alternatives asterisk-opt für fli4l 3.0.x und 3.1.x (m. hfc)
Hmmm, ja, nochmals drübergebügelt.
Asterisk startet nicht, bekomme mit asterisk -vvvvvgc Warnungen en masse:
Feb 27 21:51:18 WARNING[5175]: chan_sip.c:13202
É                Q¿Feb 27 21:51:18 WARNING[5175]: chan_sip.c:13199
Éþÿÿ$: |$¶:ÿ0|uÿp
 þÿÿ$: Unknown type 'friend' for 'bluesip' in
É
 þÿÿ$: Unknown type 'friend' for 'sipgate' in
É
 þÿÿ$: Unknown type 'friend' for 'gmx' in
É
 þÿÿ$: Unknown type 'friend' for 'webde' in
É
 þÿÿ$: Unknown type 'friend' for '991234' in
É
 þÿÿ$: Unknown type 'friend' for 'voipbuster' in
É
 þÿÿ$: Unknown type 'friend' for 'sipdiscount' in
É
 þÿÿ$: Unknown type 'friend' for 'voipdiscount' in
É
 þÿÿ$: Unknown type 'friend' for 'sparvoip' in
É
 þÿÿ$: Unknown type 'friend' for 'voipstunt' in
É
 þÿÿ$: Unknown type 'friend' for 'internetcalls' in
É
 þÿÿ$: Unknown type 'friend' for 'vbuzzer' in
É
 þÿÿ$: Unknown type 'friend' for 'voipstation' in
É
 þÿÿ$: Unknown type 'friend' for 'surheimer' in
    == Parsing '/data/share/asterisk/etc/sip_notify.conf': Found
  == Registered channel type 'SIP' (Session Initiation Protocol (SIP))
  == Registered application 'SIPDtmfMode'
  == Registered application 'SIPAddHeader'
  == Registered application 'SIPGetHeader'
  == Registered custom function SIP_HEADER
  == Registered custom function SIPPEER
  == Registered custom function SIPCHANINFO
  == Registered custom function CHECKSIPDOMAIN
  == Manager registered action SIPpeers
  == Manager registered action SIPshowpeer
  == Manager registered action SIPNotify
 [CHAN_ZAP.SO]Inconsistency detected by ld.so: dynamic-link.h: 68: elf_get_dynamic_info: Assertion `! "bad dynamic tag"' failed!
fli4l 3.1.1 #
muss wohl an meiner "alten" sip.conf liegen.
Was sagt denn ein 'cat /proc/version'?
fli4l 3.1.1 # cat /proc/version
Linux version 2.6.16.27 (jw5@eisler) (gcc version 3.4.4 20050314 (prerelease) (Debian 3.4.3-13)) #1 Tue Aug 29 13:59:47 CEST 2006
fli4l 3.1.1 #
Anscheinend sind deine config-Dateien kaputt (sie werden nicht sauber gelesen):
Éþÿÿ$: |$¶:ÿ0|uÿp
Hast du damit was angestellt?
Ich hatte sie ... Moment...ich glaube ich habe die Lösung.
Wars wohl doch nicht so ganz,
aber ich hatte einen Windows-crash, und habe jetzt ein älteres aber trotzdem identisches Backup vom Asterisk eingespielt, trotzdem macht mir etwas einen Strich durch die Rechnung:
(man beachte die letzten Zeilen)
Feb 27 22:16:38 WARNING[5268]: chan_sip.c:13202
|$               Q¿
 þ  == Parsing '/data/share/asterisk/etc/sip_notify.conf': Found
fli4l 3.1.1 #
Was kann es sein?
Hi Netview, alles so gemacht. Auch das original etc-Verzeichnis beibehalten.
asterisk -vvvvvgc gibt aus:
 Feb 27 22:45:36 WARNING[5163]: chan_sip.c:13202
|$               Q¿
fli4l 3.1.1 #
EDIT:
Hallo Holger;
ich gehe jetzt erstmal schlafen, muss morgen früh raus.
Wenn Du nichts dagegen hast, können wir ja morgen weitermachen, an dieser Stelle.
Deine Festplatte hat wohl einen Defekt (prüfen mit fschk -y /dev/hda3 bzw. hda2)!
Allerdings vorher manuell alle prozesse stoppen die auf die Platte zugreifen!
Ist die /dev/hda3 /hda2 richtig angelegt (typ 83)?
fli4l 3.1.1 # fdisk -l
Disk /dev/hda: 120.0 GB, 120060444672 bytes
255 heads, 63 sectors/track, 14596 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 * 1 5 40131 4 FAT16 <32M
/dev/hda2 6 14 72292+ 83 Linux
/dev/hda3 146 14596 116077657+ 83 Linux
Genau das war wohl die Ursache für die Fehler! Kaputte Festplatte!
Habe heute kurzerhand eine andere, fast neue Platte reingebaut; jetzt läuft alles wieder. :D
Connected to Asterisk 1.2.15-BRIstuffed-0.3.0-PRE-1y currently running on fli4l
Vielen Dank, Netview!
Gut - dann viel Spass damit (aber wie gesagt ohne Gewähr, offiziell gibt es diese Kombination bristuff-0.3.0-PRE-1y mit asterisk-1.2.15 nicht!) ;-)
Hallo Netview,
hatte ja das dazugehörige opt schon drauf, nun noch das neue mod ( 1.2.16) ---> und ging problemlos.
fli4l 3.1.1 # asterisk -r
Asterisk 1.2.16-BRIstuffed-0.3.0-PRE-1y, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created  Type 'show license' for details.
Connected to Asterisk 1.2.16-BRIstuffed-0.3.0-PRE-1y currently running on fli4l (pid = 4291)
fli4l*CLI>
Vielen Dank.
Hallo;
eben gerade das Update heruntergeladen, auf den Router geschoben und "reload", erste Telefonate geführt ---> ging alles problemlos.
Gute Arbeit, Netview; vielen Dank! :D
Hallo Holger,
für mich ist das im Augenblick noch etwas zu unübersichtlich, weil --> zum ersten mal gesehen.
Woher weißt Du z. B., was die aktuellste Revisions-Nummer ist? Ich werde das schon noch selbst herausfinden! :)
Und noch eine Frage dazu:
ist es zweckmäßig, vor dem Einspielen eines derartigen Updates eine Sicherungskopie der vorher vorhandenen Files zu machen oder sind die update-files ausreichend getestet, sodass man auf ein backup verzichten kann?
Günter
ploieel schrieb:
Hallo Holger,
Günter
zu 1) auf bereits geposteten link klicken
zu 2) ich mache keine Sicherung - patch ist zu 99,99% immer ok!
OK,
1. werde ich nach updates von jetzt ab selbst regelmäßig sehen
2. werde ich ebenfalls vor dem Patch wie Du keine Sicherung machen und
3. wäre es trotzdem nicht schlecht, hin und wieder von Dir hier auf ein update aufmerksam gemacht zu werden. Du bist eben viel näher dran...
4. werde ich hier nach wie vor Feedback geben, auch wenn ich der Einzigste bin. :)
Günter
b.t.w. Asterisk auf dem Fli4L ist ein "geiles Teil", wenn es einmal läuft! :D
rev. 58579 + chan-capi 430 (q.sig support).
rev. 58579 --> chan_sip.c gefunden; auf den Router laden --> ja oder nein?
chan-capi 430 --> bisher nicht gefunden
Was bedeutet "q.sig support" ?
curious2315
