Hylafax, IAXModem und Asterisk
ca.funke
17 Jan 2005
Hallo allerseits,
ich versuche nach >>dieser<< Anleitung Hylafax und IAXModem zu installieren, um den Faxempfang in Asterisk einbinden zu können.
Genau wie in >>diesem<< Thread habe ich das Problem, dass Hylafax das IAXModem nicht erkennt. (Den Thread habe ich ohne Erfolg komplett durchgearbeitet)
Was passiert:
faxsetup
Do you want to run faxaddmodem to configure a modem [yes]?
Serial port that modem is connected to []?ttyIAX0
/dev/ttyIAX0 is not a terminal device.
Serial port that modem is connected to [ttyIAX0]?
Wäre für jeden Lösungsansatz dankbar!
Gruß, Christian
ob sinnvoll weiss ich nicht, aber ich gebe noch so viele Daten mit wie ich kann:
root@vserver:~# tail -f /var/log/iaxmodem/ttyIAX0
[2011-09-29 01:52:37] Fatal error: failed to initialize UNIX98 master pty
[2011-09-29 01:57:06] Fatal error: failed to initialize UNIX98 master pty
[2011-09-29 14:48:35] Fatal error: failed to initialize UNIX98 master pty
[2011-09-29 16:26:09] Fatal error: failed to initialize UNIX98 master pty
[2011-09-29 16:27:23] Fatal error: failed to initialize UNIX98 master pty
[1]+  Stopped                 tail -f /var/log/iaxmodem/ttyIAX0
root@vserver:~# iaxmodem ttyIAX0
[2011-09-29 20:21:31] Modem started
[2011-09-29 20:21:31] Setting device = '/dev/ttyIAX0'
[2011-09-29 20:21:31] Setting owner = 'uucp:uucp'
[2011-09-29 20:21:31] Setting mode = '660'
[2011-09-29 20:21:31] Setting port = 4570
[2011-09-29 20:21:31] Setting refresh = 300
[2011-09-29 20:21:31] Setting server = '127.0.0.1'
[2011-09-29 20:21:31] Setting peername = 'iaxmodem'
[2011-09-29 20:21:31] Setting secret = 'password'
[2011-09-29 20:21:31] Setting codec = alaw
[2011-09-29 20:21:31] Fatal error: failed to initialize UNIX98 master pty
IAX-conf:
[general]
bindport = 4569
bindaddr = 0.0.0.0
disallow=all
allow=ulaw
allow=alaw
[iaxmodem]
type=friend
secret=geheim
port=4570
host=dynamic
context=incoming_fax
callerid=("Telefax ..." <Faxnummer>")
disallow=all
allow=alaw
qualify=yes
reiche was immer nötig gerne nach !
300 Hits und keine Antwort?
Würde mich wirklich freuen! Ich verzweifel hier, die Situation ist leider unverändert, was ich auch versuche.
Dank und Gruss, Christian
