[Gigaset Pro] Neue Firmware 02.00.08 für DE900/DE700 IP PRO
jogiwer
9 Sep 2009
Im Wiki von Gigaset kündigt sich eine neue Firmaware an.
Bis vor kurzem noch als Beta tituliert nennt sich die dort liegende Version 02.00.08 nun Release Candidate.
Edit: Mit Stand September als Release freigegeben.
Edit2: Korrektur der Links auf neue Domain.
Viele Grüße,
Jogi
-Release Date:
September 2013 - August 2013 (Release candidate)
Version:
02.00.08
Enhancements
  • As a user I want to assign functions to preprogrammed function keys
  • As a NetDirectory user I don't want to enter on my own complete search criteria
  • Support of Client and Server certificates
  • SIP diversion header - as a user I want to get information if a call is diverted from somewhere
  • As a User I want to store all settings and data in one file for backup needs
  • Configurable period for checking the Profile
  • XML-Based Central Phone Book
  • Accept incoming SIP requests only from previously addressed SIP servers
  • Phone doesn't need to perform auto-lookup for incoming anonymous call.
  • XML-based NetDirectory: private pages to be supported
  • Dialing Plan optimization behind Gigaset and Gigaset T300/T500 PBX
  • Support of different SIP privacy mechanisms (RFC3323)
  • LDAP implementation optimization
  • optimized provisioning server URL processing
  • Autoprovisioning: increased number of possible parameter
  • Optimized Firmware update/downgrade
  • Include Activation-Code provisioning for provider
  • Hidden page in WebUI for T300/T500
  • Implement SIP USER ID in XML HTTP GET request
  • Interop Timico MWI
Bugfixes
  • [Broadsoft] Clic-to-Dial; Second call doesn't work
  • Phone answer the incoming call directly, when another call is on hold
  • If user presses the corresponding flashing Line key, the incoming call should be answered
  • No firmware update or downgrade possible if BLF key configured
  • Phone reboot after pressing Dial SK via call list
  • If only a number is defined, the default number is copied to the surname field
  • After using outgoing calls list timeout, phone return to idle during one call is on hold state
  • 22_beep.mp3 belongs to factory default ringtones
  • After restore the config file, phone should check whether user uploaded ringtones still exist or not
  • After connecting extension module to DUT, DUT works slowly
  • After pressing "Play" in Voice Mail, phone could not work normally anymore except reboot it
  • User can't answer the call doing copy to directory via call list
  • Some data missing during use of GQS
  • Wrong log parsing on the web interface (related to openvpn)
  • Unexpected reboot in redial list
  • Wrong criteria in the online directory search request
  • [DECT Handset] There is no speech path if you start call using Headset button and other party will answer
  • Key tones are turned on automatically after turning on WLAN
  • It is not possible to dial out, by pressing hands free button or pickup receiver, from Outgoing Calls list
  • Phone does not inform about incoming call during the radio is playing
  • [provisioning] wrong HTTP digest authentication when plain XML is used
  • Reset while using scroll wheel in online directory
  • Phone numbers in Call list are scrolling in a loop
  • Only Gigaset T300/T500 voice mailbox is available
  • Sporadic reboot
  • After uploading caller pictures DUT works slowly
  • VM MWI problem | ihub ITSP
Known Issues
  • Inconsistent VPN files' name processing
