[Gelöst] 7240 und USBROOT
freddy02
5 Mai 2007
Nach dem aktivieren von USBROOT im freetzmenu loopt die 7240 mit
dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_488.hex' successfull
[piglet]bitfile '/lib/modules/bitfile_isdn.bit'
[piglet] clock from pll3(384000000)
[piglet] Failed: Could not open bitfile
[piglet]error: Can't load bitfile/no TDM-Clocks -> retry
patch_dectfw: c0409000, totallen = 70210(11242)
patch_dectfw: patch_adress: f1038 max_len: 26 with Version 2 Len: 17
patch_dectfw: dectmode 2
dect_loader: fast-bootmode
patch_dectfw: c0533000, totallen = 70210(11242)
********************************************[4294939851][0]system-load 6  21 tasks:47 % curr:busybox(47 %) max:busybox(47 %, pid:44), readytorun: 3, pgfault 0/s (max 0 avg 0.0)
^C
patch_dectfw: c065d000, totallen = 70210(11242)
*************************************************************************************************************************************[4294940914][0]system-load 5  21 tasks:50 % curr:busybox(50 %) max:busybox(50 %, pid:44), readytorun: 3)
^Cdect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_488.hex' successfull
patch_dectfw: c0787000, totallen = 70210(11242)
patch_dectfw: c08b1000, totallen = 70210(11242)
********************************************[4294942731][0]system-load 4  21 tasks:25 % curr:busybox(25 %) max:busybox(25 %, pid:44), readytorun: 2, pgfault 0/s (max 0 avg 0.0)
patch_dectfw: c09db000, totallen = 70210(11242)
^C*
********************************************[4294943892][0]system-load 3  21 tasks:29 % curr:busybox(28 %) max:busybox(28 %, pid:44), readytorun: 2, pgfault 0/s (max 0 avg 0.0)
mit SETENV kernel_args und SETENV kernel_args1 läufts wieder intern
devel von heute morgen,
beide (intern und usb) das gleiche image
edit:
interne image log:
[piglet]bitfile '/lib/modules/bitfile.bit'
[piglet] bitfile 72743 bytes done
[piglet]TDM: FS: 8000 Hz CLK:2047980 Hz
__io_remap_setwriteprotect: info: no pte for addr 97ae0000
JFFS2 version 2.2 (NAND) (ZLIB) (RTIME) (c) 2001-2006 Red Hat, Inc.
__io_remap_setwriteprotect: info: no pte for addr 97b1c000
loop: module loaded
[4294938597][0]system-load 7  24 tasks:18 % curr:usbcfgctl(0 %) max:init(12 %, pid:1), readytorun: 1, pgfault 1557/s (max 1 avg 1.0)
__io_remap_setwriteprotect: info: no pte for addr 97b68000
ramzswap: /dev/ramzswap0 initialized: disksize_kb=8192
Adding 8184k swap on /dev/ramzswap0.  Priority:-1 extents:1 across:8184k SS
__io_remap_setwriteprotect: info: no pte for addr 94a80000
einzig auffällig->
ist rc.usbroot evntl. falsch ?
so, ich war ein wenig blind
funktioniert : [piglet]bitfile '/lib/modules/bitfile.bit'
rc.usbroot
funktioniert nicht : [piglet]bitfile '/lib/modules/bitfile_isdn.bit'
ralf-ddd
