config FREETZ_PACKAGE_IPTABLES
bool "Iptables 1.4.11.1 (binary only, unstable)"
depends on FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE
default n
help
Netfilter/iptables
Netfilter is the set of hooks within the Linux kernel for intercepting
and manipulating network packets. The best-known component on top of
netfilter is the firewall which filters packets, but the hooks are also
used by a component which performs network address translation, and by
another which provides ipchains backwards compatibility. These
components are usually Loadable Kernel Modules.
iptables is the name of the user space tool by which administrators
create rules for the packet filtering and NAT modules. While technically
iptables is merely the tool which controls the packet filtering and NAT
components within the kernel, the name iptables is often used to refer
to the entire infrastructure, including netfilter, connection tracking
and NAT, as well as the tool itself. iptables is a standard part of all
modern Linux distributions.
config FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE
bool "Is Iptables selectable for your custom configuration?" if FREETZ_TYPE_CUSTOM
default y if \
!FREETZ_TYPE_SPEEDPORT_W501V && \
!FREETZ_TYPE_FON_5140
default n
help
Select this if you are sure that Iptables should work on your box
config FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE
bool "Iptables-save / iptables-restore"
default n
help
iptables-save & iptables-restore
config FREETZ_PACKAGE_IPTABLES_XML
bool "Iptables-xml"
depends on FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE
default n
help
Include iptables-xml to convert saved rules to xml.
# Include here for a cleaner menu structure (list packages before modules/libs)
source make/iptables-cgi/Config.in
source make/nhipt/Config.in
source make/iptables/standard-modules.in
comment "CAUTION: Use of module ip_conntrack can lead to spontaneous reboots"
depends on FREETZ_PACKAGE_IPTABLES && \
FREETZ_MODULE_ip_conntrack && \
FREETZ_KERNEL_VERSION_2_6_13
config FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES
bool "Iptables kernel modules"
default n
help
Linux kernel modules for iptables
Please note that some kernel modules have corresponding shared libraries
and vice versa, so please make sure to select both of them, if they are
needed for your purpose.
menu "Select kernel modules (IPv4)"
depends on FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES
config FREETZ_MODULE_ip_conntrack
bool "ip_conntrack.ko"
depends on FREETZ_KERNEL_VERSION_2_6_19_MAX
default n
help
Connection tracking keeps a record of what packets have passed
through your machine, in order to figure out how they are related
into connections.
This is required to do Masquerading or other kinds of Network
Address Translation (except for Fast NAT). It can also be used to
enhance packet filtering (see `Connection state match support'
below).
config FREETZ_MODULE_nf_conntrack
bool "nf_conntrack.ko"
#depends on FREETZ_KERNEL_VERSION_2_6_28_MIN
#depends on FREETZ_KERNEL_VERSION_2_6_32
default n
help
into connections.
below).
config FREETZ_MODULE_ip_conntrack_ftp
bool "ip_conntrack_ftp.ko"
select FREETZ_MODULE_ip_conntrack
default n
help
Tracking FTP connections is problematic: special helpers are
required for tracking them, and doing masquerading and other forms
of Network Address Translation on them.
config FREETZ_MODULE_nf_conntrack_ftp
bool "nf_conntrack_ftp.ko"
select FREETZ_MODULE_nf_conntrack
default n
help
config FREETZ_MODULE_ip_conntrack_h323
bool "ip_conntrack_h323.ko"
default n
help
H.323 is a VoIP signalling protocol from ITU-T. As one of the most
important VoIP protocols, it is widely used by voice hardware and
software including voice gateways, IP phones, Netmeeting, OpenPhone,
Gnomemeeting, etc.
With this module you can support H.323 on a connection tracking/NAT
firewall.
This module supports RAS, Fast Start, H.245 Tunnelling, Call
Forwarding, RTP/RTCP and T.120 based audio, video, fax, chat,
whiteboard, file transfer, etc. For more information, please
visit http://nath323.sourceforge.net/.
config FREETZ_MODULE_nf_conntrack_h323
bool "nf_conntrack_h323.ko"
default n
help
Gnomemeeting, etc.
firewall.
config FREETZ_MODULE_ip_conntrack_irc
bool "ip_conntrack_irc.ko"
default n
help
There is a commonly-used extension to IRC called
Direct Client-to-Client Protocol (DCC). This enables users to send
files to each other, and also chat to each other without the need
of a server. DCC Sending is used anywhere you send files over IRC,
and DCC Chat is most commonly used by Eggdrop bots. If you are using
NAT, this extension will enable you to send files and initiate chats.
Note that you do NOT need this extension to get files or have others
initiate chats, or everything else in IRC.
config FREETZ_MODULE_nf_conntrack_irc
bool "nf_conntrack_irc.ko"
default n
help
config FREETZ_MODULE_nf_conntrack_ipv4
bool "nf_conntrack_ipv4.ko"
default n
config FREETZ_MODULE_ip_conntrack_pptp
bool "ip_conntrack_pptp.ko"
default n
help
This module adds support for PPTP (Point to Point Tunnelling
Protocol, RFC2637) connection tracking and NAT.
If you are running PPTP sessions over a stateful firewall or NAT
box, you may want to enable this feature.
Please note that not all PPTP modes of operation are supported yet.
