7340 + phoenix (card reader) = panic in 5s
avathar
4 Okt 2010
Hello,
i'm trying to run card reader phoenix usb (3,57-6MHz ver.7.6) on my 7340.
I use this reader on my 7240 without any problem. Below i include some logs from 7240 & 7340, maybe someone can tell me something based on these logs.
Reader is attached with this command:
modprobe ftdi_sio vendor=0x403 product=0x6001
7240:
Jan  1 01:01:24 fritz kern.info kernel: usbcore: registered new interface driver usbserial
Jan  1 01:01:24 fritz kern.info kernel: usbserial: USB Serial Driver core
Jan  1 01:01:24 fritz kern.info kernel: USB Serial support registered for FTDI USB Serial Device
Jan  1 01:01:24 fritz kern.info kernel: usbcore: registered new interface driver ftdi_sio
Jan  1 01:01:24 fritz kern.info kernel: ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
7340:
Jan 23 14:35:00 fritz kern.info kernel: usbcore: registered new interface driver usbserial
Jan 23 14:35:00 fritz kern.info kernel: usbserial: USB Serial Driver core
Jan 23 14:35:00 fritz kern.info kernel: USB Serial support registered for FTDI USB Serial Device
Jan 23 14:35:00 fritz kern.info kernel: ftdi_sio 2-2:1.0: FTDI USB Serial Device converter detected
Jan 23 14:35:00 fritz kern.info kernel: usb 2-2: Detected FT232RL
Jan 23 14:35:00 fritz kern.info kernel: usb 2-2: FTDI USB Serial Device converter now attached to ttyUSB0
Jan 23 14:35:00 fritz kern.info kernel: usbcore: registered new interface driver ftdi_sio
Jan 23 14:35:00 fritz kern.info kernel: ftdi_sio: v1.4.3:USB FTDI Serial Converters Driver
and after i start application that uses this reader, i got this:
7340:
Jan 23 14:39:13 fritz auth.info login[3068]: root login on 'pts/0'
Jan 23 14:40:12 fritz kern.warn kernel: Kernel unaligned instruction access[#1]:
Jan 23 14:40:12 fritz kern.warn kernel: Cpu 0
Jan 23 14:40:12 fritz kern.warn kernel: $ 0   : 00000000 00000000 00000006 00000006
Jan 23 14:40:12 fritz kern.warn kernel: $ 4   : 00000000 8564a040 fffffffe 8058c8e0
Jan 23 14:40:12 fritz kern.warn kernel: $ 8   : 8440ffe0 0000fc00 00000000 80454000
Jan 23 14:40:12 fritz kern.warn kernel: $12   : 85703c98 00000000 0000001f 00500000
Jan 23 14:40:12 fritz kern.warn kernel: $16   : 800984bc 7edffae8 847fd200 8572cd60
Jan 23 14:40:12 fritz kern.warn kernel: $20   : 7edffb48 8303d000 00592190 0055f208
Jan 23 14:40:12 fritz kern.warn kernel: $24   : 004f8c70 2ac5f690
Jan 23 14:40:12 fritz kern.warn kernel: $28   : 8440c000 8440fe18 50ffe83c 0000540e
Jan 23 14:40:12 fritz kern.warn kernel: Hi    : 0000001a
Jan 23 14:40:12 fritz kern.warn kernel: Code: (Bad address in epc)
Jan 23 14:40:12 fritz kern.emerg kernel: Fatal exception: panic in 5 seconds
Regards,
Tom
I remember i tryed such cardreader on my 7390er with the .22 - Firmware. I got a /dev/ttyUSB0 but when i started a application (name of this application beginns with "OS") then fritzbox rebooted. With the new labor-firmware or 05.50 - Firmware i do not have this Problem anymore. At the moment the cardreader works fine with a beta-Firmware in a 7320er Fritzbox.
Maybe this post will help you.
Thanks for information.
I think that i found the source of problem. I recompiled kernel module ftdi_sio.ko and now this driver is in version 1.5.0
So far so good. So likely driver in version 1.4.3 wasn't working properly.
Regards
I forget to write, that my experiments were without freetz. It works fine with the last original-avm-firmware.
soundworx
