Ich bekomme die Version unter OpenSuse 12.3 leider nicht zum Laufen:
org.apache.http.conn.ssl.SSLInitializationException: Failure initializing default SSL context
at org.apache.http.conn.ssl.SSLSocketFactory.createDefaultSSLContext(SSLSocketFactory.java:360)
at org.apache.http.conn.ssl.SSLSocketFactory.getSocketFactory(SSLSocketFactory.java:175)
at org.apache.http.impl.conn.SchemeRegistryFactory.createDefault(SchemeRegistryFactory.java:49)
at org.apache.http.impl.client.AbstractHttpClient.createClientConnectionManager(AbstractHttpClient.java:306)
at org.apache.http.impl.client.AbstractHttpClient.getConnectionManager(AbstractHttpClient.java:466)
at org.apache.http.impl.client.AbstractHttpClient.createHttpContext(AbstractHttpClient.java:286)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:851)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:805)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:784)
at de.moonflower.jfritz.utils.JFritzUtils.getResponse(JFritzUtils.java:131)
at de.moonflower.jfritz.utils.JFritzUtils.getResponseToString(JFritzUtils.java:139)
at de.moonflower.jfritz.utils.JFritzUtils.postDataToUrlAndGetStringResponse(JFritzUtils.java:297)
at de.moonflower.jfritz.box.fritzbox.FritzBoxLoginHandler.getLoginSidResponseFromXml(FritzBoxLoginHandler.java:36)
at de.moonflower.jfritz.box.fritzbox.SIDLogin.check(SIDLogin.java:45)
at de.moonflower.jfritz.box.fritzbox.FritzBoxFirmware.login(FritzBoxFirmware.java:310)
at de.moonflower.jfritz.box.fritzbox.FritzBoxFirmware.detectFirmwareVersion(FritzBoxFirmware.java:167)
at de.moonflower.jfritz.box.fritzbox.FritzBox.detectFirmware(FritzBox.java:219)
at de.moonflower.jfritz.box.fritzbox.FritzBox.updateSettings(FritzBox.java:181)
at de.moonflower.jfritz.box.fritzbox.FritzBox.<init>(FritzBox.java:159)
at de.moonflower.jfritz.JFritz.initFritzBox(JFritz.java:149)
at de.moonflower.jfritz.Main.initJFritz(Main.java:515)
at de.moonflower.jfritz.Main.<init>(Main.java:307)
at de.moonflower.jfritz.Main.main(Main.java:327)
Caused by: java.security.KeyStoreException: problem accessing trust storejava.io.IOException: Invalid keystore format
at sun.security.ssl.TrustManagerFactoryImpl.engineInit(TrustManagerFactoryImpl.java:75)
at javax.net.ssl.TrustManagerFactory.init(TrustManagerFactory.java:250)
at org.apache.http.conn.ssl.SSLSocketFactory.createSSLContext(SSLSocketFactory.java:229)
at org.apache.http.conn.ssl.SSLSocketFactory.createDefaultSSLContext(SSLSocketFactory.java:358)
... 22 more
Hier bleibt jfritz dann leider hängen. Woran liegt`s?
MfG, Holger
... 22 more
MfG, Holger