For more info, read top of the file
net/ipv4/netfilter/ip_conntrack_pptp.c
config FREETZ_MODULE_nf_conntrack_pptp
bool "nf_conntrack_pptp.ko"
select FREETZ_MODULE_nf_conntrack_proto_gre
default n
help
config FREETZ_MODULE_nf_conntrack_proto_gre
bool "nf_conntrack_proto_gre.ko"
default n
help
config FREETZ_MODULE_ip_conntrack_rtsp
bool "ip_conntrack_rtsp.ko"
default n
help
Tracking RTSP Connections
config FREETZ_MODULE_ip_conntrack_tftp
bool "ip_conntrack_tftp.ko"
default n
help
TFTP connection tracking helper, this is required depending
on how restrictive your ruleset is.
If you are using a tftp client behind -j SNAT or -j MASQUERADING
you will need this.
config FREETZ_MODULE_nf_conntrack_tftp
bool "nf_conntrack_tftp.ko"
depends on FREETZ_KERNEL_VERSION_2_6_28 || FREETZ_KERNEL_VERSION_2_6_32
default n
help
you will need this.
config FREETZ_MODULE_ip_conntrack_proto_sctp
bool "ip_conntrack_proto_sctp.ko"
depends on FREETZ_KERNEL_VERSION_2_6_13
default n
help
With this option enabled, the connection tracking code will
be able to do state tracking on SCTP connections.
config FREETZ_MODULE_nf_defrag_ipv4
bool "nf_defrag_ipv4.ko"
default n
config FREETZ_MODULE_ip_nat
bool "ip_nat.ko"
default n
help
The Full NAT option allows masquerading, port forwarding and other
forms of full Network Address Port Translation. It is controlled by
the `nat' table in iptables: see the man page for iptables(8).
config FREETZ_MODULE_nf_nat
bool
#bool "nf_nat.ko"
select FREETZ_MODULE_nf_conntrack_ipv4
select FREETZ_MODULE_nf_defrag_ipv4
default n
help
config FREETZ_MODULE_ip_nat_ftp
bool "ip_nat_ftp.ko"
select FREETZ_MODULE_iptable_nat if FREETZ_KERNEL_VERSION_2_6_13
select FREETZ_MODULE_ip_nat if FREETZ_KERNEL_VERSION_2_6_19
select FREETZ_MODULE_ip_conntrack_ftp
default n
config FREETZ_MODULE_nf_nat_ftp
bool "nf_nat_ftp.ko"
select FREETZ_MODULE_nf_nat
select FREETZ_MODULE_nf_conntrack_ftp
default n
config FREETZ_MODULE_ip_nat_h323
bool "ip_nat_h323.ko"
select FREETZ_MODULE_ip_conntrack_h323
default n
config FREETZ_MODULE_nf_nat_h323
bool
#bool "nf_nat_h323.ko"
select FREETZ_MODULE_nf_conntrack_h323
default n
config FREETZ_MODULE_ip_nat_irc
bool "ip_nat_irc.ko"
select FREETZ_MODULE_ip_conntrack_irc if FREETZ_KERNEL_VERSION_2_6_19
default n
config FREETZ_MODULE_nf_nat_irc
bool
#bool "nf_nat_irc.ko"
select FREETZ_MODULE_nf_conntrack_irc
default n
config FREETZ_MODULE_ip_nat_pptp
bool "ip_nat_pptp.ko"
select FREETZ_MODULE_ip_conntrack_pptp
default n
config FREETZ_MODULE_nf_nat_pptp
bool
#bool "nf_nat_pptp.ko"
select FREETZ_MODULE_nf_conntrack_pptp
default n
config FREETZ_MODULE_ip_nat_rtsp
bool "ip_nat_rtsp.ko"
select FREETZ_MODULE_ip_conntrack_rtsp
default n
config FREETZ_MODULE_ip_nat_tftp
bool "ip_nat_tftp.ko"
select FREETZ_MODULE_ip_conntrack_tftp if FREETZ_KERNEL_VERSION_2_6_19
default n
config FREETZ_MODULE_nf_nat_tftp
bool "nf_nat_tftp.ko"
select FREETZ_MODULE_nf_conntrack_tftp
default n
config FREETZ_MODULE_iptable_filter
bool "iptable_filter.ko"
select FREETZ_MODULE_ip_tables
default n
help
Packet filtering defines a table `filter', which has a series of
rules for simple packet filtering at local input, forwarding and
local output. See the man page for iptables(8).
config FREETZ_MODULE_iptable_mangle
bool "iptable_mangle.ko"
default n
help
This option adds a `mangle' table to iptables: see the man page for
iptables(8). This table is used for various packet alterations
which can effect how the packet is routed.
config FREETZ_MODULE_iptable_nat
bool "iptable_nat.ko"
select FREETZ_MODULE_ip_conntrack if FREETZ_KERNEL_VERSION_2_6_19_MAX
select FREETZ_MODULE_nf_nat if FREETZ_KERNEL_VERSION_2_6_28
default n
config FREETZ_MODULE_iptable_raw
bool "iptable_raw.ko"
depends on FREETZ_KERNEL_VERSION_2_6_19_MIN
default n
config FREETZ_MODULE_ip_tables
bool "ip_tables.ko"
select FREETZ_MODULE_x_tables if FREETZ_KERNEL_VERSION_2_6_19_MIN
default n
help
iptables is a general, extensible packet identification framework.
