cmd() { PATH="/home/freetz/freetz-stable-1.2/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/bin:/home/freetz/freetz-stable-1.2/toolchain/build/mipsel_gcc-3.4.6/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j4 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12 all \
ARCH="mips" \
CROSS_COMPILE="mipsel-linux-uclibc-"
make[1]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12'
make all-recursive
make[2]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12'
Making all in include
make[3]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include'
Making all in ntfs-3g
make[4]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include/ntfs-3g'
make[4]: Für das Ziel »all« ist nichts zu tun.
make[4]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include/ntfs-3g'
Making all in fuse-lite
make[4]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include/fuse-lite'
make[4]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include/fuse-lite'
make[4]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include'
make[4]: Für das Ziel »all-am« ist nichts zu tun.
make[4]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include'
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/include'
Making all in libfuse-lite
make[3]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/libfuse-lite'
make[3]: Für das Ziel »all« ist nichts zu tun.
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/libfuse-lite'
Making all in libntfs-3g
make[3]: Betrete Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/libntfs-3g'
/bin/bash ../libtool --tag=CC --mode=link /home/freetz/freetz-stable-1.2/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -I../include/ntfs-3g -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -version-info 81 -no-undefined -o libntfs-3g.la -rpath /usr/lib libntfs_3g_la-acls.lo libntfs_3g_la-attrib.lo libntfs_3g_la-attrlist.lo libntfs_3g_la-bitmap.lo libntfs_3g_la-bootsect.lo libntfs_3g_la-cache.lo libntfs_3g_la-collate.lo libntfs_3g_la-compat.lo libntfs_3g_la-compress.lo libntfs_3g_la-debug.lo libntfs_3g_la-device.lo libntfs_3g_la-dir.lo libntfs_3g_la-efs.lo libntfs_3g_la-index.lo libntfs_3g_la-inode.lo libntfs_3g_la-lcnalloc.lo libntfs_3g_la-logfile.lo libntfs_3g_la-logging.lo libntfs_3g_la-mft.lo libntfs_3g_la-misc.lo libntfs_3g_la-mst.lo libntfs_3g_la-object_id.lo libntfs_3g_la-reparse.lo libntfs_3g_la-runlist.lo libntfs_3g_la-security.lo libntfs_3g_la-unistr.lo libntfs_3g_la-volume.lo libntfs_3g_la-xattrs.lo libntfs_3g_la-unix_io.lo ../libfuse-lite/libfuse-lite.la
libtool: link: `libntfs_3g_la-efs.lo' is not a valid libtool object
make[3]: *** [libntfs-3g.la] Fehler 1
make[3]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/libntfs-3g'
make[2]: *** [all-recursive] Fehler 1
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12'
make[1]: *** [all] Fehler 2
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-stable-1.2/source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12'
make: *** [source/target-mipsel_uClibc-0.9.29/ntfs-3g_ntfsprogs-2011.4.12/libntfs-3g/.libs/libntfs-3g.so.81.0.0] Fehler 1
