Asterisk + Hfc + VoipBuster
kandy
19 Feb 2005
I configured the asterisk with an HFC that is configured in the NT mode.
When I use the phone connected to the HFC I am not able to make a call with voipbuster and IAX.
I configured notransfer=yes since I belive that the problem is the audio stream since with XLITE everything is working.
Any idea?
Post your iax.conf and extensions.conf.
This works perfectly for me:
iax.conf
[iaxbuster]
type=peer
host=iax.voipbuster.com
auth=md5
username=...
secret=...
context=...
disallow=all
allow=gsm
extensions.conf
exten => _505.,2,Dial(IAX2/iaxbuster/${EXTEN:3},60)
Hi
I was not able with IAX but using SIP I am able to talk using my ISDN phone and the other part is able to listen me but I cannot listen him.
Any idea?
Sorry!
This is my iax.conf
[iaxbuster]
type=peer
auth=md5
secret=XXXX
username=XXXX
context=from-isdn
disallow=all
allow=gsm
allow=ulaw
allow=alaw
This is the extensions.conf
exten => s,1,dial(IAX2/iaxbuster/0039XXXXX,40)
and this from the console
-- Executing Dial("Zap/2-1", "IAX2/iaxbuster/00390XXXXXX|40") in new stack
    -- Called iaxbuster/00390XXXXXX
    -- Accepting voice call from '' to 's' on channel 0/2, span 1
    -- Call accepted by 213.61.187.157 (format ulaw)
    -- Format for call is ulaw
    -- Hungup 'IAX2/iaxbuster/2'
  == No one is available to answer at this time
    -- Executing Goto("Zap/2-1", "s-NOANSWER|1") in new stack
    -- Goto (from-isdn,s-NOANSWER,1)
    -- Executing BackGround("Zap/2-1", "nbdy-avail-to-take-call") in new stack
    -- Playing 'nbdy-avail-to-take-call' (language 'it')
    -- Channel 0/2, span 1 got hangup
  == Spawn extension (from-isdn, s-NOANSWER, 1) exited non-zero on 'Zap/2-1'
    -- Hungup 'Zap/2-1'
UPDATE
I discovered that if I made the first call with IAX everything is ok, but all the others with the iax I am not able to have the line.