The packet filtering and full NAT (masquerading, port forwarding,
etc) subsystems now use this.
config FREETZ_MODULE_ipt_connmark
bool "ipt_connmark.ko"
default n
help
This option enables support for connection marks, used by the
`CONNMARK' target and `connmark' match. Similar to the mark value
of packets, but this mark value is kept in the conntrack session
instead of the individual packets.
config FREETZ_MODULE_ipt_CONNMARK
bool "ipt_CONNMARK.ko"
default n
help
This option adds a `CONNMARK' target, which allows one to manipulate
the connection mark value. Similar to the MARK target, but
affects the connection mark value rather than the packet mark value.
config FREETZ_MODULE_ipt_conntrack
bool "ipt_conntrack.ko"
default n
config FREETZ_MODULE_ipt_helper
bool "ipt_helper.ko"
default n
help
Helper matching allows you to match packets in dynamic connections
tracked by a conntrack-helper, ie. ip_conntrack_ftp
config FREETZ_MODULE_ipt_iprange
bool "ipt_iprange.ko"
select FREETZ_MODULE_ip_tables if FREETZ_KERNEL_VERSION_2_6_13
default n
help
This option makes possible to match IP addresses against IP address
ranges.
config FREETZ_MODULE_ipt_layer7
bool "ipt_layer7.ko"
default n
help
Say Y if you want to be able to classify connections (and their
packets) based on regular expression matching of their application
layer data. This is one way to classify applications such as
peer-to-peer filesharing systems that do not always use the same
port.
config FREETZ_MODULE_ipt_ipp2p
bool "ipt_ipp2p.ko"
default n
help
This option makes possible to match some P2P packets
therefore helps controlling such traffic.
config FREETZ_MODULE_ipt_length
bool "ipt_length.ko"
default n
help
This option allows you to match the length of a packet against a
specific value or range of values.
config FREETZ_MODULE_ipt_limit
bool "ipt_limit.ko"
default n
help
limit matching allows you to control the rate at which a rule can be
matched: mainly useful in combination with the LOG target ("LOG
target support", below) and to avoid some Denial of Service attacks.
config FREETZ_MODULE_ipt_LOG
bool "ipt_LOG.ko"
select FREETZ_MODULE_ip_tables if FREETZ_KERNEL_VERSION_2_6_19_MAX
select FREETZ_MODULE_x_tables if FREETZ_KERNEL_VERSION_2_6_28_MIN
default n
help
This option adds a `LOG' target, which allows you to create rules in
any iptables table which records the packet header to the syslog.
config FREETZ_MODULE_ipt_comment
bool "ipt_comment.ko"
default n
help
This option adds a module, which allows you to add comments to your rules.
config FREETZ_MODULE_ipt_mac
bool "ipt_mac.ko"
default n
help
MAC matching allows you to match packets based on the source
Ethernet address of the packet.
config FREETZ_MODULE_ipt_mark
bool "ipt_mark.ko"
default n
help
Netfilter mark matching allows you to match packets based on the
`nfmark' value in the packet. This can be set by the MARK target
(see below).
config FREETZ_MODULE_ipt_MARK
bool "ipt_MARK.ko"
default n
help
This option adds a `MARK' target, which allows you to create rules
in the `mangle' table which alter the netfilter mark (nfmark) field
associated with the packet prior to routing. This can change
the routing method (see `Use netfilter MARK value as routing
key') and can also be used by other subsystems to change their
behavior.
config FREETZ_MODULE_ipt_MASQUERADE
bool "ipt_MASQUERADE.ko"
default n
help
Masquerading is a special case of NAT: all outgoing connections are
changed to seem to come from a particular interface's address, and
if the interface goes down, those connections are lost. This is
only useful for dialup accounts with dynamic IP address (ie. your IP
address will be different on next dialup).
config FREETZ_MODULE_ipt_multiport
bool "ipt_multiport.ko"
default n
help
Multiport matching allows you to match TCP or UDP packets based on
a series of source or destination ports: normally a rule can only
match a single range of ports.
config FREETZ_MODULE_ipt_owner
bool "ipt_owner.ko"
default n
help
Packet owner matching allows you to match locally-generated packets
based on who created them: the user, group, process or session.
config FREETZ_MODULE_ipt_REDIRECT
bool "ipt_REDIRECT.ko"
depends on FREETZ_KERNEL_VERSION_2_6_28_MAX
select FREETZ_MODULE_x_tables if FREETZ_KERNEL_VERSION_2_6_19 || FREETZ_KERNEL_VERSION_2_6_28
default n
help
REDIRECT is a special case of NAT: all incoming connections are
mapped onto the incoming interface's address, causing the packets to
come to the local machine instead of passing through. This is
useful for transparent proxies.
config FREETZ_MODULE_ipt_REJECT
bool "ipt_REJECT.ko"
default n
help
The REJECT target allows a filtering rule to specify that an ICMP
error should be issued in response to an incoming packet, rather
than silently being dropped.
config FREETZ_MODULE_ipt_state
bool "ipt_state.ko"
default n
help
Connection state matching allows you to match packets based on their
relationship to a tracked connection (ie. previous packets). This
is a powerful tool for packet classification.
config FREETZ_MODULE_ipt_tcpmss
bool "ipt_tcpmss.ko"
default n
help
This option adds a `tcpmss' match, which allows you to examine the
MSS value of TCP SYN packets, which control the maximum packet size
for that connection.
config FREETZ_MODULE_ipt_TCPMSS
bool "ipt_TCPMSS.ko"
default n
help
This option adds a `TCPMSS' target, which allows you to alter the
MSS value of TCP SYN packets, to control the maximum size for that
connection (usually limiting it to your outgoing interface's MTU
minus 40).
