxMaxByte 1104 0 0 0 0 0
RxTooLong 0 0 0 0 0 0
RxGoodByteLow 2367378 1080208 0 0 0 0
RxGoodByteHigh 0 0 0 0 0 0
RxBadByteLow 0 0 0 0 0 0
RxBadByteHigh 0 0 0 0 0 0
RxOverflow 0 0 0 0 0 0
Filtered 1 0 0 0 0 0
TxBroad 301 297 0 0 0 0
TxPause 0 0 0 0 0 0
TxMulti 611 1013 0 0 0 0
TxUnderRun 0 0 0 0 0 0
Tx64Byte 0 526 0 0 0 0
Tx128Byte 3778 397 0 0 0 0
Tx256Byte 243 266 0 0 0 0
Tx512Byte 385 1080 0 0 0 0
Tx1024Byte 326 83 0 0 0 0
Tx1518Byte 301 1182 0 0 0 0
TxMaxByte 27 0 0 0 0 0
TxOverSize 0 0 0 0 0 0
TxByteLow 1100808 2354576 0 0 0 0
TxByteHigh 0 0 0 0 0 0
TxCollision 0 0 0 0 0 0
TxAbortCol 0 0 0 0 0 0
TxMultiCol 0 0 0 0 0 0
TxSingleCol 0 0 0 0 0 0
TxExcDefer 0 0 0 0 0 0
TxDefer 0 0 0 0 0 0
TxLateCol 0 0 0 0 0 0
cat: can't open '/proc/driver/ifx_dma/ifx_dma_register': No such file or directory
PHY MDIO Register Dump
/proc/driver/avmnet/phy_ar803x_0/mdio_regs
dumping regs for phy phy_ar803x_0 [mdio:0x0]
reg[0x0]: 0x1040
reg[0x1]: 0x796d
reg[0x2]: 0x4d
reg[0x3]: 0xd036
reg[0x4]: 0x11e1
reg[0x5]: 0xcde1
reg[0x6]: 0xf
reg[0x7]: 0x2001
reg[0x8]: 0x0
reg[0x9]: 0x200
reg[0xa]: 0x7800
reg[0xb]: 0x0
reg[0xc]: 0x0
reg[0xd]: 0x4007
reg[0xe]: 0x0
reg[0xf]: 0x2000
reg[0x10]: 0x862
reg[0x11]: 0xbc50
reg[0x12]: 0x0
reg[0x13]: 0x0
reg[0x14]: 0x82c
reg[0x15]: 0x0
reg[0x16]: 0x2400
reg[0x17]: 0x0
reg[0x18]: 0x3200
reg[0x19]: 0x1000
reg[0x1a]: 0x0
reg[0x1b]: 0x0
reg[0x1c]: 0x0
reg[0x1d]: 0x0
reg[0x1e]: 0x2ee
reg[0x1f]: 0x0
/proc/driver/avmnet/phy_ar803x_1/mdio_regs
dumping regs for phy phy_ar803x_1 [mdio:0x1]
reg[0x0]: 0x1040
reg[0x1]: 0x7949
reg[0x2]: 0x4d
reg[0x3]: 0xd036
reg[0x4]: 0x11e1
reg[0x5]: 0x0
reg[0x6]: 0x4
reg[0x7]: 0x2001
reg[0x8]: 0x0
reg[0x9]: 0x200
reg[0xa]: 0x0
reg[0xb]: 0x0
reg[0xc]: 0x0
reg[0xd]: 0x4007
reg[0xe]: 0x0
reg[0xf]: 0x2000
reg[0x10]: 0x862
reg[0x11]: 0x10
reg[0x12]: 0x0
reg[0x13]: 0x0
reg[0x14]: 0x82c
reg[0x15]: 0x0
reg[0x16]: 0x2400
reg[0x17]: 0x0
reg[0x18]: 0x3200
reg[0x19]: 0x1000
reg[0x1a]: 0x0
reg[0x1b]: 0x0
reg[0x1c]: 0x0
reg[0x1d]: 0x0
reg[0x1e]: 0x2ee
reg[0x1f]: 0x0
/proc/driver/avmnet/phy_ar803x_2/mdio_regs
dumping regs for phy phy_ar803x_2 [mdio:0x2]
reg[0x0]: 0x1040
reg[0x1]: 0x7949
reg[0x2]: 0x4d
reg[0x3]: 0xd036
reg[0x4]: 0x11e1
reg[0x5]: 0x0
reg[0x6]: 0x4
reg[0x7]: 0x2001
reg[0x8]: 0x0
reg[0x9]: 0x200
reg[0xa]: 0x0
reg[0xb]: 0x0
reg[0xc]: 0x0
reg[0xd]: 0x4007
reg[0xe]: 0x0
reg[0xf]: 0x2000
reg[0x10]: 0x862
reg[0x11]: 0x10
reg[0x12]: 0x0
reg[0x13]: 0x0
reg[0x14]: 0x82c
reg[0x15]: 0x0
reg[0x16]: 0x2400
reg[0x17]: 0x0
reg[0x18]: 0x3200
reg[0x19]: 0x1000
reg[0x1a]: 0x0
reg[0x1b]: 0x0
reg[0x1c]: 0x0
reg[0x1d]: 0x0
reg[0x1e]: 0x2ee
reg[0x1f]: 0x0
/proc/driver/avmnet/phy_ar803x_3/mdio_regs
dumping regs for phy phy_ar803x_3 [mdio:0x3]
