I have used both.
Interesting thing is that
echo "kernel_args annex=A" > /proc/sys/urlader/environment
sticks after all the reboots.
However the :
echo "annex A" > /proc/sys/urlader/environment
does not stick and needs to be entered through telnet in case modem does reboot for some reason.
I have achieved not only sync (after the Annex A is typed in as a command, pictures below), but I have also now achieved PPPOE connection! Internet works, hooray!
I on purpose put the stability for downstream to maximum stability while for upstream I left it at maximum performance. Sync on ZTE and Huawei were 16Mb/1.2Mb while with these settings on FB 7412 I have now much more stable 13Mb/1.17Mb and CRC error count is very low.
I didn't mention that both ZTE and Huaweie were working "OK" meaning no sync drops UNTIL 12 in the night, when some RFI/EMI noise impusles start in my neighbourhood and this causes to SNR to drop and I lose sync. This was very bad for VOIP sessions or online games which made me look into routers who can control SNR margins (hence fritzbox). My exchange lowered my plan from 20Mb to 16Mb on my recquest in order to stabilize the line but drops still happened only after midnight.
Now I will monitor the line after midnight and see how Fritzbox does. If it does well I will stick with FB. I am still looking for a way to make Annex A change stick. I might create a script that launches cmd and telnets into the router every time I start my PC or call the script manually.
However the :