This is used to overcome criminally braindead ISPs or servers which
block ICMP Fragmentation Needed packets. The symptoms of this
problem are that everything works fine from your Linux
firewall/router, but machines behind it can never exchange large
packets:
1) Web browsers connect, then hang with no data received.
2) Small mail works fine, but large emails hang.
3) ssh works fine, but scp hangs after initial handshaking.
Workaround: activate this option and add a rule to your firewall
configuration like:
iptables -A FORWARD -p tcp --tcp-flags SYN,RST SYN \
-j TCPMSS --clamp-mss-to-pmtu
config FREETZ_MODULE_ipt_tos
bool "ipt_tos.ko"
default n
help
TOS matching allows you to match packets based on the Type Of
Service fields of the IP packet.
config FREETZ_MODULE_ipt_TOS
bool "ipt_TOS.ko"
default n
help
This option adds a `TOS' target, which allows you to create rules in
the `mangle' table which alter the Type Of Service field of an IP
config FREETZ_MODULE_ipt_ttl
bool "ipt_ttl.ko"
default n
help
This adds CONFIG_IP_NF_MATCH_TTL option, which enabled the user
to match packets by their TTL value.
# FIXME
config FREETZ_MODULE_ipt_TTL
bool "ipt_TTL.ko"
default n
endmenu
menu "x_tables (both IPv4 and IPv6)"
config FREETZ_MODULE_x_tables
bool "x_tables.ko"
default n
config FREETZ_MODULE_xt_helper
bool "xt_helper.ko"
default n
help
config FREETZ_MODULE_xt_CLASSIFY
bool "xt_CLASSIFY.ko"
default n
help
This option adds a `CLASSIFY' target, which enables the user to set
the priority of a packet. Some qdiscs can use this value for
classification, among these are:
atm, cbq, dsmark, pfifo_fast, htb, prio
config FREETZ_MODULE_xt_comment
bool "xt_comment.ko"
default n
help
This option adds a `comment' dummy-match, which allows you to put
comments in your iptables ruleset.
config FREETZ_MODULE_xt_conntrack
bool "xt_conntrack.ko"
default n
help
into connections.
Layer 3 independent connection tracking is experimental scheme
which generalize ip_conntrack to support other layer 3 protocols.
config FREETZ_MODULE_xt_esp
bool "xt_esp.ko"
default n
help
This match extension allows you to match a range of SPIs
inside ESP header of IPSec packets.
config FREETZ_MODULE_xt_length
bool "xt_length.ko"
default n
help
config FREETZ_MODULE_xt_limit
bool "xt_limit.ko"
default n
help
config FREETZ_MODULE_xt_mac
bool "xt_mac.ko"
default n
help
config FREETZ_MODULE_xt_multiport
bool "xt_multiport.ko"
default n
help
config FREETZ_MODULE_xt_mark
bool "xt_mark.ko"
default n
help
(see below).
config FREETZ_MODULE_xt_MARK
bool "xt_MARK.ko"
default n
help
behavior.
config FREETZ_MODULE_xt_NFQUEUE
bool "xt_NFQUEUE.ko"
default n
help
This target replaced the old obsolete QUEUE target.
As opposed to QUEUE, it supports 65535 different queues,
not just one.
config FREETZ_MODULE_xt_NOTRACK
bool "xt_NOTRACK.ko"
default n
help
The NOTRACK target allows a select rule to specify
which packets *not* to enter the conntrack/NAT
subsystem with all the consequences (no ICMP error tracking,
no protocol helpers for the selected packets).
config FREETZ_MODULE_xt_iprange
bool "xt_iprange.ko"
default n
help
This option adds a "iprange" match, which allows you to match
based on an IP address range. (Normal iptables only matches on
single addresses x with an optional mask.)
config FREETZ_MODULE_xt_pkttype
bool "xt_pkttype.ko"
default n
help
Packet type matching allows you to match a packet by
its "class", eg. BROADCAST, MULTICAST, ...
Typical usage:
iptables -A INPUT -m pkttype --pkt-type broadcast -j LOG
config FREETZ_MODULE_xt_physdev
bool "xt_physdev.ko"
default n
help
Physdev packet matching matches against the physical bridge ports
the IP packet arrived on or will leave by.
config FREETZ_MODULE_xt_quota
bool "xt_quota.ko"
default n
help
This option adds a `quota' match, which allows to match on a
byte counter.
config FREETZ_MODULE_xt_realm
bool "xt_realm.ko"
default n
help
This option adds a `realm' match, which allows you to use the realm
key from the routing subsystem inside iptables.
This match pretty much resembles the CONFIG_NET_CLS_ROUTE4 option
in tc world.
config FREETZ_MODULE_xt_state
bool "xt_state.ko"
#depends on FREETZ_KERNEL_VERSION_2_6_19
default n
help
config FREETZ_MODULE_xt_statistic
bool "xt_statistic.ko"
default n
help
This option adds a `statistic' match, which allows you to match
on packets periodically or randomly with a given percentage.
config FREETZ_MODULE_xt_string
bool "xt_string.ko"
default n
help
This option adds a `string' match, which allows you to look for
pattern matchings in packets.
config FREETZ_MODULE_xt_tcpudp
bool "xt_tcpudp.ko"
default n
config FREETZ_MODULE_xt_tcpmss
bool "xt_tcpmss.ko"
default n
help
endmenu
menu "Select kernel modules (IPv6)"
depends on FREETZ_TARGET_IPV6_SUPPORT
config FREETZ_MODULE_ip6_queue
bool "ip6_queue.ko"
default n
help
Userspace queueing via NETLINK
This option adds a queue handler to the kernel for IPv6
packets which lets us to receive the filtered packets
with QUEUE target using libiptc as we can do with
the IPv4 now.