reg[0x0]: 0x1040
reg[0x1]: 0x7949
reg[0x2]: 0x4d
reg[0x3]: 0xd036
reg[0x4]: 0x11e1
reg[0x5]: 0x0
reg[0x6]: 0x4
reg[0x7]: 0x2001
reg[0x8]: 0x0
reg[0x9]: 0x200
reg[0xa]: 0x0
reg[0xb]: 0x0
reg[0xc]: 0x0
reg[0xd]: 0x4007
reg[0xe]: 0x0
reg[0xf]: 0x2000
reg[0x10]: 0x862
reg[0x11]: 0x50
reg[0x12]: 0x0
reg[0x13]: 0x0
reg[0x14]: 0x82c
reg[0x15]: 0x0
reg[0x16]: 0x2400
reg[0x17]: 0x0
reg[0x18]: 0x3200
reg[0x19]: 0x1000
reg[0x1a]: 0x0
reg[0x1b]: 0x0
reg[0x1c]: 0x0
reg[0x1d]: 0x0
reg[0x1e]: 0x2ee
reg[0x1f]: 0x0
IFX PPA
##### END SECTION Ethernet
##### BEGIN SECTION Networking Supportdata networking
Networking
cat: can't open '/var/dsld.autodetect': No such file or directory
cat: can't open '/var/tmp/ethtooldump': No such file or directory
time: 2000-01-01 01:05:30
0: sync_cable: CABLE (no sync) NOT SYNCHRONIZED
maxspeed 0 1000000000 0bit/s 1000Mbit/s
actual 0 0 0bit/s 0bit/s
0% 0%
running (voip=0,tr069=0,tv=0,ntp=0,ipv6=0,ipv4=0,vpn=0)
Active Provider: -
PPPoE Forward: disabled
0: name internet
0: sync_group: sync_cable
0: iface eth_udma0 RBE/14/dsl XX:XX:XX:XX:XX:1d stay online 1 (voip) (prop: default internet) (prop6: default internet)
0: iface eth_udma0 not up
0: IPv6: native (none)
0: IPv6: disabled
0: IPv6: no address
0: IPv6: no prefix (0)
0: IPv6: mtu 1500
0: IPv4: native
0: IPv4: no sync
0: RX bytes:0 pkt error:0 discard:0 filtered:0 dropped:0
0: RX pkts:0 unicast:0 multicast:0 broadcast:0
0: TX bytes:0 pkt error:0 discard:0 filtered:0 dropped:0
0: TX pkts:0 unicast:0 multicast:0 broadcast:0
##### BEGIN SECTION udma status
udma port(0):
[udma --> l2] gap value: 0 cycles, burst size: 128 bytes
[l2 --> udma] gap value: 0 cycles, burst size: 128 bytes
udma port(1):
udma port(0):
mode: 1, ns: 1000000, ppc: 0
min_cps: 0, max_cps: 0, step_cps: 0
min_mbps: 0, max_mbps: 0, step_mbps: 0
tx.latency: 0, tx.cps: 0
rx.latency: 0, rx.cps: 0
udma port(1):
udma port(0):
[tx] Queue Size : (1024)
[tx] IRQs : (0)
[tx] Packets : (0)
[tx] Total bytes : (0)
[tx] Total drops : (0)
[tx] softIRQs : (0)
[tx] Max pkts : (0)
[tx] Acc pkts : (0)
[rx] Buffer Size : (1522)
[rx] Buffer Reserved : (0)
[rx] Queue Size : (1024)
[rx] IRQs : (0)
[rx] Packets : (0)
[rx] Total bytes : (0)
[rx] Total drops : (0)
[rx] softIRQs : (0)
[rx] Max pkts : (0)
[rx] Acc pkts : (0)
udma port(1):
[tx] IRQs : (0)
[tx] Packets : (0)
[tx] softIRQs : (0)
[tx] Max pkts : (0)
[tx] Acc pkts : (0)
[rx] IRQs : (0)
[rx] Packets : (0)
[rx] softIRQs : (0)
[rx] Max pkts : (0)
[rx] Acc pkts : (0)
##### END SECTION udma status
##### BEGIN SECTION upnp_forward UPnP forwardings
--- UPnP Forwardings ---
igdforwardrules:settings/ or igdforwardrules:status/
##### END SECTION upnp_forward
##### BEGIN SECTION forwards Configured forwardings
