I saw that in recent trunks there is the possibility to make some packages with static libraries, but i am having difficulties running it.
first default build failed because there are updated versions from both apache
(build uses 1.3.37 but on mirror there is 1.3.39 & 1.3.41) and php (builded uses 5.2.1 while on mirror only 5.2.5), but i found them on other mirrors and put them in dl folder, tried to build statically, but my debian gives an error when it arrives to build php (says that my c++ compiler cannot create executables), apache alone finished successfully and creates the apache binaries in the packages folder.
but with this done (only apache), how am i supposed to use it? upload new firmware created without apache in it on the fritz and copy the apache to a usb drive? or can i just copy that folder to any freetz-ed fritzbox?
in the second case trying to run apache i get the usual segmentation fault error..