(C) Fernando Anton 2001
IPv64 Project - Work based in IPv64 draft by Arturo Azcorra.
Universidad Carlos III de Madrid
Universidad Politecnica de Alcala de Henares
email: <[email protected]>.
config FREETZ_MODULE_ip6_tables
select FREETZ_PACKAGE_IPTABLES_SHARED_LIBS
select FREETZ_LIB_libxt_standard
bool "ip6_tables.ko"
default n
help
IP6 tables support (required for filtering/masq/NAT)
ip6tables is a general, extensible packet identification framework.
Currently only the packet filtering and packet mangling subsystem
for IPv6 use this, but connection tracking is going to follow.
config FREETZ_MODULE_ip6table_filter
depends on FREETZ_MODULE_ip6_tables
bool "ip6table_filter.ko"
default n
help
Packet filtering
config FREETZ_MODULE_ip6table_raw
bool "ip6table_raw.ko"
default n
help
raw table support (required for TRACE)
This option adds a `raw' table to ip6tables. This table is the very
first in the netfilter framework and hooks in at the PREROUTING
and OUTPUT chains.
config FREETZ_MODULE_ip6t_ah
bool "ip6t_ah.ko"
default n
help
AH match support
This module allows one to match AH and ESP packets.
config FREETZ_MODULE_ip6t_dst
depends on FREETZ_KERNEL_VERSION_2_6_13 && FREETZ_MODULE_ip6_tables
bool "ip6t_dst.ko"
default n
help
Dst opts header match support
This allows one to match packets based on the hop-by-hop
and destination options headers of a packet.
config FREETZ_MODULE_ip6t_esp
bool "ip6t_esp.ko"
default n
help
ESP match support
config FREETZ_MODULE_ip6t_eui64
bool "ip6t_eui64.ko"
default n
help
EUI64 address check
This module performs checking on the IPv6 source address
Compares the last 64 bits with the EUI64 (delivered
from the MAC address) address
config FREETZ_MODULE_ip6t_frag
bool "ip6t_frag.ko"
default n
help
Fragmentation header match support
frag matching allows you to match packets based on the fragmentation
header of the packet.
config FREETZ_MODULE_ip6t_hbh
bool "ip6t_hbh.ko"
default n
help
Hop-by-hop and header match support
config FREETZ_MODULE_ip6t_hl
bool "ip6t_hl.ko"
default n
help
HL match support
HL matching allows you to match packets based on the hop
limit of the packet.
config FREETZ_MODULE_ip6t_ipv6header
bool "ip6t_ipv6header.ko"
default n
help
IPv6 Extension Headers Match
This module allows one to match packets based upon
the ipv6 extension headers.
config FREETZ_MODULE_ip6t_length
bool "ip6t_length.ko"
default n
help
Packet Length match support
config FREETZ_MODULE_ip6t_limit
bool "ip6t_limit.ko"
default n
help
limit match support
config FREETZ_MODULE_ip6t_LOG
bool "ip6t_LOG.ko"
default n
help
LOG target support
config FREETZ_MODULE_ip6t_mac
bool "ip6t_mac.ko"
default n
help
MAC address match support
mac matching allows you to match packets based on the source
config FREETZ_MODULE_ip6t_mark
bool "ip6t_mark.ko"
default n
help
netfilter MARK match support
(see below).
config FREETZ_MODULE_ip6t_multiport
bool "ip6t_multiport.ko"
default n
help
Multiple port match support
config FREETZ_MODULE_ip6t_owner
bool "ip6t_owner.ko"
default n
help
Owner match support
config FREETZ_MODULE_ip6t_REJECT
bool "ip6t_REJECT.ko"
default n
help
The REJECT target allows a filtering rule to specify that an ICMPv6
config FREETZ_MODULE_ip6t_rt
bool "ip6t_rt.ko"
default n
help
Routing header match support
rt matching allows you to match packets based on the routing
config FREETZ_MODULE_ip6table_mangle
bool "ip6table_mangle.ko"
default n
help
Packet mangling
config FREETZ_MODULE_ip6t_MARK
bool "ip6t_MARK.ko"
default n
help
MARK target support
associated with the packet packet prior to routing. This can change
behavior.
config FREETZ_MODULE_nf_conntrack_ipv6
bool
#bool "nf_conntrack_ipv6.ko"
default n
help
into connections.
This is IPv6 support on Layer 3 independent connection tracking.
Layer 3 independent connection tracking is experimental scheme which
endmenu
config FREETZ_PACKAGE_IPTABLES_SHARED_LIBS
bool "Iptables shared libraries"
default n
help
Shared Libraries for iptables
menu "Select shared libraries (IPv4)"
depends on FREETZ_PACKAGE_IPTABLES_SHARED_LIBS
config FREETZ_LIB_libipt_addrtype
bool "libipt_addrtype.so"
default n
help
This module matches packets based on their address type.
