Hi people,
Im try few diferent manufacturer of routers and always problems (3 walls between my pc and router) till i get this device. Signal is allmost 100% but was few problems, first is from some reason broken connection on WAN port (on this device its LAN1) and second problem is device just reset from no reason. First problem im repair, im found 2 SMD resistors wich are just burn im replace it and LAN1 work, that second problem ill change all capacitors and check but how i can change in english language?? Software is FRITZ!OS 05.54 and Firmware-Version: 96.05.54 on AVM ftp server i cant found downgrade file for this device, im send email to AVM support they are say we not support this model you can buy brand new model. Im download exe file FRITZ.Box_WLAN_3270_v3.en-de-es-it-fr.05.52.recover-image but that say wrong version of firmware. Last night im desolder flash ic M29W128GH and put in my programmer ( im unzip that image and found 12mb file its firmware) but from some reason my programmer cant read and write that flash IC. Now after all is have some solution how i can write that english file in my router or i cant solve that problem? Maybe with jtag or someone else way?
with best regards
Ibro
with best regards
Ibro
