Fehler beim Freetzen...
bgx
19 Mrz 2006
Wollte mir für meinen W920 ein neues Image bauen. Speed2Fritz ist druchgelaufen aber beim anschliessenden freetzen bekomme ich folgende Fehlermeldung:
STEP 2: MODIFY
  Applying symlinks, deleting additional webinterfaces
applying patches
  applying patches (7270_labor_core-de)
    applying patch file ./patches/7270_labor_core/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    Hunk #1 succeeded at 68 (offset 2 lines).
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7270_labor_core/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7270_labor_core/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/7270_labor_core/120-rc.S-dev.patch
    applying patch file ./patches/7270_labor_core/130-rc.S-logging.patch
    applying patch file ./patches/7270_labor_core/140-rc.S-no_avm_exit.patch
    applying patch file ./patches/7270_labor_core/de/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/7270_labor_core/de/190-webmenu.patch
    patching file usr/www/all/html/de/menus/menu2_homehome.html
    patching file usr/www/all/html/de/menus/menu2_konfig.html
    applying patch file ./patches/7270_labor_core/de/200-sperre1.patch
    patching file usr/www/avm/html/de/fon/sperre1.js
    applying patch file ./patches/7270_labor_core/de/210-notmountable.patch
    patching file usr/www/all/html/de/home/home.js
    applying patch file ./patches/7270_labor_core/de/290-replace_websrv-remove_igdd.patch
    applying patch file ./patches/7270_labor_core/de/301-remove_smbd.patch
    applying patch file ./patches/7270_labor_core/de/400_remove_ftpd.patch
  creating symlinks /tmp, /mod and /home
  setting freetz-version 'freetz-develX'
    applying patch file ./patches/100-3170_7170.sh
    applying patch file ./patches/100-7113_7170.sh
    applying patch file ./patches/100-7140_7170.sh
    applying patch file ./patches/100-7141_7170.sh
    applying patch file ./patches/100-getcons.sh
  removing /bin/getcons
    rm build/modified/filesystem/bin/getcons
    patching build/modified/filesystem/etc/profile
    applying patch file ./patches/100-profile_term_password.sh
    applying patch file ./patches/100-rename_ctlmgr.sh
    applying patch file ./patches/100-w701v_7170.sh
    applying patch file ./patches/100-w900v_7170.sh
    applying patch file ./patches/101-libfreetz.sh
  patching /etc/init.d/rc.s
    patching build/modified/filesystem/etc/init.d/rc.S
    applying patch file ./patches/105-onlinechanged.sh
  Patching /bin/onlinechanged
    applying patch file ./patches/110-inittab.sh
    applying patch file ./patches/115-7270_16MB.sh
  applying 16MB patch
    applying patch file ./patches/120-dev_led.sh
  applying /dev/led patch
    patching build/modified/filesystem/bin/update_led_on
    patching build/modified/filesystem/bin/update_led_off
    applying patch file ./patches/170-rename_ar7login.sh
  renaming ar7login to make way for wrapper script
    applying patch file ./patches/180-printk.sh
  applying printk patch
    applying patch file ./patches/191-webmenu_wol.sh
    applying patch file ./patches/195-webmenu_signed.sh
  applying webmenu signed patch
    patching build/modified/filesystem/usr/www/all/html/de/home/home.js
    applying patch file ./patches/196-usbstorage.sh
  applying USB storage patch
    applying patch file ./patches/cond/usbstorage_7270_labor_core.patch
    patching file etc/hotplug/run_mount
    Hunk #1 succeeded at 10 with fuzz 2.
    Hunk #2 succeeded at 16 with fuzz 1 (offset -7 lines).
    Hunk #3 FAILED at 82.
    1 out of 3 hunks FAILED -- saving rejects to file etc/hotplug/run_mount.rej
ERROR: modpatch: Error in patch-file ./patches/cond/usbstorage_7270_labor_core.patch
make: *** [firmware-nocompile] Fehler 2
modimage=7270_labor_phone_04.80freetz-develX.de_20100202-232101.image
„./images/7270_labor_phone_04.80freetz-develX.de_20100202-232101.image“ -> „/home/fritz/Desktop/speed-to-fritz/Firmware.orig/7270_labor_phone_04.80freetz-develX.de_20100202-232101.image“
„/home/fritz/Desktop/speed-to-fritz/Firmware.conf“ -> „/home/fritz/Desktop/speed-to-fritz/conf-920-freetz“
Was hab ich falsch gemacht?
Speed2Fritz verwendet und dann hier gefragt, warum es nicht läuft.
Es gibt eine Liste mit von Freetz unterstützten Firmware-Versionen. Mit Speed2Fritz erstellte Firmwares zählen nicht dazu.
Ja sorry, dann bitte Thema nach Speed2Fritz verschieben...
@RalfFriedl
Bitte überzeuge dich, dass auch in diesen Fall die verwendete Firmware von speed-to-fritz vorher nicht verändert wurde.
Freetz läuft immer vor Speed-to-fritz auch wenn start-freetz.sh verwendet wurde.
Bitte probiert die neue streaming Firmware aus es gibt die Fehlermeldung.
Die neue NAS funktioniert.
Ja berechtigt Antwort!
erledigt
Es war aber nicht wirklich deplaziert, denn es war wirklich ein Fehler im Freetz. Freetzmount, was ich beim Bau aktiviert hatte, nutzt andere PAtches, so dass das nicht aufgefallen ist.
@JPascher: Vllt. solltest du dein sp2fritz mit der stabilen Version nutzen, da ist weniger Fluktuation vorhanden. Der trunk sceint für viele der User nicht so sinnvoll zu sein...
Aber da gibts doch keine Labor Firmwares... :)
MfG Oliver
Hoppla, jetzt kann ich nicht zurückschieben, da ich hier keine Mod-Rechte habe. :oops:
Ich trigger Ernest mal eben an ...
Danke für die Fehelrbehebung!
Der stabile Zweig mach leider wenig Sinn da wir ja nur die neuen Labor Versionen wirklich benutzen und auch für die final 7570 nur der aktuelle Trunk nutzbar ist.
Aktuell bin ich an der 7390 und an der W722 dran das wird mit sp2fritz nichts.
Werde mich wohl oder über mehr mit freetz beschäftigen müssen, da ich einen neun Kernel dafür brauche.
Arbeitet schon jemand an der Einbindung des 7390?
afaik nicht. Wir haben noch keine, denke ich. Und da dort viel zu tun ist (endianess z.b.) muss das echt debugged und getestet werden.
Uh. Stimmt. Da brauchen wir eine neue Toolchain...
MfG Oliver
Na dann hoffen wir das sich bald einige finden die das interessiert.
Von meinen Blickwinkel sieht das ganze nicht übel aus.
Konnte eine W722 Firmware mit Teilen aus der 7390 Firmware bereits mischen und zumindest mal Telnet einbauen, aber halt nur mit sp2fr.
Keine Mitglieder online.
Manfred Wolke