Address types are used within the kernel networking stack and categorize
addresses into various groups. The exact definition of that group
depends on the specific layer three protocol.
Examples: UNICAST, BROADCAST, LOCAL, MULTICAST, ANYCAST, ...
config FREETZ_LIB_libipt_ah
bool "libipt_ah.so"
default n
help
This module matches the SPIs in Authentication header of IPsec packets.
config FREETZ_LIB_libipt_CLUSTERIP
bool "lipipt_CLUSTERIP.so"
default n
help
This module allows you to configure a simple cluster of nodes that
share a certain IP and MAC address without an explicit load balancer
in front of them. Connections are statically distributed between the
nodes in this cluster.
config FREETZ_LIB_libipt_DNAT
bool "libipt_DNAT.so"
default n
help
This target is only valid in the nat table, in the PREROUTING
and OUTPUT chains, and user-defined chains which are only called from
those chains. It specifies that the destination address of the packet
should be modified (and all future packets in this connection will
also be mangled), and rules should cease being examined.
config FREETZ_LIB_libipt_ecn
bool "libipt_ecn.so"
default n
help
This allows you to match the ECN bits of the IPv4 and TCP header.
ECN is the Explicit Congestion Notification mechanism as specified in
RFC3168.
config FREETZ_LIB_libipt_ECN
bool "libipt_ECN.so"
default n
help
This target allows to selectively work around known ECN blackholes.
It can only be used in the mangle table.
config FREETZ_LIB_libipt_icmp
bool "libipt_icmp.so"
default n
help
This extension can be used if `--protocol icmp' is specified.
config FREETZ_LIB_libipt_ipp2p
bool "libipt_ipp2p.so"
depends on FREETZ_MODULE_ipt_ipp2p
default n
help
This extension can be used to match p2p protocols such as
eDonkey, KaZaA, Gnutella, BitTorrent.
config FREETZ_LIB_libipt_LOG
bool "libipt_LOG.so"
default n
help
Turn on kernel logging of matching packets. When this option is set
for a rule, the Linux kernel will print some information on all
matching packets (like most IP header fields) via the kernel log
(where it can be read with dmesg or syslogd (8)).
config FREETZ_LIB_libipt_MASQUERADE
bool "libipt_MASQUERADE.so"
default n
help
This target is only valid in the nat table, in the POSTROUTING
chain. It should only be used with dynamically assigned IP (dialup)
connections: if you have a static IP address, you should use the SNAT
target.
config FREETZ_LIB_libipt_MIRROR
bool "libipt_MIRROR.so"
default n
help
This is an experimental demonstration target which inverts the source
and destination fields in the IP header and retransmits the packet.
config FREETZ_LIB_libipt_NETMAP
bool "libipt_NETMAP.so"
default n
help
This target allows you to statically map a whole network of addresses onto
another network of addresses.
config FREETZ_LIB_libipt_realm
bool "libipt_realm.so"
select FREETZ_MODULE_xt_realm if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This matches the routing realm. Routing realms are used in complex
routing setups involving dynamic routing protocols like BGP.
config FREETZ_LIB_libipt_REDIRECT
bool "libipt_REDIRECT.so"
default n
help
This target redirects the packet to the machine itself by changing the
destination IP to the primary address of the incoming interface
(locally-generated packets are mapped to the 127.0.0.1 address).
config FREETZ_LIB_libipt_REJECT
bool "libipt_REJECT.so"
default n
help
This is used to send back an error packet in response to the matched
packet: otherwise it is equivalent to DROP
so it is a terminating TARGET, ending rule traversal.
config FREETZ_LIB_libipt_SAME
bool "libipt_SAME.so"
default n
help
Similar to SNAT/DNAT depending on chain: it takes a range of addresses
(`--to 1.2.3.4-1.2.3.7') and gives a client the same
source-/destination-address for each connection.
config FREETZ_LIB_libipt_SNAT
bool "libipt_SNAT.so"
default n
help
This target specifies that the source address of the packet should be
modified (and all future packets in this connection will also be
config FREETZ_LIB_libipt_ttl
bool "libipt_ttl.so"
default n
help
This module matches the time to live field in the IP header.
config FREETZ_LIB_libipt_TTL
bool "libipt_TTL.so"
default n
help
This is used to modify the IPv4 TTL header field. The TTL field
determines how many hops (routers) a packet can traverse until it's
time to live is exceeded.
config FREETZ_LIB_libipt_ULOG
bool "libipt_ULOG.so"
default n
help
This target provides userspace logging of matching packets. When this
target is set for a rule, the Linux kernel will multicast this packet
through a netlink socket. One or more userspace processes may then
subscribe to various multicast groups and receive the packets.
config FREETZ_LIB_libipt_unclean
bool "libipt_unclean.so"
default n
help
This module takes no options, but attempts to match packets which seem
malformed or unusual. This is regarded as experimental.
endmenu
menu "Select shared libraries (both IPv4 and IPv6)"
config FREETZ_LIB_libxt_CLASSIFY
bool "libxt_CLASSIFY.so"
default n
help
This module allows you to set the skb->priority value (and thus
classify the packet into a specific CBQ class).
config FREETZ_LIB_libxt_comment
bool "libxt_comment.so"
select FREETZ_MODULE_xt_comment if FREETZ_KERNEL_VERSION_2_6_19
default n
help
Allows you to add comments (up to 256 characters) to any rule.
config FREETZ_LIB_libxt_connbytes
bool "libxt_connbytes.so"
default n
help
Match by how many bytes or packets a connection (or one of the two
flows constituting the connection) has transferred so far, or by
average bytes per packet.
