=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2008.12.05 15:08:17 =~=~=~=~=~=~=~=~=~=~=~=
BusyBox v1.8.2 (2008-08-19 14:56:32 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
ermittle die aktuelle TTY
tty is "/dev/pts/0"
Console Ausgaben auf dieses Terminal umgelenkt
# cd /v
# cd /var/m
# cd /var/media/m f
# cd /var/media/ftp/S
# cd /var/media/ftp/SanDisk-U3CruzerMicro-01/
# ls
# wget [url]http://www.spblinux.de/fbox.new/modules16[/url] [url]http://c2a2b2.com/fbox/0.9.29/cfg_asterisk16[/url]
Connecting to c2a2b2.com (92.51.130.126:80)
cfg_asterisk16 0% | | 0 --:--:-- ETA
cfg_asterisk16 100% |*******************************| 24224 00:00:00 ETA
# chmod +x ./cfg_asterisk14 6
# ./cfg_asterisk14 usb_install-usb_installvusb_install usb_installusb_install
-sh: ./cfg_asterisk14: not found
# ./cfg_asterisk14 -v usb_install14 -v usb_install 6 -v usb_install -v usb_install
cfg.common 0% | | 0 --:--:-- ETA
cfg.common 100% |*******************************| 46767 --:--:-- ETA
INFORMATION: cfg.common: current v2.352 >= required v2.352 -> OK
INFORMATION: asterisk16 Version: 1.6.0.1
INFORMATION: Install-Script Version: 1.241
EXECUTING: _fct cfgctl@cfg_asterisk16:check:app_status
total used free shared buffers
Mem: 61344 48800 12544 0 5632
Swap: 0 0 0
Total: 61344 48800 12544
EXECUTING: _fct instdir@/var/media/ftp:addons/asterisk16:inst_dir:inst_fs_type
INFORMATION: Installing asterisk16 ([url]http://c2a2b2.com/fbox/0.9.29/26-ur8[/url]) to /var/media/ftp/SanDisk-U3CruzerMicro-01/addons ...
EXECUTING: _fct mkdr@/var:log:run:spool:log/asterisk:spool/asterisk
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29/26-ur8:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons:freeramdisk:rd.ko[/email]
freeramdisk 0% | | 0 --:--:-- ETA
freeramdisk 100% |*******************************| 13515 --:--:-- ETA
rd.ko 0% | | 0 --:--:-- ETA
rd.ko 100% |*******************************| 9294 --:--:-- ETA
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons:cfg.cust[/email]omize
cfg.customize 0% | | 0 --:--:-- ETA
cfg.customize 100% |*******************************| 1386 --:--:-- ETA
EXECUTING: _fct rdsk@start
EXECUTING: _fct rdsk@new:ramdev
asterisk16.sqf -> /var/ram0:
EXECUTING: _fct [email]wgetx@http://c2a2b2.com/fbox/0.9.29/26-ur8:/var/ram0:asterisk16.sqf[/email]
ram0 0% | | 0 --:--:-- ETA
ram0 100% |*******************************| 1760k 00:00:00 ETA
INFORMATION: Installing asterisk16 on usb device (SanDisk-U3CruzerMicro-01)
cp: cannot stat '/var/media/ftp/SanDisk-U3CruzerMicro-01/cfg.common': No such file or directory
Start extracting files ... please wait!
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/bin/rasterisk': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/asterisk/sounds/de/digits/minutes.gsm': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/asterisk/sounds/digits/minutes.gsm': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/libgcc_s.so': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/libncurses.so': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/libncurses.so.5': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/libresolv.so': Operation not permitted
cp: cannot create symlink '/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr/lib/libresolv.so.0': Operation not permitted
EXECUTING: _fct rdsk@free:/var/ram0:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons
EXECUTING: _fct lnsf@/var/log/asterisk:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/log/asterisk
EXECUTING: _fct lnsf@/var/spool/asterisk:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/spool/asterisk
COMPLETED: asterisk16 has been successfully installed to usb device SanDisk-U3CruzerMicro-01
Performing root install ... This may take a couple minutes.
Aborting during this period will render your system inoperable!!!
EXECUTING: _fct cfgctl@cfg_asterisk16:disable:SILENT
INFORMATION: asterisk16 start disabled during ROOT overlaying phase ...
EXECUTING: _fct ovrly@RO,USB:/bin:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/bin
-> /bin - ADDED SOFTLINKS: 37
-> /bin/cp NOT REPLACED with SYMLINK to file /var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/bin/cp, as RO parm was set.
-> /bin - ADDED SOFTLINKS: 18
INFORMATION: _fct ovrly@RO,USB:/bin:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/bin: Total 55 softlinks added to /bin/...
EXECUTING: _fct ovrly@RO,USB:/etc:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/etc
-> /etc - ADDED SOFTLINKS: 33
INFORMATION: _fct ovrly@RO,USB:/etc:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/etc: Total 36 softlinks added to /etc/...
EXECUTING: _fct ovrly@RO,USB:/usr:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr
-> /usr - ADDED SOFTLINKS: 4
-> /usr - ADDED SOFTLINKS: 1
INFORMATION: _fct ovrly@RO,USB:/usr:/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/asterisk16/usr: Total 5 softlinks added to /usr/...
EXECUTING: _fct mntif@-o:bind:/var/_RO_/usr/www:/usr/www
EXECUTING: _fct mntif@-o:bind:/var:/var/_RO_/var
EXECUTING: _fct cfgctl@cfg_asterisk16:enable:SILENT
INFORMATION: ROOT overlaying phase finished. asterisk16 starting enabled!
Mem: 61344 51100 10244 0 4344
Swap: 0 0 0
Total: 61344 51100 10244
to use asterisk16 type ./cfg_asterisk16 start
(or /var/media/ftp/SanDisk-U3CruzerMicro-01/addons/cfg_asterisk16 start)
After a reboot you may reinstall asterisk16 from usb with
/var/media/ftp/SanDisk-U3CruzerMicro-01/addons/cfg_asterisk16 usb_install
Found addons customization script cfg.customize in /var/media/ftp/SanDisk-U3CruzerMicro-01/addons. Will check & run customizations for asterisk16 now.
