How work VOIP over AVM VPN?
vpe
24 Feb 2006
how work P2P call via AVM VPN?
On destination side (if VPN between FBF installed) not reachable ports 5060 - how i must set?
1.2.3.4 - normal IP address (public)
192.168.150.1 - IP address of AVM VPN (Fritz)
Normal P2P call to [email protected] work for me OK, but if i call to
[email protected], then not work. On 192.168.150.1:5060 is nothing answer.
I think, must change some in fritzbox_VPN.cfg on destination, maybe in origination side too? Pls help!
Nobody Know?
As far as I know nobody has successfull performed a VoIP call over VPN. The only way is to regsiter from extern.
Then help me please how, if i want try secured calls?
some (old) Labor firmwares contains SRTP extension, but if i need actual firmware, then i must go to Freetz and OpenVPN solution, or have you or somebody other tips?
Thx.
then only way is openvpn?
Elemir