#config FREETZ_LIB_libxt_connlimit
# bool "libxt_connlimit.so"
# default n
# help
# Allows you to restrict the number of parallel connections to a server
# per client IP address (or client address block).
config FREETZ_LIB_libxt_connmark
bool "libxt_connmark.so"
default n
help
This module matches the netfilter mark field associated with a
connection (which can be set using the CONNMARK target below).
config FREETZ_LIB_libxt_CONNMARK
bool "libxt_CONNMARK.so"
default n
help
This module sets the netfilter mark value associated with a connection.
config FREETZ_LIB_libxt_CONNSECMARK
bool "libxt_CONNSECMARK.so"
default n
help
This module copies security markings from packets to connections
(if unlabeled), and from connections back to packets (also only
if unlabeled). Typically used in conjunction with SECMARK, it is
only valid in the mangle table.
config FREETZ_LIB_libxt_conntrack
bool "libxt_conntrack.so"
select FREETZ_MODULE_xt_conntrack if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module, when combined with connection tracking, allows access to
the connection tracking state for this packet/connection.
config FREETZ_LIB_libxt_dscp
bool "libxt_dscp.so"
default n
help
This module matches the 6 bit DSCP field within the TOS field in the
IP header. DSCP has superseded TOS within the IETF.
config FREETZ_LIB_libxt_DSCP
bool "libxt_DSCP.so"
default n
help
This target allows to alter the value of the DSCP bits within the TOS
header of the IPv4 packet. As this manipulates a packet, it can only
config FREETZ_LIB_libxt_esp
bool "libxt_esp.so"
default n
help
This module matches the SPIs in ESP header of IPsec packets.
config FREETZ_LIB_libxt_hashlimit
bool "libxt_hashlimit.so"
default n
help
hashlimit uses hash buckets to express a rate limiting match (like the
limit match) for a group of connections using a single iptables
rule.
config FREETZ_LIB_libxt_helper
bool "libxt_helper.so"
select FREETZ_MODULE_xt_helper if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches packets related to a specific conntrack-helper.
config FREETZ_LIB_libxt_iprange
bool "libxt_iprange.so"
default n
help
This matches on a given arbitrary range of IP addresses.
config FREETZ_LIB_libxt_length
bool "libxt_length.so"
select FREETZ_MODULE_xt_length if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches the length of the layer-3 payload (e.g. layer-4
packet) of a packet against a specific value or range of values.
config FREETZ_LIB_libxt_limit
bool "libxt_limit.so"
select FREETZ_MODULE_xt_limit if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches at a limited rate using a token bucket filter.
A rule using this extension will match until this limit is reached
(unless the `!' flag is used). It can be used in combination with the
LOG target to give limited logging, for example.
config FREETZ_LIB_libxt_mac
bool "libxt_mac.so"
select FREETZ_MODULE_xt_mac if FREETZ_KERNEL_VERSION_2_6_19
default n
help
Match source MAC address.
config FREETZ_LIB_libxt_mark
bool "libxt_mark.so"
select FREETZ_MODULE_xt_mark if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches the netfilter mark field associated with a packet
(which can be set using the MARK target below).
config FREETZ_LIB_libxt_MARK
bool "libxt_MARK.so"
select FREETZ_MODULE_xt_MARK if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This target is used to set the Netfilter mark value associated with
the packet. The target can only be used in the mangle table. It can,
for example, be used in conjunction with routing based on fwmark
(needs iproute2).
config FREETZ_LIB_libxt_multiport
bool "libxt_multiport.so"
select FREETZ_MODULE_xt_multiport if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches a set of source or destination ports. Up to 15
ports can be specified. A port range (port:port) counts as two
ports.
config FREETZ_LIB_libxt_NFLOG
bool "libxt_NFLOG.so"
default n
help
This target provides logging of matching packets. When this target is
set for a rule, the Linux kernel will pass the packet to the loaded
logging backend to log the packet.
config FREETZ_LIB_libxt_NFQUEUE
bool "libxt_NFQUEUE.so"
default n
help
This target is an extension of the QUEUE target. As opposed to QUEUE,
it allows you to put a packet into any specific queue, identified by
its 16-bit queue number.
config FREETZ_LIB_libxt_NOTRACK
bool "libxt_NOTRACK.so"
default n
help
This target disables connection tracking for all packets matching
that rule.
config FREETZ_LIB_libxt_owner
bool "libxt_owner.so"
default n
help
This module attempts to match various characteristics of the packet
creator, for locally generated packets.
config FREETZ_LIB_libxt_physdev
bool "libxt_physdev.so"
select FREETZ_MODULE_xt_physdev if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches on the bridge port input and output devices
enslaved to a bridge device.
config FREETZ_LIB_libxt_pkttype
bool "libxt_pkttype.so"
select FREETZ_MODULE_xt_pkttype if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This module matches the link-layer packet type.
config FREETZ_LIB_libxt_quota
bool "libxt_quota.so"
default n
help
Implements network quotas by decrementing a byte counter with each
packet.
config FREETZ_LIB_libxt_rateest
bool "libxt_rateest.so"
default n
config FREETZ_LIB_libxt_RATEEST
bool "libxt_RATEEST.so"
default n
help
The RATEEST target collects statistics, performs rate estimation
calculation and saves the results for later evaluation using the
rateest match.
config FREETZ_LIB_libxt_sctp
bool "libxt_sctp.so"
default n
config FREETZ_LIB_libxt_SECMARK
bool "libxt_SECMARK.so"
default n
help
This is used to set the security mark value associated with the
packet for use by security subsystems such as SELinux.
config FREETZ_LIB_libxt_standard
bool "libxt_standard.so"
default n
config FREETZ_LIB_libxt_state
bool "libxt_state.so"
select FREETZ_MODULE_xt_state if FREETZ_KERNEL_VERSION_2_6_19
default n
help
the connection tracking state for this packet.
config FREETZ_LIB_libxt_statistic
bool "libxt_statistic.so"
default n
help
This module matches packets based on some statistic condition.
config FREETZ_LIB_libxt_string
bool "libxt_string.so"
select FREETZ_MODULE_xt_string if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This modules matches a given string by using some pattern matching
strategy.
config FREETZ_LIB_libxt_tcpmss
bool "libxt_tcpmss.so"
select FREETZ_MODULE_xt_tcpmss if FREETZ_KERNEL_VERSION_2_6_19
default n
help
This matches the TCP MSS (maximum segment size) field of the TCP header.
config FREETZ_LIB_libxt_TCPMSS
bool "libxt_TCPMSS.so"
default n
help
This target allows to alter the MSS value of TCP SYN packets, to control
the maximum size for that connection (usually limiting it to your
outgoing interface's MTU minus 40 for IPv4 or 60 for IPv6,
respectively).
bool "libxt_tcp.so"
select FREETZ_MODULE_xt_tcpudp if FREETZ_KERNEL_VERSION_2_6_19
default n
help
These extensions can be used if `--protocol tcp' is specified.
config FREETZ_LIB_libxt_time
bool "libxt_time.so"
default n
help
This matches if the packet arrival time/date is within a given range.
config FREETZ_LIB_libxt_tos
bool "libxt_tos.so"
default n
help
This module matches the 8-bit Type of Service field in the IPv4 header
(i.e. including the "Precedence" bits) or the (also 8-bit) Priority
field in the IPv6 header.
config FREETZ_LIB_libxt_TOS
bool "libxt_TOS.so"
default n
help
This module sets the Type of Service field in the IPv4 header
(including the 'precedence' bits) or the Priority field in the IPv6
header.
config FREETZ_LIB_libxt_TRACE
bool "libxt_TRACE.so"
default n
help
This target marks packes so that the kernel will log every rule which
match the packets as those traverse the tables, chains, rules.
(The ipt_LOG or ip6t_LOG module is required for the logging.)
config FREETZ_LIB_libxt_u32
bool "libxt_u32.so"
default n
help
U32 tests whether quantities of up to 4 bytes extracted from a packet
have specified values. The specification of what to extract is general
enough to find data at given offsets from tcp headers or payloads.
config FREETZ_LIB_libxt_udp
bool "libxt_udp.so"
default n
help
These extensions can be used if `--protocol udp' is specified.
endmenu
menu "Select shared libraries (IPv6)"
config FREETZ_LIB_libip6t_ah
bool "libip6t_ah.so"
default n
help
This module matches the parameters in Authentication header of IPsec
packets.
config FREETZ_LIB_libip6t_dst
bool "libip6t_dst.so"
default n
help
This module matches the parameters in Destination Options header.
config FREETZ_LIB_libip6t_eui64
bool "libip6t_eui64.so"
default n
help
This module matches the EUI-64 part of a stateless autoconfigured IPv6
address.
config FREETZ_LIB_libip6t_frag
bool "libip6t_frag.so"
default n
help
This module matches the parameters in Fragment header.
config FREETZ_LIB_libip6t_hbh
bool "libip6t_hbh.so"
default n
help
This module matches the parameters in Hop-by-Hop Options header.
config FREETZ_LIB_libip6t_hl
bool "libip6t_hl.so"
default n
help
This module matches the Hop Limit field in the IPv6 header.
config FREETZ_LIB_libip6t_HL
bool "libip6t_HL.so"
default n
help
This is used to modify the Hop Limit field in IPv6 header.
The Hop Limit field is similar to what is known as TTL value in IPv4.
config FREETZ_LIB_libip6t_icmp6
bool "libip6t_icmp6.so"
default y
help
This extension can be used if `--protocol ipv6-icmp' or
`--protocol icmpv6' is specified.
config FREETZ_LIB_libip6t_ipv6header
bool "libip6t_ipv6header.so"
default n
help
This module matches IPv6 extension headers and/or upper layer header.
config FREETZ_LIB_libip6t_LOG
bool "libip6t_LOG.so"
default n
help
matching packets (like most IPv6 IPv6-header fields) via the kernel log
config FREETZ_LIB_libip6t_mh
bool "libip6t_mh.so"
default n
help
This extension is loaded if `--protocol ipv6-mh' or `--protocol mh' is
specified.
config FREETZ_LIB_libip6t_REJECT
bool "libip6t_REJECT.so"
default n
help
packet: otherwise it is equivalent to DROP so it is a terminating
config FREETZ_LIB_libip6t_rt
bool "libip6t_rt.so"
default n
help
Match on IPv6 routing header.
endmenu
